Старый 22.07.2015, 22:08   #1
lbest
lbest is an unknown quantity at this point
По умолчанию Reaver не собирается
доброго времени суток, помогите собрать reaver в прошивку
ошибка вот такая:
root@lbest-virtual-machine:~/wrt99/wrt# make package/reaver/{clean,compile} V=99
make[1]: Entering directory '/home/lbest/wrt99/wrt'
make[2]: Entering directory '/home/lbest/wrt99/wrt/package/packages/net/reaver'
rm -/home/lbest/wrt99/wrt/bin/ramips/packages/base/reaver_*
rm -/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/stamp/.reaver_installed
rm
-/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/packages/reaver.list /home/lbest/wrt99/wrt/staging_dir/host/packages/reaver.list
rm -rf /home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119
make
[2]: Leaving directory '/home/lbest/wrt99/wrt/package/packages/net/reaver'
make[1]: Leaving directory '/home/lbest/wrt99/wrt'
make[2]: Entering directory '/home/lbest/wrt99/wrt/package/libs/toolchain'
if [ -/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/toolchain.default.install.clean ]; then rm -/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/toolchain.default.install /home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/toolchain.default.install.cleanfi; echo "libc" >> /home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/toolchain.default.install
if [ -/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/toolchain.default.install.clean ]; then rm -/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/toolchain.default.install /home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/toolchain.default.install.cleanfi; echo "libgcc" >> /home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/toolchain.default.install
if [ -/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/toolchain.default.install.clean ]; then rm -/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/toolchain.default.install /home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/toolchain.default.install.cleanfi; echo "libpthread" >> /home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/toolchain.default.install
make
[2]: Leaving directory '/home/lbest/wrt99/wrt/package/libs/toolchain'
make[2]: Entering directory '/home/lbest/wrt99/wrt/package/feeds/packages/libpcap'
if [ -/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/libpcap.default.install.clean ]; then rm -/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/libpcap.default.install /home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/libpcap.default.install.cleanfi; echo "libpcap" >> /home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/libpcap.default.install
make
[2]: Leaving directory '/home/lbest/wrt99/wrt/package/feeds/packages/libpcap'
make[2]: Entering directory '/home/lbest/wrt99/wrt/package/libs/libreadline'
make[2]: Leaving directory '/home/lbest/wrt99/wrt/package/libs/libreadline'
make[2]: Entering directory '/home/lbest/wrt99/wrt/package/libs/ncurses'
make[2]: Leaving directory '/home/lbest/wrt99/wrt/package/libs/ncurses'
make[2]: Entering directory '/home/lbest/wrt99/wrt/feeds/packages/libs/sqlite3'
if [ -/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/sqlite3.default.install.clean ]; then rm -/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/sqlite3.default.install /home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/sqlite3.default.install.cleanfi; echo "libsqlite3" >> /home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/pkginfo/sqlite3.default.install
make
[2]: Leaving directory '/home/lbest/wrt99/wrt/feeds/packages/libs/sqlite3'
. /home/lbest/wrt99/wrt/include/shell.shgzip -dc /home/lbest/wrt99/wrt/dl/reaver-r119.tar.gz tar -/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/.. -xf
Applying ./patches/0001-wpscrack-big-endian-fixes.patch using plaintext
patching file src/80211.c
patching file src
/builder.c
patching file src
/defs.h
patching file src
/exchange.c
patching file src
/wpsmon.c
Applying
./patches/0002-Use-the-current-directory-for-storing-and-loading-se.patch using plaintext
patching file src/session.c
Applying
./patches/0003-wash-wpsmon-use-less-useless-spaces-in-output-to-fit.patch using plaintext
patching file src/wpsmon.c
touch
/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/.prepared_e759ae8c9bb50c3a784d334fea774193
rm
