16.03.2018, 08:40 | #831 |
Вес репутации: 9821 |
В шапке темы скетч лежит
Добавьте dimmer1=data |
16.03.2018, 17:01 | #832 |
Вес репутации: 0 |
16.03.2018, 18:16 | #833 | |
Вес репутации: 0 |
После проверки СКЕТЧА из шапки выдает вот такие ошибки.C:\Users\Владимир\Documents\Arduino\libraries\CyberLib-master\CyberLib.cpp: In function 'void WriteEEPROM_Byte(uint8_t, uint8_t)':
C:\Users\Владимир\Documents\Arduino\libraries\CyberLib-master\CyberLib.cpp:186:31: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] eeprom_write_byte((uint8_t*)addr, data); ^ C:\Users\Владимир\Documents\Arduino\libraries\CyberLib-master\CyberLib.cpp: In function 'void WriteEEPROM_Long(uint8_t, uint32_t)': C:\Users\Владимир\Documents\Arduino\libraries\CyberLib-master\CyberLib.cpp:197:37: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] eeprom_write_byte((uint8_t*)addr, data & 0xFF); ^ C:\Users\Владимир\Documents\Arduino\libraries\CyberLib-master\CyberLib.cpp:198:37: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] eeprom_write_byte((uint8_t*)addr+1, (data & 0xFF00) >> 8); ^ C:\Users\Владимир\Documents\Arduino\libraries\CyberLib-master\CyberLib.cpp:199:37: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] eeprom_write_byte((uint8_t*)addr+2, (data & 0xFF0000) >> 16); ^ C:\Users\Владимир\Documents\Arduino\libraries\CyberLib-master\CyberLib.cpp:200:37: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] eeprom_write_byte((uint8_t*)addr+3, (data & 0xFF000000) >> 24); ^ C:\Users\Владимир\Documents\Arduino\libraries\CyberLib-master\CyberLib.cpp: In function 'uint8_t ReadEEPROM_Byte(uint8_t)': C:\Users\Владимир\Documents\Arduino\libraries\CyberLib-master\CyberLib.cpp:209:37: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] return eeprom_read_byte((uint8_t*)addr); ^ C:\Users\Владимир\Documents\Arduino\libraries\CyberLib-master\CyberLib.cpp: In function 'uint32_t ReadEEPROM_Long(uint8_t)': C:\Users\Владимир\Documents\Arduino\libraries\CyberLib-master\CyberLib.cpp:220:55: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] uint32_t ir_code = eeprom_read_byte((uint8_t*)addr+3); ^ C:\Users\Владимир\Documents\Arduino\libraries\CyberLib-master\CyberLib.cpp:221:63: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] ir_code = (ir_code << 8) | eeprom_read_byte((uint8_t*)addr+2); ^ C:\Users\Владимир\Documents\Arduino\libraries\CyberLib-master\CyberLib.cpp:222:63: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] ir_code = (ir_code << 8) | eeprom_read_byte((uint8_t*)addr+1); ^ C:\Users\Владимир\Documents\Arduino\libraries\CyberLib-master\CyberLib.cpp:223:63: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] ir_code = (ir_code << 8) | eeprom_read_byte((uint8_t*)addr); ^ Скетч использует 958 байт (3%) памяти устройства. Всего доступно 30720 байт. Глобальные переменные используют 20 байт (0%) динамической памяти, оставляя 2028 байт для локальных переменных. Максимум: 2048 байт. [свернуть] |
16.03.2018, 18:17 | #834 |
Вес репутации: 0 |
Подскажите, направьте на ПУТЬ истенный!
16.03.2018, 19:32 | #835 |
Здесь готовый скетч для диммера работающего по serial http://cyber-place.ru/showpost.php?p=3925&postcount=24
17.03.2018, 06:31 | #836 | |
Вес репутации: 0 |
exit status 1 Ошибка компиляции для платы Arduino Nano. |
17.03.2018, 08:56 | #837 |
Проверенный рабочий код: http://cyber-place.ru/showthread.php?t=1068
21.03.2018, 14:49 | #838 |
Вес репутации: 0 |
Опять выдает это сообщение
21.03.2018, 14:51 | #839 |
А библиотека CyberLib установлена?
22.03.2018, 07:18 | #840 |
Вес репутации: 0 |
Да, установлена.
Здесь присутствуют: 53 (пользователей: 0 , гостей: 53) | |
