#1 |
Log заводской есть, там попадается что то похожее: rt28xx_init
Развернуть для просмотра------------- ARC-OS SYSTEM LOG -------------
Jan 1 00:04:54 ArcWeb user.warn kernel: Jan 1 00:04:54 ArcWeb user.warn kernel: eth0 mii.o query= phy_id:1, address:0 retval:3100 Jan 1 00:04:54 ArcWeb user.warn kernel: Jan 1 00:04:54 ArcWeb user.warn kernel: eth0 mii.o query= phy_id:1, address:5 retval:0 Jan 1 00:04:54 ArcWeb user.info kernel: eth0.2: dev_set_promiscuity(master, 1) Jan 1 00:04:54 ArcWeb user.info kernel: device eth0.2 entered promiscuous mode Jan 1 00:04:54 ArcWeb user.info kernel: br-lan: port 2(eth0.2) entering learning state Jan 1 00:04:54 ArcWeb user.info kernel: br-lan: topology change detected, propagating Jan 1 00:04:54 ArcWeb user.info kernel: br-lan: port 2(eth0.2) entering forwarding state Jan 1 00:04:55 ArcWeb user.info kernel: device ra0 entered promiscuous mode Jan 1 00:04:55 ArcWeb user.info kernel: br-lan: port 3(ra0) entering learning state Jan 1 00:04:55 ArcWeb user.info kernel: br-lan: topology change detected, propagating Jan 1 00:04:55 ArcWeb user.info kernel: br-lan: port 3(ra0) entering forwarding state Jan 1 00:04:56 ArcWeb user.info kernel: br-lan: port 3(ra0) entering disabled state Jan 1 00:04:56 ArcWeb user.info kernel: br-lan: port 2(eth0.2) entering disabled state Jan 1 00:04:56 ArcWeb user.info kernel: br-lan: port 1(eth0.1) entering disabled state Jan 1 00:04:56 ArcWeb user.info kernel: br-lan: port 3(ra0) entering learning state Jan 1 00:04:56 ArcWeb user.info kernel: br-lan: port 2(eth0.2) entering learning state Jan 1 00:04:56 ArcWeb user.info kernel: br-lan: port 1(eth0.1) entering learning state Jan 1 00:04:56 ArcWeb user.info kernel: br-lan: topology change detected, propagating Jan 1 00:04:56 ArcWeb user.info kernel: br-lan: port 3(ra0) entering forwarding state Jan 1 00:04:56 ArcWeb user.info kernel: br-lan: topology change detected, propagating Jan 1 00:04:56 ArcWeb user.info kernel: br-lan: port 2(eth0.2) entering forwarding state Jan 1 00:04:56 ArcWeb user.info kernel: br-lan: topology change detected, propagating Jan 1 00:04:56 ArcWeb user.info kernel: br-lan: port 1(eth0.1) entering forwarding state Jan 1 00:05:00 ArcWeb user.warn kernel: (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] Jan 1 00:05:00 ArcWeb user.warn kernel: (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] Jan 1 00:05:00 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7af8! Jan 1 00:05:00 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7b24! Jan 1 00:05:00 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7b50! Jan 1 00:05:00 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7acc! Jan 1 00:05:00 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7a48! Jan 1 00:05:00 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7a74! Jan 1 00:05:00 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13a248c! Jan 1 00:05:00 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13919ac! Jan 1 00:05:00 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13919e0! Jan 1 00:05:00 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13a2524! Jan 1 00:05:00 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13a2434! Jan 1 00:05:00 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13a24f4! Jan 1 00:05:00 ArcWeb user.warn kernel: -->RTUSBVenderReset Jan 1 00:05:00 ArcWeb user.warn kernel: <--RTUSBVenderReset Jan 1 00:05:01 ArcWeb user.warn kernel: Key1Str is Invalid key length(0) or Type(1) Jan 1 00:05:01 ArcWeb user.warn kernel: Key2Str is Invalid key length(0) or Type(0) Jan 1 00:05:01 ArcWeb user.warn kernel: Key3Str is Invalid key length(0) or Type(0) Jan 1 00:05:01 ArcWeb user.warn kernel: Key4Str is Invalid key length(0) or Type(0) Jan 1 00:05:01 ArcWeb user.warn kernel: 1. Phy Mode = 8 Jan 1 00:05:01 ArcWeb user.warn kernel: 2. Phy Mode = 8 Jan 1 00:05:01 ArcWeb user.warn kernel: (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] Jan 1 00:05:01 ArcWeb user.warn kernel: (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] Jan 1 00:05:01 ArcWeb user.warn kernel: 3. Phy Mode = 8 Jan 1 00:05:01 ArcWeb user.warn kernel: RTMPSetPhyMode: channel is out of range, use first channel=36 Jan 1 00:05:01 ArcWeb user.warn kernel: MCS Set = ff ff 00 00 00 Jan 1 00:05:01 ArcWeb user.warn kernel: <==== rt28xx_init, Status=0 Jan 1 00:05:01 ArcWeb user.warn kernel: 0x1300 = 00064300 Jan 1 00:05:02 ArcWeb user.warn kernel: (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] Jan 1 00:05:02 ArcWeb user.warn kernel: (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] Jan 1 00:05:03 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7af8! Jan 1 00:05:03 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7b24! Jan 1 00:05:03 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7b50! Jan 1 00:05:03 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7acc! Jan 