Старый 07.06.2014, 13:54   #131
Andre
Andre is an unknown quantity at this point
По умолчанию Re: Кросс компиляция прошивки OpenWRT и пакетов на Ubuntu
Вот что было ранее на этой системе:
(C) 2000 General Software, Inc.
80486-4.3-6E65-400E486 Embedded BIOS (tm) Version 4.3
Copyright (C) 2000 General Software, Inc.
Copyright (C) 2001 CompuLab Ltd.  586CORE
|          System BIOS Configuration, (C) 2000 General Software, Inc.          |
| System CPU           : 80486          | Low Memory           : 637KB         |
| Coprocessor          : Enabled        | Extended Memory      : 63MB          |
| Floppy 0 Type        : Not installed  | Serial Ports 1-2     : 03F8 02F8     |
| Floppy 1 Type        : Not installed  | Serial Ports 3-4     :               |
| Ide 0 Type           : 2              | Parallel Ports       :               |
| Ide 1 Type           : 0              | ROM Shadowing        : Enabled       |
| BIOS Date (mm/dd/yy) : 03/16/05       | Manufacturing Mode   : 03F8 / 56K    |
To enter BIOS setup hit ^C on RESET.
Onboard peripheral devices :
NAND Flash .............. 64 MB
NOR Flash ............... AMD   2 MB
USB ..................... SL811
Ethernet Port 1 ......... 82559ER
VGA ..................... CT69000
CardBus Bridge (BASE) ... PCI1420
Ethernet Port 2 (BASE) .. 82559ER
SYSLINUX 2.07 2003-11-22  Copyright (C) 1994-2003 H. Peter Anvin
boot:
Loading vmlinuz.........................
Loading initrd.gz..............................................................................................................................
Ready.
Linux version 2.6.12 (root@DLINUX) (gcc version 3.3.5 (Debian 1:3.3.5-13)) #2 Wed Aug 9 08:54:48 MSD 2006
BIOS-provided physical RAM map:
 BIOS-e820: 0000000000000000 - 000000000009f400 (usable)
 BIOS-e820: 000000000009f400 - 00000000000a0000 (reserved)
 BIOS-e820: 00000000000ea000 - 0000000000100000 (reserved)
 BIOS-e820: 0000000000100000 - 0000000004000000 (usable)
 BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
64MB LOWMEM available.
DMI not present.
ACPI: Unable to locate RSDP
Allocating PCI resources starting at 04000000 (gap: 04000000:fbf00000)
Built 1 zonelists
Kernel command line: console=ttyS0,38400 rw rootfstype=minix ramdisk_size=24576 root=/dev/ram0 initrd=initrd.gz BOOT_IMAGE=vmlinuz
No local APIC present or hardware disabled
Initializing CPU#0
PID hash table entries: 512 (order: 9, 8192 bytes)
Using pit for high-res timesource
Console: colour dummy device 80x25
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 53164k/65536k available (2013k kernel code, 11904k reserved, 809k data, 180k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Mount-cache hash table entries: 512
CPU: AMD 486 DX/4-WB stepping 04
Checking 'hlt' instruction... OK.
checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Freeing initrd memory: 7887k freed
NET: Registered protocol family 16
PCI: PCI BIOS revision 2.10 entry at 0xefdee, last bus=1
PCI: Using configuration type 1
mtrr: v2.0 (20020519)
ACPI: Subsystem revision 20050309
ACPI: Interpreter disabled.
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI: disabled
PnPBIOS: Scanning system for PnP BIOS support...
PnPBIOS: PnP BIOS support was not detected.
PCI: Probing PCI hardware
PCI: Probing PCI hardware (bus 00)
scx200: NatSemi SCx200 Driver
devfs: 2004-01-31 Richard Gooch ([email protected])
devfs: boot_options: 0x1
Initializing Cryptographic API
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
PNP: No PS/2 controller found. Probing ports directly.
