Старый 04.07.2017, 22:02   #681
vasya00
vasya00 is an unknown quantity at this point
Здравствуйте, помогите, пожалуйста настроить интернет, есть dir 320 - OpenWrt Chaos Calmer 15.05.1 + ZTE MF170 BEELINE. Все установлено, отключен cdrom успешно. Но интернета нет. В логе пытается подключится:
тут
Mon Jul  3 00:19:36 2017 local2.info chat[6473]: timeout set to 10 seconds
Mon Jul  3 00:19:36 2017 local2.info chat[6473]: send (AT&F^M)
Mon Jul  3 00:19:36 2017 local2.info chat[6473]: expect (OK)
Mon Jul  3 00:19:36 2017 local2.info chat[6473]: AT&F^M^M
Mon Jul  3 00:19:36 2017 local2.info chat[6473]: OK
Mon Jul  3 00:19:36 2017 local2.info chat[6473]:  -- got it
Mon Jul  3 00:19:36 2017 local2.info chat[6473]: send (ATE1^M)
Mon Jul  3 00:19:36 2017 local2.info chat[6473]: ^M
Mon Jul  3 00:19:36 2017 local2.info chat[6473]: ATE1^M^M
Mon Jul  3 00:19:36 2017 local2.info chat[6473]: send (AT+CGDCONT=1,"IP","ineternet.beeline.ru"^M)
Mon Jul  3 00:19:36 2017 local2.info chat[6473]: timeout set to 30 seconds
Mon Jul  3 00:19:36 2017 local2.info chat[6473]: AT+CGDCONT=1,"IP","ineternet.beeline.ru"^M^M
Mon Jul  3 00:19:36 2017 local2.info chat[6473]: send (ATD*99***1#^M)
Mon Jul  3 00:19:36 2017 local2.info chat[6473]: expect (CONNECT)
Mon Jul  3 00:19:36 2017 local2.info chat[6473]: ATD*99***1#^M^M
Mon Jul  3 00:19:36 2017 local2.info chat[6473]: ERROR
Mon Jul  3 00:19:36 2017 local2.info chat[6473]:  -- failed
Mon Jul  3 00:19:36 2017 local2.info chat[6473]: Failed (ERROR)
Mon Jul  3 00:19:36 2017 daemon.err pppd[6471]: Connect script failed
Mon Jul  3 00:19:37 2017 daemon.info pppd[6471]: Exit.
Mon Jul  3 00:19:37 2017 daemon.notice netifd: Interface 'wan' is now down
Mon Jul  3 00:19:37 2017 daemon.notice netifd: Interface 'wan' is setting up now
Mon Jul  3 00:19:39 2017 daemon.notice pppd[6493]: pppd 2.4.7 started by root, uid 0
Mon Jul  3 00:19:40 2017 local2.info chat[6495]: abort on (BUSY)
Mon Jul  3 00:19:40 2017 local2.info chat[6495]: abort on (NO CARRIER)
Mon Jul  3 00:19:40 2017 local2.info chat[6495]: abort on (ERROR)
Mon Jul  3 00:19:40 2017 local2.info chat[6495]: report (CONNECT)
Mon Jul  3 00:19:40 2017 local2.info chat[6495]: timeout set to 10 seconds
Конфиг '/etc/config/network'
config interface 'loopback'
	option ifname 'lo'
	option proto 'static'
	option ipaddr '127.0.0.1'
	option netmask '255.0.0.0'
config globals 'globals'
	option ula_prefix 'fd8e:a92d:61cc::/48'
config interface 'lan'
	option ifname 'eth0.1'
	option force_link '1'
	option macaddr 'fe:75:16:a6:e4:66'
	option type 'bridge'
	option ip6assign '60'
	option ipaddr '192.168.2.1'
config interface 'wan'
	option proto '3g'
	option device '/dev/ttyUSB0'
	option service 'umts'
	option apn 'internet.beeline.ru'
	option username 'beeline'
	option password 'beeline'
	option auto '1'
config switch
	option name 'switch0'
	option reset '1'
	option enable_vlan '1'
config switch_vlan
	option device 'switch0'
	option vlan '1'
	option ports '0 1 2 3 6t'
config switch_vlan
	option vlan '2'
	option ports '4 6t'
