Старый 09.05.2014, 18:53   #11
amod-cccp
Аватар для amod-cccp
Вес репутации: 634
По умолчанию Re: CyberWrt модуль "Драйвер аудио"
Приветствую всех. Пришла usb звуковая карта. Установил модуль "Драйвер Аудио" и "Веб Радио".
Вставил в usb-hub:
Информация об аудио устройствах.
Advanced Linux Sound Architecture Driver Version k3.10.4.
card0
device
0
subdevice
0
stream
CAPTURE
id
USB Audio
name
USB Audio
subname
subdevice #0
class: 0
subclass
0
subdevices_count
1
subdevices_avail
1
snd_usb_audio          89653  0
snd_usbmidi_lib        14266  1 snd_usb_audio
snd_compress            5855  0
snd_pcm_oss            34177  0
snd_mixer_oss          12297  1 snd_pcm_oss
snd_pcm                56029  2 snd_usb_audio
,snd_pcm_oss
snd_timer              14334  1 snd_pcm
snd_rawmidi            14851  1 snd_usbmidi_lib
snd_seq_device          4285  1 snd_rawmidi
snd_hwdep               4334  1 snd_usb_audio
snd_page_alloc          4481  1 snd_pcm
snd                    41802 10 snd_usb_audio
,snd_usbmidi_lib,snd_compress,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_timer,snd_rawmidi,snd_seq_device,snd_hwdep
soundcore               3804  1 snd
usbcore               109317 13 uvcvideo
,usbhid,pl2303,ftdi_sio,cp210x,ch341,usbserial,snd_usb_audio,snd_usbmidi_lib,cdc_acm,usb_storage,ehci_platform,ehci_hcd
input_core             24281  6 uvcvideo
,usbhid,hid,evdev,snd
controlC0
pcmC0D0c
pcmC0D0p
timer
Sound Driver
:3.8.1a-980706 (ALSA emulation code)
KernelLinux CyberWrt 3.10.4 #1 Mon Nov 25 16:28:55 MSK 2013 mips
Config options0
Installed drivers
Type 10ALSA emulation
Card config
C-Media Electronics IncUSB PnP Sound Device at usb-ehci-platform-1.4full sp
Audio devices
0USB Audio (DUPLEX)
Synth devicesNOT ENABLED IN CONFIG
Midi devices
Timers
7system timer
Mixers
0USB Mixer
 0
[Device         ]: USB-Audio USB PnP Sound Device
                      C
G0
system timer 10000.000us (10000000 ticks)
P0-0-0PCM playback 0-0-SLAVE
P0
-0-1PCM capture 0-0-SLAVE
USB Mixer
usb_id=0x0d8c013cctrlif=0ctlerr=0
Card
  Unit
9
    Control
name="Speaker Playback Volume"index=0
    Info
id=9control=2cmask=0x3channels=2type="S16"
Volumemin=-7264max=-16dBmin=-2837dBmax=-6
  Unit
9
    Control
name="Speaker Playback Switch"index=0
    Info
id=9control=1cmask=0x0channels=1type="INV_BOOLEAN"
Volumemin=0max=1dBmin=0dBmax=0
  Unit
10
    Control
name="Auto Gain Control"index=0
    Info
id=10control=7cmask=0x0channels=1type="BOOLEAN"
  Unit
10
    Control
name="Mic Capture Volume"index=0
    Info
id=10control=2cmask=0x0channels=1type="S16"
Volumemin=0max=6096dBmin=0dBmax=2381
  Unit
10
    Control
name="Mic Capture Switch"index=0
    Info
id=10control=1cmask=0x0channels=1type="INV_BOOLEAN"
  Unit
13
    Control
name="Mic Playback Volume"index=0
    Info
id=13control=2cmask=0x0channels=1type="S16"
  Unit
13
    Control
name="Mic Playback Switch"index=0
    Info
id=13control=1cmask=0x0channels=1type="INV_BOOLEAN"
C
-Media Electronics IncUSB PnP Sound Device at usb-ehci-platform-1.4full sp USB Audio
Playback
StatusStop
Interface 1
    Altset 1
    Format
S16_LE
    Channels
2
    Endpoint
1 OUT (ADAPTIVE)
Rates4800044100
Capture
StatusStop
Interface 2
    Altset 1
    Format
S16_LE
    Channels
1
    Endpoint
2 IN (ADAPTIVE)
Rates4800044100
Вставил в гнездо наушники. И слышу писк, шум и прочее. Когда вкл. "Веб радио", то вообще затыки различного плана. Но понятно, что это музыка.
