Старый 12.10.2013, 18:27   #81
MIKI
Скопировал плохо.Вот..
stty -F /dev/ttyUSB1 cs8 57600 ignbrk -brkint -icrnl -imaxbel -opost -onlcr -isig -icanon -iexten -
echo -echoe -echok -echoctl -echoke noflsh -ixon -crtscts -hupcl
exit 0
Старый 12.10.2013, 18:29   #82
CyberLab
Guest
Сообщений: n/a
А почему /dev/ttyUSB1 ?
Судя по логу у Вас ttyUSB0
[ 10.530000] usb 1-1: FTDI USB Serial Device converter now attached to ttyUSB0
Последний раз редактировалось CyberLab; 12.10.2013 в 18:31.
Старый 12.10.2013, 18:29   #83
MIKI
Может прошивку поменять?
Старый 12.10.2013, 18:31   #84
MIKI
А у меня вроде так определяется.Я пробывал Usb0 тоже работать не хочет.
dmseg
[ 9.920000] hub 1-0:1.0: 1 port detected
[ 9.950000] nf_conntrack version 0.5.0 (456 buckets, 1824 max)
[ 10.190000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 10.260000] usb 1-1: new full-speed USB device number 2 using ehci-platform
[ 10.320000] usbcore: registered new interface driver usbserial
[ 10.320000] USB Serial support registered for generic
[ 10.440000] usbcore: registered new interface driver usbserial_generic
[ 10.450000] usbserial: USB Serial Driver core
[ 10.500000] USB Serial support registered for FTDI USB Serial Device
[ 10.500000] ftdi_sio 1-1:1.0: FTDI USB Serial Device converter detected
[ 10.510000] usb 1-1: Detected FT232RL
[ 10.510000] usb 1-1: Number of endpoints 2
[ 10.520000] usb 1-1: Endpoint 1 MaxPacketSize 16384
[ 10.520000] usb 1-1: Endpoint 2 MaxPacketSize 16384
[ 10.530000] usb 1-1: Setting MaxPacketSize 64
[ 10.540000] usbcore: registered new interface driver ftdi_sio
[ 10.540000] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
[ 13.670000] device eth0 entered promiscuous mode
[ 14.230000] eth0: link up (100Mbps/Full duplex)
[ 14.230000] br-lan: port 1(eth0) entered forwarding state
[ 14.240000] br-lan: port 1(eth0) entered forwarding state
[ 16.240000] br-lan: port 1(eth0) entered forwarding state
Старый 12.10.2013, 18:33   #85
CyberLab
Guest
Сообщений: n/a
Так с чего ему работать если stty -F /dev/ttyUSB1
Старый 12.10.2013, 18:35   #86
MIKI
Сообщение от CyberLab Посмотреть сообщение
я уже поменял на USB0
не хочет
Старый 12.10.2013, 18:40   #87
MIKI
Такое впечатление что пакета не хватает,не пойму какого.
Старый 12.10.2013, 18:41   #88
MIKI
kmod usb ?
Старый 12.10.2013, 18:47   #89
CyberLab
Guest
Сообщений: n/a
А ребут сделали? Прошивка какая?
Старый 12.10.2013, 18:48   #90
CyberLab
Guest
Сообщений: n/a
Если посмотреть ls /dev то устройство видно?
Текущее время: 00:07. Часовой пояс GMT +3.
