#1 |
Для достоверности что примонтировались разделы проверь те фаилы с роутера в винсцп - не понял?
#2 |
по размеру не лезут не хватает пакетам 750кб. уже несколько дней пробовал не получается, все подключить.
#3 |
если только снести luci
#4 |
таки где USB у nanostation2???
Atheros AP2315 не имеет встроенного USB. |
#5 |
root@OpenWrt:~# dmesg
[ 0.000000] Linux version 3.3.8 (blogic@Debian-60-squeeze-64-minimal) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #1 Sat Mar 23 17:43:48 UTC 2013 [ 0.000000] gpiochip_add: registered GPIOs 0 to 21 on device: ar2315-gpio [ 0.000000] ar2315-gpio: registered 22 GPIOs [ 0.000000] bootconsole [early0] enabled [ 0.000000] CPU revision is: 00019064 (MIPS 4KEc) [ 0.000000] Determined physical RAM map: [ 0.000000] memory: 01000000 @ 00000000 (usable) [ 0.000000] Initrd not found or empty - disabling initrd [ 0.000000] Zone PFN ranges: [ 0.000000] Normal 0x00000000 -> 0x00001000 [ 0.000000] Movable zone start PFN for each node [ 0.000000] Early memory PFN ranges [ 0.000000] 0: 0x00000000 -> 0x00001000 [ 0.000000] On node 0 totalpages: 4096 [ 0.000000] free_area_init_node: node 0, pgdat 802d4700, node_mem_map 80330000 [ 0.000000] Normal zone: 32 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 4064 pages, LIFO batch:0 [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4064 [ 0.000000] Kernel command line: console=ttyS0,9600 rootfstype=squashfs,jffs2 [ 0.000000] PID hash table entries: 64 (order: -4, 256 bytes) [ 0.000000] Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.000000] Primary instruction cache 16kB, VIPT, 4-way, linesize 16 bytes. [ 0.000000] Primary data cache 16kB, 4-way, VIPT, no aliases, linesize 16 bytes [ 0.000000] Memory: 12920k/16384k available (2285k kernel code, 3464k reserved, 353k data, 168k init, 0k highmem) [ 0.000000] NR_IRQS:128 [ 0.000000] console [ttyS0] enabled, bootconsole disabled [ 0.010000] Calibrating delay loop... 183.70 BogoMIPS (lpj=918528) [ 0.110000] pid_max: default: 32768 minimum: 301 [ 0.120000] Mount-cache hash table entries: 512 [ 0.130000] NET: Registered protocol family 16 [ 0.850000] bio: create slab <bio-0> at 0 [ 0.870000] PCI host bridge to bus 0000:00 [ 0.880000] pci_bus 0000:00: root bus resource [mem 0x80800000-0x857f7fff] [ 0.890000] pci_bus 0000:00: root bus resource [io 0x817f8000-0x817ffffe] [ 0.900000] pci 0000:00:00.0: [168c:ff18] type 0 class 0x000200 [ 0.900000] pci 0000:00:00.0: reg 10: [mem 0x00000000-0x0001ffff] [ 0.900000] pci 0000:00:00.0: reg 14: [mem 0x00000000-0x03ffffff] [ 0.900000] pci 0000:00:00.0: reg 18: [mem 0x00000000-0x003fffff] [ 0.900000] pci 0000:00:03.0: [168c:ff18] type 0 class 0x000200 [ 0.900000] pci 0000:00:03.0: reg 10: [mem 0x00000000-0x0001ffff] [ 0.900000] pci 0000:00:03.0: reg 14: [mem 0x00000000-0x03ffffff] [ 0.900000] pci 0000:00:03.0: reg 18: [mem 0x00000000-0x003fffff] [ 0.900000] pci 0000:00:00.0: BAR 1: can't assign mem (size 0x4000000) [ 0.910000] pci 0000:00:03.0: BAR 1: can't assign mem (size 0x4000000) [ 0.920000] pci 0000:00:00.0: BAR 2: assigned [mem 0x80800000-0x80bfffff] [ 0.930000] pci 0000:00:03.0: BAR 2: assigned [mem 0x80c00000-0x80ffffff] [ 0.940000] pci 0000:00:00.0: BAR 0: assigned [mem 0x81000000-0x8101ffff] [ 0.950000] pci 0000:00:03.0: BAR 0: assigned [mem 0x81020000-0x8103ffff] [ 0.960000] Switching to clocksource MIPS [ 0.990000] NET: Registered protocol family 2 [ 1.040000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes) [ 