(cd /home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/src/; if [ -./configure ]; then find /home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/ -name config.guess xargs -r chmod u+wfind /home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/ -name config.guess xargs --n1 cp --remove-destination /home/lbest/wrt99/wrt/scripts/config.guessfind /home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/ -name config.sub xargs -r chmod u+wfind /home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/ -name config.sub xargs --n1 cp --remove-destination /home/lbest/wrt99/wrt/scripts/config.subAR="mipsel-openwrt-linux-musl-gcc-ar" AS="mipsel-openwrt-linux-musl-gcc -c -Os -pipe -mno-branch-likely -mips32r2 -mtune=24kec -mdsp -fno-caller-saves -fhonour-copts -Wno-error=unused-but-set-variable -msoft-float -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -I/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/usr/include -I/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/include -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/usr/include -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/include/fortify -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/include" LD=mipsel-openwrt-linux-musl-ld NM="mipsel-openwrt-linux-musl-gcc-nm" CC="mipsel-openwrt-linux-musl-gcc" GCC="mipsel-openwrt-linux-musl-gcc" CXX="mipsel-openwrt-linux-musl-g++" RANLIB="mipsel-openwrt-linux-musl-gcc-ranlib" STRIP=mipsel-openwrt-linux-musl-strip OBJCOPY=mipsel-openwrt-linux-musl-objcopy OBJDUMP=mipsel-openwrt-linux-musl-objdump SIZE=mipsel-openwrt-linux-musl-size CFLAGS="-Os -pipe -mno-branch-likely -mips32r2 -mtune=24kec -mdsp -fno-caller-saves -fhonour-copts -Wno-error=unused-but-set-variable -msoft-float -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -I/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/usr/include -I/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/include -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/usr/include -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/include/fortify -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/include " CXXFLAGS="-Os -pipe -mno-branch-likely -mips32r2 -mtune=24kec -mdsp -fno-caller-saves -fhonour-copts -Wno-error=unused-but-set-variable -msoft-float -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -I/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/usr/include -I/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/include -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/usr/include -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/include/fortify -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/include " CPPFLAGS="-I/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/usr/include -I/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/include -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/usr/include -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/include/fortify -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/include " LDFLAGS="-L/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/usr/lib -L/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/lib -L/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/usr/lib -L/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/lib -znow -zrelro "   ./configure --target=mipsel-openwrt-linux --host=mipsel-openwrt-linux --build=x86_64-linux-gnu --program-prefix="" --program-suffix="" --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --libexecdir=/usr/lib --sysconfdir=/etc --datadir=/usr/share --localstatedir=/var --mandir=/usr/man --infodir=/usr/info --disable-nls   fi; )
configureWARNINGunrecognized options: --disable-nls
configure
loading site script /home/lbest/wrt99/wrt/include/site/mipsel
checking
for mipsel-openwrt-linux-gcc... mipsel-openwrt-linux-musl-gcc
checking whether the C compiler works
... yes
checking
for C compiler default output file name... a.out
checking
for suffix of executables...
checking whether we are cross compiling... yes
checking
for suffix of object files... o
checking whether we are using the GNU C compiler
... yes
checking whether mipsel
-openwrt-linux-musl-gcc accepts -g... yes
checking
for mipsel-openwrt-linux-musl-gcc option to accept ISO C89... none needed
checking
for pcap_open_live in -lpcap... yes
checking