Пробовал включать пин код, не помогло, поменял ttyUSB0 на ttyUSB1 (кстати как определится точно с этим номером и может ли он менятся при переподключении?) рошло дальше:
Mon Jul  3 15:26:33 2017 daemon.notice netifd: Interface 'WAN' is now down
Mon Jul  3 15:26:33 2017 daemon.notice netifd: Interface 'WAN' is setting up now
Mon Jul  3 15:27:04 2017 daemon.warn odhcpd[935]: DHCPV6 SOLICIT IA_NA from 000100011cdecd96001302530637 on br-lan: ok fd9e:dd2c:54c2::afc/128
Mon Jul  3 15:27:05 2017 daemon.warn odhcpd[935]: DHCPV6 REQUEST IA_NA from 000100011cdecd96001302530637 on br-lan: ok fd9e:dd2c:54c2::afc/128
Mon Jul  3 15:27:05 2017 daemon.info dnsmasq[1219]: read /etc/hosts - 1 addresses
Mon Jul  3 15:27:05 2017 daemon.info dnsmasq[1219]: read /tmp/hosts/odhcpd - 2 addresses
Mon Jul  3 15:27:05 2017 daemon.info dnsmasq[1219]: read /tmp/hosts/dhcp - 1 addresses
Mon Jul  3 15:27:05 2017 daemon.info dnsmasq-dhcp[1219]: read /etc/ethers - 0 addresses
Mon Jul  3 15:27:05 2017 daemon.info dnsmasq-dhcp[1219]: DHCPINFORM(br-lan) 192.168.1.215 00:13:02:53:06:37
Mon Jul  3 15:27:05 2017 daemon.info dnsmasq-dhcp[1219]: DHCPACK(br-lan) 192.168.1.215 00:13:02:53:06:37 NoutR
Mon Jul  3 15:27:12 2017 daemon.notice netifd: Network device 'eth0' link is down
Mon Jul  3 15:27:12 2017 kern.info kernel: [ 1371.450000] eth0: link down
Mon Jul  3 15:27:12 2017 kern.info kernel: [ 1371.450000] br-lan: port 1(eth0) entered disabled state
Mon Jul  3 15:27:13 2017 daemon.notice netifd: Interface 'WAN' is now down
Mon Jul  3 15:27:13 2017 kern.info kernel: [ 1372.950000] eth0: link up (1000Mbps/Full duplex)
Mon Jul  3 15:27:13 2017 kern.info kernel: [ 1372.950000] br-lan: port 1(eth0) entered forwarding state
Mon Jul  3 15:27:13 2017 kern.info kernel: [ 1372.960000] br-lan: port 1(eth0) entered forwarding state
Mon Jul  3 15:27:13 2017 daemon.notice netifd: Network device 'eth0' link is up
Mon Jul  3 15:27:15 2017 kern.info kernel: [ 1374.960000] br-lan: port 1(eth0) entered forwarding state
Mon Jul  3 15:27:38 2017 daemon.notice netifd: Interface 'WAN' is setting up now
Mon Jul  3 15:27:39 2017 daemon.notice netifd: WAN (3011): comgt 15:27:39 -> -- Error Report --
Mon Jul  3 15:27:39 2017 daemon.notice netifd: WAN (3011): comgt 15:27:39 -> ---->              ^
Mon Jul  3 15:27:39 2017 daemon.notice netifd: WAN (3011): comgt 15:27:39 -> Error @114, line 9, Could not write to COM device. (1)
Mon Jul  3 15:27:41 2017 daemon.notice netifd: WAN (3011): Trying to set PIN
Mon Jul  3 15:27:42 2017 daemon.notice netifd: WAN (3011): PIN set successfully
Mon Jul  3 15:27:42 2017 daemon.notice pppd[3034]: pppd 2.4.7 started by root, uid 0
Mon Jul  3 15:27:43 2017 local2.info chat[3036]: abort on (BUSY)
Mon Jul  3 15:27:43 2017 local2.info chat[3036]: abort on (NO CARRIER)
Mon Jul  3 15:27:43 2017 local2.info chat[3036]: abort on (ERROR)
Mon Jul  3 15:27:43 2017 local2.info chat[3036]: report (CONNECT)
Mon Jul  3 15:27:43 2017 local2.info chat[3036]: timeout set to 10 seconds
Mon Jul  3 15:27:43 2017 local2.info chat[3036]: send (AT&F^M)
Mon Jul  3 15:27:43 2017 local2.info chat[3036]: expect (OK)
