Старый 15.03.2016, 23:13   #41
Вес репутации: 1030
По умолчанию Re: Buildroot openwrt напрокат?!
make[3]: Entering directory `/home/user/openwrt/barrier_breaker/openwrt/feeds/oldpackages/libs/libIDL2'
CFLAGS="-Os -pipe -march=i486 -fno-caller-saves -fhonour-copts -Wno-error=unused-but-set-variable -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libiconv-full/include -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libintl-full/include -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/include -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/include -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/toolchain-i386_i486_gcc-4.8-linaro_uClibc-0.9.33.2/usr/include -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/toolchain-i386_i486_gcc-4.8-linaro_uClibc-0.9.33.2/include -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libiconv-full/include -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libintl-full/include " CXXFLAGS="-Os -pipe -march=i486 -fno-caller-saves -fhonour-copts -Wno-error=unused-but-set-variable -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libiconv-full/include -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libintl-full/include -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/include -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/include -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/toolchain-i386_i486_gcc-4.8-linaro_uClibc-0.9.33.2/usr/include -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/toolchain-i386_i486_gcc-4.8-linaro_uClibc-0.9.33.2/include -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libiconv-full/include -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libintl-full/include " LDFLAGS="-L/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib -L/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/lib -L/home/user/openwrt/barrier_breaker/openwrt/staging_dir/toolchain-i386_i486_gcc-4.8-linaro_uClibc-0.9.33.2/usr/lib -L/home/user/openwrt/barrier_breaker/openwrt/staging_dir/toolchain-i386_i486_gcc-4.8-linaro_uClibc-0.9.33.2/lib -L/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libiconv-full/lib -L/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libintl-full/lib " make -j1 -C /home/user/openwrt/barrier_breaker/openwrt/build_dir/target-i386_i486_uClibc-0.9.33.2/libIDL-0.8.13/. AR=i486-openwrt-linux-uclibc-ar AS="i486-openwrt-linux-uclibc-gcc -c -Os -pipe -march=i486 -fno-caller-saves -fhonour-copts -Wno-error=unused-but-set-variable -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libiconv-full/include -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libintl-full/include" LD=i486-openwrt-linux-uclibc-ld NM=i486-openwrt-linux-uclibc-nm CC="i486-openwrt-linux-uclibc-gcc" GCC="i486-openwrt-linux-uclibc-gcc" CXX="i486-openwrt-linux-uclibc-g++" RANLIB=i486-openwrt-linux-uclibc-ranlib STRIP=i486-openwrt-linux-uclibc-strip OBJCOPY=i486-openwrt-linux-uclibc-objcopy OBJDUMP=i486-openwrt-linux-uclibc-objdump SIZE=i486-openwrt-linux-uclibc-size CROSS="i486-openwrt-linux-uclibc-" ARCH="i386" ;
make[4]: Entering directory `/home/user/openwrt/barrier_breaker/openwrt/build_dir/target-i386_i486_uClibc-0.9.33.2/libIDL-0.8.13'
make all-recursive
make[5]: Entering directory `/home/user/openwrt/barrier_breaker/openwrt/build_dir/target-i386_i486_uClibc-0.9.33.2/libIDL-0.8.13'
Making all in include
make[6]: Entering directory `/home/user/openwrt/barrier_breaker/openwrt/build_dir/target-i386_i486_uClibc-0.9.33.2/libIDL-0.8.13/include'
Making all in libIDL
make[7]: Entering directory `/home/user/openwrt/barrier_breaker/openwrt/build_dir/target-i386_i486_uClibc-0.9.33.2/libIDL-0.8.13/include/libIDL'
make all-am
make[8]: Entering directory `/home/user/openwrt/barrier_breaker/openwrt/build_dir/target-i386_i486_uClibc-0.9.33.2/libIDL-0.8.13/include/libIDL'
make[8]: Nothing to be done for `all-am'.