Под win7 работает как положено. Помогите разобраться.
root@CyberWrt:/# cat /proc/asound/cards
                      C
-Media Electronics IncUSB PnP Sound Device at usb-ehci-platform-1.2full sp
Какие модули использует звуковая карта.
root@CyberWrt:/# lsmod | grep snd
input_core             24281  5 usbhid,hid,evdev,snd,
snd                    41802 10 snd_usb_audio,snd_usbmidi_lib,snd_compress,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_timer,snd_rawmidi,snd_seq_device,snd_hwdep,
snd_compress            5855  0
snd_mixer_oss          12297  1 snd_pcm_oss,
snd_page_alloc          4481  1 snd_pcm,
snd_pcm                56029  2 snd_usb_audio,snd_pcm_oss,
snd_pcm_oss            34177  0
snd_seq_device          4285  1 snd_rawmidi,
snd_timer              14334  1 snd_pcm,
soundcore               3804  1 snd,
usbcore               109317 10 ohci_hcd,uhci_hcd,usbhid,usbserial,usblp,snd_usb_audio,snd_usbmidi_lib,usb_storage,ehci_platform,ehci_hcd
Последний раз редактировалось amod-cccp; 09.05.2014 в 20:44.
Старый 07.08.2014, 21:13   #12
gnom537
http://www.citilink.ru/catalog/compu...dcards/803513/
Эдуард, подскажите можно ли купить такую звуковую карту? будет работать? спасибо!
или же брать что попроще, например http://www.citilink.ru/catalog/compu...dcards/563144/
Старый 07.08.2014, 21:21   #13
П первой ссылке, без тестирования не определить , хотя что то подсказывает что там тот же самый чип, к тому же драйвер поддерживает большое количество звуковых карт
Тестировал USB головные телефоны и USB колонки, работали без проблем
Звуковая карта по второй ссылке, должна работать
P.S.
Еще есть звуковая с колонками подешевле
раз, два
Старый 25.10.2014, 06:29   #14
St@rz
Купил две звуковые карты в разных магазинах. Обе Creative SB Play. Маркировка одна, но внешне немного отличаются (пластмасса корпуса одной звуковой карты полупрозрачная). В итоге одна звуковая карта играет чуть слышно.
То же самое происходит в постах выше.
Выкладываю различия:
С хорошим звуком
Код HTML:
snd_usb_audio          89653  1
snd_compress            5855  0
snd_pcm_oss            34177  1
soundcore               3804  2 snd
usbcore               109317  4 snd_usb_audio,snd_usbmidi_lib,ehci_platform,ehci_hcd
input_core             24281  1 snd
Звук очень тихий
Код HTML:
snd_compress            5855  0
snd_pcm_oss            34177  0
Старый 25.10.2014, 11:20   #15
Что подключал на выход звуковой карты?
Наушники, динамик или усилитель?
Разбери з.к. проверь наличие конденсаторов на выходе
Старый 25.10.2014, 19:11   #16
Я подключал вот таую звуковую карту:
Creative "SoundBlaster Play!" USB Retail [SB1140], из наушников идёт звук с треском.
Прошивка АА 12.09
P.S. Хотя вот щас понял, что уровень звука не крутил... надо попробовать.
Последний раз редактировалось stD; 25.10.2014 в 19:28.
Старый 26.10.2014, 16:18   #17
St@rz
У меня точно на такой же очень тихий звук.
На аналогичной, но с черным непрозрачным корпусом все отлично играет.
Подключал к активным колонкам. Звук прибавлял на них. Если прибавлять программно то будут большие искажения.
Карты еще не разбирал. Завтра посмотрю внутренности.
Последний раз редактировалось St@rz; 26.10.2014 в 16:23.
Старый 26.10.2014, 18:07   #18
Можно пример?
Старый 26.10.2014, 23:14   #19
Моя вот так выглядит:
Старый 01.11.2014, 17:14   #20
St@rz
Разобрался, но не до конца.
Звуковая карта будет воспроизводит звук если будет присутствовать файл dsp в папке dev.
У меня он теперь всегда появляется. Только что сделал я не знаю.
Если файл удалить то звук тоже исчезнет.
Какой пакет отвечает за автоматическое создание файла dsp? Почему звуковая карта сразу не определяется? Может что то с питанием? Через хаб надо было?
Сейчас что то поправил, но не понял что. Много где копался.
Последний раз редактировалось St@rz; 01.11.2014 в 17:43.
Текущее время: 15:49. Часовой пояс GMT +3.
