#11 |
Вес репутации: 1154 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
И
lsmod |grep pptp |
#12 |
Конфиг из поста№6, только поменял wwan3g на wwan
/etc/config/network Код:
config interface 'vpn' option ifname 'pptp-vpn' option proto 'pptp' option username '*******' option password '*******' option server 'vpn.lan2lan.ru' option buffering '1' option defaultroute '0' option peerdns '0' config route option interface 'vpn' option target '192.168.99.0' option gateway '46.38.52.90' option netmask '255.255.255.0' config interface 'wwan' option proto 'dhcp' Код:
config zone option name 'wan' option input 'REJECT' option output 'ACCEPT' option forward 'REJECT' option masq '1' option mtu_fix '1' option network 'wan wan6 wwan3g wwan' что кажет ifconfig Код:
root@OpenWrt:/# ifconfig
br-lan Link encap:Ethernet HWaddr 64:70:02:76:43:87
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1057 errors:0 dropped:0 overruns:0 frame:0
TX packets:863 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:116071 (113.3 KiB) TX bytes:469776 (458.7 KiB)
eth0 Link encap:Ethernet HWaddr 64:70:02:76:43:87
RX packets:1063 errors:0 dropped:6 overruns:0 frame:0
collisions:0 txqueuelen:1000
RX bytes:131229 (128.1 KiB) TX bytes:469776 (458.7 KiB)
Interrupt:4
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:37250 errors:0 dropped:0 overruns:0 frame:0
TX packets:37250 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2467746 (2.3 MiB) TX bytes:2467746 (2.3 MiB)
pptp-vpn Link encap:Point-to-Point Protocol
inet addr:192.168.99.1 P-t-P:46.38.52.90 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1320 Metric:1
RX packets:4 errors:0 dropped:0 overruns:0 frame:0
TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:3
RX bytes:58 (58.0 B) TX bytes:76 (76.0 B)
wlan0 Link encap:Ethernet HWaddr 64:70:02:76:43:87
inet addr:192.168.0.133 Bcast:192.168.0.255 Mask:255.255.255.0
RX packets:559 errors:0 dropped:99 overruns:0 frame:0
TX packets:278 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:48068 (46.9 KiB) TX bytes:26887 (26.2 KiB)
root@OpenWrt:/#
#13 |
lsmod | grep pptp:
root@CyberWrt:~# lsmod | grep pptp gre 1826 2 pptp,ip_gre, ppp_generic 19666 4 pptp,pppox,ppp_mppe,ppp_async, pppox 1322 1 pptp, pptp 13280 0 root@CyberWrt:~# Код:
root@CyberWrt:~# ifconfig
br-lan Link encap:Ethernet HWaddr 90:F6:52:B5:FB:02
inet addr:192.168.100.100 Bcast:192.168.100.255 Mask:255.255.255.0
inet6 addr: fe80::92f6:52ff:feb5:fb02/64 Scope:Link
inet6 addr: fdfc:4c91:1e6b::1/60 Scope:Global
RX packets:358 errors:0 dropped:0 overruns:0 frame:0
TX packets:411 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:30098 (29.3 KiB) TX bytes:70930 (69.2 KiB)
eth0 Link encap:Ethernet HWaddr 90:F6:52:B5:FB:02
RX bytes:35110 (34.2 KiB) TX bytes:70930 (69.2 KiB)
Interrupt:4
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:16 errors:0 dropped:0 overruns:0 frame:0
TX packets:16 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1648 (1.6 KiB) TX bytes:1648 (1.6 KiB)
wlan0 Link encap:Ethernet HWaddr 90:F6:52:B5:FB:02
inet addr:192.168.10.101 Bcast:192.168.10.255 Mask:255.255.255.0
RX packets:78 errors:0 dropped:0 overruns:0 frame:0
TX packets:90 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:7518 (7.3 KiB) TX bytes:10317 (10.0 KiB)
root@CyberWrt:~#
root@CyberWrt:~# dmesg [ 0.000000] Linux version 3.10.4 (cyberwrt@cyberwrt) (gcc version 4.6.4 (OpenWrt/Linaro GCC 4.6-2012.12 r37816) ) #1 Mon Nov 25 16:28:55 MSK 2013 [ 0.000000] MyLoader: sysp=7ab7c29c, boardp=07ac6486, parts=24fed496 [ 0.000000] bootconsole [early0] enabled [ 0.000000] CPU revision is: 00019374 (MIPS 24Kc) [ 0.000000] SoC: Atheros AR9330 rev 1 [ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz [ 0.000000] Determined physical RAM map: [ 0.000000] memory: 02000000 @ 00000000 (usable) [ 0.000000] Initrd not found or empty - disabling initrd [ 0.000000] Zone ranges: [ 0.000000] Normal [mem 0x00000000-0x01ffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x00000000-0x01ffffff] [ 0.000000] On