Старый 01.07.2019, 22:32   #1
Вес репутации: 1032
По умолчанию php7 и openwrt
Может натолкнете на мысль толковую.
апач на openwrt не работает, начал громоздить nginx + php7-fastcfgi.
Вроде все получилось phpinfo() на тестовой странице отработал и я закачал html5-speedtest упомянутый в соседней теме и облом:
php7 вылетает, без логов.
root@OpenWrt:/# cat /etc/php.ini|grep log
; Error handling and logging
log_errors = On
log_errors_max_len = 1024
error_log = /var/log/php_errors.log
; Log errors to syslog.
;error_log = syslog
fastcgi.logging = 1
root@OpenWrt:/# php-cgi -b 1026
root@OpenWrt:/#
root@OpenWrt:/# cat /var/log/php_errors.log
root@OpenWrt:/# cat /var/log/error.log
2019/07/01 20:27:00 [error] 1945#0: *1 open() "/usr/share/htdocs/favicon.ico" failed (2: No such file or directory), client: 192.168.1.161, server: , request: "        GET /favicon.ico HTTP/1.1", host: "192.168.1.1", referrer: "http://192.168.1.1/speedtest-master/"
2019/07/01 20:27:21 [error] 1945#0: *1 open() "/usr/share/htdocs/speedtest-master/index,php" failed (2: No such file or directory), client: 192.168.1.161, serve        r: , request: "GET /speedtest-master/index,php HTTP/1.1", host: "192.168.1.1"
2019/07/01 20:27:28 [error] 1945#0: *1 open() "/usr/share/htdocs/speedtest-master/index.php" failed (2: No such file or directory), client: 192.168.1.161, serve        r: , request: "GET /speedtest-master/index.php HTTP/1.1", host: "192.168.1.1"
2019/07/01 20:27:46 [error] 1945#0: *1 directory index of "/usr/share/htdocs/" is forbidden, client: 192.168.1.161, server: , request: "GET / HTTP/1.1", host: "        192.168.1.1"
2019/07/01 20:28:08 [error] 1945#0: *389 recv() failed (104: Connection reset by peer) while reading response header from upstream, client: 192.168.1.161, serve        r: , request: "GET /speedtest-master/backend/garbage.php?r=0.3259890907825538&ckSize=100 HTTP/1.1", upstream: "fastcgi://127.0.0.1:1026", host: "192.168.1.1", r        eferrer: "http://192.168.1.1/speedtest-master/speedtest_worker.js?r=0.15776076882503487"
... и дальше куча логов nginx од отсутствии связи с php
А ларчик просто открывался. на странице работает ajax, открываем инструменты разработчика в браузере и смотрим, что происходит во вкладке "Network". А там видны и ошибки которыми плюется php:
Unknown: Timezone database is corrupt - this should *never* happen!
Решение:
# opkg install zoneinfo-europe
Новая ошибка:
Uncaught Error: Call to undefined function openssl_random_pseudo_bytes() in /usr/share/htdocs/speedtest-master/backend/garbage.php:22
Решение: opkg install php7-mod-openssl
Последний раз редактировалось Tohin; 06.07.2019 в 19:32. Причина: Отлично побеседовал с Гуглом
Текущее время: 13:37. Часовой пояс GMT +3.