Mon Jul  3 15:27:43 2017 local2.info chat[3036]: AT&F^M^M
Mon Jul  3 15:27:43 2017 local2.info chat[3036]: OK
Mon Jul  3 15:27:43 2017 local2.info chat[3036]:  -- got it
Mon Jul  3 15:27:43 2017 local2.info chat[3036]: send (ATE1^M)
Mon Jul  3 15:27:43 2017 local2.info chat[3036]: ^M
Mon Jul  3 15:27:43 2017 local2.info chat[3036]: ATE1^M^M
Mon Jul  3 15:27:43 2017 local2.info chat[3036]: send (AT+CGDCONT=1,"IP","home.beeline.ru"^M)
Mon Jul  3 15:27:43 2017 local2.info chat[3036]: timeout set to 30 seconds
Mon Jul  3 15:27:43 2017 local2.info chat[3036]: AT+CGDCONT=1,"IP","home.beeline.ru"^M^M
Mon Jul  3 15:27:43 2017 local2.info chat[3036]: send (ATD*99***1#^M)
Mon Jul  3 15:27:44 2017 local2.info chat[3036]: expect (CONNECT)
Mon Jul  3 15:27:44 2017 local2.info chat[3036]: ^M
Mon Jul  3 15:27:44 2017 kern.info kernel: [ 1403.010000] usb 1-1: USB disconnect, device number 2
Mon Jul  3 15:27:44 2017 kern.info kernel: [ 1403.010000] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Mon Jul  3 15:27:44 2017 kern.info kernel: [ 1403.030000] option 1-1:1.0: device disconnected
Mon Jul  3 15:27:44 2017 kern.err kernel: [ 1403.030000] option1 ttyUSB1: usb_wwan_indat_callback: resubmit read urb failed. (-19)
Mon Jul  3 15:27:44 2017 local2.info chat[3036]: warning: read() on stdin returned 0
Mon Jul  3 15:27:44 2017 local2.info chat[3036]: Failed
Mon Jul  3 15:27:44 2017 local2.err chat[3036]: Can't restore terminal parameters: Input/output error
Mon Jul  3 15:27:44 2017 daemon.err pppd[3034]: Connect script failed
Mon Jul  3 15:27:44 2017 kern.info kernel: [ 1403.100000] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Mon Jul  3 15:27:44 2017 kern.info kernel: [ 1403.110000] option 1-1:1.1: device disconnected
Mon Jul  3 15:27:44 2017 kern.info kernel: [ 1403.120000] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Mon Jul  3 15:27:44 2017 kern.info kernel: [ 1403.120000] option 1-1:1.2: device disconnected
Mon Jul  3 15:27:44 2017 daemon.info pppd[3034]: Exit.
Mon Jul  3 15:27:44 2017 daemon.notice netifd: Interface 'WAN' is now down
Mon Jul  3 15:27:46 2017 kern.info kernel: [ 1405.510000] usb 1-1: new high-speed USB device number 3 using ehci-platform
Mon Jul  3 15:27:46 2017 kern.info kernel: [ 1405.670000] option 1-1:1.0: GSM modem (1-port) converter detected
Mon Jul  3 15:27:46 2017 kern.info kernel: [ 1405.680000] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
[свернуть]
Пробовал этот же свисток на другом роутере TPLink OpenWRT 15, все один к одному в логе..
Подскажите, пожалуйста, в чем может быть проблема?
Спасибо!
vasya00 вне форума   Ответить с цитированием
Старый 05.07.2017, 00:29   #682
Вес репутации: 1602
vasya00
Подключитесь по ssh.
Посмотрите виден ли свисток и как называется:
cd /dev && ls
Похоже был не прав
Изучайте первоисточники:
https://wiki.openwrt.org/ru/doc/recipes/3gdongle
Поставьте люсю(вебинтерфейс) - а также luci-proto-3g
И все это элементарно настраивается из вебинтерфейса (если конечно у роутера место хватит )
Последний раз редактировалось sunny; 05.07.2017 в 00:54.
