Старый 14.11.2010, 00:35   #1
Вес репутации: 9821
По умолчанию Красивый звонок для ...
Проект переехал в тему "Воспроизведение Wav на Arduino"
Для проекта используем arduino
При нажатии на кнопку начнется воспроизведение звука , если кого заинтересует конвертер пишите скину.
#include <stdint.h>
#include <avr/interrupt.h>
#include <avr/io.h>
#include <avr/pgmspace.h>
#include "sounddata.h"
#define SAMPLE_RATE 16000
int ledPin 13;
int speakerPin 11;
volatile uint16_t sample;
byte lastSample;
// This is called at 16000 Hz to load the next sample.
ISR(TIMER1_COMPA_vect) {
    if (
sample >= sounddata_length) {
        if (
sample == sounddata_length lastSample) {
stopPlayback();
        else {
// Ramp down to zero to reduce the click at the end of playback.
OCR2A sounddata_length lastSample sample;
    else {
OCR2A pgm_read_byte(&sounddata_data[sample]);
sample;
void startPlayback()
pinMode(speakerPinOUTPUT);
// Set up Timer 2 to do pulse width modulation on the speaker
    // pin.
    // Use internal clock (datasheet p.160)
ASSR &= ~(_BV(EXCLK) | _BV(AS2));
// Set fast PWM mode  (p.157)
TCCR2A |= _BV(WGM21) | _BV(WGM20);
TCCR2B &= ~_BV(WGM22);
// Do non-inverting PWM on pin OC2A (p.155)
    // On the Arduino this is pin 11.
TCCR2A = (TCCR2A _BV(COM2A1)) & ~_BV(COM2A0);
TCCR2A &= ~(_BV(COM2B1) | _BV(COM2B0));
// No prescaler (p.158)
TCCR2B = (TCCR2B & ~(_BV(CS12) | _BV(CS11))) | _BV(CS10);
// Set initial pulse width to the first sample.
OCR2A pgm_read_byte(&sounddata_data[0]);
// Set up Timer 1 to send a sample every interrupt.
cli();
// Set CTC mode (Clear Timer on Compare Match) (p.133)
    // Have to set OCR1A *after*, otherwise it gets reset to 0!
TCCR1B = (TCCR1B & ~_BV(WGM13)) | _BV(WGM12);
TCCR1A TCCR1A & ~(_BV(WGM11) | _BV(WGM10));
// No prescaler (p.134)
TCCR1B = (TCCR1B & ~(_BV(CS12) | _BV(CS11))) | _BV(CS10);
// Set the compare register (OCR1A).
    // OCR1A is a 16-bit register, so we have to do this with
    // interrupts disabled to be safe.
OCR1A F_CPU SAMPLE_RATE;    // 16e6 / 8000 = 2000
    // Enable interrupt when TCNT1 == OCR1A (p.136)
TIMSK1 |= _BV(OCIE1A);
lastSample pgm_read_byte(&sounddata_data[sounddata_length-1]);
sample 0;
sei();
void stopPlayback()
// Disable playback per-sample interrupt.
TIMSK1 &= ~_BV(OCIE1A);
// Disable the per-sample timer completely.
TCCR1B &= ~_BV(CS10);
// Disable the PWM timer.
TCCR2B &= ~_BV(CS10);
digitalWrite(speakerPinLOW);
void setup()
pinMode(12INPUT);
digitalWrite(12HIGH);//подтягивающий резистор
pinMode(13OUTPUT);
pinMode(10OUTPUT);
void loop()
  if (
digitalRead(12)==LOW)
delay(30);
    if (
digitalWrite(10LOW);
digitalWrite(13HIGH);
startPlayback();
delay(2500);
startPlayback();
delay(2500);
pinMode(speakerPinINPUT);
digitalWrite(13LOW);
digitalWrite(10HIGH);
Тип файла: rar zvon.rar (29.0 Кб, 507 просмотров)
Старый 26.02.2012, 22:47   #2
ostapenko
ostapenko is on a distinguished road
Мне кажется очень интересная схема, а какой источник питания используется? Можно ли заказать детали через интернет или как то связаться с вами? Где узнать подробнее про конвертер? Может очень много вопросов , но я действительно очень рад что нашел ваш сайт, прямо глаза разбегаются!
ostapenko вне форума   Ответить с цитированием
Старый 26.02.2012, 23:23   #3
Вес репутации: 9821
Источник питания любой от 12 до 5в , можно использовать зарядку от мобильного телефона
Купить Arduino
Конвертер выложу
Текущее время: 02:44. Часовой пояс GMT +3.
