31.10.2015, 01:23 | #41 |
Вес репутации: 989 |
Re: Компиляция стороннего пакета для openwrt
sunny, Вылетает что-то davfs2 (из архива, ничего не правил) compile, в чём может быть проблема?
make[3] -C feeds/packages/net/davfs2 compile bash: /home/user/openwrt/BB_42625_ar71/staging_dir/host/bin/gettext: No such file or directory autoreconf: Entering directory `.' autoreconf: running: true --force autoreconf: running: /home/user/openwrt/BB_42625_ar71/staging_dir/host/bin/aclocal -I /home/user/openwrt/BB_42625_ar71/staging_dir/target-mips_34kc_uClibc-0.9.33.2/host/share/aclocal -I /home/user/openwrt/BB_42625_ar71/staging_dir/target-mips_34kc_uClibc-0.9.33.2/usr/share/aclocal -I m4 -I . --force -I config autoreconf: configure.ac: tracing autoreconf: configure.ac: not using Libtool autoreconf: running: /home/user/openwrt/BB_42625_ar71/staging_dir/host/bin/autoconf --include=/home/user/openwrt/BB_42625_ar71/staging_dir/target-mips_34kc_uClibc-0.9.33.2/host/share/aclocal --include=/home/user/openwrt/BB_42625_ar71/staging_dir/target-mips_34kc_uClibc-0.9.33.2/usr/share/aclocal --include=m4 --include=. --prepend-include=/home/user/openwrt/BB_42625_ar71/staging_dir/host/share/aclocal --force autoreconf: running: /home/user/openwrt/BB_42625_ar71/staging_dir/host/bin/autoheader --include=/home/user/openwrt/BB_42625_ar71/staging_dir/target-mips_34kc_uClibc-0.9.33.2/host/share/aclocal --include=/home/user/openwrt/BB_42625_ar71/staging_dir/target-mips_34kc_uClibc-0.9.33.2/usr/share/aclocal --include=m4 --include=. --prepend-include=/home/user/openwrt/BB_42625_ar71/staging_dir/host/share/aclocal --force autoreconf: running: /home/user/openwrt/BB_42625_ar71/staging_dir/host/bin/automake --add-missing --force-missing man/Makefile.am:53: `%'-style pattern rules are a GNU make extension man/de/Makefile.am:52: `%'-style pattern rules are a GNU make extension man/es/Makefile.am:53: `%'-style pattern rules are a GNU make extension autoreconf: Leaving directory `.' bash: /home/user/openwrt/BB_42625_ar71/staging_dir/host/bin/autopoint: No such file or directory make[3]: *** [/home/user/openwrt/BB_42625_ar71/build_dir/target-mips_34kc_uClibc-0.9.33.2/davfs2-1.5.2/.configured_] Error 127 make[2]: *** [package/feeds/packages/davfs2/compile] Error 2 make[1]: *** [/home/user/openwrt/BB_42625_ar71/staging_dir/target-mips_34kc_uClibc-0.9.33.2/stamp/.package_compile] Error 2 make -r world: build failed. Please re-run make with V=s to see what's going on make: *** [world] Ошибка 1 user@(none):~/openwrt/BB_42625_ar71$ |
31.10.2015, 01:30 | #42 |
Вес репутации: 1600 |
bash: /home/user/openwrt/BB_42625_ar71/staging_dir/host/bin/gettext: No such file or directory autoreconf: configure.ac: not using Libtool Я писал сюда: https://dev.openwrt.org/ticket/20770 Здесь: https://dev.openwrt.org/newticket Копируешь текст и описываешь свою проблему, выше мой образец. Тупо копировал последние строки из терминала -начиная с ошибки. Правили в течении 2-ух часов. Появляется здесь: https://dev.openwrt.org/query?status...port=12&desc=1 Разрабы смотрят и правят, сейчас "в Европах" не спят, так что пиши В принципе он все пишет: Please re-run make with V=s to see what's going on нужно внимательнее читать и или выполнять или писать туда Последний раз редактировалось sunny; 31.10.2015 в 01:41. |
31.10.2015, 04:36 | #43 |
Ок, 20836#ticket , ток тег code {{{ }}} не подрубился в сообщении
P.S. Думаю надо курить в сторону отсутствующих lib, которых в BB нет по умолчанию, версию neon поднял до libneon_0.30.0 (как в СС) - ошибка осталась. sunny, Кстати совет - в makefile зря меняешь пути на dl/* - это лишнее, при компиляции, по умолчание оттуда файлы беруться, если например ссылка просрочена или связи нет Последний раз редактировалось sakatgg; 31.10.2015 в 14:13. |
01.11.2015, 23:11 | #44 |
Взял davfs2 (Makefile & patches) из комплекта AA yohimba_buildroot, тут маленько написано, скомпилировался нормально на Barrier Breaker версия davfs2_1.4.7-3, запись на disk.yandex нормально пашет фотки скидывает моментом
Прикладываю feed davfs2, может кому пригодиться для компиляции Последний раз редактировалось sakatgg; 01.11.2015 в 23:44. |
01.11.2015, 23:49 | #45 | |
А камера у тебя какая ? Разрешение ? В принципе если в motion.conf ffmpeg_bps 200000 ffmpeg_video_codec swf Как в первоисточнике: http://sheldor.blogspot.com.br/2013/...53876459402197 Можно еще разрешение уменьшить и фото отключить - это позволит увеличить fsp готовых роликов и уменьшить нагрузку на железо. Кстати еще можно скомпилировать так: http://denisyuriev.ru/linux/openwrt-...iz-isxodnikov/ Цитата:
http://wiki.openwrt.org/toh/netgear/wndr3800 Последний раз редактировалось sunny; 01.11.2015 в 23:58. |
01.11.2015, 23:57 | #46 |
Логитечи С110,С270,С510 (последняя по качеству наилучшая).
01.11.2015, 23:58 | #47 |
А на кол-ве fsp готовых роликов это как-то сказывается ?
Применение с510 скажем ? Смотреть в свойствах файла |
02.11.2015, 00:01 | #48 |
Это от параметра
framerate 15 зависит, сколько поставишь сток и будет, не более 30 естественно Последний раз редактировалось sakatgg; 02.11.2015 в 00:04. |
02.11.2015, 00:07 | #49 |
А v4l2_palette - какой ставишь в конфиг motion ?
=== Пошел я пожалуй за логитеком https://www.avito.ru/moskva/tovary_d...haya_409577908 |
02.11.2015, 00:08 | #50 |
v4l2_palette 15, но тренируюсь на С110
P.S. Сегодня еще вычислил почему компиляция вываливается на одном компе, частоту памяти (4 x 2Gb) снизил с 400 до 333 - вылеты прекратились хотя мемтест на 400 гонял без ошибок, компиляция очень чувствительна к разгону и глючному железу P.S. Подскажите, запускаю davfs2 в терминале, всё пучком Код:
yes | mount.davfs https://webdav.yandex.ru /mnt Последний раз редактировалось sakatgg; 02.11.2015 в 01:35. |