node 0 totalpages: 8192 [ 0.000000] free_area_init_node: node 0, pgdat 80320b60, node_mem_map 81000000 [ 0.000000] Normal zone: 64 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 8192 pages, LIFO batch:0 [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes. [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128 [ 0.000000] Kernel command line: board=TL-MR3020 console=ttyATH0,115200 rootfstype=squashfs,jffs2 noinitrd [ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes) [ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Writing ErrCtl register=00000000 [ 0.000000] Readback ErrCtl register=00000000 [ 0.000000] Memory: 28716k/32768k available (2305k kernel code, 4052k reserved, 602k data, 224k init, 0k highmem) [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] NR_IRQS:51 [ 0.080000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104) [ 0.080000] pid_max: default: 32768 minimum: 301 [ 0.080000] Mount-cache hash table entries: 512 [ 0.090000] NET: Registered protocol family 16 [ 0.100000] MIPS: machine is TP-LINK TL-MR3020 [ 0.350000] bio: create slab <bio-0> at 0 [ 0.360000] Switching to clocksource MIPS [ 0.360000] NET: Registered protocol family 2 [ 0.370000] TCP established hash table entries: 512 (order: 0, 4096 bytes) [ 0.370000] TCP bind hash table entries: 512 (order: -1, 2048 bytes) [ 0.370000] TCP: Hash tables configured (established 512 bind 512) [ 0.380000] TCP: reno registered [ 0.380000] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.390000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.400000] NET: Registered protocol family 1 [ 0.400000] PCI: CLS 0 bytes, default 32 [ 0.420000] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.420000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc. [ 0.430000] msgmni has been set to 56 [ 0.440000] io scheduler noop registered [ 0.440000] io scheduler deadline registered (default) [ 0.440000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled [ 0.460000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) is a AR933X UART [ 0.460000] console [ttyATH0] enabled, bootconsole disabled [ 0.480000] ath79-spi ath79-spi: master is unqueued, this is deprecated [ 0.480000] m25p80 spi0.0: found w25q32, expected m25p80 [ 0.490000] m25p80 spi0.0: w25q32 (4096 Kbytes) [ 0.490000] 5 tp-link partitions found on MTD device spi0.0 [ 0.500000] Creating 5 MTD partitions on "spi0.0": [ 0.500000] 0x000000000000-0x000000020000 : "u-boot" [ 0.510000] 0x000000020000-0x000000122828 : "kernel" [ 0.510000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only [ 0.530000] 0x000000122828-0x0000003f0000 : "rootfs" [ 0.530000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only [ 0.540000] mtd: partition "rootfs" set to be root filesystem [ 0.550000] mtd: partition "rootfs_data" created automatically, ofs=0x280000, len=0x170000 [ 0.560000] 0x000000280000-0x0000003f0000 : "rootfs_data" [ 0.560000] 0x0000003f0000-0x000000400000 : "art" [ 0.570000] 0x000000020000-0x0000003f0000 : "firmware" [ 0.590000] libphy: ag71xx_mdio: probed [ 0.590000] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode:MII [ 1.150000] ag71xx ag71xx.0 eth0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY] [ 1.160000] TCP: cubic registered [ 1.160000] NET: Registered protocol family 17 [ 1.160000] Bridge firewalling registered [ 1.170000] 8021q: 802.1Q VLAN Support v1.8 [ 1.180000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2. [ 1.190000] Freeing unused kernel memory: 224K (80338000 - 80370000) [ 2.930000] usbcore: registered new interface driver usbfs [ 2.940000] usbcore: registered new interface driver hub [ 2.940000] usbcore: registered new device driver usb [ 3.050000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 3.050000] ehci-platform: EHCI generic platform driver [ 3.060000] ehci-platform ehci-platform: EHCI Host Controller [ 3.060000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1 [ 3.070000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000 [ 3.100000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00 [ 3.100000] hub 1-0:1.0: USB hub found [ 3.100000] hub 1-0:1.0: 1 port detected [ 3.450000] usb 1-1: new high-speed USB device number 2 using ehci-platform [ 6.230000] eth0: link up (100Mbps/Full duplex) [ 6.760000] jffs2: notice: (329) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 12 of xref (0 dead, 3 orphan) found. [ 6.800000] eth0: link down [ 8.230000] Loading modules backported from Linux version master-2013-06-27-0-gdcfa6d5 [ 8.240000] Backport generated by backports.git backports-20130617-4-ge3220f5 [ 8.270000] cfg80211: Calling CRDA to update world regulatory domain [ 8.270000] cfg80211: World regulatory domain updated: [ 8.280000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 8.280000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 8.290000] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm) [ 8.300000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm) [ 8.310000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 8.310000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 8.690000] NET: Registered protocol family 10 [ 9.200000] ath: EEPROM regdomain: 0x0 [ 9.200000] ath: EEPROM indicates default country code should be used [ 9.200000] ath: doing EEPROM country->regdmn map search [ 9.200000] ath: country maps to regdmn code: 0x3a [ 9.200000] ath: Country alpha2 being used: US [ 9.200000] ath: Regpair used: 0x3a [ 9.200000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht' [ 9.210000] cfg80211: Calling CRDA for country: US [ 9.220000] cfg80211: Regulatory domain changed to country: US [ 9.220000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 9.230000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm) [ 9.240000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm) [ 9.240000] cfg80211: (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 9.250000] cfg80211: (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 9.260000] cfg80211: (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 9.270000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm) [ 9.280000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2 [ 9.370000] PPP generic driver version 2.4.2 [ 9.440000] PPP MPPE Compression module registered [ 9.440000] gre: GRE over IPv4 demultiplexor driver [ 9.480000] ip_gre: GRE over IPv4 tunneling driver [ 9.500000] NET: Registered protocol family 24 [ 9.520000] PPTP driver version 0.8.5 [ 12.330000] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 12.330000] device eth0 entered promiscuous mode [ 12.340000] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready [ 13.300000] eth0: link up (100Mbps/Full duplex) [ 13.300000] br-lan: port 1(eth0) entered forwarding state [ 13.310000] br-lan: port 1(eth0) entered forwarding state [ 13.310000] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 13.320000] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready [ 15.310000] br-lan: port 1(eth0) entered forwarding state [ 17.400000] cfg80211: Calling CRDA for country: RU [ 17.410000] cfg80211: Regulatory domain changed to country: RU [ 17.410000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 17.420000] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 17.430000] cfg80211: (5735000 KHz - 5835000 KHz @ 20000 KHz), (N/A, 3000 mBm) [ 18.660000] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 20.790000] wlan0: authenticate with 20:7c:8f:98:d8:49 [ 20.830000] wlan0: send auth to 20:7c:8f:98:d8:49 (try 1/3) [ 20.830000] wlan0: authenticated [ 20.850000] wlan0: associate with 20:7c:8f:98:d8:49 (try 1/3) [ 20.860000] wlan0: RX AssocResp from 20:7c:8f:98:d8:49 (capab=0x431 status=0 aid=10) [ 20.870000] wlan0: associated [ 20.870000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready root@CyberWrt:~# |
#14 |
А как ругается на поднятие интерфейса руками, что нибудь типа ifconfig vpn up ? Что-то в Ваших логах нет и намека на PPTP :-(
#15 |
Поставьте вместо CyberWrt чистую прошивку Openwrt.
