#681 |
Здравствуйте, помогите, пожалуйста настроить интернет, есть dir 320 - OpenWrt Chaos Calmer 15.05.1 + ZTE MF170 BEELINE. Все установлено, отключен cdrom успешно. Но интернета нет. В логе пытается подключится:
тутКод:
Mon Jul 3 00:19:36 2017 local2.info chat[6473]: timeout set to 10 seconds Mon Jul 3 00:19:36 2017 local2.info chat[6473]: send (AT&F^M) Mon Jul 3 00:19:36 2017 local2.info chat[6473]: expect (OK) Mon Jul 3 00:19:36 2017 local2.info chat[6473]: AT&F^M^M Mon Jul 3 00:19:36 2017 local2.info chat[6473]: OK Mon Jul 3 00:19:36 2017 local2.info chat[6473]: -- got it Mon Jul 3 00:19:36 2017 local2.info chat[6473]: send (ATE1^M) Mon Jul 3 00:19:36 2017 local2.info chat[6473]: expect (OK) Mon Jul 3 00:19:36 2017 local2.info chat[6473]: ^M Mon Jul 3 00:19:36 2017 local2.info chat[6473]: ATE1^M^M Mon Jul 3 00:19:36 2017 local2.info chat[6473]: OK Mon Jul 3 00:19:36 2017 local2.info chat[6473]: -- got it Mon Jul 3 00:19:36 2017 local2.info chat[6473]: send (AT+CGDCONT=1,"IP","ineternet.beeline.ru"^M) Mon Jul 3 00:19:36 2017 local2.info chat[6473]: timeout set to 30 seconds Mon Jul 3 00:19:36 2017 local2.info chat[6473]: expect (OK) Mon Jul 3 00:19:36 2017 local2.info chat[6473]: ^M Mon Jul 3 00:19:36 2017 local2.info chat[6473]: AT+CGDCONT=1,"IP","ineternet.beeline.ru"^M^M Mon Jul 3 00:19:36 2017 local2.info chat[6473]: OK Mon Jul 3 00:19:36 2017 local2.info chat[6473]: -- got it Mon Jul 3 00:19:36 2017 local2.info chat[6473]: send (ATD*99***1#^M) Mon Jul 3 00:19:36 2017 local2.info chat[6473]: expect (CONNECT) Mon Jul 3 00:19:36 2017 local2.info chat[6473]: ^M Mon Jul 3 00:19:36 2017 local2.info chat[6473]: ATD*99***1#^M^M Mon Jul 3 00:19:36 2017 local2.info chat[6473]: ERROR Mon Jul 3 00:19:36 2017 local2.info chat[6473]: -- failed Mon Jul 3 00:19:36 2017 local2.info chat[6473]: Failed (ERROR) Mon Jul 3 00:19:36 2017 daemon.err pppd[6471]: Connect script failed Mon Jul 3 00:19:37 2017 daemon.info pppd[6471]: Exit. Mon Jul 3 00:19:37 2017 daemon.notice netifd: Interface 'wan' is now down Mon Jul 3 00:19:37 2017 daemon.notice netifd: Interface 'wan' is setting up now Mon Jul 3 00:19:39 2017 daemon.notice pppd[6493]: pppd 2.4.7 started by root, uid 0 Mon Jul 3 00:19:40 2017 local2.info chat[6495]: abort on (BUSY) Mon Jul 3 00:19:40 2017 local2.info chat[6495]: abort on (NO CARRIER) Mon Jul 3 00:19:40 2017 local2.info chat[6495]: abort on (ERROR) Mon Jul 3 00:19:40 2017 local2.info chat[6495]: report (CONNECT) Mon Jul 3 00:19:40 2017 local2.info chat[6495]: timeout set to 10 seconds Конфиг '/etc/config/network' Код:
config interface 'loopback' option ifname 'lo' option proto 'static' option ipaddr '127.0.0.1' option netmask '255.0.0.0' config globals 'globals' option ula_prefix 'fd8e:a92d:61cc::/48' config interface 'lan' option ifname 'eth0.1' option force_link '1' option macaddr 'fe:75:16:a6:e4:66' option type 'bridge' option proto 'static' option netmask '255.255.255.0' option ip6assign '60' option ipaddr '192.168.2.1' config interface 'wan' option proto '3g' option device '/dev/ttyUSB0' option service 'umts' option apn 'internet.beeline.ru' option username 'beeline' option password 'beeline' option auto '1' config switch option name 'switch0' option reset '1' option enable_vlan '1' config switch_vlan option device 'switch0' option vlan '1' option ports '0 1 2 3 6t' config switch_vlan option device 'switch0' option vlan '2' option ports '4 6t' Код:
Mon Jul 3 15:26:33 2017 daemon.notice netifd: Interface 'WAN' is now down Mon Jul 3 15:26:33 2017 daemon.notice netifd: Interface 'WAN' is setting up now Mon Jul 3 15:27:04 2017 daemon.warn odhcpd[935]: DHCPV6 SOLICIT IA_NA from 000100011cdecd96001302530637 on br-lan: ok fd9e:dd2c:54c2::afc/128 Mon Jul 3 15:27:05 2017 daemon.warn odhcpd[935]: DHCPV6 REQUEST IA_NA from 000100011cdecd96001302530637 on br-lan: ok fd9e:dd2c:54c2::afc/128 Mon Jul 3 15:27:05 2017 daemon.info dnsmasq[1219]: read /etc/hosts - 1 addresses Mon Jul 3 15:27:05 2017 daemon.info dnsmasq[1219]: read /tmp/hosts/odhcpd - 2 addresses Mon Jul 3 15:27:05 2017 daemon.info dnsmasq[1219]: read /tmp/hosts/dhcp - 1 addresses Mon Jul 3 15:27:05 2017 daemon.info dnsmasq-dhcp[1219]: read /etc/ethers - 0 addresses Mon Jul 3 15:27:05 2017 daemon.info dnsmasq-dhcp[1219]: DHCPINFORM(br-lan) 192.168.1.215 00:13:02:53:06:37 Mon Jul 3 15:27:05 2017 daemon.info dnsmasq-dhcp[1219]: DHCPACK(br-lan) 192.168.1.215 00:13:02:53:06:37 NoutR Mon Jul 3 15:27:12 2017 daemon.notice netifd: Network device 'eth0' link is down Mon Jul 3 15:27:12 2017 kern.info kernel: [ 1371.450000] eth0: link down Mon Jul 3 15:27:12 2017 kern.info kernel: [ 1371.450000] br-lan: port 1(eth0) entered disabled state Mon Jul 3 15:27:13 2017 daemon.notice netifd: Interface 'WAN' is now down Mon Jul 3 15:27:13 2017 kern.info kernel: [ 1372.950000] eth0: link up (1000Mbps/Full duplex) Mon Jul 3 15:27:13 2017 kern.info kernel: [ 1372.950000] br-lan: port 1(eth0) entered forwarding state Mon Jul 3 15:27:13 2017 kern.info kernel: [ 1372.960000] br-lan: port 1(eth0) entered forwarding state Mon Jul 3 15:27:13 2017 daemon.notice netifd: Network device 'eth0' link is up Mon Jul 3 15:27:15 2017 kern.info kernel: [ 1374.960000] br-lan: port 1(eth0) entered forwarding state Mon Jul 3 15:27:38 2017 daemon.notice netifd: Interface 'WAN' is setting up now Mon Jul 3 15:27:39 2017 daemon.notice netifd: WAN (3011): comgt 15:27:39 -> -- Error Report -- Mon Jul 3 15:27:39 2017 daemon.notice netifd: WAN (3011): comgt 15:27:39 -> ----> ^ Mon Jul 3 15:27:39 2017 daemon.notice netifd: WAN (3011): comgt 15:27:39 -> Error @114, line 9, Could not write to COM device. (1) Mon Jul 3 15:27:39 2017 daemon.notice netifd: WAN (3011): Mon Jul 3 15:27:41 2017 daemon.notice netifd: WAN (3011): Trying to set PIN Mon Jul 3 15:27:42 2017 daemon.notice netifd: WAN (3011): PIN set successfully Mon Jul 3 15:27:42 2017 daemon.notice pppd[3034]: pppd 2.4.7 started by root, uid 0 Mon Jul 3 15:27:43 2017 local2.info chat[3036]: abort on (BUSY) Mon Jul 3 15:27:43 2017 local2.info chat[3036]: abort on (NO CARRIER) Mon Jul 3 15:27:43 2017 local2.info chat[3036]: abort on (ERROR) Mon Jul 3 15:27:43 2017 local2.info chat[3036]: report (CONNECT) Mon Jul 3 15:27:43 2017 local2.info chat[3036]: timeout set to 10 seconds Mon Jul 3 15:27:43 2017 local2.info chat[3036]: send (AT&F^M) Mon Jul 3 15:27:43 2017 local2.info chat[3036]: expect (OK) Mon Jul 3 15:27:43 2017 local2.info chat[3036]: AT&F^M^M Mon Jul 3 15:27:43 2017 local2.info chat[3036]: OK Mon Jul 3 15:27:43 2017 local2.info chat[3036]: -- got it Mon Jul 3 15:27:43 2017 local2.info chat[3036]: send (ATE1^M) Mon Jul 3 15:27:43 2017 local2.info chat[3036]: expect (OK) Mon Jul 3 15:27:43 2017 local2.info chat[3036]: ^M Mon Jul 3 15:27:43 2017 local2.info chat[3036]: ATE1^M^M Mon Jul 3 15:27:43 2017 local2.info chat[3036]: OK Mon Jul 3 15:27:43 2017 local2.info chat[3036]: -- got it Mon Jul 3 15:27:43 2017 local2.info chat[3036]: send (AT+CGDCONT=1,"IP","home.beeline.ru"^M) Mon Jul 3 15:27:43 2017 local2.info chat[3036]: timeout set to 30 seconds