1 00:05:03 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7a48! Jan 1 00:05:03 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7a74! Jan 1 00:05:03 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13a248c! Jan 1 00:05:03 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13919ac! Jan 1 00:05:03 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13919e0! Jan 1 00:05:03 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13a2524! Jan 1 00:05:03 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13a2434! Jan 1 00:05:03 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13a24f4! Jan 1 00:05:03 ArcWeb user.warn kernel: -->RTUSBVenderReset Jan 1 00:05:03 ArcWeb user.warn kernel: <--RTUSBVenderReset Jan 1 00:05:03 ArcWeb user.warn kernel: Key1Str is Invalid key length(0) or Type(1) Jan 1 00:05:03 ArcWeb user.warn kernel: Key2Str is Invalid key length(0) or Type(0) Jan 1 00:05:03 ArcWeb user.warn kernel: Key3Str is Invalid key length(0) or Type(0) Jan 1 00:05:03 ArcWeb user.warn kernel: Key4Str is Invalid key length(0) or Type(0) Jan 1 00:05:03 ArcWeb user.warn kernel: 1. Phy Mode = 8 Jan 1 00:05:03 ArcWeb user.warn kernel: 2. Phy Mode = 8 Jan 1 00:05:03 ArcWeb user.warn kernel: (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] Jan 1 00:05:03 ArcWeb user.warn kernel: (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] Jan 1 00:05:03 ArcWeb user.warn kernel: 3. Phy Mode = 8 Jan 1 00:05:03 ArcWeb user.warn kernel: RTMPSetPhyMode: channel is out of range, use first channel=36 Jan 1 00:05:03 ArcWeb user.warn kernel: MCS Set = ff ff 00 00 00 Jan 1 00:05:03 ArcWeb user.warn kernel: <==== rt28xx_init, Status=0 Jan 1 00:05:03 ArcWeb user.warn kernel: 0x1300 = 00064300 Jan 1 00:05:07 ArcWeb user.notice upnp firewall: removing wan interface Jan 1 00:05:07 ArcWeb user.info kernel: br-lan: port 3(ra0) entering disabled state Jan 1 00:05:09 ArcWeb user.notice root: [Wireless] ra0 is enabled. Jan 1 00:05:09 ArcWeb user.warn kernel: RX DESC a138a000 size = 2048 Jan 1 00:05:09 ArcWeb user.warn kernel: <-- RTMPAllocTxRxRingMemory, Status=0 Jan 1 00:05:09 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c11f7b78! Jan 1 00:05:09 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c11c6358! Jan 1 00:05:09 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c11c6330! Jan 1 00:05:09 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c11c6308! Jan 1 00:05:09 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c11ce90c! Jan 1 00:05:09 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c11cea10! Jan 1 00:05:09 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c11ce934! Jan 1 00:05:09 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c119cc2c! Jan 1 00:05:09 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c118e520! Jan 1 00:05:09 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c118f358! Jan 1 00:05:09 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c1190190! Jan 1 00:05:09 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c1190fc8! Jan 1 00:05:09 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c1191e00! Jan 1 00:05:09 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c1192c38! Jan 1 00:05:09 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c1193a70! Jan 1 00:05:09 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c119c948! Jan 1 00:05:09 ArcWeb user.warn kernel: default ApCliAPSDCapable[0]=1 Jan 1 00:05:09 ArcWeb user.warn kernel: 1. Phy Mode = 9 Jan 1 00:05:09 ArcWeb user.warn kernel: 2. Phy Mode = 9 Jan 1 00:05:09 ArcWeb user.warn kernel: 3. Phy Mode = 9 Jan 1 00:05:09 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c118e12c! Jan 1 00:05:09 ArcWeb user.warn kernel: MCS Set = ff 00 00 00 00 Jan 1 00:05:09 ArcWeb user.warn kernel: SYNC - BBP R4 to 20MHz.l Jan 1 00:05:12 ArcWeb user.warn kernel: Main bssid = a8:87:ed:33:6b:38 Jan 1 00:05:12 ArcWeb user.warn kernel: <==== rt28xx_init, Status=0 Jan 1 00:05:12 ArcWeb user.warn kernel: 0x1300 = 00064320 Jan 1 00:05:12 ArcWeb user.info kernel: br-lan: port 3(ra0) entering learning state Jan 1 00:05:12 ArcWeb user.info kernel: br-lan: topology change detected, propagating Jan 1 00:05:12 ArcWeb user.info kernel: br-lan: port 3(ra0) entering forwarding state Jan 1 00:05:13 ArcWeb user.info kernel: device ra0 left promiscuous mode Jan 1 00:05:13 ArcWeb user.info kernel: br-lan: port 3(ra0) entering disabled state Jan 1 00:05:13 ArcWeb user.info kernel: device ra0 entered promiscuous mode Jan 1 00:05:13 ArcWeb user.info kernel: br-lan: port 3(ra0) entering learning state Jan 1 00:05:13 ArcWeb user.info kernel: br-lan: topology change detected, propagating Jan 1 00:05:13 ArcWeb user.info kernel: br-lan: port 3(ra0) entering forwarding state Jan 1 00:05:13 ArcWeb user.notice root: [Wireless] ra1 is enabled. Jan 1 00:05:14 ArcWeb user.notice root: [Wireless] ra3 is disabled. Jan 1 00:05:14 ArcWeb user.notice root: [Wireless] ra3 is disabled. Jan 1 00:05:14 ArcWeb user.notice root: Loading rt3572sta module Jan 1 00:05:15 ArcWeb user.warn kernel: (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] Jan 1 00:05:15 ArcWeb user.warn kernel: (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] Jan 1 00:05:15 ArcWeb user.debug kernel: usb 1-1.3: ifconfig timed out on ep0out len=0/0 Jan 1 00:05:15 ArcWeb user.debug kernel: usb 1-1.3: ifconfig timed out on ep0out len=0/0 Jan 1 00:05:15 ArcWeb user.debug kernel: usb 1-1.3: ifconfig timed out on ep0out len=0/0 Jan 1 00:05:15 ArcWeb user.debug kernel: usb 1-1.3: ifconfig timed out on ep0out len=0/0 Jan 1 00:05:15 ArcWeb user.debug kernel: usb 1-1.3: ifconfig timed out on ep0out len=0/0 Jan 1 00:05:15 ArcWeb user.debug kernel: usb 1-1.3: ifconfig timed out on ep0out len=0/0 Jan 1 00:05:15 ArcWeb user.debug kernel: usb 1-1.3: ifconfig timed out on ep0out len=0/0 Jan 1 00:05:15 ArcWeb user.debug kernel: usb 1-1.3: ifconfig timed out on ep0out len=0/0 Jan 1 00:05:15 ArcWeb user.debug kernel: usb 1-1.3: ifconfig timed out on ep0out len=0/0 Jan 1 00:05:15 ArcWeb user.debug kernel: usb 1-1.3: ifconfig timed out on ep0out len=0/0 Jan 1 00:05:16 ArcWeb user.debug kernel: usb 1-1.3: ifconfig timed out on ep0out len=0/0 Jan 1 00:05:16 ArcWeb user.debug kernel: usb 1-1.3: ifconfig timed out on ep0out len=0/0 Jan 1 00:05:16 ArcWeb user.debug kernel: usb 1-1.3: ifconfig timed out on ep0out len=0/0 Jan 1 00:05:16 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7af8! Jan 1 00:05:16 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7b24! Jan 1 00:05:16 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7b50! Jan 1 00:05:16 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7acc! Jan 1 00:05:16 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7a48! Jan 1 00:05:16 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7a74! Jan 1 00:05:16 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13a248c! Jan 1 00:05:16 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13919ac! Jan 1 00:05:16 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13919e0! Jan 1 00:05:16 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13a2524! Jan 1 00:05:16 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13a2434! Jan 1 00:05:16 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13a24f4! Jan 1 00:05:16 ArcWeb user.warn kernel: -->RTUSBVenderReset Jan 1 00:05:16 ArcWeb user.warn kernel: <--RTUSBVenderReset Jan 1 00:05:16 ArcWeb user.warn kernel: Key1Str is Invalid key length(0) or Type(1) Jan 1 00:05:16 ArcWeb user.warn kernel: Key2Str is Invalid key length(0) or Type(0) Jan 1 00:05:16 ArcWeb user.warn kernel: Key3Str is Invalid key length(0) or Type(0) Jan 1 00:05:16 ArcWeb user.warn kernel: Key4Str is Invalid key length(0) or Type(0) Jan 1 00:05:16 ArcWeb user.warn kernel: 1. Phy Mode = 8 Jan 1 00:05:16 ArcWeb user.warn kernel: 2. Phy Mode = 8 Jan 1 00:05:17 ArcWeb user.warn kernel: (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] Jan 1 00:05:17 ArcWeb user.warn kernel: (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] Jan 1 00:05:17 ArcWeb user.warn kernel: 3. Phy Mode = 8 Jan 1 00:05:17 ArcWeb user.warn kernel: RTMPSetPhyMode: channel is out of range, use first channel=36 Jan 1 00:05:17 ArcWeb user.warn kernel: MCS Set = ff ff 00 00 00 Jan 1 00:05:17 ArcWeb user.warn kernel: <==== rt28xx_init, Status=0 Jan 1 00:05:17 ArcWeb user.warn kernel: 0x1300 = 00064300 Jan 1 00:05:18 ArcWeb user.warn kernel: (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] Jan 1 00:05:18 ArcWeb user.warn kernel: (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] Jan 1 00:05:18 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7af8! Jan 1 00:05:18 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7b24! Jan 1 00:05:18 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7b50! Jan 1 00:05:18 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7acc! Jan 1 00:05:18 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7a48! Jan 1 00:05:18 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13d7a74! Jan 1 00:05:18 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13a248c! Jan 1 00:05:18 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13919ac! Jan 1 00:05:18 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13919e0! Jan 1 00:05:18 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13a2524! Jan 1 00:05:18 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13a2434! Jan 1 00:05:18 ArcWeb user.warn kernel: RTMP_TimerListAdd: add timer obj c13a24f4! Jan 1 00:05:18 ArcWeb user.warn kernel: -->RTUSBVenderReset Jan 1 00:05:18 ArcWeb user.warn kernel: <--RTUSBVenderReset Jan 1 00:05:19 ArcWeb user.warn kernel: Key1Str is Invalid key length(0) or Type(1) Jan 1 00:05:19 ArcWeb