for sqlite3_open in -lsqlite3... yes
checking how to run the C preprocessor
... mipsel-openwrt-linux-musl-gcc -E
checking
for grep that handles long lines and -e... /home/lbest/wrt99/wrt/staging_dir/host/bin/grep
checking
for egrep... /home/lbest/wrt99/wrt/staging_dir/host/bin/grep -E
checking
for ANSI C header files... yes
checking
for sys/types.h... yes
checking
for sys/stat.h... yes
checking
for stdlib.h... yes
checking
for string.h... yes
checking
for memory.h... yes
checking
for strings.h... yes
checking
for inttypes.h... yes
checking
for stdint.h... yes
checking
for unistd.h... yes
checking
for stdlib.h... (cachedyes
checking
for stdint.h... (cachedyes
checking
for string.h... (cachedyes
checking pcap
.h usability... yes
checking pcap
.h presence... yes
checking
for pcap.h... yes
checking sqlite3
.h usability... yes
checking sqlite3
.h presence... yes
checking
for sqlite3.h... yes
configure
creating ./config.status
config
.statuscreating Makefile
configure
rm
-/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/.configured_*
touch /home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/.configured_yyyyyyyy
CFLAGS
="-Os -pipe -mno-branch-likely -mips32r2 -mtune=24kec -mdsp -fno-caller-saves -fhonour-copts -Wno-error=unused-but-set-variable -msoft-float -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -I/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/usr/include -I/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/include -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/usr/include -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/include/fortify -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/include  -I/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/usr/include -I/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/include -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/usr/include -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/include/fortify -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/include " CXXFLAGS="-Os -pipe -mno-branch-likely -mips32r2 -mtune=24kec -mdsp -fno-caller-saves -fhonour-copts -Wno-error=unused-but-set-variable -msoft-float -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -I/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/usr/include -I/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/include -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/usr/include -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/include/fortify -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/include  -I/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/usr/include -I/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/include -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/usr/include -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/include/fortify -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/include " LDFLAGS="-L/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/usr/lib -L/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/lib -L/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/usr/lib -L/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/lib -znow -zrelro " make -j1 -/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/src AR="mipsel-openwrt-linux-musl-gcc-ar" AS="mipsel-openwrt-linux-musl-gcc -c -Os -pipe -mno-branch-likely -mips32r2 -mtune=24kec -mdsp -fno-caller-saves -fhonour-copts -Wno-error=unused-but-set-variable -msoft-float -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -I/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/usr/include -I/home/lbest/wrt99/wrt/staging_dir/target-mipsel_24kec+dsp_musl-1.1.10/include -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/usr/include -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/include/fortify -I/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/include" LD=mipsel-openwrt-linux-musl-ld NM="mipsel-openwrt-linux-musl-gcc-nm" CC="mipsel-openwrt-linux-musl-gcc" GCC="mipsel-openwrt-linux-musl-gcc" CXX="mipsel-openwrt-linux-musl-g++" RANLIB="mipsel-openwrt-linux-musl-gcc-ranlib" STRIP=mipsel-openwrt-linux-musl-strip OBJCOPY=mipsel-openwrt-linux-musl-objcopy OBJDUMP=mipsel-openwrt-linux-musl-objdump SIZE=mipsel-openwrt-linux-musl-size CROSS="mipsel-openwrt-linux-musl-" ARCH="mipsel" ;
make[3]: Entering directory '/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/src'
