Старый 25.04.2016, 16:32   #1
kalina_vet
kalina_vet is an unknown quantity at this point
Журнал ядра:
Код HTML:
[    0.000000] Linux version 3.18.23 (buildbot@builder1) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r47269) ) #1 Sun Jan 31 14:39:33 CET 2016
[    0.000000] SoC Type: Ralink RT5350 id:1 rev:3
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU0 revision is: 0001964c (MIPS 24KEc)
[    0.000000] MIPS: machine is D-Link DIR-300 B7
[    0.000000] Determined physical RAM map:
[    0.000000]  memory: 02000000 @ 00000000 (usable)
[    0.000000] Initrd not found or empty - disabling initrd
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x00000000-0x01ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00000000-0x01ffffff]
[    0.000000] Initmem setup node 0 [mem 0x00000000-0x01ffffff]
[    0.000000] On node 0 totalpages: 8192
[    0.000000] free_area_init_node: node 0, pgdat 802f6290, node_mem_map 81000000
[    0.000000]   Normal zone: 64 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 8192 pages, LIFO batch:0
[    0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[    0.000000] Primary data cache 16kB, 4-way, VIPT, no aliases, linesize 32 bytes
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 8128
[    0.000000] Kernel command line: console=ttyS0,57600 rootfstype=squashfs,jffs2
[    0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
[    0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Writing ErrCtl register=00040f60
[    0.000000] Readback ErrCtl register=00040f60
[    0.000000] Memory: 28948K/32768K available (2508K kernel code, 119K rwdata, 492K rodata, 136K init, 185K bss, 3820K reserved)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS:256
[    0.000000] CPU Clock: 360MHz
[    0.000000] systick: running - mult: 214748, shift: 32
[    0.010000] Calibrating delay loop... 239.61 BogoMIPS (lpj=1198080)
[    0.080000] pid_max: default: 32768 minimum: 301
[    0.090000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.100000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.110000] pinctrl core: initialized pinctrl subsystem
[    0.120000] NET: Registered protocol family 16
[    0.130000] rt2880-pinmux pinctrl: try to register 28 pins ...
[    0.130000] pinctrl core: registered pin 0 (io0) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 1 (io1) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 2 (io2) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 3 (io3) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 4 (io4) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 5 (io5) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 6 (io6) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 7 (io7) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 8 (io8) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 9 (io9) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 10 (io10) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 11 (io11) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 12 (io12) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 13 (io13) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 14 (io14) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 15 (io15) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 16 (io16) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 17 (io17) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 18 (io18) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 19 (io19) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 20 (io20) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 21 (io21) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 22 (io22) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 23 (io23) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 24 (io24) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 25 (io25) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 26 (io26) on rt2880-pinmux
[    0.130000] pinctrl core: registered pin 27 (io27) on rt2880-pinmux
[    0.130000] pinctrl core: add 5 pinmux maps
[    0.130000] rt2880-pinmux pinctrl: found group selector 0 for i2c
[    0.130000] rt2880-pinmux pinctrl: found group selector 4 for jtag
[    0.130000] rt2880-pinmux pinctrl: invalid group "rgmii" for function "gpio"
