Старый 10.01.2015, 02:35   #11
elik745i
По умолчанию Re: CyberWrt и HUB
вот тут
пишут, что нужен пакет kmod-usb-ohci для функционирования хаба, у меня он не установлен, да и поиск его не находит в доступных пакетах для установки, может в этом все дело?
Старый 10.01.2015, 03:05   #12
elik745i
вот что пишет команда dmesg в терминале:
root@CyberWrt:/www/> dmesg
[    0.000000] Linux version 3.10.4 (cyberwrt@cyberwrt) (gcc version 4.6.4 (OpenWrt/Linaro GCC 4.6-2012.12 r37816) ) #1 Mon Nov 18 00:53:16 MSK 2013
[    0.000000] MyLoader: sysp=388dd517, boardp=04505212, parts=7709ac36
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU revision is: 00019374 (MIPS 24Kc)
0.000000] SoC: Atheros AR9330 rev 1
[    0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
[    0.000000] Determined physical RAM map:
0.000000]  memory: 02000000 @ 00000000 (usable)
0.000000] Initrd not found or empty - disabling initrd
[    0.000000] Zone ranges:
0.000000]   Normal   [mem 0x00000000-0x01ffffff]
0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00000000-0x01ffffff]
0.000000] On node 0 totalpages: 8192
[    0.000000] free_area_init_node: node 0, pgdat 80320b60, node_mem_map 81000000
[    0.000000]   Normal zone: 64 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 8192 pages, LIFO batch:0
[    0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 8128
[    0.000000] Kernel command line:  board=TL-WR703N console=ttyATH0,115200 rootfstype=squashfs,jffs2 noinitrd
[    0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
0.000000] Writing ErrCtl register=00000000
[    0.000000] Readback ErrCtl register=00000000
[    0.000000] Memory: 28716k/32768k available (2305k kernel code, 4052k reserved, 602k data, 224k init, 0k highmem)
0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS:51
[    0.080000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
0.080000] pid_max: default: 32768 minimum: 301
[    0.080000] Mount-cache hash table entries: 512
[    0.090000] NET: Registered protocol family 16
[    0.100000] MIPS: machine is TP-LINK TL-WR703N v1
[    0.350000] bio: create slab  at 0
[    0.360000] Switching to clocksource MIPS
[    0.360000] NET: Registered protocol family 2
[    0.370000] TCP established hash table entries: 512 (order: 0, 4096 bytes)
0.370000] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
0.370000] TCP: Hash tables configured (established 512 bind 512)
0.380000] TCP: reno registered
[    0.380000] UDP hash table entries: 256 (order: 0, 4096 bytes)
0.390000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
0.400000] NET: Registered protocol family 1
[    0.400000] PCI: CLS 0 bytes, default 32
[    0.420000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.420000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
0.430000] msgmni has been set to 56
[    0.440000] io scheduler noop registered
[    0.440000] io scheduler deadline registered (default)
0.440000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    0.460000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) is a AR933X UART
[    0.460000] console [ttyATH0] enabled, bootconsole disabled
[    0.480000] ath79-spi ath79-spi: master is unqueued, this is deprecated
[    0.480000] m25p80 spi0.0: found s25sl032p, expected m25p80
[    0.490000] m25p80 spi0.0: s25sl032p (4096 Kbytes)
0.490000] 5 tp-link partitions found on MTD device spi0.0
[    0.500000] Creating 5 MTD partitions on "spi0.0":
0.500000] 0x000000000000-0x000000020000 : "u-boot"
[    0.510000] 0x000000020000-0x0000001227dc : "kernel"
[    0.510000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[    0.530000] 0x0000001227dc-0x0000003f0000 : "rootfs"
[    0.530000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[    0.550000] mtd: partition "rootfs" set to be root filesystem
[    0.550000] mtd: partition "rootfs_data" created automatically, ofs=0x280000, len=0x170000
[    0.560000] 0x000000280000-0x0000003f0000 : "rootfs_data"
[    0.570000] 0x0000003f0000-0x000000400000 : "art"
[    0.570000] 0x000000020000-0x0000003f0000 : "firmware"
[    0.590000] libphy: ag71xx_mdio: probed
[    0.590000] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode:MII
[    1.150000] ag71xx ag71xx.0 eth0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY]
1.160000] TCP: cubic registered
[    1.160000] NET: Registered protocol family 17
[    1.160000] Bridge firewalling registered
[    1.170000] 8021q: 802.1Q VLAN Support v1.8
[    1.180000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
[    1.190000] Freeing unused kernel memory: 224K (80338000 - 80370000)
2.930000] usbcore: registered new interface driver usbfs
[    2.940000] usbcore: registered new interface driver hub
[    2.940000] usbcore: registered new device driver usb
[    3.050000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.050000] ehci-platform: EHCI generic platform driver
[    3.060000] ehci-platform ehci-platform: EHCI Host Controller
[    3.060000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[    3.070000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[    3.100000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[    3.100000] hub 1-0:1.0: USB hub found
[    3.100000] hub 1-0:1.0: 1 port detected
[    3.450000] usb 1-1: new full-speed USB device number 2 using ehci-platform
[    3.600000] hub 1-1:1.0: USB hub found
[    3.610000] hub 1-1:1.0: 4 ports detected
[    3.900000] usb 1-1.1: new full-speed USB device number 3 using ehci-platform
[    4.010000] usb 1-1.1: not running at top speed; connect to a high speed hub
[    4.100000] usb 1-1.2: new full-speed USB device number 4 using ehci-platform
[    4.340000] usb 1-1.2: not running at top speed; connect to a high speed hub
[    4.430000] usb 1-1.3: new full-speed USB device number 5 using ehci-platform
[    4.640000] usb 1-1.4: new full-speed USB device number 6 using ehci-platform
[    4.760000] usb 1-1.4: not running at top speed; connect to a high speed hub
[    6.770000] jffs2: notice: (337) jffs2_build_xattr_subsystem: complete building xattr subsystem, 2 of xdatum (1 unchecked, 1 orphan) and 18 of xref (0 dead, 9 orphan) found.