Старый 05.07.2017, 12:31   #683
vasya00
Спасибо, вебинтерфейс стоит, настраивал все в соответствии с первоисточником, как из вебинтерфейса, так и вручную правкой /etc/config/network, судя по логу, как я понимаю, свисток виден, и даже пытается подключится, но потом что то идет не так.. Но что не понять(
Старый 05.07.2017, 12:33   #684
vasya00
Кстати в первоисточнике https://wiki.openwrt.org/ru/doc/recipes/3gdongle значения параметров /etc/config/network не взяты в апострофы, ошибка?
Старый 05.07.2017, 13:56   #685
vasya00
Как я понимаю, судя по логу, модем отвечает корректно на AT команды, но после команды набора номера отваливается, но почему? Модем отлично работает с компьютера. Может команда другая нужна?
лог
send (AT+CGDCONT=1,"IP","internet.beeline.ru"^M)
Wed Jul 5 13:45:07 2017 local2.info chat[1458]: timeout set to 30 seconds
Wed Jul 5 13:45:07 2017 local2.info chat[1458]: expect (OK)
Wed Jul 5 13:45:07 2017 local2.info chat[1458]: ^M
Wed Jul 5 13:45:07 2017 local2.info chat[1458]: AT+CGDCONT=1,"IP","internet.beeline.ru"^M^M
Wed Jul 5 13:45:07 2017 local2.info chat[1458]: OK
Wed Jul 5 13:45:07 2017 local2.info chat[1458]: -- got it
Wed Jul 5 13:45:07 2017 local2.info chat[1458]: send (ATD*99#^M)
Wed Jul 5 13:45:08 2017 local2.info chat[1458]: expect (CONNECT)
Wed Jul 5 13:45:08 2017 local2.info chat[1458]: ^M
Wed Jul 5 13:45:08 2017 kern.info kernel: [ 134.150000] usb 1-1: USB disconnect, device number 2
Wed Jul 5 13:45:08 2017 kern.info kernel: [ 134.160000] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Wed Jul 5 13:45:08 2017 kern.info kernel: [ 134.180000] option 1-1:1.0: device disconnected
Wed Jul 5 13:45:08 2017 kern.err kernel: [ 134.190000] option1 ttyUSB1: usb_wwan_indat_callback: resubmit read urb failed. (-19)
Wed Jul 5 13:45:08 2017 kern.err kernel: [ 134.200000] option1 ttyUSB1: usb_wwan_indat_callback: resubmit read urb failed. (-19)
Wed Jul 5 13:45:08 2017 kern.err kernel: [ 134.220000] option1 ttyUSB1: usb_wwan_indat_callback: resubmit read urb failed. (-19)
Wed Jul 5 13:45:08 2017 kern.err kernel: [ 134.240000] option1 ttyUSB1: usb_wwan_indat_callback: resubmit read urb failed. (-19)
Wed Jul 5 13:45:08 2017 kern.info kernel: [ 134.260000] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Wed Jul 5 13:45:08 2017 kern.info kernel: [ 134.270000] option 1-1:1.1: device disconnected
Wed Jul 5 13:45:08 2017 kern.info kernel: [ 134.280000] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Wed Jul 5 13:45:08 2017 kern.info kernel: [ 134.300000] option 1-1:1.2: device disconnected
Wed Jul 5 13:45:08 2017 local2.info chat[1458]: warning: read() on stdin returned 0
Wed Jul 5 13:45:08 2017 local2.info chat[1458]: Failed
Wed Jul 5 13:45:08 2017 local2.err chat[1458]: Can't restore terminal parameters: Input/output error
Wed Jul 5 13:45:08 2017 daemon.err pppd[1454]: Connect script failed
Wed Jul 5 13:45:09 2017 daemon.info pppd[1454]: Exit.