1.130000] TCP established hash table entries: 512 (order: 0, 4096 bytes) [ 1.210000] TCP bind hash table entries: 512 (order: -1, 2048 bytes) [ 1.290000] TCP: Hash tables configured (established 512 bind 512) [ 1.360000] TCP reno registered [ 1.400000] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 1.470000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 1.550000] NET: Registered protocol family 1 [ 1.600000] PCI: CLS 0 bytes, default 16 [ 1.600000] Radio config found at offset 0xf8(0x1f8) [ 1.690000] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 1.760000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc. [ 1.870000] msgmni has been set to 25 [ 1.920000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254) [ 2.010000] io scheduler noop registered [ 2.060000] io scheduler deadline registered (default) [ 2.120000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled [ 2.220000] serial8250: ttyS0 at MMIO 0xb1100003 (irq = 37) is a 16550A [ 2.340000] gpiodev: gpio device registered with major 253 [ 2.420000] Searching for RedBoot partition table in spiflash at offset 0x3d0000 [ 2.560000] Searching for RedBoot partition table in spiflash at offset 0x3e0000 [ 2.690000] 7 RedBoot partitions found on MTD device spiflash [ 2.760000] Creating 7 MTD partitions on "spiflash": [ 2.820000] 0x000000000000-0x000000030000 : "RedBoot" [ 2.890000] 0x000000030000-0x000000120000 : "kernel" [ 2.960000] 0x000000120000-0x0000003c0000 : "rootfs" [ 3.030000] mtd: partition "rootfs" set to be root filesystem [ 3.100000] mtd: partition "rootfs_data" created automatically, ofs=2D0000, len=F0000 [ 3.200000] 0x0000002d0000-0x0000003c0000 : "rootfs_data" [ 3.270000] 0x0000003c0000-0x0000003e0000 : "cfg" [ 3.340000] 0x0000003e0000-0x0000003ef000 : "FIS directory" [ 3.420000] 0x0000003ef000-0x0000003f0000 : "RedBoot config" [ 3.500000] 0x0000003f0000-0x000000400000 : "boardconfig" [ 3.650000] eth0: Atheros AR231x: 00:15:6d:f1:96:db, irq 4 [ 3.900000] ar231x_eth_mii: probed [ 3.950000] eth0: attached PHY driver [Generic PHY] (mii_bus ![]() [ 4.040000] Registered led device: gpio1 [ 4.040000] Registered led device: gpio2 [ 4.040000] Registered led device: gpio3 [ 4.040000] Registered led device: gpio4 [ 4.040000] Registered led device: wlan [ 4.050000] TCP cubic registered [ 4.090000] NET: Registered protocol family 17 [ 4.140000] Bridge firewalling registered [ 4.190000] 8021q: 802.1Q VLAN Support v1.8 [ 4.260000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2. [ 4.350000] Freeing unused kernel memory: 168k freed [ 12.790000] JFFS2 notice: (462) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 8 of xref (0 dead, 2 orphan) found. [ 17.550000] Compat-drivers backport release: compat-drivers-2012-09-04-2-gddac993 [ 17.640000] Backport based on wireless-testing.git master-2012-09-07 [ 17.710000] compat.git: wireless-testing.git [ 17.850000] cfg80211: Calling CRDA to update world regulatory domain [ 17.930000] cfg80211: World regulatory domain updated: [ 17.990000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 18.090000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 18.180000] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm) [ 18.270000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm) [ 18.370000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 18.460000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 19.030000] SCSI subsystem initialized [ 19.410000] usbcore: