Старый 02.04.2016, 21:25   #1
Dewnet
Dewnet is an unknown quantity at this point
По умолчанию 3g модем
Подскажите что может быть на плату raspberry pi установлен openwrt, я пытаюсь его подружить с модемом zte mf 627 на модеме включен режим только модем. Ниже прикладываю лог подключения подскажите в чем может проблема
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 2.216344] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 2.227398] VFS: Mounted root (ext4 filesystem) on device 179:2.
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 2.235647] Freeing unused kernel memory: 116K (c03b9000 - c03d6000)
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 2.335247] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 2.343806] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 2.353653] hub 1-1:1.0: USB hub found
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 2.359391] hub 1-1:1.0: 5 ports detected
Sat Apr 2 15:14:13 2016 user.info kernel: [ 2.389274] init: Console is alive
Sat Apr 2 15:14:13 2016 user.info kernel: [ 2.395099] init: - watchdog -
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 2.634259] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 2.643593] ehci-platform: EHCI generic platform driver
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 2.650890] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 2.755128] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 2.763818] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 2.775767] smsc95xx v1.0.4
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 2.838682] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:ae:46:ca
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 2.944765] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 3.068248] usb 1-1.2: New USB device found, idVendor=19d2, idProduct=0031
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 3.076970] usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=3
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 3.086069] usb 1-1.2: Product: ZTE CDMA Technologies MSM
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 3.093159] usb 1-1.2: Manufacturer: ZTE, Incorporated
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 3.099956] usb 1-1.2: SerialNumber: 1234567890ABCDEF
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 3.109244] usb-storage 1-1.2:1.2: USB Mass Storage device detected
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 3.117800] scsi host0: usb-storage 1-1.2:1.2
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 3.204763] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 3.332479] usb 1-1.3: New USB device found, idVendor=148f, idProduct=5370
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 3.341154] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 3.350245] usb 1-1.3: Product: 802.11 n WLAN
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 3.356345] usb 1-1.3: Manufacturer: Ralink
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 3.362172] usb 1-1.3: SerialNumber: 1.0
Sat Apr 2 15:14:13 2016 user.info kernel: [ 3.401196] init: - preinit -
Sat Apr 2 15:14:13 2016 kern.notice kernel: [ 3.497260] random: procd urandom read with 71 bits of entropy available
Sat Apr 2 15:14:13 2016 kern.notice kernel: [ 4.116217] scsi 0:0:0:0: Direct-Access ZTE MMC Storage 2.31 PQ: 0 ANSI: 2
Sat Apr 2 15:14:13 2016 kern.notice kernel: [ 4.132089] sd 0:0:0:0: [sda] Attached SCSI removable disk
Sat Apr 2 15:14:13 2016 user.notice kernel: [ 6.651439] mount_root: mounting /dev/root
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 6.660600] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Sat Apr 2 15:14:13 2016 user.info kernel: [ 6.678286] procd: - early -
Sat Apr 2 15:14:13 2016 user.info kernel: [ 6.683007] procd: - watchdog -
Sat Apr 2 15:14:13 2016 user.info kernel: [ 7.386173] procd: - ubus -
Sat Apr 2 15:14:13 2016 user.info kernel: [ 8.398526] procd: - init -
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.317181] NET: Registered protocol family 10
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.381392] ip6_tables: (C) 2000-2006 Netfilter Core Team
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.410576] hidraw: raw HID events driver (C) Jiri Kosina
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.464851] usbcore: registered new interface driver cdc_acm
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.472016] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.484075] Loading modules backported from Linux version master-2015-03-09-0-g141f155
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.495202] Backport generated by backports.git backports-20150129-0-gdd4a670
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.534454] ip_tables: (C) 2000-2006 Netfilter Core Team
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.549386] nf_conntrack version 0.5.0 (7036 buckets, 28144 max)
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.605795] usbcore: registered new interface driver usbhid
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.613093] usbhid: USB HID core driver
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.624975] usbcore: registered new interface driver usbserial
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.632655] usbcore: registered new interface driver usbserial_generic
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.640964] usbserial: USB Serial support registered for generic
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.700007] xt_time: kernel timezone is -0000
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.722833] cfg80211: Calling CRDA to update world regulatory domain
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.736127] cfg80211: World regulatory domain updated:
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.743079] cfg80211: DFS Master region: unset
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.747590] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.762449] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.774098] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.785732] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.797368] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.809018] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.822274] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.834221] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.846327] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.923173] PPP generic driver version 2.4.2
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.936037] NET: Registered protocol family 24
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.973077] usbcore: registered new interface driver option
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.981113] usbserial: USB Serial support registered for GSM modem (1-port)
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.990942] option 1-1.2:1.0: GSM modem (1-port) converter detected
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 10.999836] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 11.009299] option 1-1.2:1.1: GSM modem (1-port) converter detected
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 11.018274] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 11.027864] option 1-1.2:1.3: GSM modem (1-port) converter detected
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 11.036686] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 11.144847] usb 1-1.3: reset high-speed USB device number 5 using dwc_otg
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 11.285939] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 detected
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 11.365062] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5370 detected
Sat Apr 2 15:14:13 2016 kern.debug kernel: [ 11.383765] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
Sat Apr 2 15:14:13 2016 kern.info kernel: [ 11.386114] usbcore: registered new interface driver rt2800usb
Sat Apr 2 15:14:16 2016 authpriv.info dropbear[819]: Not backgrounding
Sat Apr 2 15:14:17 2016 user.emerg syslog: setting up led MMC
Sat Apr 2 15:14:18 2016 daemon.info procd: - init complete -
Sat Apr 2 15:14:18 2016 kern.info kernel: [ 18.817622] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Sat Apr 2 15:14:18 2016 kern.info kernel: [ 18.829880] device eth0 entered promiscuous mode
Sat Apr 2 15:14:18 2016 kern.info kernel: [ 18.840263] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
Sat Apr 2 15:14:18 2016 daemon.notice netifd: Interface 'lan' is enabled
Sat Apr 2 15:14:18 2016 daemon.notice netifd: Interface '3g' is setting up now
Sat Apr 2 15:14:18 2016 daemon.notice netifd: Interface 'loopback' is enabled
Sat Apr 2 15:14:18 2016 daemon.notice netifd: Interface 'loopback' is setting up now
Sat Apr 2 15:14:18 2016 daemon.notice netifd: Interface 'loopback' is now up
Sat Apr 2 15:14:18 2016 daemon.notice netifd: Network device 'lo' link is up
Sat Apr 2 15:14:18 2016 daemon.notice netifd: Interface 'loopback' has link connectivity
Sat Apr 2 15:14:19 2016 kern.notice kernel: [ 19.748261] random: nonblocking pool is initialized
Sat Apr 2 15:14:20 2016 daemon.notice netifd: radio0 (892): Configuration file: /var/run/hostapd-phy0.conf
Sat Apr 2 15:14:20 2016 kern.info kernel: [ 20.304365] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
Sat Apr 2 15:14:20 2016 kern.info kernel: [ 20.350680] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
Sat Apr 2 15:14:20 2016 kern.info kernel: [ 20.385913] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
Sat Apr 2 15:14:20 2016 kern.info kernel: [ 20.829855] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Sat Apr 2 15:14:20 2016 kern.info kernel: [ 20.841348] br-lan: port 1(eth0) entered forwarding state
Sat Apr 2 15:14:20 2016 kern.info kernel: [ 20.849031] br-lan: port 1(eth0) entered forwarding state
Sat Apr 2 15:14:20 2016 daemon.notice netifd: Network device 'eth0' link is up
Sat Apr 2 15:14:20 2016 kern.info kernel: [ 20.881461] device wlan0 entered promiscuous mode
Sat Apr 2 15:14:20 2016 kern.info kernel: [ 20.889069] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Sat Apr 2 15:14:20 2016 daemon.notice netifd: Bridge 'br-lan' link is up
Sat Apr 2 15:14:20 2016 daemon.notice netifd: Interface 'lan' has link connectivity
Sat Apr 2 15:14:20 2016 daemon.notice netifd: Interface 'lan' is setting up now
Sat Apr 2 15:14:20 2016 daemon.notice netifd: radio0 (892): wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Sat Apr 2 15:14:20 2016 daemon.notice netifd: radio0 (892): Using interface wlan0 with hwaddr 00:c1:40:58:08:03 and ssid «OpenWrt»
Sat Apr 2 15:14:21 2016 daemon.info dnsmasq[1044]: started, version 2.73 cachesize 150
Sat Apr 2 15:14:21 2016 daemon.info dnsmasq[1044]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC loop-detect inotify
Sat Apr 2 15:14:21 2016 daemon.info dnsmasq[1044]: DNS service limited to local subnets
Sat Apr 2 15:14:21 2016 daemon.info dnsmasq[1044]: using local addresses only for domain lan
Sat Apr 2 15:14:21 2016 daemon.warn dnsmasq[1044]: no servers found in /tmp/resolv.conf.auto, will retry
Sat Apr 2 15:14:21 2016 daemon.info dnsmasq[1044]: read /etc/hosts - 1 addresses
Sat Apr 2 15:14:21 2016 daemon.notice netifd: lan (1047): udhcpc (v1.23.2) started
Sat Apr 2 15:14:21 2016 daemon.notice netifd: lan (1047): Sending discover...
Sat Apr 2 15:14:21 2016 daemon.notice netifd: lan (1047): Sending select for 172.16.1.100...