6.930000] SCSI subsystem initialized
[    7.470000] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[    7.470000] scsi0 : usb-storage 1-1.1:1.0
[    7.480000] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[    7.480000] scsi1 : usb-storage 1-1.2:1.0
[    7.490000] usbcore: registered new interface driver usb-storage
[    8.480000] scsi 0:0:0:0: Direct-Access     ChipsBnk   Multi-Reader   4082 PQ: 0 ANSI: 2
[    8.500000] sd 0:0:0:0: [sda] 3973120 512-byte logical blocks: (2.03 GB/1.89 GiB)
8.510000] sd 0:0:0:0: [sda] Write Protect is off
[    8.510000] sd 0:0:0:0: [sda] Mode Sense: 0b 00 00 08
[    8.520000] sd 0:0:0:0: [sda] No Caching mode page present
[    8.520000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    8.550000] sd 0:0:0:0: [sda] No Caching mode page present
[    8.560000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    8.580000]  sda: sda1 sda2
[    8.600000] sd 0:0:0:0: [sda] No Caching mode page present
[    8.600000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    8.610000] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    9.000000] scsi 1:0:0:0: Direct-Access     General  USB Flash Disk   1100 PQ: 0 ANSI: 0 CCS
[    9.010000] sd 1:0:0:0: [sdb] 31506432 512-byte logical blocks: (16.1 GB/15.0 GiB)
9.020000] sd 1:0:0:0: [sdb] Write Protect is off
[    9.030000] sd 1:0:0:0: [sdb] Mode Sense: 43 00 00 00
[    9.030000] sd 1:0:0:0: [sdb] No Caching mode page present
[    9.030000] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[    9.060000] sd 1:0:0:0: [sdb] No Caching mode page present
[    9.070000] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[    9.080000]  sdb: sdb1 sdb2
[    9.100000] sd 1:0:0:0: [sdb] No Caching mode page present
[    9.100000] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[    9.110000] sd 1:0:0:0: [sdb] Attached SCSI removable disk
[   14.220000] EXT4-fs (sda1): recovery complete
[   14.230000] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts:
16.260000] Loading modules backported from Linux version master-2013-06-27-0-gdcfa6d5
[   16.270000] Backport generated by backports.git backports-20130617-4-ge3220f5
[   16.350000] cfg80211: Calling CRDA to update world regulatory domain
[   16.390000] cfg80211: World regulatory domain updated:
16.390000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
16.400000] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
16.400000] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
16.410000] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
16.420000] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
16.430000] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
17.050000] ath: EEPROM regdomain: 0x0
[   17.050000] ath: EEPROM indicates default country code should be used
[   17.050000] ath: doing EEPROM country->regdmn map search
[   17.050000] ath: country maps to regdmn code: 0x3a
[   17.050000] ath: Country alpha2 being used: US
[   17.050000] ath: Regpair used: 0x3a
[   17.070000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   17.070000] cfg80211: Calling CRDA for country: US
[   17.080000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
[   17.080000] cfg80211: Regulatory domain changed to country: US
[   17.090000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
17.100000] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
17.100000] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm)
17.110000] cfg80211:   (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
17.120000] cfg80211:   (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
17.130000] cfg80211:   (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
17.130000] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm)
17.280000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   17.330000] uhci_hcd: USB Universal Host Controller Interface driver
[   17.350000] i2c /dev entries driver
[   17.400000] usbcore: registered new interface driver usbserial
[   17.400000] usbcore: registered new interface driver usbserial_generic
[   17.410000] usbserial: USB Serial support registered for generic
[   17.580000] Linux video capture interface: v2.00
[   17.650000] usbcore: registered new interface driver ftdi_sio
[   17.650000] usbserial: USB Serial support registered for FTDI USB Serial Device
[   17.660000] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
[   17.680000] usb 1-1.3: Detected FT232RL
[   17.680000] usb 1-1.3: Number of endpoints 2
[   17.680000] usb 1-1.3: Endpoint 1 MaxPacketSize 16384
[   17.690000] usb 1-1.3: Endpoint 2 MaxPacketSize 16384
[   17.690000] usb 1-1.3: Setting MaxPacketSize 64
[   17.700000] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
[   17.900000] uvcvideo: Found UVC 1.00 device  (046d:0825)
18.000000] input: UVC Camera (046d:0825) as /devices/platform/ehci-platform/usb1/1-1/1-1.4/1-1.4:1.0/input/input0
[   18.020000] usbcore: registered new interface driver uvcvideo
[   18.020000] USB Video Class driver (1.1.1)
18.720000] uvcvideo: Failed to submit URB 0 (-28).
