Старый 02.12.2015, 15:05   #1
Сергей В
Exclamation Поломка wdr3500
Добрый день, помогите выявить причину поломки\сбоев в работе роутера.
лог
Using username "root".
[email protected]'s password:
BusyBox v1.22.1 (2014-09-20 22:01:35 CEST) built-in shell (ash)
 BARRIER BREAKER (14.07, r42625)
  * 1/2 oz Galliano         Pour all ingredients into
  * 4 oz cold Coffee        an irish coffee mug filled
  * 1 1/2 oz Dark Rum       with crushed ice. Stir.
  * 2 tsp. Creme de Cacao
root@OpenWrt:~# logread
Sat Nov 28 16:32:16 2015 kern.notice kernel: [    0.740000] 0x00000012e6a8-0x0000007f0000 : "rootfs"
Sat Nov 28 16:32:16 2015 kern.warn kernel: [    0.750000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
Sat Nov 28 16:32:16 2015 kern.notice kernel: [    0.760000] mtd: device 2 (rootfs) set to be root filesystem
Sat Nov 28 16:32:16 2015 kern.notice kernel: [    0.770000] 1 squashfs-split partitions found on MTD device rootfs
Sat Nov 28 16:32:16 2015 kern.notice kernel: [    0.770000] 0x000000350000-0x0000007f0000 : "rootfs_data"
Sat Nov 28 16:32:16 2015 kern.notice kernel: [    0.780000] 0x0000007f0000-0x000000800000 : "art"
Sat Nov 28 16:32:16 2015 kern.notice kernel: [    0.790000] 0x000000020000-0x0000007f0000 : "firmware"
Sat Nov 28 16:32:16 2015 kern.info kernel: [    0.810000] libphy: ag71xx_mdio: probed
Sat Nov 28 16:32:16 2015 kern.info kernel: [    1.360000] ag71xx-mdio.1: Found an AR934X built-in switch
Sat Nov 28 16:32:16 2015 kern.info kernel: [    2.400000] eth0: Atheros AG71xx at 0xba000000, irq 5, mode:GMII
Sat Nov 28 16:32:16 2015 kern.info kernel: [    2.950000] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd042, driver=Generic PHY]
Sat Nov 28 16:32:16 2015 kern.info kernel: [    2.960000] eth1: Atheros AG71xx at 0xb9000000, irq 4, mode:MII
Sat Nov 28 16:32:16 2015 kern.info kernel: [    2.970000] TCP: cubic registered
Sat Nov 28 16:32:16 2015 kern.info kernel: [    2.980000] NET: Registered protocol family 17
Sat Nov 28 16:32:16 2015 kern.notice kernel: [    2.980000] Bridge firewalling registered
Sat Nov 28 16:32:16 2015 kern.info kernel: [    2.980000] 8021q: 802.1Q VLAN Support v1.8
Sat Nov 28 16:32:16 2015 kern.info kernel: [    3.000000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Sat Nov 28 16:32:16 2015 kern.info kernel: [    3.000000] Freeing unused kernel memory: 272K (8034c000 - 80390000)
Sat Nov 28 16:32:16 2015 kern.info kernel: [    5.170000] usbcore: registered new interface driver usbfs
Sat Nov 28 16:32:16 2015 kern.info kernel: [    5.180000] usbcore: registered new interface driver hub
Sat Nov 28 16:32:16 2015 kern.info kernel: [    5.180000] usbcore: registered new device driver usb
Sat Nov 28 16:32:16 2015 kern.info kernel: [    5.190000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Sat Nov 28 16:32:16 2015 kern.info kernel: [    5.200000] ehci-platform: EHCI generic platform driver
Sat Nov 28 16:32:16 2015 kern.info kernel: [    5.210000] ehci-platform ehci-platform: EHCI Host Controller
Sat Nov 28 16:32:16 2015 kern.info kernel: [    5.210000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
Sat Nov 28 16:32:16 2015 kern.info kernel: [    5.220000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
Sat Nov 28 16:32:16 2015 kern.info kernel: [    5.250000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
Sat Nov 28 16:32:16 2015 kern.info kernel: [    5.250000] hub 1-0:1.0: USB hub found
Sat Nov 28 16:32:16 2015 kern.info kernel: [    5.260000] hub 1-0:1.0: 1 port detected
Sat Nov 28 16:32:16 2015 kern.info kernel: [    7.220000] eth0: link up (1000Mbps/Full duplex)
Sat Nov 28 16:32:16 2015 kern.notice kernel: [    9.950000] jffs2: notice: (336) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 24 of xref (0 dead, 10 orphan) found.