Sat Apr 2 15:14:21 2016 daemon.notice netifd: lan (1047): Lease of 172.16.1.100 obtained, lease time 28800
Sat Apr 2 15:14:21 2016 kern.info kernel: [ 21.494834] br-lan: port 2(wlan0) entered forwarding state
Sat Apr 2 15:14:21 2016 kern.info kernel: [ 21.502505] br-lan: port 2(wlan0) entered forwarding state
Sat Apr 2 15:14:21 2016 kern.info kernel: [ 21.510125] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Sat Apr 2 15:14:21 2016 daemon.notice netifd: radio0 (892): wlan0: interface state COUNTRY_UPDATE->ENABLED
Sat Apr 2 15:14:21 2016 daemon.notice netifd: radio0 (892): wlan0: AP-ENABLED
Sat Apr 2 15:14:21 2016 daemon.notice netifd: Interface 'lan' is now up
Sat Apr 2 15:14:21 2016 daemon.info dnsmasq[1044]: reading /tmp/resolv.conf.auto
Sat Apr 2 15:14:21 2016 daemon.info dnsmasq[1044]: using nameserver 172.16.1.1#53
Sat Apr 2 15:14:21 2016 daemon.info dnsmasq[1044]: read /tmp/hosts/odhcpd - 0 addresses
Sat Apr 2 15:14:21 2016 daemon.notice netifd: Network device 'wlan0' link is up
Sat Apr 2 15:14:21 2016 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Sat Apr 2 15:14:21 2016 daemon.notice netifd: lan (1047): Performing a DHCP renew
Sat Apr 2 15:14:21 2016 daemon.notice netifd: lan (1047): Sending renew...
Sat Apr 2 15:14:22 2016 kern.info kernel: [ 22.844796] br-lan: port 1(eth0) entered forwarding state
Sat Apr 2 15:14:23 2016 daemon.notice netifd: 3g (890): Trying to set PIN
Sat Apr 2 15:14:23 2016 kern.info kernel: [ 23.494750] br-lan: port 2(wlan0) entered forwarding state
Sat Apr 2 15:14:23 2016 daemon.notice netifd: 3g (890): PIN set successfully
Sat Apr 2 15:14:24 2016 daemon.notice pppd[1146]: pppd 2.4.7 started by root, uid 0
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: abort on (BUSY)
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: abort on (ERROR)
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: abort on (NO ANSWER)
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: abort on (NO CARRIER)
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: abort on (NO DIALTONE)
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: abort on (Invalid Login)
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: abort on (Login incorrect)
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: timeout set to 5 seconds
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: send (\\d^M)
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: send (AT^M)
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: expect (OK)
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: AT^M^M
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: OK
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: — got it
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: send (ATV1^M)
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: ^M
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: ATV1^M^M
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: send (ATE0^M)
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: ATE0^M^M
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: send (AT&F&D2&C1S0=0^M)
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: +ZDONR: «Not Found»^M
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: +ZPASR: «No Service»^M
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: send (ATS7=60S30=0^M)
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: send (ATS0=0^M)
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: timeout set to 10 seconds
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: send (ATZ^M)
Sat Apr 2 15:14:25 2016 local2.info chat[1148]: send (AT+CGDCONT=1,\«IP\»,\«internet.mts.r u\»^M)
Sat Apr 2 15:14:26 2016 local2.info chat[1148]: timeout set to 20 seconds
Sat Apr 2 15:14:26 2016 local2.info chat[1148]: expect (OK)
Sat Apr 2 15:14:26 2016 local2.info chat[1148]: ^M
Sat Apr 2 15:14:26 2016 local2.info chat[1148]: OK
Sat Apr 2 15:14:26 2016 local2.info chat[1148]: — got it
Sat Apr 2 15:14:26 2016 local2.info chat[1148]: send (ATDT*99#^M)
Sat Apr 2 15:14:26 2016 local2.info chat[1148]: expect (CONNECT)
Sat Apr 2 15:14:26 2016 local2.info chat[1148]: AT+CGDCONT=1,«IP»,«internet.mts.ru»^ M^M
Sat Apr 2 15:14:26 2016 local2.info chat[1148]: OK^M
Sat Apr 2 15:14:46 2016 local2.info chat[1148]: alarm
Sat Apr 2 15:14:46 2016 local2.info chat[1148]: Failed
Sat Apr 2 15:14:46 2016 daemon.err pppd[1146]: Connect script failed
Sat Apr 2 15:14:47 2016 daemon.info pppd[1146]: Exit.
Sat Apr 2 15:14:47 2016 daemon.notice netifd: Interface '3g' is now down
Sat Apr 2 15:14:47 2016 daemon.notice netifd: Interface '3g' is setting up now
Sat Apr 2 16:38:52 2016 daemon.notice netifd: 3g (1186): comgt 16:38:52 -> — Error Report --
Sat Apr 2 16:38:52 2016 daemon.notice netifd: 3g (1186): comgt 16:38:52 -> ----> ^
Sat Apr 2 16:38:52 2016 daemon.notice netifd: 3g (1186): comgt 16:38:52 -> Error @152, line 10, Could not write to COM device. (1)
Dewnet вне форума   Ответить с цитированием
3g modem
Текущее время: 06:20. Часовой пояс GMT +3.