registered new interface driver usbfs [ 19.480000] usbcore: registered new interface driver hub [ 19.550000] usbcore: registered new device driver usb [ 20.590000] ath: EEPROM regdomain: 0x0 [ 20.590000] ath: EEPROM indicates default country code should be used [ 20.590000] ath: doing EEPROM country->regdmn map search [ 20.590000] ath: country maps to regdmn code: 0x3a [ 20.590000] ath: Country alpha2 being used: US [ 20.590000] ath: Regpair used: 0x3a [ 20.590000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht' [ 20.600000] ath5k: phy0: Atheros AR2315 chip found (MAC: 0x86, PHY: 0x48) [ 20.690000] cfg80211: Calling CRDA for country: US [ 20.740000] cfg80211: Regulatory domain changed to country: US [ 20.810000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 20.910000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm) [ 21.010000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm) [ 21.100000] cfg80211: (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 21.190000] cfg80211: (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 21.290000] cfg80211: (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 21.380000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm) [ 21.940000] PPP generic driver version 2.4.2 [ 22.450000] ip_tables: (C) 2000-2006 Netfilter Core Team [ 23.000000] NET: Registered protocol family 24 [ 23.230000] nf_conntrack version 0.5.0 (204 buckets, 816 max) [ 24.130000] uhci_hcd: USB Universal Host Controller Interface driver [ 35.860000] device eth0 entered promiscuous mode [ 36.020000] br-lan: port 1(eth0) entered forwarding state [ 36.080000] br-lan: port 1(eth0) entered forwarding state [ 38.080000] br-lan: port 1(eth0) entered forwarding state [ 797.610000] Initializing USB Mass Storage driver... [ 797.670000] usbcore: registered new interface driver usb-storage [ 797.750000] USB Mass Storage support registered. [ 879.210000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 879.290000] Warning! ehci_hcd should always be loaded before uhci_hcd and ohci_hcd, not after [ 3428.080000] ext4: Unknown symbol crc16 (err 0) [ 3809.710000] NTFS driver 2.1.30 [Flags: R/O MODULE]. [ 4988.200000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver root@OpenWrt:~# я про это писал на наносе нет встроеного усб пытаюсь через комп или вариант nfs? |
#6 |
root@OpenWrt:~# opkg list-installed
base-files - 117-r36088 block-mount - 0.2.0-9 busybox - 1.19.4-6 chat - 2.4.5-8 comgt - 0.32-21 dnsmasq - 2.62-2 dropbear - 2011.54-2 firewall - 2-55.1 gpioctl - 1.0-1 hotplug2 - 1.0-beta-4 iptables - 1.4.10-4 iw - 3.6-1 kmod-ath5k - 3.3.8+2012-09-07-3 kmod-crypto-aes - 3.3.8-1 kmod-crypto-core - 3.3.8-1 kmod-fs-ext4 - 3.3.8-1 kmod-ipt-conntrack - 3.3.8-1 kmod-lib-crc-ccitt - 3.3.8-1 kmod-lib-crc16 - 3.3.8-1 kmod-mac80211 - 3.3.8+2012-09-07-3 kmod-nls-cp1251 - 3.3.8-1 kmod-nls-utf8 - 3.3.8-1 kmod-pppoe - 3.3.8-1 kmod-pppox - 3.3.8-1 kmod-usb-core - 3.3.8-1 kmod-usb-ohci - 3.3.8-1 kmod-usb-storage - 3.3.8-1 kmod-usb-test - 3.3.8-1 kmod-usb2 - 3.3.8-1 libblkid - 2.21.2-1 libblobmsg-json - 2013-01-29-0bc317aa4d9af44806c28ca286d79a8b5a92b2b8 libc - 0.9.33.2-1 libgcc - 4.6-linaro-1 libip4tc - 1.4.10-4 libiwinfo - 36 libiwinfo-lua - 36 libjson - 0.9-2 liblua - 5.1.4-8 libubox - 2013-01-29-0bc317aa4d9af44806c28ca286d79a8b5a92b2b8 libubus-lua - 2013-01-13-bf566871bd6a633e4504c60c6fc55b2a97305a50 libuci - 2013-01-04.1-1 libuci-lua - 2013-01-04.1-1 libuuid - 2.21.2-1 