#271 |
Делаю все как в 5 посте. Установил relayd.
root@OpenWrt:/# opkg list-installed ... relayd - 2011-10-24-4e8f1fa4ca2b176500362843a9e57ea5abd4b7a3 ... Но похоже, но не запускается. root@OpenWrt:/# ps PID USER VSZ STAT COMMAND 1 root 1504 S init 2 root 0 SW [kthreadd] 3 root 0 SW [ksoftirqd/0] 5 root 0 SW [kworker/u:0] 6 root 0 SW< [khelper] 63 root 0 SW [sync_supers] 65 root 0 SW [bdi-default] 67 root 0 SW< [kblockd] 96 root 0 SW [kswapd0] 144 root 0 SW [fsnotify_mark] 173 root 0 SW< [ath79-spi] 184 root 0 SW [mtdblock0] 189 root 0 SW [mtdblock1] 194 root 0 SW [mtdblock2] 199 root 0 SW [mtdblock3] 204 root 0 SW [mtdblock4] 209 root 0 SW [mtdblock5] 250 root 0 SW [kworker/0:1] 470 root 0 SW [khubd] 480 root 0 SW [scsi_eh_0] 481 root 0 SW [usb-storage] 482 root 0 SW [kworker/0:2] 483 root 0 SW [kworker/u:2] 504 root 0 SW [jbd2/sda1-8] 505 root 0 SW< [ext4-dio-unwrit] 527 root 1500 S /bin/ash --login 564 root 0 SW< [cfg80211] 669 root 1508 S /sbin/syslogd -C16 671 root 1488 S /sbin/klogd 673 root 864 S /sbin/hotplug2 --override --persistent --set-rules-f 679 root 860 S /sbin/ubusd 683 root 1520 S /sbin/netifd 1054 root 1436 S hostapd -P /var/run/wifi-phy0.pid -B /var/run/hostap 1296 root 1500 S /sbin/watchdog -t 5 /dev/watchdog 1382 root 1428 S wpa_supplicant -B -P /var/run/wifi-wlan0-1.pid -D nl 1781 root 1152 S /usr/sbin/dropbear -P /var/run/dropbear.1.pid -p 22 1792 root 1492 S /usr/sbin/telnetd -l /bin/login.sh 1821 nobody 940 S /usr/sbin/dnsmasq -C /var/etc/dnsmasq.conf 1835 root 1500 S /usr/sbin/ntpd -n -p 0.openwrt.pool.ntp.org -p 1.ope 1886 root 1496 R ps С 3020 инет есть. А дальше нету. Пробовал подключаться к 3020 по wifi и по шнурку. И не могу попасть в вебморду 3020. Где ошибка? |
#272 | |
#273 |
Какие настройки показать?
#274 |
Вот:
network config interface 'loopback' option ifname 'lo' option proto 'static' option ipaddr '127.0.0.1' option netmask '255.0.0.0' config interface 'lan' option ifname 'eth0' option type 'bridge' option proto 'static' option ipaddr '192.168.2.1' option netmask '255.255.255.0' option gateway '192.168.1.1' option dns '192.168.1.1' config interface 'wwan' option proto 'static' option ipaddr '192.168.1.55' option netmask '255.255.255.0' option gateway '192.168.1.1' option dns '192.168.1.1' =========================== wireless config wifi-device 'radio0' option type 'mac80211' option macaddr 'f8:d1:11:xx:xx:xx' option hwmode '11ng' option htmode 'HT20' list ht_capab 'SHORT-GI-20' list ht_capab 'SHORT-GI-40' list ht_capab 'RX-STBC1' list ht_capab 'DSSS_CCK-40' option disabled '0' # option channel '11' option country 'RU' option txpower '20' option channel 'auto' #client for XXXXX config wifi-iface option ssid 'XXXXXX' #..... . ..... ..... ....... WiFi option device 'radio0' option mode 'sta' option bssid '90:f6:52:xx:xx:xx' option key '********' #...... . ..... ..... ....... WiFi ================================ dhcp config dnsmasq option domainneeded '1' option boguspriv '1' option filterwin2k '0' option localise_queries '1' option rebind_protection '1' option rebind_localhost '1' option local '/lan/' option domain 'lan' option expandhosts '1' option nonegcache '0' option authoritative '1' option readethers '1' option leasefile '/tmp/dhcp.leases' option resolvfile '/tmp/resolv.conf.auto' config dhcp 'lan' option interface 'lan' option start 100 option limit 150 option leasetime 12h option ignore '1' =========================== firewall config defaults option syn_flood '1' option input 'ACCEPT' option output 'ACCEPT' option forward 'REJECT' config zone option name 'lan' option network 'lan wwan' option input 'ACCEPT' option output 'ACCEPT' option forward 'ACCEPT' # option network ' ' config zone option name 'wan' option network 'wan' option input 'REJECT' option output 'ACCEPT' option forward 'REJECT' option masq '1' option mtu_fix '1' Help me! |
#275 |
Вес репутации: 602 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Скинь не обрывки настроек, а три файла целиком запихни в архив и прикрепи к сообщению. Фаилы network, wireless, firewall.
Если прошивка attitude_adjustment сборки до сентября 2013г, то wifi с багами. Посмотреть дату сборки можно во вкладке Status - Kernel Log в первой строке. Последний раз редактировалось melsem; 10.04.2014 в 22:20. |
#277 |
#278 |
На какую? Как обновить? Или ставить по новой?
#279 |
Закинь эти файлы. Только в wireless исправь маки и ключ на свои.
И чем редактируеш? Файлы портиш. |
#280 |
Сейчас попробую.
Редактирую редактором VI продключившись к роутеру терминалом. Сюда попробовал вставлять, получились обрывки, не досмотрел. А что именно испорчено? Или имелись ввиду обрывки? |
| Метки |
| network openwrt, wi-fi openwrt, настройка сети openwrt |
| Здесь присутствуют: 36 (пользователей: 0 , гостей: 36) | |