[    0.140000] rt2880-pinmux pinctrl: invalid group "mdio" for function "gpio"
[    0.150000] rt2880-pinmux pinctrl: found group selector 2 for uartf
[    0.150000] rt2880-pinmux pinctrl: request pin 1 (io1) for pinctrl
[    0.150000] rt2880-pinmux pinctrl: request pin 2 (io2) for pinctrl
[    0.150000] rt2880-pinmux pinctrl: request pin 17 (io17) for pinctrl
[    0.150000] rt2880-pinmux pinctrl: request pin 18 (io18) for pinctrl
[    0.150000] rt2880-pinmux pinctrl: request pin 19 (io19) for pinctrl
[    0.150000] rt2880-pinmux pinctrl: request pin 20 (io20) for pinctrl
[    0.150000] rt2880-pinmux pinctrl: request pin 21 (io21) for pinctrl
[    0.150000] rt2880-pinmux pinctrl: request pin 7 (io7) for pinctrl
[    0.150000] rt2880-pinmux pinctrl: request pin 8 (io8) for pinctrl
[    0.150000] rt2880-pinmux pinctrl: request pin 9 (io9) for pinctrl
[    0.150000] rt2880-pinmux pinctrl: request pin 10 (io10) for pinctrl
[    0.150000] rt2880-pinmux pinctrl: request pin 11 (io11) for pinctrl
[    0.150000] rt2880-pinmux pinctrl: request pin 12 (io12) for pinctrl
[    0.150000] rt2880-pinmux pinctrl: request pin 13 (io13) for pinctrl
[    0.150000] rt2880-pinmux pinctrl: request pin 14 (io14) for pinctrl
[    0.150000] rt2880-pinmux pinctrl: failed to lookup the sleep state
[    0.160000] rt2880_gpio 10000600.gpio: registering 22 gpios
[    0.170000] rt2880_gpio 10000600.gpio: registering 22 irq handlers
[    0.180000] Switched to clocksource systick
[    0.190000] NET: Registered protocol family 2
[    0.200000] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.210000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.220000] TCP: Hash tables configured (established 1024 bind 1024)
[    0.240000] TCP: reno registered
[    0.240000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.250000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.270000] NET: Registered protocol family 1
[    0.280000] rt-timer 10000100.timer: maximum frequency is 7324Hz
[    0.290000] alarmtimer alarmtimer: no of_node; not parsing pinctrl DT
[    0.290000] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.320000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.330000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.350000] msgmni has been set to 56
[    0.360000] io scheduler noop registered
[    0.370000] io scheduler deadline registered (default)
[    0.380000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    0.400000] serial8250 serial8250: no of_node; not parsing pinctrl DT
[    0.400000] pinctrl core: add 1 pinmux maps
[    0.400000] rt2880-pinmux pinctrl: found group selector 3 for uartlite
[    0.400000] rt2880-pinmux pinctrl: request pin 15 (io15) for 10000c00.uartlite
[    0.400000] rt2880-pinmux pinctrl: request pin 16 (io16) for 10000c00.uartlite
[    0.400000] console [ttyS0] disabled
[    0.410000] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 20, base_baud = 2500000) is a 16550A
[    0.420000] console [ttyS0] enabled
[    0.440000] bootconsole [early0] disabled
[    0.460000] pinctrl core: add 1 pinmux maps
[    0.460000] rt2880-pinmux pinctrl: found group selector 1 for spi
[    0.460000] rt2880-pinmux pinctrl: found group selector 6 for spi_cs1
[    0.460000] rt2880-pinmux pinctrl: request pin 3 (io3) for 10000b00.spi
[    0.460000] rt2880-pinmux pinctrl: request pin 4 (io4) for 10000b00.spi
[    0.460000] rt2880-pinmux pinctrl: request pin 5 (io5) for 10000b00.spi
[    0.460000] rt2880-pinmux pinctrl: request pin 6 (io6) for 10000b00.spi
[    0.460000] rt2880-pinmux pinctrl: request pin 27 (io27) for 10000b00.spi
[    0.530000] m25p80 spi32766.0: s25fl064k (8192 Kbytes)
[    0.540000] 4 ofpart partitions found on MTD device spi32766.0
[    0.550000] Creating 4 MTD partitions on "spi32766.0":
[    0.560000] 0x000000000000-0x000000030000 : "u-boot"
[    0.570000] 0x000000030000-0x000000040000 : "u-boot-env"
[    0.590000] 0x000000040000-0x000000050000 : "factory"
[    0.600000] 0x000000050000-0x000000800000 : "firmware"
[    0.680000] 2 uimage-fw partitions found on MTD device firmware
[    0.690000] 0x000000050000-0x000000162b47 : "kernel"
[    0.700000] 0x000000162b47-0x000000800000 : "rootfs"