Mon Jul 3 15:27:43 2017 local2.info chat[3036]: expect (OK) Mon Jul 3 15:27:43 2017 local2.info chat[3036]: ^M Mon Jul 3 15:27:43 2017 local2.info chat[3036]: AT+CGDCONT=1,"IP","home.beeline.ru"^M^M Mon Jul 3 15:27:43 2017 local2.info chat[3036]: OK Mon Jul 3 15:27:43 2017 local2.info chat[3036]: -- got it Mon Jul 3 15:27:43 2017 local2.info chat[3036]: send (ATD*99***1#^M) Mon Jul 3 15:27:44 2017 local2.info chat[3036]: expect (CONNECT) Mon Jul 3 15:27:44 2017 local2.info chat[3036]: ^M Mon Jul 3 15:27:44 2017 kern.info kernel: [ 1403.010000] usb 1-1: USB disconnect, device number 2 Mon Jul 3 15:27:44 2017 kern.info kernel: [ 1403.010000] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0 Mon Jul 3 15:27:44 2017 kern.info kernel: [ 1403.030000] option 1-1:1.0: device disconnected Mon Jul 3 15:27:44 2017 kern.err kernel: [ 1403.030000] option1 ttyUSB1: usb_wwan_indat_callback: resubmit read urb failed. (-19) Mon Jul 3 15:27:44 2017 kern.err kernel: [ 1403.030000] option1 ttyUSB1: usb_wwan_indat_callback: resubmit read urb failed. (-19) Mon Jul 3 15:27:44 2017 kern.err kernel: [ 1403.030000] option1 ttyUSB1: usb_wwan_indat_callback: resubmit read urb failed. (-19) Mon Jul 3 15:27:44 2017 kern.err kernel: [ 1403.030000] option1 ttyUSB1: usb_wwan_indat_callback: resubmit read urb failed. (-19) Mon Jul 3 15:27:44 2017 local2.info chat[3036]: warning: read() on stdin returned 0 Mon Jul 3 15:27:44 2017 local2.info chat[3036]: Failed Mon Jul 3 15:27:44 2017 local2.err chat[3036]: Can't restore terminal parameters: Input/output error Mon Jul 3 15:27:44 2017 daemon.err pppd[3034]: Connect script failed Mon Jul 3 15:27:44 2017 kern.info kernel: [ 1403.100000] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1 Mon Jul 3 15:27:44 2017 kern.info kernel: [ 1403.110000] option 1-1:1.1: device disconnected Mon Jul 3 15:27:44 2017 kern.info kernel: [ 1403.120000] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2 Mon Jul 3 15:27:44 2017 kern.info kernel: [ 1403.120000] option 1-1:1.2: device disconnected Mon Jul 3 15:27:44 2017 daemon.info pppd[3034]: Exit. Mon Jul 3 15:27:44 2017 daemon.notice netifd: Interface 'WAN' is now down Mon Jul 3 15:27:46 2017 kern.info kernel: [ 1405.510000] usb 1-1: new high-speed USB device number 3 using ehci-platform Mon Jul 3 15:27:46 2017 kern.info kernel: [ 1405.670000] option 1-1:1.0: GSM modem (1-port) converter detected Mon Jul 3 15:27:46 2017 kern.info kernel: [ 1405.680000] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0 [свернуть] Пробовал этот же свисток на другом роутере TPLink OpenWRT 15, все один к одному в логе.. Подскажите, пожалуйста, в чем может быть проблема? Спасибо! |
#682 |
vasya00
Подключитесь по ssh. Посмотрите виден ли свисток и как называется: cd /dev && ls Похоже был не прав ![]() Изучайте первоисточники: https://wiki.openwrt.org/ru/doc/recipes/3gdongle Поставьте люсю(вебинтерфейс) - а также luci-proto-3g И все это элементарно настраивается из вебинтерфейса (если конечно у роутера место хватит )
Читаю ваши мысли по аватару ... Последний раз редактировалось sunny; 05.07.2017 в 00:54. |
#683 |
Спасибо, вебинтерфейс стоит, настраивал все в соответствии с первоисточником, как из вебинтерфейса, так и вручную правкой /etc/config/network, судя по логу, как я понимаю, свисток виден, и даже пытается подключится, но потом что то идет не так.. Но что не понять(
#684 |
Кстати в первоисточнике https://wiki.openwrt.org/ru/doc/recipes/3gdongle значения параметров /etc/config/network не взяты в апострофы, ошибка?
