Старый 02.07.2019, 23:03   #631
Вес репутации: 1031
Настройки сети какие? Файервол? ps|grep mjpg что показывает?
Старый 02.07.2019, 23:12   #632
blakx87
blakx87 is an unknown quantity at this point
root@OpenWrt:~# ps|grep mjpg
4439 root 1484 S grep mjpg
root@OpenWrt:~#
blakx87 вне форума   Ответить с цитированием
Старый 02.07.2019, 23:15   #633
blakx87
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd6e:85a4:db22::/48'
config interface 'lan'
option ifname 'eth0.1'
option force_link '1'
option type 'bridge'
option ip6assign '60'
option ipaddr '192.168.2.1'
config switch
option name 'eth0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'eth0'
option vlan '1'
option ports '0 1 2 8t'
config switch_vlan
option vlan '2'
option ports '3 8t'
config interface 'wan'
option proto 'dhcp'
option ifname 'eth0.2'
config interface 'gsm'
option _orig_ifname 'eth1'
option _orig_bridge 'false'
option proto '3g'
option device '/dev/ttyS0'
option service 'umts'
config interface 'LTE'
option proto 'dhcp'
option ifname 'eth1'
Старый 02.07.2019, 23:17   #634
blakx87
config defaults
option syn_flood '1'
option input 'ACCEPT'
option output 'ACCEPT'
option forward 'REJECT'
config zone
option name 'lan'
option forward 'ACCEPT'
option network 'lan'
config zone
option name 'wan'
option input 'REJECT'
option masq '1'
option mtu_fix '1'
option network 'wan wan6 gsm LTE'
config forwarding
option src 'lan'
option dest 'wan'
config rule
option src 'wan'
option proto 'udp'
option dest_port '68'
option target 'ACCEPT'
option family 'ipv4'
config rule
option name 'Allow-Ping'
option src 'wan'
option proto 'icmp'
config rule
option name 'Allow-IGMP'
option src 'wan'
option proto 'igmp'
config rule
option name 'Allow-DHCPv6'
option src 'wan'
option proto 'udp'
option src_ip 'fe80::/10'
option src_port '547'
option dest_ip 'fe80::/10'
option dest_port '546'
option family 'ipv6'
config rule
option name 'Allow-MLD'
option src 'wan'
option proto 'icmp'
list icmp_type '130/0'
list icmp_type '131/0'
list icmp_type '132/0'
list icmp_type '143/0'
config rule
option src 'wan'
option proto 'icmp'
list icmp_type 'echo-request'
list icmp_type 'echo-reply'
list icmp_type 'bad-header'
option limit '1000/sec'
config rule
option src 'wan'
option dest '*'
option proto 'icmp'
config include
config rule
option src 'wan'
option dest 'lan'
option proto 'esp'
config rule
option src 'wan'
option dest 'lan'
option dest_port '500'
option proto 'udp'
config include 'miniupnpd'
option type 'script'
option path '/usr/share/miniupnpd/firewall.include'
option family 'any'
option reload '1'
Старый 02.07.2019, 23:33   #635
Сообщение от blakx87 Посмотреть сообщение
Не могу войти в веб интерфейс, что бы просматривать видео
Для того чтобы войти в веб интерфейс нужно его установить для начала - пакет luci, а также установить пакеты для работы с камерой luci-app-mjpg-streamer
Просмотр камеры в любом браузере:
http://IP_роутера:порт роутера/?action=stream
Старый 03.07.2019, 01:40   #636
blakx87
почему то этих пакетов нет у меня в списке для установки
Старый 03.07.2019, 12:15   #637
blakx87
Роутер какой ?
Сколько памяти у него ?
Где брали openwrt ?
Старый 05.07.2019, 19:09   #638
blakx87
blakx87
теперь видео есть. Не сохраняет фотки в папке. Химичили начал выдавать и какую то запись удалил в loсal и теперь перестало( Через стандартное меню MJPG-streamer ничего не получается. После команды /etc/init.d/mjpg-streamer start
выдает /etc/init.d/mjpg-streamer: unsuported output option 'file' in section 'core'
Старый 05.07.2019, 19:41   #639
blakx87
запустил
mjpg_streamer -i "input_uvc.so -d /dev/video0 -r 640x480 -f 5 -o "output_http.so -w /www/webcam -p 8080"
заработало
Старый 05.07.2019, 19:55   #640
запустил
заработало
Да там есть тонкости, от версии mjpg streamer-а зависит
Главное чтобы места хватило, а оно может быстро закончится))
Текущее время: 06:45. Часовой пояс GMT +3.