Или добавляйте в CyberWrt как минимум iptables, иначе пакеты вам что будет натить? Код:
root@CyberWrt:/# opkg list_installed base-files - 146-r37816 busybox - 1.19.4-7 dnsmasq - 2.66-3 dropbear - 2012.55-2 iw - 3.10-1 jshn - 2013-08-01-04f194aa8a04926fe7f2e42bbf9ba6c62d49339e kernel - 3.10.4-1-6910dd36396650e8ef41514cdbde550a kmod-ath - 3.10.4+2013-06-27-1 kmod-ath9k - 3.10.4+2013-06-27-1 kmod-ath9k-common - 3.10.4+2013-06-27-1 kmod-cfg80211 - 3.10.4+2013-06-27-1 kmod-crypto-aes - 3.10.4-1 kmod-crypto-arc4 - 3.10.4-1 kmod-crypto-core - 3.10.4-1 kmod-crypto-hash - 3.10.4-1 kmod-crypto-manager - 3.10.4-1 kmod-gpio-button-hotplug - 3.10.4-1 kmod-input-core - 3.10.4-1 kmod-leds-gpio - 3.10.4-1 kmod-ledtrig-default-on - 3.10.4-1 kmod-ledtrig-netdev - 3.10.4-1 kmod-ledtrig-timer - 3.10.4-1 kmod-lib-crc-ccitt - 3.10.4-1 kmod-lib-crc16 - 3.10.4-1 kmod-mac80211 - 3.10.4+2013-06-27-1 kmod-nls-base - 3.10.4-1 kmod-usb-core - 3.10.4-1 kmod-usb2 - 3.10.4-1 libblobmsg-json - 2013-08-01-04f194aa8a04926fe7f2e42bbf9ba6c62d49339e libc - 0.9.33.2-1 libgcc - 4.6-linaro-1 libjson-c - 0.11-2 libjson-script - 2013-08-01-04f194aa8a04926fe7f2e42bbf9ba6c62d49339e libnl-tiny - 0.1-3 libubox - 2013-08-01-04f194aa8a04926fe7f2e42bbf9ba6c62d49339e libubus - 2013-08-08-b20a8a01c7faea5bcc9d34d10dcf7736589021b8 libuci - 2013-06-11.1-1 mtd - 20 netifd - 2013-07-16-2674941b06c1ec67f1aff1bff9212e1372106641 opkg - 618-3 procd - 2013-08-16-85a5ce27f5f02e4ddab6916d69ba7f7375d289d4-1 uboot-envtools - 2013.07-rc1-2 ubox - 2013-08-16.1-5290ec879aa4d9f4192df00aad4434b0f0afa872 ubus - 2013-08-08-b20a8a01c7faea5bcc9d34d10dcf7736589021b8 ubusd - 2013-08-08-b20a8a01c7faea5bcc9d34d10dcf7736589021b8 uci - 2013-06-11.1-1 uhttpd - 2013-07-31-fae8886f8aa5d996c8de607abea8b677216549b5 wpad-mini - 20130807-1 root@CyberWrt:/# Последний раз редактировалось paulerr; 13.03.2014 в 21:32. |
#16 | |
root@CyberWrt:~# ifconfig vpn up ifconfig: SIOCGIFFLAGS: No such device root@CyberWrt:~# lsmod |grep pptp это подтверждает: Код:
root@CyberWrt:~# lsmod | grep pptp gre 1826 2 pptp,ip_gre, ppp_generic 19666 4 pptp,pppox,ppp_mppe,ppp_async, pppox 1322 1 pptp, pptp 13280 0 root@CyberWrt:~# |
#17 |
Здравствуйте!