Wed Jul 5 13:45:09 2017 daemon.notice netifd: Interface 'WAN' is now down
Wed Jul 5 13:45:10 2017 kern.info kernel: [ 136.630000] usb 1-1: new high-speed USB device number 3 using ehci-platform
Wed Jul 5 13:45:10 2017 kern.debug kernel: [ 136.790000] usb 1-1: no of_node; not parsing pinctrl DT
Wed Jul 5 13:45:10 2017 kern.debug kernel: [ 136.830000] option 1-1:1.0: no of_node; not parsing pinctrl DT
Wed Jul 5 13:45:10 2017 kern.info kernel: [ 136.840000] option 1-1:1.0: GSM modem (1-port) converter detected
Wed Jul 5 13:45:10 2017 kern.debug kernel: [ 136.850000] option1 ttyUSB0: no of_node; not parsing pinctrl DT
Wed Jul 5 13:45:10 2017 kern.info kernel: [ 136.860000] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
[свернуть]
Старый 05.07.2017, 14:36   #686
Вес репутации: 1602
vasya00
Судя по логам у вас и wan падает...
И девайс отваливается:
Первопричина похоже девайс, пакеты все установлены ?
И если установлены то какие именно ?
Пробуйте:
kmod-usb2 (aka EHCI);
kmod-usb3 (aka XHCI);
У вас он похоже в режиме usb1.1 работает:
Последний раз редактировалось sunny; 05.07.2017 в 14:45.
Старый 05.07.2017, 16:02   #687
vasya00
[QUOTE=sunny;37526]
Установлен и kmod-usb2 и 3 и еще:
Развернуть для просмотра
root@OpenWrt:~# opkg list-installed
base-files - 157.2-r48532
busybox - 1.23.2-1
chat - 2.4.7-6
comgt - 0.32-25
dnsmasq - 2.73-1
dropbear - 2015.67-1
etherwake - 1.09-3
firewall - 2015-07-27
fstools - 2016-01-10-96415afecef35766332067f4205ef3b2c7561d21
hostapd-common - 2015-03-25-1
ip6tables - 1.4.21-1
iptables - 1.4.21-1
iw - 3.17-1
jshn - 2015-11-08-10429bccd0dc5d204635e110a7a8fae7b80d16cb
jsonfilter - 2014-06-19-cdc760c58077f44fc40adbbe41e1556a67c1b9a9
kernel - 3.18.23-1-b26e7eea6fef8f04502f65d1115c0f1c
kmod-cfg80211 - 3.18.23+2015-03-09-3
kmod-crypto-aes - 3.18.23-1
kmod-crypto-arc4 - 3.18.23-1
kmod-crypto-core - 3.18.23-1
kmod-eeprom-93cx6 - 3.18.23-1
kmod-gpio-button-hotplug - 3.18.23-1
kmod-ip6tables - 3.18.23-1
kmod-ipt-conntrack - 3.18.23-1
kmod-ipt-core - 3.18.23-1
kmod-ipt-nat - 3.18.23-1
kmod-ipv6 - 3.18.23-1
kmod-l2tp - 3.18.23-1
kmod-leds-gpio - 3.18.23-1
kmod-ledtrig-usbdev - 3.18.23-1
kmod-lib-crc-ccitt - 3.18.23-1
kmod-lib-crc-itu-t - 3.18.23-1
kmod-mac80211 - 3.18.23+2015-03-09-3
kmod-nf-conntrack - 3.18.23-1
kmod-nf-conntrack6 - 3.18.23-1
kmod-nf-ipt - 3.18.23-1
kmod-nf-ipt6 - 3.18.23-1
kmod-nf-nat - 3.18.23-1
kmod-nf-nathelper - 3.18.23-1
kmod-nls-base - 3.18.23-1
kmod-ppp - 3.18.23-1
kmod-pppoe - 3.18.23-1
kmod-pppol2tp - 3.18.23-1
kmod-pppox - 3.18.23-1
kmod-rt2800-lib - 3.18.23+2015-03-09-3
kmod-rt2800-mmio - 3.18.23+2015-03-09-3