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
Serial: 8250/16550 driver $Revision: 1.90 $ 8 ports, IRQ sharing enabled
ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 24576K size 1024 blocksize
netconsole: not configured, aborting
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
hda: TRANSCEND DOM032M, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
hda: max request size: 128KiB
hda: 63488 sectors (32 MB) w/2KiB Cache, CHS=496/4/32
hda: cache flushes not supported
 /dev/ide/host0/bus0/target0/lun0: p1
mice: PS/2 mouse device common for all mice
NET: Registered protocol family 2
IP: routing cache hash table of 128 buckets, 4Kbytes
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 4, 114688 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
NET: Registered protocol family 17
BIOS EDD facility v0.16 2004-Jun-25, 1 devices found
RAMDISK: Compressed image found at block 0
VFS: Mounted root (minix filesystem).
Mounted devfs on /dev
Freeing unused kernel memory: 180k freed
init started:  BusyBox v1.1.3 (2006.06.30-22:02+0000) multi-call binary
loop: loaded (max 8 devices)
Real Time Clock Driver v1.12
CSLIP: code copyright 1989 Regents of the University of California
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
Linux video capture interface: v1.00
bttv: driver version 0.9.15 loaded
bttv: using 32 buffers with 204k (51 pages) each for capture
bttv: pci latency fixup [80]
8139too Fast Ethernet driver 0.9.27
e100: Intel(R) PRO/100 Network Driver, 3.4.8-k2-NAPI
e100: Copyright(c) 1999-2005 Intel Corporation
e100: eth0: e100_probe: addr 0xc0000000, irq 10, MAC addr 00:01:C0:01:5D:1D
e100: eth1: e100_probe: addr 0xc0040000, irq 11, MAC addr 00:01:C0:01:52:FD
ip_tables: (C) 2000-2002 Netfilter core team
ip_conntrack version 2.1 (512 buckets, 4096 max) - 272 bytes per conntrack
e100: eth1: e100_watchdog: link up, 100Mbps, full-duplex
Вот с моей версией:
GRUB loading, please wait...
[    0.000000] Linux version 3.3.8 (jean@worker) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #2 Sat Jun 7 13:19:22 MSK 2014
[    0.000000] BIOS-provided physical RAM map:
[    0.000000]  BIOS-e820: 0000000000000000 - 000000000009f400 (usable)
[    0.000000]  BIOS-e820: 000000000009f400 - 00000000000a0000 (reserved)
[    0.000000]  BIOS-e820: 00000000000ea000 - 0000000000100000 (reserved)
[    0.000000]  BIOS-e820: 0000000000100000 - 0000000004000000 (usable)
[    0.000000]  BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
[    0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[    0.000000] DMI not present or invalid.
[    0.000000] last_pfn = 0x4000 max_arch_pfn = 0x100000
[    0.000000] init_memory_mapping: 0000000000000000-0000000004000000
[    0.000000] ACPI Error: A valid RSDP was not found (20120111/tbxfroot-219)
[    0.000000] 64MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 04000000
[    0.000000]   low ram: 0 - 04000000
[    0.000000] Zone PFN ranges:
[    0.000000]   DMA      0x00000010 -> 0x00001000
[    0.000000]   Normal   0x00001000 -> 0x00004000
[    0.000000] Movable zone start PFN for each node
[    0.000000] Early memory PFN ranges
[    0.000000]     0: 0x00000010 -> 0x0000009f
[    0.000000]     0: 0x00000100 -> 0x00004000
[    0.000000] Using APIC driver default
[    0.000000] No local APIC present or hardware disabled
[    0.000000] APIC: disable apic facility
[    0.000000] APIC: switched to apic NOOP
[    0.000000] Allocating PCI resources starting at 4000000 (gap: 4000000:fbf00000)
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16143
[    0.000000] Kernel command line: block2mtd.block2mtd=/dev/sda2,65536,rootfs root=/dev/mtdblock0 rootfstype=squashfs rootwait console=tty0 console=ttyS0,38400n8 noinitrd reboot=bios
[    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Initializing CPU#0
[    0.000000] Memory: 59800k/65536k available (3164k kernel code, 5284k reserved, 897k data, 312k init, 0k highmem)
[    0.000000] virtual kernel memory layout:
[    0.000000]     fixmap  : 0xfffa2000 - 0xfffff000   ( 372 kB)
[    0.000000]     vmalloc : 0xc4800000 - 0xfffa0000   ( 951 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xc4000000   (  64 MB)
[    0.000000]       .init : 0xc13f8000 - 0xc1446000   ( 312 kB)
[    0.000000]       .data : 0xc1317164 - 0xc13f7900   ( 897 kB)
[    0.000000]       .text : 0xc1000000 - 0xc1317164   (3164 kB)
[    0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.000000] SLUB: Genslabs=15, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS:2304 nr_irqs:256 16
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty0] enabled
[    0.000000] console [ttyS0] enabled
[    0.020000] Calibrating delay loop... 65.53 BogoMIPS (lpj=327680)
[    0.110000] pid_max: default: 32768 minimum: 301
[    0.120000] Mount-cache hash table entries: 512
[    0.140000] CPU: AMD 486 DX/4-WB stepping 04
[    0.150000] Checking 'hlt' instruction... OK.