20.810000] uvcvideo: Failed to submit URB 0 (-28).
21.780000] device eth0 entered promiscuous mode
[   23.070000] Adding 131068k swap on /dev/sda2.  Priority:-1 extents:1 across:131068k
[   23.650000] Adding 131068k swap on /dev/sdb2.  Priority:-2 extents:1 across:131068k
[   26.890000] cfg80211: Calling CRDA for country: RU
[   26.910000] cfg80211: Regulatory domain changed to country: RU
[   26.910000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
26.920000] cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
26.930000] cfg80211:   (5735000 KHz - 5835000 KHz @ 20000 KHz), (N/A, 3000 mBm)
30.150000] wlan0: authenticate with 98:f5:37:7e:11:84
[   30.190000] wlan0: send auth to 98:f5:37:7e:11:84 (try 1/3)
30.190000] wlan0: authenticated
[   30.210000] ath9k ar933x_wmac wlan0: disabling HT/VHT due to WEP/TKIP use
30.220000] wlan0: associate with 98:f5:37:7e:11:84 (try 1/3)
30.220000] wlan0: RX AssocResp from 98:f5:37:7e:11:84 (capab=0x411 status=0 aid=2)
30.230000] wlan0: associated
[   37.560000] uvcvideo: Failed to submit URB 0 (-28).
42.510000] uvcvideo: Failed to submit URB 0 (-28).
46.190000] uvcvideo: Failed to submit URB 0 (-28).
Старый 10.01.2015, 04:05   #13
elik745i
Короче разобрался в 5 утра )))))
Проблема в слишком большом потоке, ни в питании, ни в чем то еще.
Выставил 320х240 и 10ФПС (это максимум) камера начала работать.....удивительÐ ½о но почему так слабо? вроде тот же хаб цепляю к компу все идет на максимальном разрешении 720П и 25и кадрах....
Пока загадка....
будем копать дальше...
Старый 11.01.2015, 00:06   #14
Alex19279
См. Фото.
У меня с данным роутером не завелся вот такой хаб.
Поменял на Ginnzu, тот который часто фигурирует при имплантации хаба внутрь роутера - и всё работает на максималке.
Попробуй поменять хаб.
Старый 11.01.2015, 03:23   #15
elik745i
См. Фото.
Попробую найти что нибудь завтра, кинз нету у нас тут, заказывать не охота... Думаю вы правы, но странно то, что комп понимает тот хаб, и камера с компом общается на ты.....
Вот бы еще вкрутить поддержку других камер, не только логитек, у меня тут еще 2 откопал старые, то было бы вообще супер.....
Старый 11.01.2015, 10:43   #16
age0811
age0811 is an unknown quantity at this point
Пока загадка....
Для примера. Камера Log 310 с хабом, приобретенным в магазине спонсора сайта https://duino.ru/product_info.php/in...centrator.html работает без проблем в максимально возможном разрешени. Без танцев, сразу.
Сейчас попробовал давно валяющийся пассивный хаб (весь такой цветной в виде раскладушки, KONOOS UK-06). Камера не работает ни в каком режиме. Переключил на прежний кардуиновский - все нормально.
age0811 вне форума   Ответить с цитированием
Старый 11.01.2015, 12:11   #17
elik745i
Сообщение от age0811 Посмотреть сообщение
Для примера. Камера Log 310 с хабом, приобретенным в магазине спонсора сайта работает без проблем в максимально возможном разрушении. Без танцев, сразу.
Сейчас попробовал давно валяющийся пассивный хаб (весь такой цветной в виде раскладушки, KONOOS UK-06). Камера не работает ни в каком режиме. Переключил на прежний ардуиновский - все нормально.
Попробуйте в самом низком разрешении на 5 ФПС, если пассивный хаб понимает игрушка, то должен работать...
Цпасибо за наводку, поддержу, чем смогу!
Старый 11.01.2015, 13:59   #18
age0811
Не понятно. Сейчас попробовал еще раз с этим хабом. Камера работает...
Старый 11.01.2015, 14:15   #19
Alex19279
Попробовал свой хаб нонейм, с камерой логитеч с200 - роутер не смог эту связку запустить (ставил разрешение 320х240 и 5 фпс), подключил следом гинзу - всё запустилось.
См. Фото применяемых контроллеров внутри хабов.
Изображения
Старый 11.01.2015, 19:20   #20
elik745i
Выкинул на ветер сегодня 5 баксов, купил хаб, вот такой
На упаковке, на хабе самом написано 100% поддержка, но на самом деле оказалась подделка, скорость закачки 1Мб/с не более. Жаль....надо комп брать, что бы в магазине проверять....
Текущее время: 12:20. Часовой пояс GMT +3.
