Старый 22.11.2012, 17:42   #1
По умолчанию Список одноплатных компьютеров
Список одноплатных компьютеров:
Raspberry Pi Model B
MK802
Mele A1000
Rhombus-Tech A10 EOMA-68
Gooseberry board
A13-OLinuXino
VIA APC
VIA ARTiGO A1200
VIA ARTiGO A1150
BeagleBoard Rev. C4
BeagleBoard-xM
BeagleBone
PandaBoard
PandaBoard ES
Cotton Candy
CuBox
Hawkboard
IGEP v2
IGEP COM Proton
IGEP COM Module
Gumstix Overo series
Origen Board
Nimbus
Stratus
SheevaPlug dev kit (Basic)
GuruPlug Standard
GuruPlug Display
DreamPlug
D2Plug
Trim-Slice series
Snowball
i.MX53 Quick Start Board
Pineriver H24/MiniX
Smallart UHOST
Genesi Efika MX Smarttop
Embest DevKit8600
Embest SBC8018
Embest SBC8530
Embest DevKit8500D
Odroid-X
Odroid-X2
Odroid-U
Odroid-U2
Samsung S3C2440
SOM2416
Micro2440
OK6410
LS6410
mini X
Старый 25.11.2012, 16:51   #2
Samsung S3C2440
Название: Samsung S3C2440.jpg
CPU Samsung S3C2440A 400MHz, Max freq. 533Mhz
SDRAM 64MB
Flash 256MB Nand Flash
2MB Nor Flash, BIOS installed
LCD 4 wire resistive touch screen interface
Up to 4096 color STN, 3.5 inches to12.1 inches, up to 1024x768 pixels
Up to 64K color TFT, 3.5 inches to 12.1 inches, up to1024x768 pixels
Interface and Resource
1 x 10M Ethernet RJ-45(CS8900)
3 x Serial Ports(1 RS232 with CTS and RTS)
1 x USB Host
1 x USB Slave Type B
1 x SD Card Interface
1 x Stereo audio out, 1 Micro In
1 x 20-Pin JTAG
4 x USER LEDs
4 x USER buttons
1 x PWM Beeper
1 x POT can be used for A/D converter adjust
1 x AT24C08 for I2C test
1 x 20-Pin Camera Interface
1 x Battery for RTC
1 x Power In(12V), with switch and lamp
Genuine Friendly 3.5 Touch Screen. Сделан на базе Samsung S3C2440
Старый 25.11.2012, 17:12   #3
SOM2416
Processor(Core) Samsung S3C2416(ARM926EJ)-65nm
Speed: CORE/SDRAM 400MHz(cpu)/266M(DDR2 SDRAM)
I-Cache/ D-Cache, L2 16KB/16KB
Internal SRAM 64KB for internal SRAM Buffer
SDRAM 64MB, 16-Bit DDR2
Flash Availability 64MB~4GB of Nand Flash optional
Connectivity
UART]4-ch: Uart0/1: 4-wire(TX/RX/RTS/CTS);uart2/3: 2-wire(TX/RX)
Slow IrDA/ Fast IrDA IrDA 1.0, multiplex with UARTs
SPI, # of Chip Selects 1-CH high speed SPl, protocol version 2.11
I2C Bus 1-CH Multi-Master IIC-Bus
USB Host Ports 1-CH of OHCI 1.0 USB Host,Compatible USB 1.1
USB Device Port 1-CH USB 2.0 Spec USB device, 9 Endpoints
Ethernet Interface 10/100MB high performance Ethernet(LAN9220/LAN9221)
SD/MMC Interface 2-CH,SDIO 1.0/HS-MMC 4.2/SD Host 2.0/SD Memory Card Protocol 2.1/CE-ATA
PCMCIA/Compact Flash No
Interactivity
LCD I/F (Resolution,Depth) Typically 800x600,16bit/18bit
Touch Panel Controller 4-wire,support Resistive Touch Panel
2D/3D Graphics 2D Graphics Accelerator Engine
Video Performance(Res@fps) (To Be Determined)
Audio I/F I2S of WM8731 codec, Line In/Line Out/Microphone I/F
RTC CPU internal, external backup battery input
Watchdog Yes,CPU Internal
Extendability
Expansion Bus Add/Data 7-Bit Address/8-Bit Data Local Bus
GPIO]10+~30+ Channels
Interrupt Source 12
Timer/PWM 3-CH 16bit
ADC/DAC 2-CH ADC
Изображения
Старый 25.11.2012, 17:17   #4
Micro2440
Specification:
CPU: 400 MHz Samsung S3C2440A ARM920T (max freq. 533 MHz)
RAM: 64 MB SDRAM, 32 bit Bus
Flash: 256 MB NAND Flash and 2 MB NOR Flash with BIOS
LCD Interface: STN Displays: Monochrome, 4 gray levels, 16 gray levels, 256 colors, 4096 colors Max: 1024x768 TFT Displays: Monochrome, 4 gray levels, 16 gray levels, 256 colors, 64k colors, true color Max: 1024x768,
Touch Panel: 4 wire resistive
User Outputs: 4x LEDs Expansion headers (2.0 mm)
Debug: 10 pin JTAG (2.0 mm)
Dimension: 63 x 52 mm
OS Support Windows CE 5 and 6, Linux 2.6, Android
Изображения
Старый 25.11.2012, 17:26   #5
CORE6410
LS6410CORE is an small size, low power, and high performance ARM11 core board. It can be used on car, home automation, industry PDA, industry digital control, consumer electronics, mobile terminal etc.