Sat Nov 28 16:32:16 2015 kern.notice kernel: [   10.940000] SCSI subsystem initialized
Sat Nov 28 16:32:16 2015 kern.info kernel: [   10.950000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Sat Nov 28 16:32:16 2015 kern.info kernel: [   10.960000] uhci_hcd: USB Universal Host Controller Interface driver
Sat Nov 28 16:32:16 2015 kern.info kernel: [   10.980000] usbcore: registered new interface driver usb-storage
Sat Nov 28 16:32:16 2015 kern.info kernel: [   11.240000] eth0: link down
Sat Nov 28 16:32:16 2015 kern.info kernel: [   12.990000] NET: Registered protocol family 10
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.010000] zram: Created 1 device(s) ...
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.030000] NTFS driver 2.1.30 [Flags: R/O MODULE].
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.080000] nf_conntrack version 0.5.0 (1973 buckets, 7892 max)
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.100000] ip6_tables: (C) 2000-2006 Netfilter Core Team
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.110000] Loading modules backported from Linux version master-2014-05-22-0-gf2032ea
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.120000] Backport generated by backports.git backports-20140320-37-g5c33da0
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.130000] ip_tables: (C) 2000-2006 Netfilter Core Team
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.160000] usbcore: registered new interface driver ums-alauda
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.170000] usbcore: registered new interface driver ums-cypress
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.190000] usbcore: registered new interface driver ums-datafab
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.190000] usbcore: registered new interface driver ums-freecom
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.200000] usbcore: registered new interface driver ums-isd200
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.210000] usbcore: registered new interface driver ums-jumpshot
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.220000] usbcore: registered new interface driver ums-karma
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.230000] usbcore: registered new interface driver ums-sddr09
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.240000] usbcore: registered new interface driver ums-sddr55
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.240000] usbcore: registered new interface driver ums-usbat
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.260000] usbcore: registered new interface driver usbserial
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.270000] usbcore: registered new interface driver usbserial_generic
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.280000] usbserial: USB Serial support registered for generic
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.300000] xt_time: kernel timezone is -0000
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.340000] cfg80211: Calling CRDA to update world regulatory domain
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.340000] cfg80211: World regulatory domain updated:
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.350000] cfg80211:  DFS Master region: unset
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.350000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.360000] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.370000] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.380000] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.390000] cfg80211:   (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.390000] cfg80211:   (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.400000] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.410000] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.420000] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.430000] usbcore: registered new interface driver ch341
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.450000] usbserial: USB Serial support registered for ch341-uart
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.450000] usbcore: registered new interface driver cp210x
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.470000] usbserial: USB Serial support registered for cp210x