kmod-rt2800-soc - 3.18.23+2015-03-09-3
kmod-rt2x00-lib - 3.18.23+2015-03-09-3
kmod-rt2x00-mmio - 3.18.23+2015-03-09-3
kmod-slhc - 3.18.23-1
kmod-udptunnel4 - 3.18.23-1
kmod-udptunnel6 - 3.18.23-1
kmod-usb-acm - 3.18.23-1
kmod-usb-core - 3.18.23-1
kmod-usb-dwc2 - 3.18.23-1
kmod-usb-serial - 3.18.23-1
kmod-usb-serial-option - 3.18.23-1
kmod-usb-serial-wwan - 3.18.23-1
kmod-usb-uhci - 3.18.23-1
kmod-usb2 - 3.18.23-1
kmod-usb3 - 3.18.23-1
libblobmsg-json - 2015-11-08-10429bccd0dc5d204635e110a7a8fae7b80d16cb
libc - 0.9.33.2-1
libgcc - 4.8-linaro-1
libip4tc - 1.4.21-1
libip6tc - 1.4.21-1
libiwinfo - 2015-06-01-ade8b1b299cbd5748db1acf80dd3e9f567938371
libiwinfo-lua - 2015-06-01-ade8b1b299cbd5748db1acf80dd3e9f567938371
libjson-c - 0.12-1
libjson-script - 2015-11-08-10429bccd0dc5d204635e110a7a8fae7b80d16cb
liblua - 5.1.5-1
libnl-tiny - 0.1-4
libpthread - 0.9.33.2-1
librt - 0.9.33.2-1
libubox - 2015-11-08-10429bccd0dc5d204635e110a7a8fae7b80d16cb
libubus - 2015-05-25-f361bfa5fcb2daadf3b160583ce665024f8d108e
libubus-lua - 2015-05-25-f361bfa5fcb2daadf3b160583ce665024f8d108e
libuci - 2015-08-27.1-1
libuci-lua - 2015-08-27.1-1
libusb-1.0 - 1.0.19-1
libxtables - 1.4.21-1
lua - 5.1.5-1
luci - git-16.018.33482-3201903-1
luci-app-firewall - git-16.018.33482-3201903-1
luci-app-wol - git-16.018.33482-3201903-1
luci-base - git-16.018.33482-3201903-1
luci-lib-ip - git-16.018.33482-3201903-1
luci-lib-nixio - git-16.018.33482-3201903-1
luci-mod-admin-full - git-16.018.33482-3201903-1
luci-proto-3g - git-16.018.33482-3201903-1
luci-proto-ipv6 - git-16.018.33482-3201903-1
luci-proto-ppp - git-16.018.33482-3201903-1
luci-theme-bootstrap - git-16.018.33482-3201903-1
mtd - 21
netifd - 2015-12-16-245527193e90906451be35c2b8e972b8712ea6ab
odhcp6c - 2015-07-13-024525798c5f6aba3af9b2ef7b3af2f3c14f1db8
odhcpd - 2015-11-19-01d3f9d64486ac1daa144848944e877e7f0cb762
opkg - 9c97d5ecd795709c8584e972bfdf3aee3a5b846d-9
ppp - 2.4.7-6
ppp-mod-pppoe - 2.4.7-6
ppp-mod-pppol2tp - 2.4.7-6
procd - 2015-10-29.1-d5fddd91b966424bb63e943e789704d52382cc18
resolveip - 2
rpcd - 2015-01-10-f00890cd6eb47ad9bb5da0fb6c50aedc8406e7c5
swconfig - 10
ubox - 2015-11-22-c086167a0154745c677f8730a336ea9cf7d71031
ubusd - 2015-05-25-f361bfa5fcb2daadf3b160583ce665024f8d108e
uhttpd - 2015-11-08-fe01ef3f52adae9da38ef47926cd50974af5d6b7
uhttpd-mod-ubus - 2015-11-08-fe01ef3f52adae9da38ef47926cd50974af5d6b7
usb-modeswitch - 2014-08-26-993a9a542791953c4804f7ddbb3a07756738e37a
usbutils - 007-1
usign - 2015-05-08-cf8dcdb8a4e874c77f3e9a8e9b643e8c17b19131
wpad-mini - 2015-03-25-1
xl2tpd - devel-20150930-1
zlib - 1.2.8-1
[свернуть]
Вроде все необходимое.
