Старый 18.01.2015, 16:49   #101
elik745i
По умолчанию Re: Модуль "CyberBot-2"
Вот что получилось:
скетч:
Sketch based on Cyberlib library from
cyber-place.ru, however due to some hangups
desition were taken to get rid of this library
and use arduino standard libraries
and Adafrruit libraries. LCD module used
just for debuging and is optional, however
many useful information can be hooked to it.
Wiring:
1.8''LCD is just insertewd to MEGA pins 8 -> AREF
2 servos (yaw and pitch) hooked to digital pins 2
and 3 (configurable, just like LCD pins)
Servos powered by 5 volt regulator from external
power supply (this is important not to fry arduino
or your modem)
For video demonstration please visit my youtube:
http://youtu.be/HcA-f-SeI6g
Any references/updates please visit my blog:
www.voltrans.az
//#include <CyberLib.h>  // Подключаем библиотеку
#include <Servo.h> // Подключаем библиотеку сервоприводов
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include <SPI.h>
Servo myservo1;
Servo myservo2;
//long previousMillis; // Нужно для таймера
//uint8_t LedStep = 0; // Счетчик
int val1 0;
int val2 0;
//int servoSpeed = 20;
int servoAngle 20;
int minAngle 0;
int maxAngle 180;
//int i;
int q=2;
int w=114;
boolean light_stat
uint8_t inByte;
uint8_t speed=255//максимальная скорость по умолчанию
//#define init {D4_Out; D5_Out; D6_Out; D7_Out; D8_Out; D11_Out; D12_Out;}
#define TFT_CS     13
#define TFT_RST    12  // you can also connect this to the Arduino reset
                      // in which case, set this #define pin to 0!
#define TFT_DC     11
#define TFT_SCLK 9   // set these to be whatever pins you like!
#define TFT_MOSI 10   // set these to be whatever pins you like!
Adafruit_ST7735 tft Adafruit_ST7735(TFT_CSTFT_DCTFT_MOSITFT_SCLKTFT_RST);
const
int ledPin =  8
const
int irlight 46;
const
int blastLed 47;
int backlit 100;     //backlit
noTone(49);
pinMode(ledPinOUTPUT);
pinMode(irlightOUTPUT);
pinMode(blastLedOUTPUT);
analogWrite(ledPinbacklit);
tft.initR(INITR_BLACKTAB);   // ST7735-Chip initialisieren
tft.fillScreen(ST7735_BLACK);
tft.drawRoundRect(0,0,128,160,6,ST7735_WHITE);
tft.drawRect(0,100,128,12,ST7735_WHITE);
tft.drawTriangle(64543358635ST7735_WHITE);
tft.drawTriangle(649543658665ST7735_WHITE);
tft.drawTriangle(55040354065ST7735_WHITE);
tft.drawTriangle(1235089358965ST7735_WHITE);
tft.setTextColor(ST7735_WHITE);
tft.setCursor(4642);
tft.print("WEBCAM");
tft.setCursor(4652);
tft.print("CONTROL");
tft.setCursor(10102);
tft.setTextWrap(true);
tft.print("Serial Monitor:");
myservo1.attach(24); // Подключение сервоприводов к порту
myservo2.attach(26); // Подключение сервоприводов к порту
myservo1.write(val1);
myservo2.write(val2);
delay(500);
myservo1.detach();
myservo2.detach();
init;  // Инициализация портов
horn(); //звуковое оповещение готовности робота
Serial.begin(57600);// Инициализация порта для связи с роутером
  //wdt_enable (WDTO_500MS);
tft.setCursor(7290);
tft.setTextColor(ST7735_RED);
tft.print("BLAST OFF");
tft.setCursor(890);
tft.print("IR OFF");
    unsigned long currentMillis = millis(); // Обновление таймера
      if (LedStep == 0 && currentMillis - previousMillis > 500){ // Задержка 0,5 сек.
      previousMillis = currentMillis; // обновление таймер
      LedStep = 1; // Счетчик шагов
    if (LedStep == 1 && currentMillis - previousMillis > 500){ // Задержка 0,5 сек.
      LedStep = 2; // Счетчик шагов
    if (LedStep == 2 && currentMillis - previousMillis > 500){ // Задержка 0,5 сек.
