Старый 11.12.2015, 19:07   #1
Letatis
Letatis is an unknown quantity at this point
По умолчанию Re: VPN и OpenWRT
Вывод 2 отключаем openwrt от главного роутера. Подключаем комп на прямую. Включаем модем и начинаем получать от него интернет.
ifconfig
br-lan Link encap:Ethernet HWaddr C4:6E:1F:64:CA:9C
inet addr:192.168.1.199 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::c66e:1fff:fe64:ca9c/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1461 errors:0 dropped:0 overruns:0 frame:0
TX packets:1284 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:98370 (96.0 KiB) TX bytes:102354 (99.9 KiB)
eth0 Link encap:Ethernet HWaddr C4:6E:1F:64:CA:9C
RX packets:1546 errors:0 dropped:31 overruns:0 frame:0
TX packets:1285 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:130925 (127.8 KiB) TX bytes:102384 (99.9 KiB)
Interrupt:4
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:96 errors:0 dropped:0 overruns:0 frame:0
TX packets:96 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:9846 (9.6 KiB) TX bytes:9846 (9.6 KiB)
usb0 Link encap:Ethernet HWaddr 36:4B:50:B7:EF:2E
inet addr:192.168.99.183 Bcast:192.168.99.255 Mask:255.255.255.0
inet6 addr: fe80::344b:50ff:feb7:ef2e/64 Scope:Link
RX packets:32 errors:0 dropped:0 overruns:0 frame:0
TX packets:19 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2560 (2.5 KiB) TX bytes:4352 (4.2 KiB)
route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 192.168.99.1 0.0.0.0 UG 0 0 0 usb0
46.38.52.90 192.168.1.1 255.255.255.255 UGH 0 0 0 br-lan
192.168.1.0 * 255.255.255.0 U 0 0 0 br-lan
192.168.99.0 * 255.255.255.0 U 0 0 0 usb0
traceroute ya.ru
traceroute to ya.ru (213.180.204.3), 30 hops max, 38 byte packets
1 192.168.99.1 (192.168.99.1) 1.199 ms 0.908 ms 0.705 ms
2 172.16.9.146 (172.16.9.146) 189.416 ms 19.242 ms 16.867 ms
3 * * *
4 130.gprs.mts.ru (213.87.140.130) 242.656 ms 21.550 ms 20.440 ms
5 ss-cr04-be11.100.msk.stream-internet.net (212.188.41.205) 19.482 ms 19.315 ms 23.842 ms
6 m9-cr04-be9.77.msk.stream-internet.net (195.34.59.249) 22.718 ms 19.205 ms 20.473 ms
7 m9-cr03-ae13.77.msk.stream-internet.net (212.188.42.106) 18.606 ms 19.275 ms 19.699 ms
8 Yandex-m9.msk.stream-internet.net (195.34.36.30) 20.607 ms 19.282 ms 18.072 ms
9 std-p1-be14.yndx.net (87.250.239.62) 28.372 ms m9-p1-be1.yndx.net (87.250.239.22) 20.561 ms 19.376 ms
10 std-p1-be7.yndx.net (87.250.239.14) 21.636 ms iva-b-c2-ae4.yndx.net (87.250.239.117) 18.424 ms std-p1-be7.yndx.net (87.250.239.14) 20.401 ms
11 * * *
12 www.yandex.ru (213.180.204.3) 335.591 ms 20.533 ms 20.337 ms
13 * * *
14 www.yandex.ru (213.180.204.3) 44.767 ms 20.458 ms 20.337 ms
traceroute vpn.lan2lan.ru
traceroute to vpn.lan2lan.ru (46.38.52.90), 30 hops max, 38 byte packets
1 OpenWrt.lan (192.168.1.199) 2255.604 ms !H 2997.795 ms !H 2999.053 ms !H
Letatis вне форума   Ответить с цитированием
Старый 11.12.2015, 20:23   #2
paulerr
Вес репутации: 1154
Когда модем подключаете роутер перегружаете? C чего запись в route
осталась?
Принципиально иметь шлюз по умолчанию не совпадающий с адресом самого роутера?
Последний раз редактировалось paulerr; 11.12.2015 в 20:30.
Старый 11.12.2015, 21:13   #3
Letatis
все без перезагрузки (но перегружать соответственно пробывал). не принципиально надо чтобы работал vpn межту роутером(модем) и удаленным телефоном
Старый 11.12.2015, 22:55   #4
paulerr
Вес репутации: 1154
видится несколько вариантов:
удалите запись(выше) в таблице машрутизации или настройте дефолтный шлюз на адрес роутера или поиграйтесь с метриками интерфейсов
Старый 12.12.2015, 01:05   #5
Letatis
Ни слова не понял после "или"
Старый 12.12.2015, 01:27   #6
Вес репутации: 1602
Очевидно он имел ввиду пробовать менять настройки интерфейсов, как то: wan, lan.
