Старый 05.03.2017, 14:47   #21
WideAreaNetwork
WideAreaNetwork is an unknown quantity at this point
По умолчанию Re: OpenWrt проблема с WAN-портом
а вот при переходе на DHCP
Updating your configuration...
Committing network ...
Committing webif ...
Waiting for the commit to finish...
Reloading network ...
udhcpc (v1.11.2) started
Sending discover...
Sending select for 10.168.0.135...
Lease of 10.168.0.135 obtained, lease time 3600
udhcpc: ifconfig eth0.2 10.168.0.135 netmask 255.255.255.0 broadcast +
udhcpc: setting default routers: 10.168.0.2
udhcpc: setting dns servers: 10.168.0.2
Applying Installing language pack ...
0.openwrt.pool.ntp.org: Unknown host
1.openwrt.pool.ntp.org: Unknown host
wget: bad address 'downloads.x-wrt.org'
Downloading http://downloads.x-wrt.org/xwrt/kami...3-4754_all.ipk
Collected errors:
* opkg_download: ERROR: Command failed with return value 1: `wget --passive-ftp -P /tmp/opkg-b8dedX http://downloads.x-wrt.org/xwrt/kami...3-4754_all.ipk'
Error installing language pack!
Done
Initializing theme ...
Done
WideAreaNetwork вне форума   Ответить с цитированием
Старый 05.03.2017, 15:52   #22
WideAreaNetwork
возможно еще это поможет
Jan  1 00:00:15 OpenWrt syslog.info syslogd started: BusyBox v1.11.2
Jan  1 00:00:15 OpenWrt user.notice kernel: klogd started: BusyBox v1.11.2 (2009-08-26 16:24:10 EEST)
Jan  1 00:00:20 kernel: switch_robo: Unknown symbol nvram_get
Jan  1 00:00:20 kernel: switch-ip175c: Found a IP175C chip at ar2313_eth_mii, id 0
Jan  1 00:00:20 kernel: switch-ip175c: Found IP175C switch at bus id 0:00 (PHY 0)
Jan  1 00:00:20 kernel: switch-ip175c: Found IP175C switch at bus id 0:01 (PHY 1)
Jan  1 00:00:20 kernel: switch-ip175c: Found IP175C switch at bus id 0:02 (PHY 2)
Jan  1 00:00:20 kernel: switch-ip175c: Found IP175C switch at bus id 0:03 (PHY 3)
Jan  1 00:00:20 kernel: switch-ip175c: Found IP175C switch at bus id 0:04 (PHY 4)
Jan  1 00:00:21 kernel: device eth0.1 entered promiscuous mode
Jan  1 00:00:21 kernel: device eth0 entered promiscuous mode
Jan  1 00:00:21 kernel: br-lan: port 1(eth0.1) entering learning state
Jan  1 00:00:21 kernel: br-lan: topology change detected, propagating
Jan  1 00:00:21 kernel: br-lan: port 1(eth0.1) entering forwarding state
Jan  1 00:00:22 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Jan  1 00:00:25 kernel: nf_conntrack version 0.5.0 (1024 buckets, 4096 max)
Jan  1 00:00:29 kernel: IPP2P v0.8.1_rc1 loading
Jan  1 00:00:30 kernel: IMQ driver loaded successfully.
Jan  1 00:00:30 kernel: 	Hooking IMQ before NAT on PREROUTING.
Jan  1 00:00:30 kernel: 	Hooking IMQ after NAT on POSTROUTING.
Jan  1 00:00:36 kernel: wlan: trunk
Jan  1 00:00:38 kernel: ath_hal: module license 'Proprietary' taints kernel.
Jan  1 00:00:38 kernel: ath_hal: 2009-05-08 (AR5212, AR5312, RF5111, RF5112, RF2316, RF2317, REGOPS_FUNC, TX_DESC_SWAP, XR)
Jan  1 00:00:38 kernel: ath_rate_minstrel: Minstrel automatic rate control algorithm 1.2 (trunk)
Jan  1 00:00:38 kernel: ath_rate_minstrel: look around rate set to 10%
Jan  1 00:00:38 kernel: ath_rate_minstrel: EWMA rolloff level set to 75%
Jan  1 00:00:38 kernel: ath_rate_minstrel: max segment size in the mrr set to 6000 us
Jan  1 00:00:38 kernel: wlan: mac acl policy registered
Jan  1 00:00:40 kernel: ath_ahb: trunk
Jan  1 00:00:40 kernel: Atheros HAL provided by OpenWrt, DD-WRT and MakSat Technologies
Jan  1 00:00:40 kernel: wifi0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbps
Jan  1 00:00:40 kernel: wifi0: 11g rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
Jan  1 00:00:40 kernel: wifi0: turboG rates: 6Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
Jan  1 00:00:40 kernel: wifi0: H/W encryption support: WEP AES AES_CCM TKIP
Jan  1 00:00:40 kernel: ath_ahb: wifi0: Atheros 2317 WiSoC REV1: mem=0xb0000000, irq=3
Jan  1 02:00:45 kernel: device ath0 entered promiscuous mode
Jan  1 02:00:45 kernel: br-lan: port 2(ath0) entering learning state
Jan  1 02:00:45 kernel: br-lan: topology change detected, propagating
Jan  1 02:00:45 kernel: br-lan: port 2(ath0) entering forwarding state
Jan  1 02:00:45 OpenWrt cron.err crond[926]: crond (busybox 1.11.2) started, log level 5
Jan  1 02:00:46 OpenWrt authpriv.info dropbear[931]: Running in background
Jan  1 02:00:51 OpenWrt daemon.info dnsmasq[1008]: started, version 2.47 cachesize 150
Jan  1 02:00:51 OpenWrt daemon.info dnsmasq[1008]: compile time options: IPv6 GNU-getopt no-DBus no-I18N TFTP
Jan  1 02:00:51 OpenWrt daemon.info dnsmasq[1008]: using local addresses only for domain lan
Jan  1 02:00:51 OpenWrt daemon.info dnsmasq[1008]: reading /tmp/resolv.conf.auto
Jan  1 02:00:51 OpenWrt daemon.info dnsmasq[1008]: using nameserver 10.168.0.2#53
Jan  1 02:00:51 OpenWrt daemon.info dnsmasq[1008]: read /etc/hosts - 1 addresses
Jan  1 02:00:52 OpenWrt user.info sysinit: setconsole: TIOCCONS: Inappropriate ioctl for device
Jan  1 02:03:01 OpenWrt cron.err crond[926]: USER root pid 1472 cmd rdate time-b.nist.gov
Текущее время: 06:37. Часовой пояс GMT +3.
