#81 |
Получается дополнительно установились пакеты
kmod-fs-ext4 - 3.8.2-1 kmod-fs-vfat - 3.8.2-1 kmod-nls-cp437 - 3.8.2-1 kmod-nls-cp850 - 3.8.2-1 kmod-nls-iso8859-1 - 3.8.2-1 kmod-nls-iso8859-15 - 3.8.2-1 kmod-sound-core - 3.8.2-1 kmod-usb-audio - 3.8.2-1 kmod-usb-storage - 3.8.2-1 kmod-usb-uhci - 3.8.2-1 libid3tag - 0.15.1b-3 madplay - 0.15.2b-3 zlib - 1.2.7-1 |
#82 |
Удали следующие пакеты
kmod-fs-vfat - 3.8.2-1 kmod-nls-cp437 - 3.8.2-1 kmod-nls-cp850 - 3.8.2-1 kmod-nls-iso8859-1 - 3.8.2-1 kmod-nls-iso8859-15 - 3.8.2-1 kmod-sound-core - 3.8.2-1 kmod-usb-audio - 3.8.2-1 libid3tag - 0.15.1b-3 madplay - 0.15.2b-3 zlib - 1.2.7-1 |
#83 |
![]() Код:
root@OpenWrt:~# opkg remove kmod-fs-vfat No packages removed. root@OpenWrt:~# opkg remove kmod-fs-vfat - 3.8.2-1 No packages removed. root@OpenWrt:~# opkg remove kmod-nls-cp437 No packages removed. root@OpenWrt:~# opkg remove kmod-nls-cp850 No packages removed. root@OpenWrt:~# opkg remove kmod-nls-iso8859-1 No packages removed. root@OpenWrt:~# opkg remove kmod-sound-core No packages removed. root@OpenWrt:~# opkg remove kmod-usb-audio No packages removed. root@OpenWrt:~# opkg remove libid3tag No packages removed. Collected errors: * print_dependents_warning: Package libid3tag is depended upon by packages: * print_dependents_warning: madplay * print_dependents_warning: These might cease to work if package libid3tag is removed. * print_dependents_warning: Force removal of this package with --force-depends. * print_dependents_warning: Force removal of this package and its dependents * print_dependents_warning: with --force-removal-of-dependent-packages. root@OpenWrt:~# opkg remove madplay Removing package madplay from root... root@OpenWrt:~# opkg remove zlib No packages removed. Collected errors: * print_dependents_warning: Package zlib is depended upon by packages: * print_dependents_warning: libid3tag * print_dependents_warning: These might cease to work if package zlib is removed. * print_dependents_warning: Force removal of this package with --force-depends. * print_dependents_warning: Force removal of this package and its dependents * print_dependents_warning: with --force-removal-of-dependent-packages. root@OpenWrt:~# Из предложенного списка удалился только один пакет Пакеты libid3tag и zlib связаны с другими в т.ч. и критическими процессами (он работать не будет) |
#84 |
есть ли смысл использовать боеле новую прошивку чем эту ?
например более новая и рекомендуемая вот тут есть: http://downloads.openwrt.org/attitud...fs-factory.bin Это версия Attitude Adjustment 12.09 rc1 версия билда r34185 а в этой r33482 |
#85 |
отвечаю сам себе.
прошивка AA rc1 содержит в себе luci и несколько других пакетов, что занимают место на диске и поэтому не получается установить поддержку USB и перенести систему на флешку.. ![]() |
#86 | |
#87 |
Поставил самую свежую прошивку от 21/03/2013: http://downloads.openwrt.org/snapsho...fs-factory.bin
root@OpenWrt:~# uname -a Linux OpenWrt 3.8.3 #1 Thu Mar 21 01:17:39 UTC 2013 mips GNU/Linux Cодержимое конфигурационного файла /etc/opkg.conf src/gz barrier_breaker http://downloads.openwrt.org/snapsho...r71xx/packages dest root / dest ram /tmp lists_dir ext /var/opkg-lists option overlay_root /overlay Флешка на 1Гб благополучно разбита на 2 раздела и примонтирована: root@OpenWrt:~# fdisk -l Device Boot Start End Blocks Id System /dev/sda1 * 133120 1965055 915968 83 Linux /dev/sda2 2048 133119 65536 82 Linux swap / Solaris root@OpenWrt:~# df -h Filesystem Size Used Available Use% Mounted on rootfs 864.4M 14.4M 805.3M 2% / /dev/root 1.8M 1.8M 0 100% /rom tmpfs 14.2M 392.0K 13.8M 3% /tmp tmpfs 512.0K 0 512.0K 0% /dev /dev/sda1 864.4M 14.4M 805.3M 2% /overlay overlayfs:/overlay 864.4M 14.4M 805.3M 2% / Как видно, свободного места навалом, а вот LuCI установить не удается: root@OpenWrt:~# opkg update Downloading http://downloads.openwrt.org/snapsho...es/Packages.gz. Updated list of available packages in /var/opkg-lists/barrier_breaker. root@OpenWrt:~# opkg install luci Unknown package 'luci'. Collected errors: * opkg_install_cmd: Cannot install package luci. В чем причина? |
#88 |
Похоже что в репозитории отсутствует Luci
#89 |
Подскажите, где можно ознакомиться со списком пакетов, находящихся в репозитарии к соответствующей прошивке? Ставил именно trunk версию т.к. она содержит необходимый мне пакет rtl-sdr для того чтобы превратить роутер в sdr сервер для USB dvb-t dongle. |
#90 |
Если с этого форума (от 21.09.12) то вот ссылка: http://cyber-place.ru/download/packages/
с openwrt свежая здесь: http://downloads.openwrt.org/snapsho...71xx/packages/ |
