Старый 05.09.2013, 14:11   #81
Ромка
Ромка is an unknown quantity at this point
Вот сам сгенерированный скетч уже не проходит ,даже без правки IK команд
#if defined(ARDUINO) && ARDUINO >= 100
  #include "Arduino.h"
  #include "SoftwareSerial.h"
SoftwareSerial port(12,13);
#else // Arduino 0022 - use modified NewSoftSerial
  #include "WProgram.h"
  #include "NewSoftSerial.h"
NewSoftSerial port(12,13);
#endif
#include "EasyVR.h"
EasyVR easyvr(port);
//Groups and Commands
enum Groups
GROUP_0  0,
GROUP_1  1,
GROUP_2  2,
GROUP_3  3,
enum Group0
G0_EVA 0,
enum Group1
G1_SWITH 0,
G1_KOMPUTER 1,
G1_EVA 2,
enum Group2
G2_ON 0,
G2_OFF 1,
enum Group3
G3_LIGHT 0,
EasyVRBridge bridge;
int8_t groupidx;
// bridge mode?
if (bridge.check())
cli();
bridge.loop(011213);
// run normally
Serial.begin(9600);
port.begin(9600);
  if (!
easyvr.detect())
Serial.println("EasyVR not detected!");
    for (;;);
easyvr.setPinOutput(EasyVR::IO1LOW);
Serial.println("EasyVR detected!");
easyvr.setTimeout(5);
easyvr.setLanguage(0);
group EasyVR::TRIGGER//<-- start group (customize)
void action();
easyvr.setPinOutput(EasyVR::IO1HIGH); // LED on (listening)
Serial.print("Say a command in Group ");
Serial.println(group);
easyvr.recognizeCommand(group);
  do
// can do some processing while waiting for a spoken command
  while (!
easyvr.hasFinished());
easyvr.setPinOutput(EasyVR::IO1LOW); // LED off
idx easyvr.getWord();
  if (
idx >= 0)
// built-in trigger (ROBOT)
    // group = GROUP_X; <-- jump to another group X
return;
idx easyvr.getCommand();
  if (
idx >= 0)
// print debug message
uint8_t train 0;
char name[32];
Serial.print("Command: ");
Serial.print(idx);
    if (
easyvr.dumpCommand(groupidxnametrain))
Serial.print(" = ");
Serial.println(name);
    else
Serial.println();
easyvr.playSound(0EasyVR::VOL_FULL);
// perform some action
action();
  else
// errors or timeout
    if (
easyvr.isTimeout())
Serial.println("Timed out, try again...");
int16_t err easyvr.getError();
    if (
err >= 0)
Serial.print("Error ");
Serial.println(errHEX);
void action()
    switch (
group)
    case
GROUP_0:
      switch (
idx)
      case
G0_EVA:
unsigned long ir_code=ReadEEPROM_Long(0);//прочитать код кнопоки из EEPROM в переменную
for (int i 03i++) { irsend.sendsSamsung(ir_code9);  delay_ms(100); }//теперь считанный код передаем по ИК каналу
break;
      break;
    case
GROUP_1:
      switch (
idx)
      case
G1_SWITH:
// write your action code here
        // group = GROUP_X; <-- or jump to another group X for composite commands
break;
      case
G1_KOMPUTER:
break;
      case
G1_EVA:
break;
      break;
    case
GROUP_2:
      switch (
idx)
      case
G2_ON:
break;
      case
G2_OFF:
break;
      break;
    case
GROUP_3:
      switch (
idx)
      case
G3_LIGHT:
break;
      break;
Да ладно,один фиг ничего уже не получается. Это прокатит -в другом месте будет затырк
Ромка вне форума   Ответить с цитированием
Старый 05.09.2013, 14:27   #82
А ошибка то какая?
Скорее всего не установил библиотеки
EasyVR
SoftwareSerial
Старый 05.09.2013, 18:15   #83
Ромка
Вот ошибки (скетч пробовал загнать только что сгенерированный без ВСТАВКИ ik команд)
Это отсутствие этих библиотек?
Старый 05.09.2013, 18:21   #84
Не хватает библиотек
Старый 05.09.2013, 18:29   #85
Ромка
А откуда их качать? Они тут есть ? http://www.cyber-place.ru/showpost.p...8&postcount=73
Старый 05.09.2013, 18:45   #86
Есть
Старый 05.09.2013, 19:32   #87
Ромка
Вроде скачал,но как-то не прет
Старый 05.09.2013, 19:46   #88
Еще требует Библиотеку CyberLib
Старый 05.09.2013, 19:56   #89
Ромка
Так а ее тут по ссылке нет, я просмотрел все архивы
Старый 05.09.2013, 19:58   #90
CyberLib
Текущее время: 17:00. Часовой пояс GMT +3.