user.warn kernel: Key2Str is Invalid key length(0) or Type(0) Jan 1 00:05:19 ArcWeb user.warn kernel: Key3Str is Invalid key length(0) or Type(0) Jan 1 00:05:19 ArcWeb user.warn kernel: Key4Str is Invalid key length(0) or Type(0) Jan 1 00:05:19 ArcWeb user.warn kernel: 1. Phy Mode = 8 Jan 1 00:05:19 ArcWeb user.warn kernel: 2. Phy Mode = 8 Jan 1 00:05:19 ArcWeb user.warn kernel: (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] Jan 1 00:05:19 ArcWeb user.warn kernel: (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] Jan 1 00:05:19 ArcWeb user.warn kernel: 3. Phy Mode = 8 Jan 1 00:05:19 ArcWeb user.warn kernel: RTMPSetPhyMode: channel is out of range, use first channel=36 Jan 1 00:05:19 ArcWeb user.warn kernel: MCS Set = ff ff 00 00 00 Jan 1 00:05:19 ArcWeb user.warn kernel: <==== rt28xx_init, Status=0 Jan 1 00:05:19 ArcWeb user.warn kernel: 0x1300 = 00064300 Jan 1 00:05:19 ArcWeb user.notice root: [Chilli] Stopping Chillispot. Jan 1 00:05:19 ArcWeb user.notice root: [Chilli] Chillispot not enabled, skipping. Jan 1 00:05:21 ArcWeb user.notice upnp firewall: removing wan interface ------------- ARC-OS DMESG OUTPUT ------------- [ARC] FillChList: Adding channel=120 [ARC] FillChList: Adding channel=121 [ARC] FillChList: Adding channel=122 [ARC] FillChList: Adding channel=123 [ARC] FillChList: Adding channel=124 [ARC] FillChList: Adding channel=125 [ARC] FillChList: Adding channel=126 [ARC] FillChList: Adding channel=127 [ARC] FillChList: Adding channel=128 [ARC] FillChList: Adding channel=129 [ARC] FillChList: Adding channel=130 [ARC] FillChList: Adding channel=131 [ARC] FillChList: Adding channel=132 [ARC] FillChList: Adding channel=133 [ARC] FillChList: Adding channel=134 [ARC] FillChList: Adding channel=135 [ARC] FillChList: Adding channel=136 [ARC] FillChList: Adding channel=137 [ARC] FillChList: Adding channel=138 [ARC] FillChList: Adding channel=139 [ARC] FillChList: Adding channel=140 [ARC] FillChList: Adding channel=141 [ARC] FillChList: Adding channel=142 [ARC] FillChList: Adding channel=143 [ARC] FillChList: Adding channel=149 [ARC] FillChList: Adding channel=150 [ARC] FillChList: Adding channel=151 [ARC] FillChList: Adding channel=152 [ARC] FillChList: Adding channel=153 [ARC] FillChList: Adding channel=154 [ARC] FillChList: Adding channel=155 [ARC] FillChList: Adding channel=156 [ARC] FillChList: Adding channel=157 [ARC] FillChList: Adding channel=158 [ARC] FillChList: Adding channel=159 [ARC] FillChList: Adding channel=160 [ARC] FillChList: Adding channel=161 [ARC] FillChList: Adding channel=162 [ARC] FillChList: Adding channel=163 [ARC] FillChList: Adding channel=164 [ARC] FillChList: Adding channel=165 [ARC] FillChList: Adding channel=166 [ARC] FillChList: Adding channel=167 [ARC] FillChList: Adding channel=168 RTMPSetPhyMode: channel is out of range, use first channel=36 usb 1-1.3: ifconfig timed out on ep0in len=4/4 MCS Set = ff ff 00 00 00 == rt28xx_init, Status=0 0x1300 = 00064300 br-lan: port 3(ra0) entering disabled state RX DESC a0a54000 size = 2048 RTMPAllocTxRxRingMemory, Status=0 RTMP_TimerListAdd: add timer obj c11f7b78! RTMP_TimerListAdd: add timer obj c11c6358! RTMP_TimerListAdd: add timer obj c11c6330! RTMP_TimerListAdd: add timer obj c11c6308! RTMP_TimerListAdd: add timer obj c11ce90c! RTMP_TimerListAdd: add timer obj c11cea10! RTMP_TimerListAdd: add timer obj c11ce934! RTMP_TimerListAdd: add timer obj c119cc2c! RTMP_TimerListAdd: add timer obj c118e520! RTMP_TimerListAdd: add timer obj c118f358! RTMP_TimerListAdd: add timer obj c1190190! RTMP_TimerListAdd: add timer obj c1190fc8! RTMP_TimerListAdd: add timer obj c1191e00! RTMP_TimerListAdd: add timer obj c1192c38! RTMP_TimerListAdd: add timer obj c1193a70! RTMP_TimerListAdd: add timer obj c119c948! default ApCliAPSDCapable[0]=1 1. Phy Mode = 9 2. Phy Mode = 9 3. Phy Mode = 9 RTMP_TimerListAdd: add timer obj c118e12c! MCS Set = ff 00 00 00 00 SYNC - BBP R4 to 20MHz.l Main bssid = a8:87:ed:33:6b:38 == rt28xx_init, Status=0 0x1300 = 00064320 br-lan: port 3(ra0) entering learning state br-lan: topology change detected, propagating br-lan: port 3(ra0) entering forwarding state device ra0 left promiscuous mode br-lan: port 3(ra0) entering disabled state device ra0 entered promiscuous mode br-lan: port 3(ra0) entering learning state br-lan: topology change detected, propagating br-lan: port 3(ra0) entering forwarding state (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 RTMP_TimerListAdd: add timer obj c13d7af8! RTMP_TimerListAdd: add timer obj c13d7b24! RTMP_TimerListAdd: add timer obj c13d7b50! RTMP_TimerListAdd: add timer obj c13d7acc! RTMP_TimerListAdd: add timer obj c13d7a48! RTMP_TimerListAdd: add timer obj c13d7a74! RTMP_TimerListAdd: add timer obj c13a248c! RTMP_TimerListAdd: add timer obj c13919ac! RTMP_TimerListAdd: add timer obj c13919e0! RTMP_TimerListAdd: add timer