[    0.200000] Performance Events: no PMU driver, software events only.
[    0.230000] NET: Registered protocol family 16
[    0.260000] PCI: PCI BIOS revision 2.10 entry at 0xefdee, last bus=1
[    0.270000] PCI: Using configuration type 1 for base access
[    0.520000] bio: create slab <bio-0> at 0
[    0.540000] ACPI: Interpreter disabled.
[    0.560000] SCSI subsystem initialized
[    0.580000] usbcore: registered new interface driver usbfs
[    0.590000] usbcore: registered new interface driver hub
[    0.600000] usbcore: registered new device driver usb
[    0.610000] PCI: Probing PCI hardware
[    0.620000] PCI host bridge to bus 0000:00
[    0.630000] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    0.640000] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[    0.680000] Switching to clocksource pit
[    0.690000] pnp: PnP ACPI: disabled
[    0.852679] pci 0000:00:11.1: BAR 10: assigned [mem 0x04000000-0x07ffffff]
[    0.869928] pci 0000:00:11.1: BAR 9: assigned [mem 0x0c000000-0x0fffffff pref]
[    0.882239] pci 0000:00:11.1: BAR 8: assigned [io  0x1000-0x10ff]
[    0.891078] pci 0000:00:11.1: BAR 7: assigned [io  0x1400-0x14ff]
[    0.899911] pci 0000:00:11.0: BAR 10: assigned [mem 0x10000000-0x13ffffff]
[    0.911111] pci 0000:00:11.0: BAR 9: assigned [mem 0x14000000-0x17ffffff pref]
[    0.913393] pci 0000:00:11.0: BAR 8: assigned [io  0x1800-0x18ff]
[    0.932230] pci 0000:00:11.0: BAR 7: assigned [io  0x1c00-0x1cff]
[    0.941072] pci 0000:00:11.0: CardBus bridge to [bus 01-04]
[    0.948288] pci 0000:00:11.0:   bridge window [io  0x1c00-0x1cff]
[    0.957048] pci 0000:00:11.0:   bridge window [io  0x1800-0x18ff]
[    0.965823] pci 0000:00:11.0:   bridge window [mem 0x14000000-0x17ffffff pref]
[    0.978046] pci 0000:00:11.0:   bridge window [mem 0x10000000-0x13ffffff]
[    0.988918] pci 0000:00:11.1: CardBus bridge to [bus 05-08]
[    0.996125] pci 0000:00:11.1:   bridge window [io  0x1400-0x14ff]
[    1.004888] pci 0000:00:11.1:   bridge window [io  0x1000-0x10ff]
[    1.013659] pci 0000:00:11.1:   bridge window [mem 0x0c000000-0x0fffffff pref]
[    1.025874] pci 0000:00:11.1:   bridge window [mem 0x04000000-0x07ffffff]
[    1.036737] NET: Registered protocol family 2
[    1.042806] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    1.054852] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[    1.068798] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[    1.078601] TCP: Hash tables configured (established 2048 bind 2048)
[    1.088244] TCP reno registered
[    1.098038] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    1.106038] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    1.115412] NET: Registered protocol family 1
[    1.130716] pci 0000:00:12.0: Firmware left e100 interrupts enabled; disabling
[    1.133503] pci 0000:00:13.0: Firmware left e100 interrupts enabled; disabling
[    1.145966] platform rtc_cmos: registered platform RTC device (no PNP device found)
[    1.153087] scx200: NatSemi SCx200 Driver
[    1.167451] scx200: Configuration Block not found
[    1.402696] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.414236] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    1.423712] msgmni has been set to 116
[    1.433360] io scheduler noop registered
[    1.445834] io scheduler deadline registered (default)
[    1.472686] isapnp: Scanning for PnP cards...
