Старый 30.03.2014, 10:58   #1
Siper
Siper is an unknown quantity at this point
По умолчанию Компиляция OpenWRT для HLK-RM04
Здравствуйте, пытаюсь скомпилировать последний trunk для HLK-RM04. Процесс компиляции останавливается на применении патча: 130-mips_remove_plat_dma_functions.patch. Помогите, уже весь гугл перелопатил. Лог прилогаю.
Applying /home/siper/openwrt/trunk/target/linux/generic/patches-3.10/130-mips_remove_plat_dma_functions.patch using plaintext:
patching file arch/mips/include/asm/mach-cavium-octeon/dma-coherence.h
patching file arch/mips/include/asm/mach-generic/dma-coherence.h
patching file arch/mips/include/asm/mach-ip27/dma-coherence.h
patching file arch/mips/include/asm/mach-ip32/dma-coherence.h
patching file arch/mips/include/asm/mach-jazz/dma-coherence.h
patching file arch/mips/include/asm/mach-loongson/dma-coherence.h
patching file arch/mips/include/asm/mach-powertv/dma-coherence.h
patching file arch/mips/mm/dma-default.c
Hunk #1 succeeded at 293 (offset 4 lines).
Hunk #2 succeeded at 326 (offset 4 lines).
Hunk #3 succeeded at 339 (offset 4 lines).
Applying /home/siper/openwrt/trunk/target/linux/generic/patches-3.10/130-mips_remove_plat_dma_functions.patch~ using plaintext:
Hunk #1 FAILED at 46.
1 out of 1 hunk FAILED -- saving rejects to file arch/mips/include/asm/mach-cavium-octeon/dma-coherence.h.rej
Hunk #1 FAILED at 47.
1 out of 1 hunk FAILED -- saving rejects to file arch/mips/include/asm/mach-generic/dma-coherence.h.rej
Hunk #1 FAILED at 58.
1 out of 1 hunk FAILED -- saving rejects to file arch/mips/include/asm/mach-ip27/dma-coherence.h.rej
Hunk #1 FAILED at 80.
1 out of 1 hunk FAILED -- saving rejects to file arch/mips/include/asm/mach-ip32/dma-coherence.h.rej
Hunk #1 FAILED at 48.
1 out of 1 hunk FAILED -- saving rejects to file arch/mips/include/asm/mach-jazz/dma-coherence.h.rej
Hunk #1 FAILED at 53.
1 out of 1 hunk FAILED -- saving rejects to file arch/mips/include/asm/mach-loongson/dma-coherence.h.rej
Hunk #1 FAILED at 99.
1 out of 1 hunk FAILED -- saving rejects to file arch/mips/include/asm/mach-powertv/dma-coherence.h.rej
Hunk #1 FAILED at 293.
Hunk #2 FAILED at 327.
Hunk #3 FAILED at 340.
3 out of 3 hunks FAILED -- saving rejects to file arch/mips/mm/dma-default.c.rej
Patch failed!  Please fix /home/siper/openwrt/trunk/target/linux/generic/patches-3.10/130-mips_remove_plat_dma_functions.patch~!
make[3]: *** [/home/siper/openwrt/trunk/build_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_uClibc-0.9.33.2/linux-3.10.34/.prepared] Error 1
make[3]: Leaving directory `/home/siper/openwrt/trunk/toolchain/kernel-headers'
make[2]: *** [toolchain/kernel-headers/prepare] Error 2
make[2]: Leaving directory `/home/siper/openwrt/trunk'
make[1]: *** [/home/siper/openwrt/trunk/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_uClibc-0.9.33.2/stamp/.toolchain_install] Error 2
make[1]: Leaving directory `/home/siper/openwrt/trunk'
make: *** [world] Ошибка 2
siper@siper-pc:~/openwrt/trunk$
Последний раз редактировалось Siper; 30.03.2014 в 11:49.
Siper вне форума   Ответить с цитированием
Старый 31.03.2014, 06:47   #2
По умолчанию Re: Компиляция OpenWRT для HLK-RM04
Что-то с версией ядра: https://dev.openwrt.org/ticket/15410
Старый 20.06.2014, 22:50   #3
Siper
Проблема была из-за применения сторонних патчей для данного модуля.
Старый 20.06.2014, 23:39   #4
Поделитесь прошивкой
Текущее время: 09:17. Часовой пояс GMT +3.
