#1 |
#2 |
#3 | |
Последний раз редактировалось sakatgg; 25.02.2016 в 19:37. |
#4 |
#5 |
Привет всем. Помогите настроить IpTv/ посмотрите может что не так я сделал
vi /etc/init.d/udpxy root@OpenWrt:~# vi /etc/init.d/udpxy # # config 'rule' # option 'target' 'ACCEPT' # option '_name' 'multicast' # option 'src' 'wan' # option 'proto' 'all' # option 'dest_ip' '224.0.0.0/4' START=99 STOP=10 SERVICE_DAEMONIZE=1 SERVICE_WRITE_PID=1 IGMP_OPTS="-T -S -m 192.168.1.1 -p 4022 -B 2Mb -M 600" start() { service_start /usr/bin/udpxy $OPTIONS } stop() { service_stop /usr/bin/udpxy } - /etc/init.d/udpxy 27/28 96% vi /etc/config/udpxy config udpxy option respawn '1' option verbose '0' option status '1' option port '4022' option disabled '0' option bind '192.168.1.1' option max_clients '3' option buffer_size '4096' ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ - /etc/config/udpxy 1/11 9% vi /etc/config/igmpproxy root@OpenWrt:~# vi /etc/config/igmpproxy config igmpproxy option quickleave 1 config phyint wan option network wan option direction upstream list altnet 192.168.0.0/24 list altnet 172.16.0.0/12 list altnet 10.0.0.0/8 list altnet 233.0.0.0/4 list altnet 192.168.0.0/16 list altnet 239.0.0.0/4 list altnet 82.208.79.0/24 list altnet 224.0.0.0/4 config phyint lan option network lan option direction downstream config phyint option network loopback option direction disabled ~ - /etc/config/igmpproxy 1/22 4% vi /etc/config/firewall config defaults option syn_flood '1' option input 'ACCEPT' option output 'ACCEPT' option forward 'REJECT' config zone option name 'lan' list network 'lan' option input 'ACCEPT' option output 'ACCEPT' option forward 'ACCEPT' config zone option name 'wan' list network 'wan' list network 'wan6' option input 'REJECT' option output 'ACCEPT' option forward 'REJECT' option masq '1' option mtu_fix '1' config forwarding option src 'lan' option dest 'wan' config rule option name 'Allow-DHCP-Renew' option src 'wan' option proto 'udp' option dest_port '68' option target 'ACCEPT' option family 'ipv4' config rule option name 'Allow-Ping' option src 'wan' option proto 'icmp' option icmp_type 'echo-request' option family 'ipv4' option target 'ACCEPT' config rule option name 'Allow-IGMP' option src 'wan' option proto 'igmp' option family 'ipv4' option target 'ACCEPT' config rule option name 'Allow-DHCPv6' option src 'wan' option proto 'udp' option src_ip 'fe80::/10' option src_port '547' option dest_ip 'fe80::/10' option dest_port '546' option family 'ipv6' option target 'ACCEPT' config rule option name 'Allow-MLD' option src 'wan' option proto 'icmp' option src_ip 'fe80::/10' list icmp_type '130/0' list icmp_type '131/0' list icmp_type '132/0' list icmp_type '143/0' option family 'ipv6' option target 'ACCEPT' config rule option name 'Allow-ICMPv6-Input' option src 'wan' option proto 'icmp' list icmp_type 'echo-request' list icmp_type 'echo-reply' list icmp_type 'destination-unreachable' list icmp_type 'packet-too-big' list icmp_type 'time-exceeded' list icmp_type 'bad-header' list icmp_type 'unknown-header-type' list icmp_type 'router-solicitation' list icmp_type 'neighbour-solicitation' list icmp_type 'router-advertisement' list icmp_type 'neighbour-advertisement' option limit '1000/sec' option family 'ipv6' option target 'ACCEPT' config rule option name 'Allow-ICMPv6-Forward' option src 'wan' option dest '*' option proto 'icmp' list icmp_type 'echo-request' list icmp_type 'echo-reply' list icmp_type 'destination-unreachable' list icmp_type 'packet-too-big' list icmp_type 'time-exceeded' list icmp_type 'bad-header' list icmp_type 'unknown-header-type' option limit '1000/sec' option family 'ipv6' option target 'ACCEPT' config include option path '/etc/firewall.user' config rule option src 'wan' option dest 'lan' option proto 'esp' option target 'ACCEPT' option enabled '0' config rule option src 'wan' option dest 'lan' option dest_port '500' option proto 'udp' option target 'ACCEPT' option enabled '0' config rule option name 'Allow-IPTV-IGMPPROXY' option src 'wan' option dest_ip '224.0.0.0/4' option target 'ACCEPT' option proto 'all' config rule option name 'Allow-IPTV-ALL' option src 'wan' option dest_ip '224.0.0.0/4' option target 'ACCEPT' option proto 'all' option dest 'lan' ps |grep udpxy root@OpenWrt:~# ps |grep udpxy 2568 root 1356 S grep udpxy |
#6 |
Вес репутации: 601 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Что бы получить помощь, ответь на вопросы.
1. Какой тип подключение к сети Это у прова уточнить.Или можно в любой комп от свитча подключить кабель, не вводя никаких настроек и интернет заработает ![]() 2, Модель роутера
#7 | |
Hame-Pr1 |
#8 | |
1. Подключить кабель к роутеру в WAN разъем, включить роутер. Подождать полной загрузки. 2. Сделать сброс настроек (Reset to defaults . Вкладка System >> Backup / Flash Firmware >> кнопка Perform reset и со всем согласиться.После перезагрузки войти в веб-морду не вводя никаких настроек на вкладку Status Overview и в параграфе Network IPv4 WAN Status посмотреть что выдал роутеру провайдер ---------------- Вот пример как у меня. Код:
Type: dhcp Address: 192.168.0.2 Netmask: 255.255.255.0 Gateway: 192.168.0.1 DNS 1: 192.168.0.1 А что бы роутер еще и раздавал интернет в настройках LAN порта ip Address может быть любой, но только что бы в третьей групе (где у меня стоит 0) не совпадал. После сброса в OpenWrt ip LAN 192.168.1.1 я у себя так и оставил. ----------------- Это не понял. А при чем здесь пароль от wifi, если подключение по кабелю ![]()
#9 | |
#10 |
Пока не решил проблему.
| Метки |
| network openwrt, wi-fi openwrt, настройка сети openwrt |
| Здесь присутствуют: 11 (пользователей: 0 , гостей: 11) | |
| Опции просмотра | |