Помогите поднять на cyberwrt ifconfig vpn up Код:
root@CyberWrt:/www/> ifconfig vpn up ifconfig: SIOCGIFFLAGS: No such device Код:
root@CyberWrt:/www/> lsmod |grep pptp pptp 13280 0 pppox 1322 1 pptp gre 1826 2 pptp,ip_gre ppp_generic 19666 4 pptp,pppox,ppp_mppe,ppp_async Код:
root@CyberWrt:/www/> opkg list-installed base-files - 146-r37816 block-mount - 2013-08-16.1-5290ec879aa4d9f4192df00aad4434b0f0afa872 busybox - 1.19.4-7 coreutils - 8.16-1 coreutils-base64 - 8.16-1 coreutils-stty - 8.16-1 davfs2 - 1.4.7-2 dnsmasq - 2.66-3 dropbear - 2012.55-2 e2fsprogs - 1.42.4-1 fdisk - 2.21.2-2 firewall - 2013-08-14 iptables - 1.4.19.1-2 iw - 3.10-1 jshn - 2013-08-01-04f194aa8a04926fe7f2e42bbf9ba6c62d49339e kernel - 3.10.4-1-6910dd36396650e8ef41514cdbde550a kmod-ath - 3.10.4+2013-06-27-1 kmod-ath9k - 3.10.4+2013-06-27-1 kmod-ath9k-common - 3.10.4+2013-06-27-1 kmod-cfg80211 - 3.10.4+2013-06-27-1 kmod-crypto-aes - 3.10.4-1 kmod-crypto-arc4 - 3.10.4-1 kmod-crypto-core - 3.10.4-1 kmod-crypto-ecb - 3.10.4-1 kmod-crypto-hash - 3.10.4-1 kmod-crypto-manager - 3.10.4-1 kmod-crypto-sha1 - 3.10.4-1 kmod-fs-ext4 - 3.10.4-1 kmod-fuse - 3.10.4-1 kmod-gpio-button-hotplug - 3.10.4-1 kmod-gre - 3.10.4-1 kmod-hid - 3.10.4-1 kmod-hid-generic - 3.10.4-1 kmod-i2c-core - 3.10.4-1 kmod-input-core - 3.10.4-1 kmod-input-evdev - 3.10.4-1 kmod-ipt-conntrack - 3.10.4-1 kmod-ipt-core - 3.10.4-1 kmod-ipt-nat - 3.10.4-1 kmod-iptunnel - 3.10.4-1 kmod-ipv6 - 3.10.4-1 kmod-leds-gpio - 3.10.4-1 kmod-ledtrig-default-on - 3.10.4-1 kmod-ledtrig-netdev - 3.10.4-1 kmod-ledtrig-timer - 3.10.4-1 kmod-lib-crc-ccitt - 3.10.4-1 kmod-lib-crc16 - 3.10.4-1 kmod-mac80211 - 3.10.4+2013-06-27-1 kmod-mppe - 3.10.4-1 kmod-nls-base - 3.10.4-1 kmod-ppp - 3.10.4-1 kmod-pppox - 3.10.4-1 kmod-pptp - 3.10.4-1 kmod-scsi-core - 3.10.4-1 kmod-slhc - 3.10.4-1 kmod-sound-core - 3.10.4-1 kmod-usb-audio - 3.10.4-1 kmod-usb-core - 3.10.4-1 kmod-usb-hid - 3.10.4-1 kmod-usb-serial - 3.10.4-1 kmod-usb-serial-cp210x - 3.10.4-1 kmod-usb-storage - 3.10.4-1 kmod-usb2 - 3.10.4-1 kmod-video-core - 3.10.4-1 kmod-video-uvc - 3.10.4-1 kmod-video-videobuf2 - 3.10.4-1 