      LedStep = 0; // Счетчик шагов
if (Serial.available()) //Еесли что то пришло
byte inByte Serial.read();
tft.setCursor(qw);
tft.print(inByte);
tft.print(", ");
q=q+24;
    if(
q>=120){
w=w+10;
q=2;
    if(
w>=150){
tft.fillRect(1,111,126,46,ST7735_BLACK);
q=2;
w=114;
    switch (
inByte)  // Смотрим какая команда пришла
       case
'U'// Серво поднимается
if(val1<maxAngle){
up();
myservo1.attach(24);               // attaches the servo on pin 2
for(int i=0;i<servoAngle;i++){
myservo1.write(val1+i);           // sets the servo position according to the scaled value
delay(servoAngle);
val1=val1+servoAngle;
myservo1.detach();                // detaches the servo on pin 2
//up();
         // myservo1.write(i -= 10);
break;
        case
'J'// Серво опускается
if(val1>minAngle){
dn();
myservo1.write(val1-i);           // sets the servo position according to the scaled value
delay(servoAngle);
val1=val1-servoAngle;
//dn();
          //myservo1.write(i += 10);
break;
        case
'H'// Серво поворачивается влево
if(val2<maxAngle){
lt();
myservo2.attach(26);               // attaches the servo on pin 2
myservo2.write(val2+i);           // sets the servo position according to the scaled value
delay(servoAngle);
val2=val2+servoAngle;
myservo2.detach();                // detaches the servo on pin 2
//lt();
          //myservo2.write(i += 10);
break;
        case
'K'// Серво поворачивается вправо
if(val2>minAngle){
rt();
myservo2.write(val2-i);           // sets the servo position according to the scaled value
delay(servoAngle);
val2=val2-servoAngle;
//rt();
          //myservo2.write(i -= 10);
break;
         case
'B'//  Бластер
if(light_stat
digitalWrite(blastLedLOW);
bIRoff();
light_stat=false
        } else
digitalWrite(blastLedHIGH);
bIRon();
light_stat=true
        break;
        case
'C'// Клаксон
horn();
        break;
        case
'V'// Включить/Выключить фары
if(light_stat
digitalWrite(irlightLOW);
IRoff();
light_stat=false
        } else
digitalWrite(irlightHIGH);
IRon();
light_stat=true
        break;
     if(
inByte>47 && inByte<58speed=(inByte-47)*25+5;//принимает команду и преобразуем в скорость
// wdt_reset();
void up(){
tft.fillTriangle(64644348534ST7735_GREEN);
tft.fillTriangle(64644348534ST7735_BLACK);
void dn(){
tft.fillTriangle(649246678367ST7735_GREEN);
tft.fillTriangle(649246678367ST7735_BLACK);
void lt(void){
tft.fillTriangle(65039363964ST7735_GREEN);
tft.fillTriangle(65039363964ST7735_BLACK);
void rt(void){
tft.fillTriangle(1225090369064ST7735_GREEN);
tft.fillTriangle(1225090369064ST7735_BLACK);
void horn()
noTone(49);
tone(49440150);
delay(250);
tone(49440700);
void bIRon(){
tft.setTextColor(ST7735_BLACK);
tft.setTextColor(ST7735_GREEN);
tft.print("BLAST ON");
void bIRoff(){
void IRon(){
tft.setCursor(890);
tft.setCursor(890);
tft.print("IR ON");
void IRoff(){
tft.setCursor(890);
tft.print("IR ON");
tft.setCursor(890);
видео в работе:
Единственное, кто нить может подсказать как подключить ардуино pro mini минуя USB порт, что то читал через RX TX, но без подробностей, если кто знает опишите...если получится подключить минуя USB порт, то я могу его использовать для камеры минуя хаб (нет у нас тут полноценного хаба на усб 2, все, что нашел только усб 1.0 (остальное китайское все равно усб 1.1, хотя любят наврать что усб 2.0)
и тогда все запляшет на полном разрешении, без артефактов....
Старый 18.01.2015, 18:43   #102
Подключаете Arduino mini к RX и TX роутера и устанавливаете модуль "Free UART"
Старый 18.01.2015, 19:07   #103
elik745i
а где в роутере RХ и ТХ?
Старый 18.01.2015, 19:23   #104
Здесь
Старый 19.01.2015, 22:14   #105
elik745i
Ура, сделал, припаивался очень осторожно, там буквально контакты точечьки с размером с волосик, далее, как припаялся сразу залил жидким паяльным клеем, что бы не дай бог не оторвалось с текстолита.....Самое главное работает на полном разрешении!
Старый 24.01.2015, 11:44   #106
soviet
Возникла проблема, через 20 сек работы зависает картинка, после обновления станицы, команды не выполняются. В чем беда?
Старый 24.01.2015, 18:13   #107
uni
Аватар для uni
Admin, можешь приложить полный список деталек для сборки нового робота? Мне нужно спецификацию подготовить для покупки двух-трёх наборов таких роботов, чтобы школьникам показать (покупать на duino.ru ).
Ищу-ищу, не могу найти в разбросанных сообщениях что-же заказывать. Мне нужно сделать робота с использованием TL-MR3020 и вебкамерой C270. Магнитные датчики и пр. акселерометры пока не нужны, но ультразвуковой можно оставить. Непонятно с оптическим датчиком вращения колёс, он в комплекте или как? Если в комплекте, то с чем?
В общем, получил такой список:
- набор-конструктор робота;
- драйвер электродвигателя;
- ультразвуковой дальномер;
- сервопривод SG90;
- Arduino Nano 7;
- плата контроллера робота;
- батарейный отсек;
- аккумуляторы (4 шт);
- роутер TL-MR3020;
- web-камера Logitech C270;
- беспроводное зарядное устройство;
Что я забыл для полного счастья? К плате детальки идут в комплекте или их докупать надо?
Много ли времени занимает сборка, если детали робота уже подготовлены (распаяны)?
Россия навсегда!
Старый 27.01.2015, 11:57   #108
Постараюсь сегодня написать
Деталей нет в комплекте
Если плата распаяна то 10-20 мин.
Старый 28.01.2015, 07:24   #109
Under
Under is an unknown quantity at this point
Подскажите, где можно заказать фары для робота? А то функция в модуле есть, грех не пользоваться, но самому выдергивать LED-части из фонариков и колхозить особо не хочется. Я таскаю детали для робота с ТаоБао (живу во Владивостоке, поэтому оттуда удобнее и дешевле), и вот заметил шикарные фонари на одном из роботов, но отдельно их нагуглить не смог. Может кто поделится ссылками/идеями?
Under вне форума   Ответить с цитированием
Старый 03.02.2015, 11:46   #110
soviet
Кто нибудь пробовал: Роутер принимает в виде команд символы и цифры?
Текущее время: 12:59. Часовой пояс GMT +3.