[    0.710000] mtd: device 5 (rootfs) set to be root filesystem
[    0.720000] 1 squashfs-split partitions found on MTD device rootfs
[    0.730000] 0x000000390000-0x000000800000 : "rootfs_data"
[    0.750000] ralink_soc_eth 10100000.ethernet eth0: ralink at 0xb0100000, irq 5
[    0.770000] rt2880_wdt 10000120.watchdog: Initialized
[    0.780000] TCP: cubic registered
[    0.790000] NET: Registered protocol family 17
[    0.800000] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    0.820000] Bridge firewalling registered
[    0.830000] 8021q: 802.1Q VLAN Support v1.8
[    0.880000] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[    0.900000] Freeing unused kernel memory: 136K (8030e000 - 80330000)
[    3.810000] init: Console is alive
[    3.820000] init: - watchdog -
[    6.770000] usbcore: registered new interface driver usbfs
[    6.780000] usbcore: registered new interface driver hub
[    6.790000] usbcore: registered new device driver usb
[    6.820000] rt2880-pinmux pinctrl: request pin 9 (io9) for pio:9
[    6.820000] rt2880-pinmux pinctrl: request pin 13 (io13) for pio:13
[    6.860000] init: - preinit -
[    8.290000] rt305x-esw 10110000.esw: link changed 0x00
[    8.620000] random: mktemp urandom read with 13 bits of entropy available
[   12.390000] jffs2: notice: (305) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[   12.440000] mount_root: switching to jffs2 overlay
[   12.530000] procd: - early -
[   12.540000] procd: - watchdog -
[   13.690000] procd: - ubus -
[   14.720000] procd: - init -
[   18.660000] NET: Registered protocol family 10
[   18.780000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   18.820000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   18.840000] ohci-platform: OHCI generic platform driver
[   19.050000] phy phy-usbphy.0: remote usb device wakeup disabled
[   19.060000] phy phy-usbphy.0: UTMI 16bit 30MHz
[   19.070000] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
[   19.080000] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 1
[   19.100000] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
[   19.170000] usb usb1: no of_node; not parsing pinctrl DT
[   19.170000] hub 1-0:1.0: no of_node; not parsing pinctrl DT
[   19.170000] hub 1-0:1.0: USB hub found
[   19.190000] hub 1-0:1.0: 1 port detected
[   19.200000] i2c /dev entries driver
[   19.270000] snd-soc-dummy snd-soc-dummy: no of_node; not parsing pinctrl DT
[   19.360000] Loading modules backported from Linux version master-2015-03-09-0-g141f155
[   19.380000] Backport generated by backports.git backports-20150129-0-gdd4a670
[   19.400000] ip_tables: (C) 2000-2006 Netfilter Core Team
[   19.440000] nf_conntrack version 0.5.0 (454 buckets, 1816 max)
[   19.540000] xt_time: kernel timezone is -0000
[   19.610000] usb 1-1: new full-speed USB device number 2 using ohci-platform
[   19.710000] cfg80211: Calling CRDA to update world regulatory domain
[   19.730000] cfg80211: World regulatory domain updated:
[   19.740000] cfg80211:  DFS Master region: unset
[   19.740000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   19.760000] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   19.780000] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   19.800000] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[   19.810000] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   19.830000] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[   19.850000] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   19.870000] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   19.890000] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[   19.940000] PPP generic driver version 2.4.2
[   19.950000] NET: Registered protocol family 24
[   20.010000] usbcore: registered new interface driver snd-usb-audio
[   20.060000] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5350, rev 0500 detected
[   20.080000] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5350 detected
[   20.090000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   20.320000] usb 1-1: no of_node; not parsing pinctrl DT
[   20.320000] hub 1-1:1.0: no of_node; not parsing pinctrl DT
[   20.320000] hub 1-1:1.0: USB hub found