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.470000] usbcore: registered new interface driver ftdi_sio
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.490000] usbserial: USB Serial support registered for FTDI USB Serial Device
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.530000] PPP generic driver version 2.4.2
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.540000] NET: Registered protocol family 24
Sat Nov 28 16:32:16 2015 kern.debug kernel: [   13.590000] ath: EEPROM regdomain: 0x0
Sat Nov 28 16:32:16 2015 kern.debug kernel: [   13.590000] ath: EEPROM indicates default country code should be used
Sat Nov 28 16:32:16 2015 kern.debug kernel: [   13.590000] ath: doing EEPROM country->regdmn map search
Sat Nov 28 16:32:16 2015 kern.debug kernel: [   13.590000] ath: country maps to regdmn code: 0x3a
Sat Nov 28 16:32:16 2015 kern.debug kernel: [   13.590000] ath: Country alpha2 being used: US
Sat Nov 28 16:32:16 2015 kern.debug kernel: [   13.590000] ath: Regpair used: 0x3a
Sat Nov 28 16:32:16 2015 kern.debug kernel: [   13.600000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.610000] ieee80211 phy0: Atheros AR9340 Rev:0 mem=0xb8100000, irq=47
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.620000] cfg80211: Calling CRDA for country: US
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.620000] cfg80211: Regulatory domain changed to country: US
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.630000] cfg80211:  DFS Master region: FCC
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.630000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.640000] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.650000] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm), (N/A)
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.660000] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm), (0 s)
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.670000] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.670000] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
Sat Nov 28 16:32:16 2015 kern.warn kernel: [   13.680000] PCI: Enabling device 0000:00:00.0 (0000 -> 0002)
Sat Nov 28 16:32:16 2015 kern.debug kernel: [   13.690000] ath: EEPROM regdomain: 0x0
Sat Nov 28 16:32:16 2015 kern.debug kernel: [   13.690000] ath: EEPROM indicates default country code should be used
Sat Nov 28 16:32:16 2015 kern.debug kernel: [   13.690000] ath: doing EEPROM country->regdmn map search
Sat Nov 28 16:32:16 2015 kern.debug kernel: [   13.690000] ath: country maps to regdmn code: 0x3a
Sat Nov 28 16:32:16 2015 kern.debug kernel: [   13.690000] ath: Country alpha2 being used: US
Sat Nov 28 16:32:16 2015 kern.debug kernel: [   13.690000] ath: Regpair used: 0x3a
Sat Nov 28 16:32:16 2015 kern.debug kernel: [   13.720000] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
Sat Nov 28 16:32:16 2015 kern.info kernel: [   13.720000] ieee80211 phy1: Atheros AR9300 Rev:4 mem=0xb0000000, irq=40
Sat Nov 28 16:32:18 2015 user.emerg syslog: 'radio1' is disabled
Sat Nov 28 16:32:19 2015 user.emerg syslog: uinteger - 8 = true
Sat Nov 28 16:32:19 2015 cron.info crond[924]: crond: crond (busybox 1.22.1) started, log level 8
Sat Nov 28 16:32:20 2015 authpriv.info dropbear[945]: Not backgrounding
Sat Nov 28 16:32:21 2015 local0.notice udpxy[976]: udpxy 1.0-23.9 (prod) standard [Linux 3.10.49 mips] is starting
Sat Nov 28 16:32:22 2015 user.emerg syslog: Error, serial port '/dev/ttyUSB0' does not exists!
Sat Nov 28 16:32:22 2015 user.emerg syslog: setting up led USB
Sat Nov 28 16:32:22 2015 user.emerg syslog: setting up led WLAN2G
Sat Nov 28 16:32:22 2015 user.emerg syslog: - init complete -
Sat Nov 28 16:32:22 2015 kern.info kernel: [   22.720000] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Sat Nov 28 16:32:22 2015 kern.info kernel: [   22.720000] device eth0 entered promiscuous mode
Sat Nov 28 16:32:22 2015 daemon.notice netifd: Interface 'lan' is enabled
Sat Nov 28 16:32:22 2015 daemon.notice netifd: Interface 'lan' is setting up now
Sat Nov 28 16:32:22 2015 kern.info kernel: [   22.730000] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
Sat Nov 28 16:32:22 2015 daemon.notice netifd: Interface 'lan' is now up