libblkid - 2.21.2-2 libblobmsg-json - 2013-08-01-04f194aa8a04926fe7f2e42bbf9ba6c62d49339e libc - 0.9.33.2-1 libexpat - 2.0.1-1 libext2fs - 1.42.4-1 libfuse - 2.9.0-2 libgcc - 4.6-linaro-1 libid3tag - 0.15.1b-3 libip4tc - 1.4.19.1-2 libip6tc - 1.4.19.1-2 libiwinfo - 46 libiwinfo-lua - 46 libjpeg - 6b-1 libjson-c - 0.11-2 libjson-script - 2013-08-01-04f194aa8a04926fe7f2e42bbf9ba6c62d49339e liblua - 5.1.5-1 libmad - 0.15.1b-3 libneon - 0.29.6-2 libnl-tiny - 0.1-3 libopenssl - 1.0.1e-2 libpthread - 0.9.33.2-1 libubox - 2013-08-01-04f194aa8a04926fe7f2e42bbf9ba6c62d49339e libubus - 2013-08-08-b20a8a01c7faea5bcc9d34d10dcf7736589021b8 libubus-lua - 2013-08-08-b20a8a01c7faea5bcc9d34d10dcf7736589021b8 libuci - 2013-06-11.1-1 libuci-lua - 2013-06-11.1-1 libuuid - 2.21.2-2 libxtables - 1.4.19.1-2 lua - 5.1.5-1 luci - svn-r9933-1 luci-app-firewall - svn-r9933-1 luci-i18n-english - svn-r9933-1 luci-i18n-russian - svn-r9933-1 luci-lib-core - svn-r9933-1 luci-lib-ipkg - svn-r9933-1 luci-lib-nixio - svn-r9933-1 luci-lib-sys - svn-r9933-1 luci-lib-web - svn-r9933-1 luci-mod-admin-core - svn-r9933-1 luci-mod-admin-full - svn-r9933-1 luci-proto-core - svn-r9933-1 luci-proto-ppp - svn-r9933-1 luci-proto-relay - svn-r9933-1 luci-sgi-cgi - svn-r9933-1 luci-theme-base - svn-r9933-1 luci-theme-bootstrap - svn-r9933-1 madplay - 0.15.2b-3 mjpg-streamer - r181-1 mtd - 20 netifd - 2013-07-16-2674941b06c1ec67f1aff1bff9212e1372106641 opkg - 618-3 ppp-mod-pptp - 2.4.5-10 procd - 2013-08-16-85a5ce27f5f02e4ddab6916d69ba7f7375d289d4-1 relayd - 2011-10-24-4e8f1fa4ca2b176500362843a9e57ea5abd4b7a3 resolveip - 2 ssmtp - 2.64-4 uboot-envtools - 2013.07-rc1-2 ubox - 2013-08-16.1-5290ec879aa4d9f4192df00aad4434b0f0afa872 ubus - 2013-08-08-b20a8a01c7faea5bcc9d34d10dcf7736589021b8 ubusd - 2013-08-08-b20a8a01c7faea5bcc9d34d10dcf7736589021b8 uci - 2013-06-11.1-1 uhttpd - 2013-07-31-fae8886f8aa5d996c8de607abea8b677216549b5 uhttpd-mod-ubus - 2013-07-31-fae8886f8aa5d996c8de607abea8b677216549b5 wpad-mini - 20130807-1 zlib - 1.2.8-1 |
#18 |
А вот при таком раскладе я стал онлайн, но состыковать два клиента пока не получилось.