Я не очень разбираюсь в этих AT командах, но подумал почему отваливается после команды набора номера.. Послушал COM порт при подключении компьютера через билайновское приложение, что интересно там нет команд с точкой доступа логином и паролем? и команда набора номера "ATDT*99#" вместо "ATD*99***1#"
<20170705153710.824 TX>
AT [len=2]
<20170705153710.825 RX>
[len=0]
<LF>OK [len=3]
<LF>
<20170705153710.835 TX>
ATV1 [len=4]
<20170705153710.840 RX>
[len=0]
<LF>OK [len=3]
<LF>
<20170705153710.851 TX>
ATE0 [len=4]
<20170705153710.857 RX>
[len=0]
<LF>OK [len=3]
<LF>
<20170705153710.867 TX>
AT&F&D2&C1S0=0 [len=14]
<20170705153710.874 RX>
[len=0]
<LF>OK [len=3]
<LF>
<20170705153710.884 TX>
ATS7=60S30=0 [len=12]
<20170705153710.890 RX>
[len=0]
<LF>OK [len=3]
<LF>
<20170705153710.901 TX>
ATDT*99# [len=8]
<20170705153710.904 RX>
[len=0]
<LF>CONNECT 3600000 [len=16]
<LF>
[свернуть]
Может я что то не так понимаю? Или это не принципиально?
Спасибо!
Старый 05.07.2017, 18:24   #688
Вес репутации: 1602
Да, имхо тут с пакетами надо разбираться..
У вас dir 320
Удалите: kmod-usb3
Удалите: kmod-usb-uhci
Поставьте: kmod-usb-ohci
Попробуйте и смотрите дальше по инструкции:
Проверяем dmesg ("Kernel log" в LUCI):
Здесь возможно, чего то не хватает:
kmod-l2tp............................ Layer Two Tunneling Protocol (L2TP)
kmod-l2tp-eth................ L2TP ethernet pseudowire support for L2TPv3
kmod-l2tp-ip............................ L2TP IP encapsulation for L2TPv3
Ну да, но если вы настриваете впервые и есть возможность настроить из веб интерфейса, лучше делать этого из под вебинтерфейса.
Когда разберетесь, как оно должно работать, тогда уж лезть в конфиги
Я не настраивал себе 3g/4g - поэтому, конкретики не подскажу...
Надо пробовать...
Последний раз редактировалось sunny; 05.07.2017 в 20:37.
Старый 06.07.2017, 16:30   #689
vasya00
Внезапно соединение установилось с ttyUSB2, странно как тогда он с ttyUSB1 связывался и тот отвечал ОК.
Но на этом трудности не прекратились, соединение хоть и есть но очень плохое, жутко тормозит, куда то теряются пакеты:
Статистика Ping для 87.250.250.242:
Пакетов: отправлено = 100, получено = 80, потеряно = 20
(20% потерь)
Приблизительное время приема-передачи в мс:
Минимальное = 140мсек, Максимальное = 3120 мсек, Среднее = 601 мсек
Фактически скорость колеблется от 1 мбит/с до 0, при том на 0 лежит иногда долго. Соответственно связь хорошая и в том же месте, с тем же свистом в ноутбуке все отлично..
Команды почему то не идут
root@OpenWrt:~# gcom info -d /dev/ttyUSB2
##### Wireless WAN Modem Configuration #####
Product text:
comgt 13:15:52 -> -- Error Report --
comgt 13:15:52 -> ----> ^
comgt 13:15:52 -> Error @187, line 10, Could not write to COM device. (1)
root@OpenWrt:~# gcom -d /dev/ttyUSB2
comgt 13:16:15 -> -- Error Report --
comgt 13:16:15 -> ----> ^
comgt 13:16:15 -> Error @74, line 4, Could not write to COM device. (1)
Старый 06.07.2017, 16:48   #690
Вес репутации: 1602
Это уже прогресс
У вас не работало из-за kmod-usb-uhci - 3.18.23-1
После reboot-a ttyUSB2 - станет имхо ttyUSB0
После выполнения настроек, неплохо бы выполнить reboot.
Чтобы установить соединения автоматом на перезагруженном роутере...
Оpenwrt любит - reboot(команда перезагрузки)
Если вы сначала правили конфиги, а потом настроили через вебинтерфейс - то вполне вероятны ваши нынешние проблемы с нестабильной связью..
Последний раз редактировалось sunny; 06.07.2017 в 16:52.
Текущее время: 12:10. Часовой пояс GMT +3.