[    1.842637] isapnp: No Plug & Play device found
[    1.857985] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[    1.882432] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    1.903529] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[    1.932697] Non-volatile memory driver v1.3
[    1.949950] Linux agpgart interface v0.103
[    1.952798] [drm] Initialized drm 1.1.0 20060810
[    1.971124] [drm:i915_init] *ERROR* drm/i915 can't work without intel_agp module!
[    2.002702] scsi0 : pata_legacy
[    2.022687] ata1: PATA max PIO4 cmd 0x1f0 ctl 0x3f6 irq 14
[    2.212660] ata1.00: ATA-0: TRANSCEND    032M, 1.1, max PIO2
[    2.230547] ata1.00: 63488 sectors, multi 0: LBA
[    2.235100] ata1.00: configured for PIO
[    2.247123] scsi 0:0:0:0: Direct-Access     ATA      TRANSCEND    032 1.1  PQ: 0 ANSI: 5
[    2.262703] sd 0:0:0:0: [sda] 63488 512-byte logical blocks: (32.5 MB/31.0 MiB)
[    2.278797] sd 0:0:0:0: [sda] Write Protect is off
[    2.286519] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    2.308530]  sda: sda1 sda2
[    2.319409] sda: p2 size 98721 extends beyond EOD, enabling native capacity
[    2.342818]  sda: sda1 sda2
[    2.354783] sda: p2 size 98721 extends beyond EOD, truncated
[    2.382752] sd 0:0:0:0: [sda] Attached SCSI disk
[    2.412692] scsi1 : pata_legacy
[    2.422706] ata2: PATA max PIO4 cmd 0x170 ctl 0x376 irq 15
[    2.612701] Creating 1 MTD partitions on "rootfs":
[    2.623331] 0x000000000000-0x000001a80000 : "rootfs"
[    2.642697] mtd: partition "rootfs" set to be root filesystem
[    2.662693] mtd: partition "rootfs_data" created automatically, ofs=1A0000, len=18E0000
[    2.677891] 0x0000001a0000-0x000001a80000 : "rootfs_data"
[    2.692708] block2mtd: mtd0: [rootfs] erase_size = 64KiB [65536]
[    2.703893] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.714039] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.725118] uhci_hcd: USB Universal Host Controller Interface driver
[    2.736592] Initializing USB Mass Storage driver...
[    2.743906] usbcore: registered new interface driver usb-storage
[    2.754505] USB Mass Storage support registered.
[    2.772704] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    2.790536] serio: i8042 KBD port at 0x60,0x64 irq 1
[    2.796745] serio: i8042 AUX port at 0x60,0x64 irq 12
[    2.812664] mousedev: PS/2 mouse device common for all mice
[    2.832730] rtc_cmos rtc_cmos: rtc core: registered rtc_cmos as rtc0
[    2.849517] rtc0: alarms up to one day, 114 bytes nvram
[    2.855857] cpuidle: using governor ladder
[    2.870334] cpuidle: using governor menu
[    2.882656] TCP cubic registered
[    2.896027] NET: Registered protocol family 17
[    2.909911] 8021q: 802.1Q VLAN Support v1.8
[    2.913504] Using IPI Shortcut mode
[    2.924946] rtc_cmos rtc_cmos: setting system clock to 2003-02-27 19:19:37 UTC (1046373577)
[    3.299404] VFS: Mounted root (squashfs filesystem) readonly on device 31:0.