root@CyberWrt:/www/> opkg list-installed base-files - 146-r37816 block-mount - 2013-08-16.1-5290ec879aa4d9f4192df00aad4434b0f0afa872 busybox - 1.19.4-7 coreutils - 8.16-1 coreutils-base64 - 8.16-1 coreutils-stty - 8.16-1 davfs2 - 1.4.7-2 dnsmasq - 2.66-3 dropbear - 2012.55-2 e2fsprogs - 1.42.4-1 fdisk - 2.21.2-2 firewall - 2013-08-14 iptables - 1.4.19.1-2 iw - 3.10-1 jshn - 2013-08-01-04f194aa8a04926fe7f2e42bbf9ba6c62d49339e kernel - 3.10.4-1-6910dd36396650e8ef41514cdbde550a kmod-ath - 3.10.4+2013-06-27-1 kmod-ath9k - 3.10.4+2013-06-27-1 kmod-ath9k-common - 3.10.4+2013-06-27-1 kmod-cfg80211 - 3.10.4+2013-06-27-1 kmod-crypto-aes - 3.10.4-1 kmod-crypto-arc4 - 3.10.4-1 kmod-crypto-core - 3.10.4-1 kmod-crypto-ecb - 3.10.4-1 kmod-crypto-hash - 3.10.4-1 kmod-crypto-manager - 3.10.4-1 kmod-crypto-sha1 - 3.10.4-1 kmod-fs-ext4 - 3.10.4-1 kmod-fuse - 3.10.4-1 kmod-gpio-button-hotplug - 3.10.4-1 kmod-gre - 3.10.4-1 kmod-hid - 3.10.4-1 kmod-hid-generic - 3.10.4-1 kmod-i2c-core - 3.10.4-1 kmod-input-core - 3.10.4-1 kmod-input-evdev - 3.10.4-1 kmod-ipt-conntrack - 3.10.4-1 kmod-ipt-core - 3.10.4-1 kmod-ipt-nat - 3.10.4-1 kmod-iptunnel - 3.10.4-1 kmod-ipv6 - 3.10.4-1 kmod-leds-gpio - 3.10.4-1 kmod-ledtrig-default-on - 3.10.4-1 kmod-ledtrig-netdev - 3.10.4-1 kmod-ledtrig-timer - 3.10.4-1 kmod-lib-crc-ccitt - 3.10.4-1 kmod-lib-crc16 - 3.10.4-1 kmod-mac80211 - 3.10.4+2013-06-27-1 kmod-mppe - 3.10.4-1 kmod-nls-base - 3.10.4-1 kmod-ppp - 3.10.4-1 kmod-pppox - 3.10.4-1 kmod-pptp - 3.10.4-1 kmod-scsi-core - 3.10.4-1 kmod-slhc - 3.10.4-1 kmod-sound-core - 3.10.4-1 kmod-usb-audio - 3.10.4-1 kmod-usb-core - 3.10.4-1 kmod-usb-hid - 3.10.4-1 kmod-usb-serial - 3.10.4-1 kmod-usb-serial-cp210x - 3.10.4-1 kmod-usb-storage - 3.10.4-1 kmod-usb2 - 3.10.4-1 kmod-video-core - 3.10.4-1 kmod-video-uvc - 3.10.4-1 kmod-video-videobuf2 - 3.10.4-1 libblkid - 2.21.2-2 libblobmsg-json - 2013-08-01-04f194aa8a04926fe7f2e42bbf9ba6c62d49339e libc - 0.9.33.2-1 libexpat - 2.0.1-1 libext2fs - 1.42.4-1 libfuse - 2.9.0-2 libgcc - 4.6-linaro-1 libid3tag - 0.15.1b-3 libip4tc - 1.4.19.1-2 libip6tc - 1.4.19.1-2 libiwinfo - 46 libiwinfo-lua - 46 libjpeg - 6b-1 libjson-c - 0.11-2 libjson-script - 2013-08-01-04f194aa8a04926fe7f2e42bbf9ba6c62d49339e liblua - 5.1.5-1 libmad - 0.15.1b-3 libneon - 0.29.6-2 libnl-tiny - 0.1-3 libopenssl - 1.0.1e-2 libpthread - 0.9.33.2-1 libubox - 2013-08-01-04f194aa8a04926fe7f2e42bbf9ba6c62d49339e libubus - 2013-08-08-b20a8a01c7faea5bcc9d34d10dcf7736589021b8 libubus-lua - 2013-08-08-b20a8a01c7faea5bcc9d34d10dcf7736589021b8 libuci - 