make[8]: Leaving directory `/home/user/openwrt/barrier_breaker/openwrt/build_dir/target-i386_i486_uClibc-0.9.33.2/libIDL-0.8.13/include/libIDL'
make[7]: Leaving directory `/home/user/openwrt/barrier_breaker/openwrt/build_dir/target-i386_i486_uClibc-0.9.33.2/libIDL-0.8.13/include/libIDL'
make[7]: Entering directory `/home/user/openwrt/barrier_breaker/openwrt/build_dir/target-i386_i486_uClibc-0.9.33.2/libIDL-0.8.13/include'
make[7]: Nothing to be done for `all-am'.
make[7]: Leaving directory `/home/user/openwrt/barrier_breaker/openwrt/build_dir/target-i386_i486_uClibc-0.9.33.2/libIDL-0.8.13/include'
make[6]: Leaving directory `/home/user/openwrt/barrier_breaker/openwrt/build_dir/target-i386_i486_uClibc-0.9.33.2/libIDL-0.8.13/include'
make[6]: Entering directory `/home/user/openwrt/barrier_breaker/openwrt/build_dir/target-i386_i486_uClibc-0.9.33.2/libIDL-0.8.13'
/bin/bash ./libtool --tag=CC --mode=link i486-openwrt-linux-uclibc-gcc -Os -pipe -march=i486 -fno-caller-saves -fhonour-copts -Wno-error=unused-but-set-variable -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libiconv-full/include -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libintl-full/include -L/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib -L/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/lib -L/home/user/openwrt/barrier_breaker/openwrt/staging_dir/toolchain-i386_i486_gcc-4.8-linaro_uClibc-0.9.33.2/usr/lib -L/home/user/openwrt/barrier_breaker/openwrt/staging_dir/toolchain-i386_i486_gcc-4.8-linaro_uClibc-0.9.33.2/lib -L/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libiconv-full/lib -L/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libintl-full/lib -o tstidl tstidl.o libIDL-2.la -L/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib -lglib-2.0 -lintl
OpenWrt-libtool: link: i486-openwrt-linux-uclibc-gcc -Os -pipe -march=i486 -fno-caller-saves -fhonour-copts -Wno-error=unused-but-set-variable -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libiconv-full/include -I/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libintl-full/include -o .libs/tstidl tstidl.o -L/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib -L/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/lib -L/home/user/openwrt/barrier_breaker/openwrt/staging_dir/toolchain-i386_i486_gcc-4.8-linaro_uClibc-0.9.33.2/usr/lib -L/home/user/openwrt/barrier_breaker/openwrt/staging_dir/toolchain-i386_i486_gcc-4.8-linaro_uClibc-0.9.33.2/lib -L/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libiconv-full/lib -L/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libintl-full/lib ./.libs/libIDL-2.so -lglib-2.0 -lintl
/home/user/openwrt/barrier_breaker/openwrt/staging_dir/toolchain-i386_i486_gcc-4.8-linaro_uClibc-0.9.33.2/lib/gcc/i486-openwrt-linux-uclibc/4.8.3/../../../../i486-openwrt-linux-uclibc/bin/ld: warning: libiconv.so.2, needed by /home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libglib-2.0.so, not found (try using -rpath or -rpath-link)
/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libglib-2.0.so: undefined reference to `libiconv'
/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libglib-2.0.so: undefined reference to `libiconv_open'
/home/user/openwrt/barrier_breaker/openwrt/staging_dir/target-i386_i486_uClibc-0.9.33.2/usr/lib/libglib-2.0.so: undefined reference to `libiconv_close'
collect2: error: ld returned 1 exit status
make[6]: *** [tstidl] Error 1
make[6]: Leaving directory `/home/user/openwrt/barrier_breaker/openwrt/build_dir/target-i386_i486_uClibc-0.9.33.2/libIDL-0.8.13'
Нифига не понимаю...3 раза запускал компиляцию 3 раза ошибки. Но разные....
Последний на сегодня вариант сохраню на память.
Текущее время: 16:40. Часовой пояс GMT +3.