Люсю установить невозможно ввиду нехватки места ?
Я бы на вашем месте, попробовал бы настроить тоже самое - с гуя, с девайса с большей памятью, а потом бы просто скопировал конфиги.
Последний раз редактировалось sunny; 12.12.2015 в 01:46.
Старый 12.12.2015, 12:18   #7
Letatis
Люся стоит флешка затянута
Старый 12.12.2015, 12:26   #8
Вес репутации: 1602
Тогда наверное проще выложить видео (или скриншоты) настроек
Старый 12.12.2015, 13:36   #9
paulerr
Вес репутации: 1154
классический вариант настройки : роутер как шлюз в интернет и поднятие на нем vpn, описан в этом топике. Он работает(на АА openwrt точно).
Если хотите шашечки, тогда читайте про маршрутизацию, выкладывайте что получилось.
Для ВВ скаченного с сайта openwrt , для СС что-то с pptd намудрили, нормально не работает. Модема GSM под рукой нет, так что инет на роутере через wifi (wwan)
root@OpenWrt:/# ifconfig
br-lan    Link encap:Ethernet  HWaddr 64:70:02:76:43:87
          inet addr:192.168.2.1  Bcast:192.168.2.255  Mask:255.255.255.0
          inet6 addr: fde5:b860:5d23::1/60 Scope:Global
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
eth0      Link encap:Ethernet  HWaddr 64:70:02:76:43:87
          Interrupt:4
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:50 errors:0 dropped:0 overruns:0 frame:0
          TX packets:50 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:4750 (4.6 KiB)  TX bytes:4750 (4.6 KiB)
pptp-vpn  Link encap:Point-to-Point Protocol
          inet addr:192.168.99.1  P-t-P:46.38.52.90  Mask:255.255.255.255
          UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1320  Metric:1
          RX packets:4 errors:0 dropped:0 overruns:0 frame:0
          TX packets:5 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:3
          RX bytes:58 (58.0 B)  TX bytes:90 (90.0 B)
wlan0     Link encap:Ethernet  HWaddr 64:70:02:76:43:87
          inet addr:192.168.0.137  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::6670:2ff:fe76:4387/64 Scope:Link
          RX packets:655 errors:0 dropped:0 overruns:0 frame:0
          TX packets:319 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:62200 (60.7 KiB)  TX bytes:29343 (28.6 KiB)
root@OpenWrt:/# ping 192.168.99.2
PING 192.168.99.2 (192.168.99.2): 56 data bytes
64 bytes from 192.168.99.2: seq=0 ttl=127 time=10.888 ms
64 bytes from 192.168.99.2: seq=1 ttl=127 time=10.174 ms
64 bytes from 192.168.99.2: seq=2 ttl=127 time=10.729 ms
полный /etc/config/network
root@OpenWrt:/# cat /etc/config/network
config interface 'loopback'
        option ifname 'lo'
        option proto 'static'
        option ipaddr '127.0.0.1'
        option netmask '255.0.0.0'
config globals 'globals'
        option ula_prefix 'fde5:b860:5d23::/48'
config interface 'lan'
        option ifname 'eth0'
        option force_link '1'
        option type 'bridge'
        option ip6assign '60'
        option ipaddr '192.168.2.1'
config interface 'wwan'
        option proto 'dhcp'
config interface 'vpn'
        option ifname 'pptp-vpn'
        option proto 'pptp'
        option username 'user'
        option password 'password'
        option server 'vpn.lan2lan.ru'
        option buffering '1'
        option defaultroute '0'
        option peerdns '0'
config route
        option interface 'vpn'
        option target '192.168.99.0'
        option gateway '46.38.52.90'
часть /etc/config/firewall
config zone
        option name 'vpn'
        option input 'ACCEPT'
        option output 'ACCEPT'
        option forward 'ACCEPT'
        option masq '1'
        option network 'vpn'
config forwarding
        option dest 'lan'
        option src 'vpn'
config forwarding
        option dest 'vpn'
        option src 'lan']
etc/ppp/options.pptp
root@OpenWrt:/# cat /etc/ppp/options.pptp
noipdefault
noauth
nobsdcomp
nodeflate
idle 0
#mppe required,no40,no56,stateless
maxfail 0
refuse-eap
root@OpenWrt:/#
Последний раз редактировалось paulerr; 12.12.2015 в 23:04.
Старый 12.12.2015, 23:03   #10
Letatis
Так проблема в том что и делал раньше по этому топику и сейчас но не работает. И не надо ничего больше. Просто сеть через lan2lan. Весь вопрос в том где ошибка?
Текущее время: 03:05. Часовой пояс GMT +3.