2013-06-11.1-1 libuci-lua - 2013-06-11.1-1 libuuid - 2.21.2-2 libxtables - 1.4.19.1-2 lua - 5.1.5-1 luci - svn-r9933-1 luci-app-firewall - svn-r9933-1 luci-i18n-english - svn-r9933-1 luci-i18n-russian - svn-r9933-1 luci-lib-core - svn-r9933-1 luci-lib-ipkg - svn-r9933-1 luci-lib-nixio - svn-r9933-1 luci-lib-sys - svn-r9933-1 luci-lib-web - svn-r9933-1 luci-mod-admin-core - svn-r9933-1 luci-mod-admin-full - svn-r9933-1 luci-proto-core - svn-r9933-1 luci-proto-ppp - svn-r9933-1 luci-proto-relay - svn-r9933-1 luci-sgi-cgi - svn-r9933-1 luci-theme-base - svn-r9933-1 luci-theme-bootstrap - svn-r9933-1 luci-theme-openwrt - svn-r9933-1 madplay - 0.15.2b-3 mjpg-streamer - r181-1 mtd - 20 netifd - 2013-07-16-2674941b06c1ec67f1aff1bff9212e1372106641 opkg - 618-3 ppp - 2.4.5-10 ppp-mod-pptp - 2.4.5-10 procd - 2013-08-16-85a5ce27f5f02e4ddab6916d69ba7f7375d289d4-1 relayd - 2011-10-24-4e8f1fa4ca2b176500362843a9e57ea5abd4b7a3 resolveip - 2 ssmtp - 2.64-4 uboot-envtools - 2013.07-rc1-2 ubox - 2013-08-16.1-5290ec879aa4d9f4192df00aad4434b0f0afa872 ubus - 2013-08-08-b20a8a01c7faea5bcc9d34d10dcf7736589021b8 ubusd - 2013-08-08-b20a8a01c7faea5bcc9d34d10dcf7736589021b8 uci - 2013-06-11.1-1 uhttpd - 2013-07-31-fae8886f8aa5d996c8de607abea8b677216549b5 uhttpd-mod-ubus - 2013-07-31-fae8886f8aa5d996c8de607abea8b677216549b5 wpad-mini - 20130807-1 zlib - 1.2.8-1 |
#19 |
У вас клиент поднимается? А что пишется в логах?
#20 |
Вроде вот это кусок
Mon Mar 31 18:58:33 2014 daemon.info sysinit: - init complete - Mon Mar 31 18:58:33 2014 daemon.info pppd[28029]: Plugin pptp.so loaded. Mon Mar 31 18:58:33 2014 daemon.info pppd[28029]: PPTP plugin version 1.00 Mon Mar 31 18:58:33 2014 daemon.error pppd[28029]: pppd 2.4.5 started by root, uid 0 Mon Mar 31 18:58:36 2014 daemon.info pppd[28029]: Using interface pptp-vpn Mon Mar 31 18:58:36 2014 daemon.error pppd[28029]: Connect: pptp-vpn <--> pptp (vpn.lan2lan.ru) Mon Mar 31 18:58:40 2014 daemon.info pppd[28029]: CHAP authentication succeeded Mon Mar 31 18:58:40 2014 daemon.error pppd[28029]: CHAP authentication succeeded Mon Mar 31 18:58:42 2014 daemon.error pppd[28029]: local IP address 192.168.99.1 Mon Mar 31 18:58:42 2014 daemon.error pppd[28029]: remote IP address 46.38.52.90 Mon Mar 31 18:58:42 2014 daemon.error netifd: Interface 'vpn' is now up Mon Mar 31 18:58:42 2014 authpriv.error firewall: Reloading firewall due to ifup of vpn (pptp-vpn) Mon Mar 31 18:58:54 2014 daemon.info pppd[28029]: System time change detected. |
| Здесь присутствуют: 2 (пользователей: 0 , гостей: 2) | |
| Опции просмотра | |