obj c13a2524! RTMP_TimerListAdd: add timer obj c13a2434! RTMP_TimerListAdd: add timer obj c13a24f4! -->RTUSBVenderReset RTUSBVenderReset Key1Str is Invalid key length(0) or Type(1) Key2Str is Invalid key length(0) or Type(0) Key3Str is Invalid key length(0) or Type(0) Key4Str is Invalid key length(0) or Type(0) 1. Phy Mode = 8 2. Phy Mode = 8 (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] 3. Phy Mode = 8 RTMPSetPhyMode: channel is out of range, use first channel=36 MCS Set = ff ff 00 00 00 == rt28xx_init, Status=0 0x1300 = 00064300 usb 1-1.3: RtmpMlmeTask timed out on ep0out len=0/0 (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] RTMP_TimerListAdd: add timer obj c13d7af8! RTMP_TimerListAdd: add timer obj c13d7b24! RTMP_TimerListAdd: add timer obj c13d7b50! RTMP_TimerListAdd: add timer obj c13d7acc! RTMP_TimerListAdd: add timer obj c13d7a48! RTMP_TimerListAdd: add timer obj c13d7a74! RTMP_TimerListAdd: add timer obj c13a248c! RTMP_TimerListAdd: add timer obj c13919ac! RTMP_TimerListAdd: add timer obj c13919e0! RTMP_TimerListAdd: add timer obj c13a2524! RTMP_TimerListAdd: add timer obj c13a2434! RTMP_TimerListAdd: add timer obj c13a24f4! -->RTUSBVenderReset RTUSBVenderReset Key1Str is Invalid key length(0) or Type(1) Key2Str is Invalid key length(0) or Type(0) Key3Str is Invalid key length(0) or Type(0) Key4Str is Invalid key length(0) or Type(0) 1. Phy Mode = 8 2. Phy Mode = 8 (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] 3. Phy Mode = 8 RTMPSetPhyMode: channel is out of range, use first channel=36 MCS Set = ff ff 00 00 00 == rt28xx_init, Status=0 0x1300 = 00064300 usb 1-1.3: RtmpMlmeTask timed out on ep0in len=4/4 br-lan: port 3(ra0) entering disabled state br-lan: port 2(eth0.2) entering disabled state br-lan: port 1(eth0.1) entering disabled state eth0.1: del 01:00:5e:00:00:01 mcast address from vlan interface eth0.1: del 01:00:5e:00:00:01 mcast address from master interface eth0.2: del 01:00:5e:00:00:01 mcast address from vlan interface eth0.2: del 01:00:5e:00:00:01 mcast address from master interface device ra0 left promiscuous mode br-lan: port 3(ra0) entering disabled state device eth0.2 left promiscuous mode br-lan: port 2(eth0.2) entering disabled state device eth0.1 left promiscuous mode br-lan: port 1(eth0.1) entering disabled state usb 1-1.3: RtmpMlmeTask timed out on ep0out len=0/0 eth0.1: dev_set_promiscuity(master, -1) eth0.1: add 01:00:5e:00:00:01 mcast address to master interface eth0 mii.o query= phy_id:1, address:4 retval:5e1 eth0 mii.o query= phy_id:1, address:0 retval:3100 eth0 mii.o query= phy_id:1, address:5 retval:0 eth0.1: dev_set_promiscuity(master, 1) device eth0.1 entered promiscuous mode br-lan: port 1(eth0.1) entering learning state br-lan: topology change detected, propagating br-lan: port 1(eth0.1) entering forwarding state eth0.2: dev_set_promiscuity(master, -1) eth0.2: add 01:00:5e:00:00:01 mcast address to master interface eth0 mii.o query= phy_id:1, address:4 retval:5e1 eth0 mii.o query= phy_id:1, address:0 retval:3100 eth0 mii.o query= phy_id:1, address:5 retval:0 eth0.2: dev_set_promiscuity(master, 1) device eth0.2 entered promiscuous mode br-lan: port 2(eth0.2) entering learning state br-lan: topology change detected, propagating br-lan: port 2(eth0.2) entering forwarding state device ra0 entered promiscuous mode br-lan: port 3(ra0) entering learning state br-lan: topology change detected, propagating br-lan: port 3(ra0) entering forwarding state br-lan: port 3(ra0) entering disabled state br-lan: port 2(eth0.2) entering disabled state br-lan: port 1(eth0.1) entering disabled state br-lan: port 3(ra0) entering learning state br-lan: port 2(eth0.2) entering learning state br-lan: port 1(eth0.1) entering learning state br-lan: topology change detected, propagating br-lan: port 3(ra0) entering forwarding state br-lan: topology change detected, propagating br-lan: port 2(eth0.2) entering forwarding state br-lan: topology change detected, propagating br-lan: port 1(eth0.1) entering forwarding state (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] RTMP_TimerListAdd: add timer obj c13d7af8! RTMP_TimerListAdd: add timer obj c13d7b24! RTMP_TimerListAdd: add timer obj c13d7b50! RTMP_TimerListAdd: add timer obj c13d7acc! RTMP_TimerListAdd: add timer obj c13d7a48! RTMP_TimerListAdd: add timer obj c13d7a74! RTMP_TimerListAdd: add timer obj c13a248c! RTMP_TimerListAdd: add timer obj c13919ac! RTMP_TimerListAdd: add timer obj c13919e0! RTMP_TimerListAdd: add timer obj c13a2524! RTMP_TimerListAdd: add timer obj c13a2434! RTMP_TimerListAdd: add timer obj c13a24f4! -->RTUSBVenderReset RTUSBVenderReset Key1Str is Invalid key length(0) or Type(1) Key2Str is Invalid key length(0) or Type(0) Key3Str is Invalid key length(0) or Type(0) Key4Str is Invalid key length(0) or Type(0) 1. Phy Mode = 8 2. Phy Mode = 8 (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] 3. Phy Mode = 8 RTMPSetPhyMode: channel is out of range, use first channel=36 MCS Set = ff ff 00 00 00 == rt28xx_init, Status=0 0x1300 = 00064300 (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] RTMP_TimerListAdd: add timer obj c13d7af8! RTMP_TimerListAdd: add timer obj c13d7b24! RTMP_TimerListAdd: add timer obj c13d7b50! RTMP_TimerListAdd: add timer obj c13d7acc! RTMP_TimerListAdd: add timer obj c13d7a48! RTMP_TimerListAdd: add timer obj c13d7a74! RTMP_TimerListAdd: add timer obj c13a248c! RTMP_TimerListAdd: add timer obj c13919ac! RTMP_TimerListAdd: add timer obj c13919e0! RTMP_TimerListAdd: add timer obj c13a2524! RTMP_TimerListAdd: add timer obj c13a2434! RTMP_TimerListAdd: add timer obj c13a24f4! -->RTUSBVenderReset RTUSBVenderReset Key1Str is Invalid key length(0) or Type(1) Key2Str is Invalid key length(0) or Type(0) Key3Str is Invalid key length(0) or Type(0) Key4Str is Invalid key length(0) or Type(0) 1. Phy Mode = 8 2. Phy Mode = 8 (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] 3. Phy Mode = 8 RTMPSetPhyMode: channel is out of range, use first channel=36 MCS Set = ff ff 00 00 00 == rt28xx_init, Status=0 0x1300 = 00064300 br-lan: port 3(ra0) entering disabled state RX DESC a138a000 size = 2048 RTMPAllocTxRxRingMemory, Status=0 RTMP_TimerListAdd: add timer obj c11f7b78! RTMP_TimerListAdd: add timer obj c11c6358! RTMP_TimerListAdd: add timer obj c11c6330! RTMP_TimerListAdd: add timer obj c11c6308! RTMP_TimerListAdd: add timer obj c11ce90c! RTMP_TimerListAdd: add timer obj c11cea10! RTMP_TimerListAdd: add timer obj c11ce934! RTMP_TimerListAdd: add timer obj c119cc2c! RTMP_TimerListAdd: add timer obj c118e520! RTMP_TimerListAdd: add timer obj c118f358! RTMP_TimerListAdd: add timer obj c1190190! RTMP_TimerListAdd: add timer obj c1190fc8! RTMP_TimerListAdd: add timer obj c1191e00! RTMP_TimerListAdd: add timer obj c1192c38! RTMP_TimerListAdd: add timer obj c1193a70! RTMP_TimerListAdd: add timer obj c119c948! default ApCliAPSDCapable[0]=1 1. Phy Mode = 9 2. Phy Mode = 9 3. Phy Mode = 9 RTMP_TimerListAdd: add timer obj c118e12c! MCS Set = ff 00 00 00 00 SYNC - BBP R4 to 20MHz.l Main bssid = a8:87:ed:33:6b:38 == rt28xx_init, Status=0 0x1300 = 00064320 br-lan: port 3(ra0) entering learning state br-lan: topology change detected, propagating br-lan: port 3(ra0) entering forwarding state device ra0 left promiscuous mode br-lan: port 3(ra0) entering disabled state device ra0 entered promiscuous mode br-lan: port 3(ra0) entering learning state br-lan: topology change detected, propagating br-lan: port 3(ra0) entering forwarding state (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 usb 1-1.3: ifconfig timed out on ep0out len=0/0 RTMP_TimerListAdd: add timer obj c13d7af8! RTMP_TimerListAdd: add timer obj c13d7b24! RTMP_TimerListAdd: add timer obj c13d7b50! RTMP_TimerListAdd: add timer obj c13d7acc! RTMP_TimerListAdd: add timer obj c13d7a48! RTMP_TimerListAdd: add timer obj c13d7a74! RTMP_TimerListAdd: add timer obj c13a248c! RTMP_TimerListAdd: add timer obj c13919ac! RTMP_TimerListAdd: add timer obj c13919e0! RTMP_TimerListAdd: add timer obj c13a2524! RTMP_TimerListAdd: add timer obj c13a2434! RTMP_TimerListAdd: add timer obj c13a24f4! -->RTUSBVenderReset RTUSBVenderReset Key1Str is Invalid key length(0) or Type(1) Key2Str is Invalid key length(0) or Type(0) Key3Str is Invalid key length(0) or Type(0) Key4Str is Invalid key length(0) or Type(0) 1. Phy Mode = 8 2. Phy Mode = 8 (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] 3. Phy Mode = 8 RTMPSetPhyMode: channel is out of range, use first channel=36 MCS Set = ff ff 00 00 00 == rt28xx_init, Status=0 0x1300 = 00064300 (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] RTMP_TimerListAdd: add timer obj c13d7af8! RTMP_TimerListAdd: add timer obj c13d7b24! RTMP_TimerListAdd: add timer obj c13d7b50! RTMP_TimerListAdd: add timer obj c13d7acc! RTMP_TimerListAdd: add timer obj c13d7a48! RTMP_TimerListAdd: add timer obj c13d7a74! RTMP_TimerListAdd: add timer obj c13a248c! RTMP_TimerListAdd: add timer obj c13919ac! RTMP_TimerListAdd: add timer obj c13919e0! RTMP_TimerListAdd: add timer obj c13a2524! RTMP_TimerListAdd: add timer obj c13a2434! RTMP_TimerListAdd: add timer obj c13a24f4! -->RTUSBVenderReset RTUSBVenderReset Key1Str is Invalid key length(0) or Type(1) Key2Str is Invalid key length(0) or Type(0) Key3Str is Invalid key length(0) or Type(0) Key4Str is Invalid key length(0) or Type(0) 1. Phy Mode = 8 2. Phy Mode = 8 (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] (Reassign Efuse for 3x7x/3x9x/53xx) Size=0x3c [3c0-3fb] 3. Phy Mode = 8 RTMPSetPhyMode: channel is out of range, use first channel=36 MCS Set = ff ff 00 00 00 == rt28xx_init, Status=0 0x1300 = 00064300 [свернуть] |
#2 |
Там даже попадаются слова "Loading rt3572sta module" ������.