(cd utils && make)
make[4]: Entering directory '/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/src/utils'
CC  base64.c
  CC  common
.c
  CC  ip_addr
.c
  CC  radiotap
.c
  CC  trace
.c
  CC  uuid
.c
  CC  wpa_debug
.c
  CC  wpabuf
.c
  CC  os_unix
.c
  CC  eloop
.c
mipsel
-openwrt-linux-musl-gcc-ar crT libutils.a base64.o common.o ip_addr.o radiotap.o trace.o uuid.o wpa_debug.o wpabuf.o os_unix.o eloop.o
make
[4]: Leaving directory '/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/src/utils'
(cd tls && make)
make[4]: Entering directory '/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/src/tls'
CC  asn1.c
In file included from bignum
.c:21:0:
libtommath.cIn function 'mp_exptmod':
libtommath.c:580:7warningvariable 'dr' set but not used [-Wunused-but-set-variable]
int dr;
CC  bignum.c
  CC  pkcs1
.c
  CC  pkcs5
.c
  CC  pkcs8
.c
  CC  rsa
.c
  CC  tlsv1_client
.c
  CC  tlsv1_client_read
.c
  CC  tlsv1_client_write
.c
  CC  tlsv1_common
.c
  CC  tlsv1_cred
.c
  CC  tlsv1_record
.c
  CC  tlsv1_server
.c
tlsv1_server_read
.cIn function 'tls_process_client_key_exchange_rsa':
tlsv1_server_read.c:474:6warningvariable 'encr_len' set but not used [-Wunused-but-set-variable]
u16 encr_len;
CC  tlsv1_server_read.c
  CC  tlsv1_server_write
.c
  CC  x509v3
.c
mipsel
-openwrt-linux-musl-gcc-ar crT libtls.a asn1.o bignum.o pkcs1.o pkcs5.o pkcs8.o rsa.o tlsv1_client.o tlsv1_client_read.o tlsv1_client_write.o tlsv1_common.o tlsv1_cred.o tlsv1_record.o tlsv1_server.o tlsv1_server_read.o tlsv1_server_write.o x509v3.o
make
[4]: Leaving directory '/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/src/tls'
(cd crypto && make)
make[4]: Entering directory '/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/src/crypto'
CC  aes-cbc.c
  CC  aes
-ctr.c
  CC  aes
-eax.c
  CC  aes
-encblock.c
  CC  aes
-internal.c
  CC  aes
-internal-dec.c
  CC  aes
-internal-enc.c
  CC  aes
-omac1.c
  CC  aes
-unwrap.c
  CC  aes
-wrap.c
  CC  des
-internal.c
  CC  dh_group5
.c
  CC  dh_groups
.c
  CC  md4
-internal.c
  CC  md5
.c
../utils/common.h:18:0,
from md5-internal.c:17:
md5-internal.cIn function 'MD5Final':
md5-internal.c:191:29warningargument to 'sizeof' in 'memset' call is the same expression as the destinationdid you mean to dereference it? [-Wsizeof-pointer-memaccess]
os_memset(ctx0sizeof(ctx)); /* In case it's sensitive */
utils/os.h:413:41notein definition of macro 'os_memset'
#define os_memset(s, c, n) memset(s, c, n)
CC  md5-internal.c
  CC  md5
-non-fips.c
  CC  milenage
.c
  CC  ms_funcs
.c
  CC  rc4
.c
  CC  sha1
.c
  CC  sha1
-internal.c
  CC  sha1
-pbkdf2.c
  CC  sha1
-tlsprf.c
  CC  sha1
-tprf.c
  CC  sha256
.c
  CC  sha256
-internal.c
  CC  crypto_internal
.c
  CC  crypto_internal
-cipher.c
  CC  crypto_internal
-modexp.c
  CC  crypto_internal
-rsa.c
  CC  tls_internal
.c
  CC  fips_prf_internal
.c
mipsel
-openwrt-linux-musl-gcc-ar crT libcrypto.a aes-cbc.o aes-ctr.o aes-eax.o aes-encblock.o aes-internal.o aes-internal-dec.o aes-internal-enc.o aes-omac1.o aes-unwrap.o aes-wrap.o des-internal.o dh_group5.o dh_groups.o md4-internal.o md5.o md5-internal.o md5-non-fips.o milenage.o ms_funcs.o rc4.o sha1.o sha1-internal.o sha1-pbkdf2.o sha1-tlsprf.o sha1-tprf.o sha256.o sha256-internal.o crypto_internal.o crypto_internal-cipher.o crypto_internal-modexp.o crypto_internal-rsa.o tls_internal.o fips_prf_internal.o
make
[4]: Leaving directory '/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/src/crypto'
(cd wps && make)
make[4]: Entering directory '/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/src/wps'
mipsel-openwrt-linux-musl-gcc -I../utils -../ wps_attr_build.-c
cc1
notesomeone does not honour COPTS correctlypassed 0 times
mipsel
-openwrt-linux-musl-gcc -I../utils -../ wps_attr_parse.-c
cc1
mipsel
-openwrt-linux-musl-gcc -I../utils -../ wps_attr_process.-c
cc1
mipsel
-openwrt-linux-musl-gcc -I../utils -../ wps.-c
cc1
mipsel
-openwrt-linux-musl-gcc -I../utils -../ wps_common.-c
cc1
mipsel
-openwrt-linux-musl-gcc -I../utils -../ wps_dev_attr.-c
cc1
mipsel
-openwrt-linux-musl-gcc -I../utils -../ wps_enrollee.-c
cc1
mipsel
-openwrt-linux-musl-gcc -I../utils -../ wps_registrar.-c
cc1
mipsel
-openwrt-linux-musl-gcc -I../utils -../ wps_ufd.-c
cc1
make