[    3.303512] Freeing unused kernel memory: 312k freed
- preinit -
Press the [f] key and hit [enter] to enter failsafe mode
- regular preinit -
jffs2 not ready yet; using ramdisk
[   16.502906] EXT4-fs warning (device sda1): ext4_update_dynamic_rev:720: updating to rev 1 because of new feature flag, running e2fsck is recommended
[   16.522911] EXT4-fs (sda1): mounted filesystem without journal. Opts: (null)
- init -
Please press Enter to activate this console. [   20.182965] natsemi dp8381x driver, version 2.1, Sept 11, 2006
[   20.182965]   originally by Donald Becker <[email protected]>
[   20.182965]   2.4.x kernel port by Jeff Garzik, Tjeerd Mulder
[   21.082984] PPP generic driver version 2.4.2
[   23.813016] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[   23.829572] e1000: Copyright (c) 1999-2006 Intel Corporation.
[   25.263051] ip_tables: (C) 2000-2006 Netfilter Core Team
[   25.843055] NET: Registered protocol family 24
[   25.923067] nf_conntrack version 0.5.0 (939 buckets, 3756 max)
[   27.333086] 8139too: 8139too Fast Ethernet driver 0.9.28
[   27.413083] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[   27.424198] e100: Copyright(c) 1999-2006 Intel Corporation
[   27.473082] e100 0000:00:12.0: eth0: addr 0xc0000000, irq 10, MAC addr 00:01:c0:01:5d:1d
[   27.513024] e100 0000:00:13.0: eth1: addr 0xc0040000, irq 11, MAC addr 00:01:c0:01:52:fd
[   27.583079] scx200_gpio: no SCx200 gpio present
[   28.333090] ne2k-pci.c:v1.03 9/22/2003 D. Becker/P. Gortmaker
[   29.013100] pcnet32: pcnet32.c:v1.35 21.Apr.2008 [email protected]
[   29.153106] sis900.c: v1.08.10 Apr. 2 2006
[   29.913116] via_rhine: v1.10-LK1.5.0 2010-10-09 Written by Donald Becker
[   30.773138] usbcore: registered new interface driver snd-usb-audio
[   52.133462] device eth0 entered promiscuous mode
[   66.053660] jffs2_scan_eraseblock(): End of filesystem marker found at 0x0
[   66.083671] jffs2_build_filesystem(): unlocking the mtd device... done.
[   66.104711] jffs2_build_filesystem(): erasing all blocks after the end marker... done.
[  133.886433] JFFS2 notice: (1017) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
BusyBox v1.19.4 (2014-06-07 12:15:13 MSK) built-in shell (ash)
 ATTITUDE ADJUSTMENT (Attitude Adjustment, r41027)
  * 1/4 oz Vodka      Pour all ingredients into mixing
  * 1/4 oz Gin        tin with ice, strain into glass.
  * 1/4 oz Amaretto
  * 1/4 oz Triple sec
  * 1/4 oz Peach schnapps
  * 1/4 oz Sour mix
  * 1 splash Cranberry juice
root@OpenWrt:/# ls /dev
console    ppp        tty10      tty24      tty38      tty51      tty8
full       psaux      tty11      tty25      tty39      tty52      tty9
input      ptmx       tty12      tty26      tty4       tty53      ttyS0
kmsg       pts        tty13      tty27      tty40      tty54      ttyS1
log        random     tty14      tty28      tty41      tty55      urandom
mem        root       tty15      tty29      tty42      tty56      vcs
mtd0       rtc0       tty16      tty3       tty43      tty57      vcs1
mtd0ro     sda        tty17      tty30      tty44      tty58      vcsa
mtd1       sda1       tty18      tty31      tty45      tty59      vcsa1
mtd1ro     sda2       tty19      tty32      tty46      tty6       zero
mtdblock0  shm        tty2       tty33      tty47      tty60
mtdblock1  snd        tty20      tty34      tty48      tty61
null       tty        tty21      tty35      tty49      tty62
nvram      tty0       tty22      tty36      tty5       tty63
port       tty1       tty23      tty37      tty50      tty7
Смущает это:
и это
Повторюсь - проблема в том что в системе отсутствует USB.