Всё-таки, есть у меня подозрения, что надо как-то знать/сказать модулю, что есть усилители (искать даташиты на них, смотреть как управляются). Явно не сильно распространенная железка. У меня идеи кончились :-( Можно востановить заводскую прошивку, через mtd или программатор. Или устроить лабу, изучая взаимодействие модуля rt2800-usb с конкретным железом на openwrt.. |
#3 |
На заводской только режим клиента, это в крайнем случае чтобы про запас на хранение положить.
#4 | |
Вес репутации: 690 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
На Ubuntu например, чтобы использовать AP режим - устанавливают hostapd утилиту. Вот ссылка. |
#5 |
Вот конфиг для сборки под ваше устройство. Там есть модули
CONFIG_DEFAULT_kmod-leds-gpio=y CONFIG_DEFAULT_kmod-rt2500-usb=y CONFIG_DEFAULT_kmod-rt2800-soc=y CONFIG_DEFAULT_kmod-rt2800-usb=y CONFIG_DEFAULT_kmod-rt2x00-usb=y CONFIG_DEFAULT_kmod-usb-dwc2=y |
#6 |
Подскажите как мне этот конфиг внедрить в мою lede прошивку, его нужно положить в папку /etc/config? Или нужно делать свою сборку?
Последний раз редактировалось girk; 26.10.2017 в 22:08. |
#7 | |
Конфиг - от среды сборки. То, что стандартно генериться при выборе данного оборудования.
Провел тест, есть A5-V11 на RT5350, нашел два адаптера, один ASUS USB-N11 (перешит в WIS09BGN) на RT2870+RT2820, другой Dlink DWA-140B2 на RT3072. Оба работают через rt2800usb как AP PS. Trunk LEDE с добавленным LUCI и usb-ohci/uhci(на всякий случай) https://cloud.mail.ru/public/7aZo/ohtHB8FDB Последний раз редактировалось paulerr; 27.10.2017 в 00:13. |
#8 |
На вашей последней сборке (первую не ставил) сигнал значительно усилился, до километровых испытаний пока не приступил, но даже смартфоном на частоте 2,4 при 5ггц антенне это заметно.
Спасибо вам за сборку и за участие и вам и sunny. Только вопрос, а обязательно было пересобирать или можно было эти пакеты доустановить? И усилители SE2595L работают без драйверов, автоматически? Почему тогда не усиливали сигнал когда rt3572 работал без драйвера или они подхватывают сигнал только определенной силы, а то что выдавал rt3572 считали шумом? Отмечу что я подключался к интернету на смартфоне через rt3572 без драйверов, правда на малой скорости и очень близком расстоянии. Если это адресовалось мне то: Развернуть для просмотраroot@LEDE:~# iw list
Wiphy phy1 max # scan SSIDs: 4 max scan IEs length: 2257 bytes max # sched scan SSIDs: 0 max # match sets: 0 max # scan plans: 1 max scan plan interval: -1 max scan plan iterations: 0 Retry short long limit: 2 Coverage class: 0 (up to 0m) Available Antennas: TX 0 RX 0 Supported interface modes: * IBSS * managed * AP * AP/VLAN * monitor * mesh point Band 1: Capabilities: 0x2fe HT20/HT40 SM Power Save disabled RX Greenfield RX HT20 SGI RX HT40 SGI TX STBC RX STBC 2-streams Max AMSDU length: 3839 bytes No DSSS/CCK HT40 Maximum RX AMPDU length 65535 bytes (exponent: 0x003) Minimum RX AMPDU time spacing: 2 usec (0x04) HT TX/RX MCS rate indexes supported: 0-15, 32 Frequencies: * 2412 MHz [1] (20.0 dBm) * 2417 MHz [2] (20.0 dBm) * 2422 MHz [3] (20.0 dBm) * 2427 MHz [4] (20.0 dBm) * 2432 MHz [5] (20.0 dBm) * 2437 MHz [6] (20.0 dBm) * 2442 MHz [7] (20.0 dBm) * 2447 MHz [8] (20.0 dBm) * 2452 MHz [9] (20.0 dBm) * 2457 MHz [10] (20.0 dBm) * 2462 MHz [11] (20.0 dBm) * 2467 MHz [12] (20.0 dBm) * 2472 MHz [13] (20.0 dBm) * 2484 MHz [14] (disabled) Band 2: Capabilities: 0x2fe HT20/HT40 SM Power Save disabled RX Greenfield RX HT20 SGI RX HT40 SGI TX STBC RX STBC 2-streams Max AMSDU length: 3839 bytes No DSSS/CCK HT40 Maximum RX AMPDU length 65535 bytes (exponent: 0x003) Minimum RX AMPDU time spacing: 2 usec (0x04) HT TX/RX MCS rate indexes supported: 0-15, 32 Frequencies: * 5180 MHz [36] (20.0 dBm) * 5190 MHz [38] (20.0 dBm) * 5200 MHz [40] (20.0 dBm) * 5220 MHz [44] (20.0 dBm) * 5230 MHz [46] (20.0 dBm) * 5240 MHz [48] (20.0 dBm) * 5260 MHz [52] (20.0 dBm) (radar detection) * 5270 MHz [54] (20.0 dBm) (radar detection) * 5280 MHz [56] (20.0 dBm) (radar detection) * 5300 MHz [60] (20.0 dBm) (radar detection) * 5310 MHz [62] (20.0 dBm) (radar detection) * 5320 MHz [64] (20.0 dBm) (radar detection) * 5500 MHz [100] (20.0 dBm) (radar detection) * 5510 MHz [102] (20.0 dBm) (radar detection) * 5520 MHz [104] (20.0 dBm) (radar detection) * 5540 