[4]: Leaving directory '/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/src/wps'
(cd lwe && make BUILD_STATIC=y libiw.a)
make[4]: Entering directory '/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/src/lwe'
cp wireless.21.h wireless.h
mipsel
-openwrt-linux-musl-gcc -Os --Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Winline -I. -MMD     -fPIC --o iwlib.so iwlib.c
cc1
rm
-f libiw.a
mipsel
-openwrt-linux-musl-gcc-ar cru libiw.a iwlib.so
/home/lbest/wrt99/wrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_musl-1.1.10/lib/gcc/mipsel-openwrt-linux-musl/4.8.3/../../../../mipsel-openwrt-linux-musl/bin/ar: `u' modifier ignored since `D' is the default (see `U')
mipsel-openwrt-linux-musl-gcc-ranlib libiw.a
make
[4]: Leaving directory '/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/src/lwe'
(cd libwps && make)
make[4]: Entering directory '/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/src/libwps'
mipsel-openwrt-linux-musl-gcc -Wall libwps.-c
cc1
In file included from libwps
.c:14:0:
libwps.h:50:1errorunknown type name 'u_char'
int parse_wps_parameters(const u_char *packetsize_t lenstruct libwps_data *wps);
libwps.h:129:1errorunknown type name 'u_char'
int parse_wps_tag(const u_char *tagssize_t lenstruct libwps_data *wps);
libwps.h:130:1errorunknown type name 'u_char'
unsigned char *get_wps_data(const u_char *datasize_t lensize_t *tag_len);
libwps.h:131:1errorunknown type name 'u_char'
unsigned char *get_wps_data_element(const u_char *datasize_t lenuint16_t typesize_t *el_len);
libwps.h:132:1errorunknown type name 'u_char'
int libwps_has_rt_header(const u_char *packetsize_t len);
libwps.h:133:1errorunknown type name 'u_char'
const u_char *libwps_radio_header(const u_char *packetsize_t len);
libwps.c:26:1errorunknown type name 'u_char'
libwps.cIn function 'parse_wps_parameters':
libwps.c:28:2errorunknown type name 'u_char'
const u_char *data NULL;
libwps.c:29:9warningvariable 'data_len' set but not used [-Wunused-but-set-variable]
size_t data_len 0offset 0;
libwps.cAt top level:
libwps.c:55:1errorunknown type name 'u_char'
libwps.cIn function 'parse_wps_tag':
libwps.c:89:4warningpassing argument 1 of 'get_wps_data_element' from incompatible pointer type [enabled by default]
el get_wps_data_element(wps_ie_datawps_data_lenelements[i], &el_len);
In file included from libwps.c:14:0:
libwps.h:131:16noteexpected 'const int *' but argument is of type 'unsigned char *'
libwps.c:190:1errorunknown type name 'u_char'
libwps.c:234:1errorunknown type name 'u_char'
libwps.c:269:1errorunknown type name 'u_char'
libwps.c:291:1errorunknown type name 'u_char'
libwps.cIn function 'libwps_radio_header':
libwps.c:299:25error'u_char' undeclared (first use in this function)
                 return (
u_char *) FAKE_RADIO_TAP_HEADER;
libwps.c:299:25noteeach undeclared identifier is reported only once for each function it appears in
libwps
.c:299:33errorexpected expression before ')' token
return (u_char *) FAKE_RADIO_TAP_HEADER;
libwps.c:302:1warningcontrol reaches end of non-void function [-Wreturn-type]
Makefile:5recipe for target 'libwps.o' failed
make
[4]: *** [libwps.oError 1
make
[4]: Leaving directory '/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/src/libwps'
Makefile:19recipe for target 'libwps.o' failed
make
[3]: *** [libwps.oError 2
make
[3]: Leaving directory '/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/src'
Makefile:53recipe for target '/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/.built' failed
make
[2]: *** [/home/lbest/wrt99/wrt/build_dir/target-mipsel_24kec+dsp_musl-1.1.10/reaver-r119/.builtError 2
make
package/Makefile:191recipe for target 'package/packages/net/reaver/compile' failed
make
[1]: *** [package/packages/net/reaver/compileError 2
make
/home/lbest/wrt99/wrt/include/toplevel.mk:181ошибка выполнения рецепта для цели «package/reaver/compile»
make
: *** [package/reaver/compileОшибка 2
root
lbest вне форума   Ответить с цитированием
Старый 23.07.2015, 01:30   #2
По умолчанию Re: Reaver не собирается
lbest, Когда на trunk компилил, похожее здесь было, там же, чуть пониже как решил
Да еще на trunk, если libpcap-1.5.3 - то reaver не будет работать. Компилить версию надо libpcap_1.6.2-1(из исходников) или какая там последняя
Последний раз редактировалось sakatgg; 23.07.2015 в 01:45.
Текущее время: 18:46. Часовой пояс GMT +3.