Features:
1. 8 layer design. Two layers of blind via, and one layer of buried via.
2. Size 6X6cm, and thickness of 2.8mm.
3. Single power supply of range 3.7 - 6.5V.
4. ARM 11S3C6410 of800MHZ.
5. MobileDDR of 256M Byte, and system bus running at 266MHz.
6. 1GB of NANDFlash with support to up to 8GB.
7. iNAND Flash, with support upto 8GB (with spare PCB mounting area)
8. WM9713 Audio output, supports two line input and two line output; support TOUCH function, and can be with GSM to do voice communication
9. Integrated 100M Ethernet
10. 170 pins that provide access to all CPU's functions. Detail please refer to the definition of pins.
Изображения
Старый 25.11.2012, 17:34   #6
OK6410-B board+4.3"LCD(256M RAM,4GB FLASH)
Specification
OK6410-B ARM11 development board bundled with a 4.3" TFT LCD. Samsung S3C6410 MCU, 256MB DDR RAM, 4GB NAND Flash, WinCE / Linux / Android / uCos-II support, advanced Video / graphic support with 3D acceleration.
Samsung S3C6410 microcontroller based on the ARM1176JZF-S core, main frequency @ 533/667MHz;
256MB Mobile DDRram;
4GB NAND Flash;
12MHz、48MHz、27MHz、32.768KH clock source;
5V power supply adaptable
One reset button implemented with specific reset chip;
8-bit toggle switch for selecting boot mode;
Four serial ports, including 1 5-wire RS232 and 3 3-wire TTL;
One 100M Ethernet port with DM9000AE and indicators;
One USB Host interface supporting USB1.1 protocol;
One USB Slave (MINI-USB) interface supporting USB2.0 protocol;
One high-speed SD card slot supporting SD Memory and SDIO;
One WIFI expansion interface;
Stereo audio I/O sockets;
LCD and touch screen interface supporting 3.5”, 4.3”, 5.6”, 5.7”, 7” TFT LCD;
One CVBS output interface (PAL/NTSC)
One CMOS camera connector supporting ITU-R BT601/656 8-bit mode;
Built-in RTC (Real Time Clock) with back-up battery;
One JTAG interface using 2*10pin connector;
One Infrared receiver;
Four user LEDs;
One Buzzer;
2 x SPI channel
2 x DA
8 x AD
7 x interrupt
38 x GPIO
IIC interface
Dimension: 81 x 105mm
Working Temperature: -20 to 70℃
4.3" LCD
Старый 25.11.2012, 17:51   #7
iMX233-OLinuXino-Micro
iMX233 ARM926J processor at 454Mhz
64 MB RAM
SD-card connector for booting the Linux image
TV PAL/NTSC video output
1 USB High Speed Host
three Buttons
2x30 pin GPIO for connection of other hardware
PCB dimensions: 3.00'' x 1.70'' (76.2mm x 43.2mm)
Nominal dimensions: 3.40'' x 1.70'' (86.4mm x 43.2mm)
Изображения
Старый 25.11.2012, 17:58   #8
Gooseberry board
Specs
CPU : A10 1 Ghz overclockable to 1.5 Ghz (1.2 Ghz highest stable overclock on android)
Graphics Processor : Mali 400 MHz
Operating System : Android 4.0 ICS
Onboard Storage: 4Gb (upgradeable by Micro SD memory card- 32gb)
Wifi: 802.11 b/g/n
Connectivity: Ac jack, 1x 3.5mm Earphone Jack, 1x Mini Usb, 1x Hdmi Out, Micro Sd slot
Compatible software: Android ICS is the only fully compatible OS! Ubuntu a possibility with advanced technical knowledge
Старый 25.11.2012, 18:18   #9
Beaglebone
Board size: 3.4" x 2.1"
Shipped with 4 GB microSD card with the Angstrom Distribution with node.js and Cloud9 IDE
Single cable development environment with built-in FTDI-based serial/JTAG and on-board hub to give the same cable simultaneous access to a USB device port on the target processor
Industry standard 3.3V I/Os on the expansion headers with easy-to-use 0.1" spacing
On-chip Ethernet, not off of USB
256MB of DDR2
700-MHz super-scalar ARM Cortex™-A8
Easier to clone thanks to larger pitch on BGA devices (0.8mm vs. 0.4mm), no package-on-package memories, standard DDR2 vs. LPDDR, integrated USB PHYs and more.
Старый 26.11.2012, 21:26   #10
Hackberry
CPU 1.2GHz Allwinner A10 ARM Cortex A8
GPU Mali400 with hardware 3D acceleration and hardware video decoding
Serial port 3.3v TTL 4-pin header
Audio input 3.5mm microphone jack
Audio output Audio over HDMI
USB 2 x USB A 2.0 ports
Internal storage 4GB NAND storage, 1.5GB available in user partition in Android
External storage SDHC card slot supporting up to 32GB
Networking 10/100 Ethernet, Realtek 802.11n WiFi
Memory DDR3 512MB / 1GB, ~100MB is reserved for the GPU
Boot Boot from SD card and internal storage via u-boot
OS Android 4.0 ICS, Linux support
Digital video output HDMI up to 1080p (cable not included)
Analog video output 3.5mm composite AV, 3.5mm component Y/Pb/Pr (cables not included)
Power NEMA 2-pin power adapter included Input AC100-240V-0.4A 50/60Hz Output DC5v
Изображения
Текущее время: 23:40. Часовой пояс GMT +3.