[   20.340000] hub 1-1:1.0: 4 ports detected
[   20.630000] usb 1-1.1: new full-speed USB device number 3 using ohci-platform
[   20.790000] usb 1-1.1: no of_node; not parsing pinctrl DT
[   20.790000] snd-usb-audio 1-1.1:1.0: no of_node; not parsing pinctrl DT
[   32.070000] device eth0.1 entered promiscuous mode
[   32.080000] device eth0 entered promiscuous mode
[   32.110000] br-lan: port 1(eth0.1) entered forwarding state
[   32.120000] br-lan: port 1(eth0.1) entered forwarding state
[   34.120000] br-lan: port 1(eth0.1) entered forwarding state
[   34.220000] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   36.010000] IPv6: ADDRCONF(NETDEV_UP): wlan0-1: link is not ready
[   37.240000] wlan0: authenticate with 90:94:e4:3e:1b:36
[   37.280000] wlan0: direct probe to 90:94:e4:3e:1b:36 (try 1/3)
[   37.500000] wlan0: send auth to 90:94:e4:3e:1b:36 (try 2/3)
[   37.510000] wlan0: authenticated
[   37.530000] wlan0: associate with 90:94:e4:3e:1b:36 (try 1/3)
[   37.540000] wlan0: RX AssocResp from 90:94:e4:3e:1b:36 (capab=0x431 status=0 aid=1)
[   37.560000] wlan0: associated
[   37.560000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   42.370000] wlan0-1: authenticate with 30:b5:c2:34:42:3e
[   42.390000] wlan0-1: send auth to 30:b5:c2:34:42:3e (try 1/3)
[   42.410000] wlan0-1: authenticated
[   42.430000] wlan0-1: associate with 30:b5:c2:34:42:3e (try 1/3)
[   42.440000] wlan0-1: RX AssocResp from 30:b5:c2:34:42:3e (capab=0x431 status=0 aid=3)
[   42.460000] wlan0-1: associated
[   42.470000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0-1: link becomes ready
[   57.830000] random: nonblocking pool is initialized
kalina_vet вне форума   Ответить с цитированием
Старый 25.04.2016, 16:44   #2
kalina_vet
Выгледит:
Старый 25.04.2016, 17:04   #3
madplay нет в ImageBuilder
Старый 25.04.2016, 17:32   #4
kalina_vet
без него. тоисть:kmod-usb-core kmod-usb-uhci kmod-usb-ohci kmod-usb-audio kmod-sound-core kmod-sound-cs5535audio kmod-sound-i8x0 kmod-sound-soc-core но обезательно удалите kmod-usb2.Без madplay усби будет раотать поставлю другой проигрователь.Сейчяс борюсь за роботу звуковухи.
Последний раз редактировалось kalina_vet; 25.04.2016 в 17:58.
Старый 25.04.2016, 17:54   #5
Здесь добавил, ток не уверен насчет kmod-usb2, исключил, но он может зависимым пакетом затянуться, проверишь
Последний раз редактировалось sakatgg; 25.04.2016 в 17:57.
Старый 25.04.2016, 18:18   #6
kalina_vet
ок.спс.
Старый 25.04.2016, 19:09   #7
kalina_vet
всё работает.kmod-usb2 не подтянулся.Огромное спасибо за проделанную роботу.
Старый 26.04.2016, 21:25   #8
denisy
denisy is an unknown quantity at this point
Здравствуйте сообщество cyberwrt,
Поскольку у меня нет роутера поддерживаемого cyberwrt, но есть несколько роутеров других производителей с openwrt, я решил попробовать просто тупо заменить весь веб-интерфейс (все в папке /www) на таковой от cyberwrt и, О чудо! - все заработало без сучка и задоринки (ну почти - иконки не грузятся, но это вобщем для меня не критично). Тестировалось на asus wl-500gp v2 c openwrt 15.04 (CC). все драйвера естественно установлены из репозитория openwrt. Далее я стал прикручивать ардуину и разные i2c датчики и дисплей - все работает без проблем. Однако со вчерашнего дня перестали подгружаться модули из репозитория cyberwrt, интернет на роутере есть, RSS строка грузится исправно, а вот модули никак не приходят. Переустановил файлы в папке www, но не помогло... Подскажите куда копать, я правильно понимаю что репозитории доступны в онлайне? Не могли ли меня за блеклистить по IP случайно или намеренно? Спасибо!
denisy вне форума   Ответить с цитированием
Старый 26.04.2016, 22:08   #9
Если не затруднит, скажите, как работает роутер под 15.04 (CC), есть какие-либо проблемы?
istarik.ru
Старый 26.04.2016, 22:26   #10
denisy
Проблем пока не заметил - но с уверенностью сказать что проблем нет пока не могу - нужно еще тестировать. С китайской ардуиной ch341 и i2c-tiny работает нормально (подозреваю все проблемы ch341 никуда не денуться, но никаких особых проблем пока не замечено), про стабильность комментировать еще рано - буду смотреть дальше.
Здесь присутствуют: 12 (пользователей: 0 , гостей: 12)
Текущее время: 19:06. Часовой пояс GMT +3.