MHz [108] (20.0 dBm) (radar detection) * 5550 MHz [110] (20.0 dBm) (radar detection) * 5560 MHz [112] (20.0 dBm) (radar detection) * 5580 MHz [116] (20.0 dBm) (radar detection) * 5590 MHz [118] (20.0 dBm) (radar detection) * 5600 MHz [120] (20.0 dBm) (radar detection) * 5620 MHz [124] (20.0 dBm) (radar detection) * 5630 MHz [126] (20.0 dBm) (radar detection) * 5640 MHz [128] (20.0 dBm) (radar detection) * 5660 MHz [132] (20.0 dBm) (radar detection) * 5670 MHz [134] (disabled) * 5680 MHz [136] (disabled) * 5700 MHz [140] (disabled) * 5745 MHz [149] (20.0 dBm) * 5755 MHz [151] (20.0 dBm) * 5765 MHz [153] (20.0 dBm) * 5785 MHz [157] (20.0 dBm) * 5795 MHz [159] (20.0 dBm) * 5805 MHz [161] (20.0 dBm) * 5825 MHz [165] (20.0 dBm) * 5835 MHz [167] (disabled) * 5845 MHz [169] (disabled) * 5855 MHz [171] (disabled) * 5865 MHz [173] (disabled) valid interface combinations: * #{ managed, AP, mesh point } <= 8, total <= 8, #channels <= 1 HT Capability overrides: * MCS: ff ff ff ff ff ff ff ff ff ff * maximum A-MSDU length * supported channel width * short GI for 40 MHz * max A-MPDU length exponent * min MPDU start spacing Wiphy phy0 max # scan SSIDs: 4 max scan IEs length: 2257 bytes max # sched scan SSIDs: 0 max # match sets: 0 max # scan plans: 1 max scan plan interval: -1 max scan plan iterations: 0 Retry short long limit: 2 Coverage class: 0 (up to 0m) Available Antennas: TX 0 RX 0 Supported interface modes: * IBSS * managed * AP * AP/VLAN * monitor * mesh point Band 1: Capabilities: 0x17e HT20/HT40 SM Power Save disabled RX Greenfield RX HT20 SGI RX HT40 SGI RX STBC 1-stream Max AMSDU length: 3839 bytes No DSSS/CCK HT40 Maximum RX AMPDU length 32767 bytes (exponent: 0x002) Minimum RX AMPDU time spacing: 2 usec (0x04) HT TX/RX MCS rate indexes supported: 0-7, 32 Frequencies: * 2412 MHz [1] (20.0 dBm) * 2417 MHz [2] (20.0 dBm) * 2422 MHz [3] (20.0 dBm) * 2427 MHz [4] (20.0 dBm) * 2432 MHz [5] (20.0 dBm) * 2437 MHz [6] (20.0 dBm) * 2442 MHz [7] (20.0 dBm) * 2447 MHz [8] (20.0 dBm) * 2452 MHz [9] (20.0 dBm) * 2457 MHz [10] (20.0 dBm) * 2462 MHz [11] (20.0 dBm) * 2467 MHz [12] (20.0 dBm) * 2472 MHz [13] (20.0 dBm) * 2484 MHz [14] (disabled) valid interface combinations: * #{ managed, AP, mesh point } <= 8, total <= 8, #channels <= 1 HT Capability overrides: * MCS: ff ff ff ff ff ff ff ff ff ff * maximum A-MSDU length * supported channel width * short GI for 40 MHz * max A-MPDU length exponent * min MPDU start spacing [свернуть] Развернуть для просмотраroot@LEDE:~# wifi status
{ "radio0": { "up": false, "pending": false, "autostart": true, "disabled": true, "retry_setup_failed": false, "config": { "channel": "11", "hwmode": "11g", "path": "platform\/10180000.wmac", "htmode": "HT20", "disabled": true }, "interfaces": [ { "section": "default_radio0", "config": { "mode": "ap", "ssid": "LEDE", "encryption": "none", "network": [ "lan" ], "mode": "ap" } } ] }, "radio1": { "up": true, "pending": false, "autostart": true, "disabled": false, "retry_setup_failed": false, "config": { "path": "platform\/101c0000.otg\/usb1\/1-1\/1-1.3\/1-1.3:1.0", "htmode": "HT20", "txpower": 0, "hwmode": "11a", "country": "UA", "distance": 1400, "channel": "40" }, "interfaces": [ { "section": "default_radio1", "ifname": "wlan1", "config": { "mode": "ap", "encryption": "none", "ssid": "LEDE1", "macfilter": "allow", "maclist": [ "77:77:77:77:77:77", ], "hidden": true, "network": [ "lan" ], "mode": "ap" } } ] } } [свернуть] Только у меня же LEDE Последний раз редактировалось girk; 27.10.2017 в 16:06. |
#9 | |
Глядя на выдачу IW LIST, есть большая вероятность, что по умолчанию больше 20.0 dBm не получите. Так что не факт, что усилители работают на полную. Можно посмотреть на логе от оригинальной прошивки, там есть передача каких-то конфигурационных параметров в устройство (efuse). ЗЫ.Нашел USB свисток TL-WDN3200 на базе RT5572, он умеет abgn. Вот заставить его работать на 5Г еще та история. Работал только на стандартных каналах 36-40-44-48. После любых изменений требовался рестарт (wifi restart). В какой-то момент на экране inssider вообще увидел работу его в двух диапазонах (правда до перезагрузки) ![]() |
#10 | ||
И вообще мало какие USB свистульки поддерживают AP режим на уровне своего проприетарного драйвера. |
Метки |