Sat Nov 28 16:32:22 2015 daemon.notice netifd: Interface 'loopback' is enabled
Sat Nov 28 16:32:22 2015 daemon.notice netifd: Interface 'loopback' is setting up now
Sat Nov 28 16:32:22 2015 daemon.notice netifd: Interface 'loopback' is now up
Sat Nov 28 16:32:22 2015 kern.info kernel: [   22.740000] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Sat Nov 28 16:32:22 2015 daemon.notice netifd: Interface 'wan' is enabled
Sat Nov 28 16:32:22 2015 daemon.notice netifd: Network device 'lo' link is up
Sat Nov 28 16:32:22 2015 daemon.notice netifd: Interface 'loopback' has link connectivity
Sat Nov 28 16:32:23 2015 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Sat Nov 28 16:32:23 2015 kern.info kernel: [   23.320000] eth0: link up (1000Mbps/Full duplex)
Sat Nov 28 16:32:23 2015 kern.info kernel: [   23.320000] br-lan: port 1(eth0) entered forwarding state
Sat Nov 28 16:32:23 2015 kern.info kernel: [   23.330000] br-lan: port 1(eth0) entered forwarding state
Sat Nov 28 16:32:23 2015 kern.info kernel: [   23.330000] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Sat Nov 28 16:32:23 2015 daemon.notice netifd: Network device 'eth0' link is up
Sat Nov 28 16:32:23 2015 daemon.notice netifd: Bridge 'br-lan' link is up
Sat Nov 28 16:32:23 2015 daemon.notice netifd: Interface 'lan' has link connectivity
Sat Nov 28 16:32:23 2015 kern.info kernel: [   23.360000] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Sat Nov 28 16:32:24 2015 kern.info kernel: [   24.120000] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Sat Nov 28 16:32:24 2015 kern.info kernel: [   24.130000] device wlan0 entered promiscuous mode
Sat Nov 28 16:32:24 2015 kern.info kernel: [   24.140000] br-lan: port 2(wlan0) entered forwarding state
Sat Nov 28 16:32:24 2015 kern.info kernel: [   24.150000] br-lan: port 2(wlan0) entered forwarding state
Sat Nov 28 16:32:24 2015 kern.info kernel: [   24.150000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Sat Nov 28 16:32:24 2015 daemon.notice netifd: Network device 'wlan0' link is up
Sat Nov 28 16:32:25 2015 kern.info kernel: [   25.330000] br-lan: port 1(eth0) entered forwarding state
Sat Nov 28 16:32:26 2015 kern.info kernel: [   26.100000] eth1: link up (100Mbps/Full duplex)
Sat Nov 28 16:32:26 2015 kern.info kernel: [   26.100000] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Sat Nov 28 16:32:26 2015 daemon.notice netifd: Network device 'eth1' link is up
Sat Nov 28 16:32:26 2015 daemon.notice netifd: Interface 'wan' has link connectivity
Sat Nov 28 16:32:26 2015 daemon.notice netifd: Interface 'wan' is setting up now
Sat Nov 28 16:32:26 2015 kern.info kernel: [   26.150000] br-lan: port 2(wlan0) entered forwarding state
Sat Nov 28 16:32:26 2015 daemon.notice netifd: wan (1178): udhcpc (v1.22.1) started
Sat Nov 28 16:32:26 2015 daemon.notice netifd: wan (1178): Sending discover...
Sat Nov 28 16:32:26 2015 daemon.notice netifd: wan (1178): Sending select for 192.168.1.41...
Sat Nov 28 16:32:26 2015 daemon.notice netifd: wan (1178): Lease of 192.168.1.41 obtained, lease time 25200
Sat Nov 28 16:32:26 2015 daemon.notice netifd: Interface 'wan' is now up
Sat Nov 28 16:32:28 2015 daemon.info dnsmasq[1200]: started, version 2.71 cachesize 150
Sat Nov 28 16:32:28 2015 daemon.info dnsmasq[1200]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC
Sat Nov 28 16:32:28 2015 daemon.info dnsmasq-dhcp[1200]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Sat Nov 28 16:32:28 2015 daemon.info dnsmasq[1200]: using local addresses only for domain lan
Sat Nov 28 16:32:28 2015 daemon.info dnsmasq[1200]: reading /tmp/resolv.conf.auto
Sat Nov 28 16:32:28 2015 daemon.warn dnsmasq[1200]: ignoring nameserver 192.168.1.1 - local interface
Sat Nov 28 16:32:28 2015 daemon.info dnsmasq[1200]: read /etc/hosts - 1 addresses
Sat Nov 28 16:32:28 2015 daemon.info dnsmasq[1200]: read /tmp/hosts/dhcp - 1 addresses
Sat Nov 28 16:32:28 2015 daemon.info dnsmasq-dhcp[1200]: read /etc/ethers - 0 addresses
Sat Nov 28 16:32:28 2015 daemon.info dnsmasq[1200]: exiting on receipt of SIGTERM
Sat Nov 28 16:32:29 2015 daemon.info dnsmasq[1254]: started, version 2.71 cachesize 150
Sat Nov 28 16:32:29 2015 daemon.info dnsmasq[1254]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC
Sat Nov 28 16:32:29 2015 daemon.info dnsmasq-dhcp[1254]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Sat Nov 28 16:32:29 2015 daemon.info dnsmasq[1254]: using local addresses only for domain lan
Sat Nov 28 16:32:29 2015 daemon.info dnsmasq[1254]: reading /tmp/resolv.conf.auto
Sat Nov 28 16:32:29 2015 daemon.warn dnsmasq[1254]: ignoring nameserver 192.168.1.1 - local interface
Sat Nov 28 16:32:29 2015 daemon.info dnsmasq[1254]: read /etc/hosts - 1 addresses
Sat Nov 28 16:32:29 2015 daemon.info dnsmasq[1254]: read /tmp/hosts/dhcp - 1 addresses
Sat Nov 28 16:32:29 2015 daemon.info dnsmasq-dhcp[1254]: read /etc/ethers - 0 addresses
Sat Nov 28 16:32:29 2015 user.notice firewall: Reloading firewall due to ifup of wan (eth1)
Sat Nov 28 16:32:36 2015 daemon.info dnsmasq-dhcp[1254]: DHCPREQUEST(br-lan) 192.168.1.102 00:1c:c4:d0:0f:7c
Sat Nov 28 16:32:36 2015 daemon.info dnsmasq-dhcp[1254]: DHCPACK(br-lan) 192.168.1.102 00:1c:c4:d0:0f:7c AdminHP
Sat Nov 28 16:32:39 2015 authpriv.info dropbear[1316]: Child connection from 192.168.1.102:58194
Sat Nov 28 16:32:40 2015 daemon.info dnsmasq-dhcp[1254]: DHCPINFORM(br-lan) 192.168.1.102 00:1c:c4:d0:0f:7c
Sat Nov 28 16:32:40 2015 daemon.info dnsmasq-dhcp[1254]: DHCPACK(br-lan) 192.168.1.102 00:1c:c4:d0:0f:7c AdminHP
Sat Nov 28 16:32:45 2015 authpriv.notice dropbear[1316]: Password auth succeeded for 'root' from 192.168.1.102:58194
root@OpenWrt:~#
Cуть проблемы такова:
При старте роутера не соединятся с поступает интернет, хотя в веб морде активный соединений трафик идет. (хотя слабый за 2 минуты 12 килобайт) но при этом интернет не доступен на устройствах (ноут, стоц, смартфон).
Очень редко помогает релог кнопкой (10-90)
Релог ребутом помогает получше (50-50)
Релог через /etc/config/network restart (60-40)
При стоковой прошивки от tp-link заметны аналогичные проблемы но гораздо меньше.
Единственное в чем может причина быть - это в железе, но где именно?!
в какую сторону капать?! единственное на что могу грешить (причину) подключение hdd к роутеру т.е. жесткий диск+юсб с выходом на дополнительное питание. жестки+блок питания+основной провод в роутер) возможно "лишнее" питание сожгло что -нить в роутере и нарушило его работоспособность. Прошу помощи=) в поисках этой неисправности и ее устранения). так же (основное мое мнение это нарушение работы чипа памяти но как это проверить я не знаю, пробовал подключится через юсб-уарт, нечего не вышло, видимо кривые руки(.
Старый 02.12.2015, 15:46   #2
По умолчанию Re: Поломка wdr3500
Интернет подключение какое?
Старый 02.12.2015, 16:00   #3
Сергей В
оптоволокно привязка по маку Динамический IP-адрес.
Настраиваю как всегда, но как выше писал видимо в железе дело
Старый 02.12.2015, 16:05   #4
Может питание попробовать мощнее подключить?
Старый 02.12.2015, 16:08   #5
Сергей В
а смысл если стартует через раз даже без подключенной перефирии.
Старый 02.12.2015, 16:11   #6
Сергей В
В связи будущей покупкой Archer C9 готов дать wdr3500 для тестирования кому нибудь желательно с москвы)
Старый 02.12.2015, 16:54   #7
Сергей В
но хотелось бы отремонтировать и wdr3500 для развертывания второго домашнего сервера.
Старый 02.12.2015, 18:42   #8
Вес репутации: 1031
В приложенном логе часто проскакивает:
Может ДНС в ручную забит, поэтому инет и не работает?
Проверить можно пингом (при неработающем инете) на ya.ru по ИПу 213.180.193.3
Старый 02.12.2015, 19:44   #9
Именно так, или прописать DNS провайдера или пустое место оставить.
Можно конечно попробовать турецкие прописать:
- Primary DNS server: 195.175.39.40 (dns40.turktelekom.com.tr)
- Secondary DNS server: 195.175.39.39 (dns39.turktelekom.com.tr)
- Может питание попробовать мощнее подключить?
- а смысл если стартует через раз даже без подключенной перефирии
Смысл есть, его не может не быть
- Интернет подключение какое?
- оптоволокно привязка по маку Динамический IP-адрес.
Имхо, задающиий вопрос хотел услышать PPPoE или L2TP или IPoE
Старый 02.12.2015, 21:14   #10
Это случайно не ip на WAN роутера, выданный провом??
Вот и конфликт ip. Соединение есть а интернета нету.
Попробуй так;
Если в роутере ip-адрес LAN 192.168.1.1 то смени на 192.168.2.1
Вход в роутер будет по 192.168.2.1
Последний раз редактировалось melsem; 03.12.2015 в 02:12.
Текущее время: 05:39. Часовой пояс GMT +3.