Последний раз редактировалось Andre; 07.06.2014 в 14:23.
Andre вне форума   Ответить с цитированием
Старый 01.07.2014, 18:25   #132
rv3bj
rv3bj is an unknown quantity at this point
Удалось пройти весь процесс компиляции прошивки OpenWRT, используя Debian запущенный из под Windows 7 на виртуальной машине от Oracle.
Пришлось сделать одно изменение в строке:
"apt-get install subversion build-essential libncurses5-dev zlib1g-dev gawk flex quilt git-core mkisofs".
Вместо mkisofs надо вводить имя другого файла genisoimage.
Далее все прошло нормально.
Также пробую скомпилировать прошивку, используя Ubuntu. Пока не получается. Ubuntu также установлена на виртуальной машине. Правда процесс установки самой Ubuntu не такой простой как Debian. В Ubuntu необходимо принудительно делать обновление ядра гостевой машины. В противном случае есть проблемы с разрешением экрана.
Ниже ссылка, по которой описывается процесс адаптации Гостевой Ubuntu.
http://aboutubuntu.ru/content/nastro...windows-khoste
Последний раз редактировалось rv3bj; 01.07.2014 в 18:58. Причина: Дополнение
rv3bj вне форума   Ответить с цитированием
Старый 01.07.2014, 18:57   #133
Сколько времени занял процесс компиляции в VM?
Старый 01.07.2014, 21:38   #134
rv3bj
Я специально не замерял, но где-то часа полтора. Интересно, что я все это делал на Debian 64 бита. Сегодня поставил Debian 32 и пока не смог откомпилировать. Получил ошибку, что недоступен сайт svn.nomi.cz.
Пробовал пинговать этот сайт - получается. Хотя имя его распознается и появляется его IP адрес. Сеть работает. Сайт www.mail.ru пингуется.
Сейчас хочу сохранить в архиве результат успешной компиляции и стартовать make clean на Debian 64.
Старый 01.07.2014, 22:15   #135
rv3bj
Так вот докладываю результат компиляции на VM.
Ноутбук Toshiba Portege R835 (не самый новый). Процессор i5-2410M [email protected]. Windows 64 bit.
Виртуальная машина: Debian 64 bit, memory 1920 байт, два CPU.
Время ПОЛНОЙ (предварительно выполнена команда make clean) компиляции 16 минут. Перед компиляцией также была удалена директория BIN. Компиляция выполнялась командой
make -j3.
Так что вполне хороший результат.
Старый 01.07.2014, 22:27   #136
Хороший результат
Старый 07.07.2014, 15:07   #137
Executer4732
Executer4732 is an unknown quantity at this point
Кто подскажет где посмотреть пример компилирования под C++. Под дебиан скрипт компилируется а под Openwrt нет.
Executer4732 вне форума   Ответить с цитированием
Старый 24.07.2014, 01:54   #138
CrazyPit
CrazyPit is an unknown quantity at this point
Пример компиляции через vmware
какая то там хрень.. а не пример.. а по инструкции делаю на виртуалке вроде работает.(сейчас компилирует)
если кому интересно могу сделать инструкцию.
CrazyPit вне форума   Ответить с цитированием
Старый 24.07.2014, 09:56   #139
Если не затруднит, хотел бы попробовать
Старый 24.07.2014, 20:01   #140
У меня ноутбук Lenovo u-310 на не так все просто с UEFI
Прошивку пачить я не хочу так как он еще на гарантии
Поэтому для меня VM это выход
Текущее время: 16:43. Часовой пояс GMT +3.