#685 | |
Как я понимаю, судя по логу, модем отвечает корректно на AT команды, но после команды набора номера отваливается, но почему? Модем отлично работает с компьютера. Может команда другая нужна?
логЦитата:
[свернуть] |
#686 |
vasya00
Судя по логам у вас и wan падает... Wed Jul 5 13:45:09 2017 daemon.notice netifd: Interface 'WAN' is now down И девайс отваливается: Wed Jul 5 13:45:08 2017 kern.info kernel: [ 134.300000] option 1-1:1.2: device disconnected Первопричина похоже девайс, пакеты все установлены ? И если установлены то какие именно ? Пробуйте: kmod-usb2 (aka EHCI); kmod-usb3 (aka XHCI); У вас он похоже в режиме usb1.1 работает:
Читаю ваши мысли по аватару ... Последний раз редактировалось sunny; 05.07.2017 в 14:45. |
#687 | ||
[QUOTE=sunny;37526]
Установлен и kmod-usb2 и 3 и еще: Цитата:
Я не очень разбираюсь в этих AT командах, но подумал почему отваливается после команды набора номера.. Послушал COM порт при подключении компьютера через билайновское приложение, что интересно там нет команд с точкой доступа логином и паролем? и команда набора номера "ATDT*99#" вместо "ATD*99***1#" Цитата:
Спасибо! |
#688 | ||
Да, имхо тут с пакетами надо разбираться..
У вас dir 320 Удалите: kmod-usb3 Удалите: kmod-usb-uhci Поставьте: kmod-usb-ohci Попробуйте и смотрите дальше по инструкции: Цитата:
kmod-l2tp............................ Layer Two Tunneling Protocol (L2TP) kmod-l2tp-eth................ L2TP ethernet pseudowire support for L2TPv3 kmod-l2tp-ip............................ L2TP IP encapsulation for L2TPv3 === Цитата:
Когда разберетесь, как оно должно работать, тогда уж лезть в конфиги ![]() === Я не настраивал себе 3g/4g - поэтому, конкретики не подскажу... Надо пробовать...
Читаю ваши мысли по аватару ... Последний раз редактировалось sunny; 05.07.2017 в 20:37. |
#689 | ||
Внезапно соединение установилось с ttyUSB2, странно как тогда он с ttyUSB1 связывался и тот отвечал ОК.
Но на этом трудности не прекратились, соединение хоть и есть но очень плохое, жутко тормозит, куда то теряются пакеты: Цитата:
Команды почему то не идут Цитата:
#690 |
Это уже прогресс
![]() У вас не работало из-за kmod-usb-uhci - 3.18.23-1 После reboot-a ttyUSB2 - станет имхо ttyUSB0 После выполнения настроек, неплохо бы выполнить reboot. Чтобы установить соединения автоматом на перезагруженном роутере... Оpenwrt любит - reboot(команда перезагрузки) === Если вы сначала правили конфиги, а потом настроили через вебинтерфейс - то вполне вероятны ваши нынешние проблемы с нестабильной связью..
Читаю ваши мысли по аватару ... Последний раз редактировалось sunny; 06.07.2017 в 16:52. |
| Метки |
| network openwrt, wi-fi openwrt, настройка сети openwrt |
| Здесь присутствуют: 41 (пользователей: 0 , гостей: 41) | |