lua - 5.1.4-8 luci-app-firewall - 0.11.1-1 luci-lib-ipkg - 0.11.1-1 luci-lib-sys - 0.11.1-1 luci-lib-web - 0.11.1-1 luci-mod-admin-core - 0.11.1-1 luci-mod-admin-full - 0.11.1-1 luci-proto-ppp - 0.11.1-1 luci-sgi-cgi - 0.11.1-1 luci-theme-base - 0.11.1-1 luci-theme-openwrt - 0.11.1-1 mtd - 18.1 netifd - 2013-01-29.2-4bb99d4eb462776336928392010b372236ac3c93 opkg - 618-3 ppp - 2.4.5-8 swconfig - 10 ubus - 2013-01-13-bf566871bd6a633e4504c60c6fc55b2a97305a50 ubusd - 2013-01-13-bf566871bd6a633e4504c60c6fc55b2a97305a50 uci - 2013-01-04.1-1 wpad-mini - 20120910-1 Collected errors: * parse_from_stream_nomalloc: Missing new line character at end of file! root@OpenWrt:~# |
#7 |
[ 0.000000] Linux version 3.3.8 (blogic@Debian-60-squeeze-64-minimal) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #1 Sat Mar 23 17:43:48 UTC 2013 [ 0.000000] gpiochip_add: registered GPIOs 0 to 21 on device: ar2315-gpio [ 0.000000] ar2315-gpio: registered 22 GPIOs [ 0.000000] bootconsole [early0] enabled [ 0.000000] CPU revision is: 00019064 (MIPS 4KEc) [ 0.000000] Determined physical RAM map: [ 0.000000] memory: 01000000 @ 00000000 (usable) [ 0.000000] Initrd not found or empty - disabling initrd [ 0.000000] Zone PFN ranges: [ 0.000000] Normal 0x00000000 -> 0x00001000 [ 0.000000] Movable zone start PFN for each node [ 0.000000] Early memory PFN ranges [ 0.000000] 0: 0x00000000 -> 0x00001000 [ 0.000000] On node 0 totalpages: 4096 [ 0.000000] free_area_init_node: node 0, pgdat 802d4700, node_mem_map 80330000 [ 0.000000] Normal zone: 32 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 4064 pages, LIFO batch:0 [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4064 [ 0.000000] Kernel command line: console=ttyS0,9600 rootfstype=squashfs,jffs2 [ 0.000000] PID hash table entries: 64 (order: -4, 256 bytes) [ 0.000000] Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.000000] Primary instruction cache 16kB, VIPT, 4-way, linesize 16 bytes. [ 0.000000] Primary data cache 16kB, 4-way, VIPT, no aliases, linesize 16 bytes [ 0.000000] Memory: 12920k/16384k available (2285k kernel code, 3464k reserved, 353k data, 168k init, 0k highmem) [ 0.000000] NR_IRQS:128 [ 0.000000] console [ttyS0] enabled, bootconsole disabled [ 0.010000] Calibrating delay loop... 183.70 BogoMIPS (lpj=918528) [ 0.110000] pid_max: default: 32768 minimum: 301 [ 0.120000] Mount-cache hash table entries: 512 [ 0.130000] NET: Registered protocol family 16 [ 0.850000] bio: create slab <bio-0> at 0 [ 0.870000] PCI host bridge to bus 0000:00 [ 0.880000] pci_bus 0000:00: root bus resource [mem 0x80800000-0x857f7fff] [ 0.890000] pci_bus 0000:00: root bus resource [io 0x817f8000-0x817ffffe] [ 0.900000] pci 0000:00:00.0: [168c:ff18] type 0 class 0x000200 [ 0.900000] pci 0000:00:00.0: reg 10: [mem 0x00000000-0x0001ffff] [ 0.900000] pci 0000:00:00.0: reg 14: [mem 0x00000000-0x03ffffff] [ 0.900000] pci 0000:00:00.0: reg 18: [mem 0x00000000-0x003fffff] [ 0.900000] pci 0000:00:03.0: [168c:ff18] type 0 class 0x000200 [ 0.900000] pci 0000:00:03.0: reg 10: [mem 0x00000000-0x0001ffff] [ 0.900000] pci 0000:00:03.0: reg 14: [mem 0x00000000-0x03ffffff] [ 0.900000] pci 0000:00:03.0: reg 18: [mem 0x00000000-0x003fffff] [ 0.900000] pci 0000:00:00.0: BAR 1: can't assign mem (size 0x4000000) [ 0.910000] pci 0000:00:03.0: BAR 1: can't assign mem (size 0x4000000) [ 0.920000] pci 0000:00:00.0: BAR 2: assigned [mem 0x80800000-0x80bfffff] [ 0.930000] pci 0000:00:03.0: BAR 2: assigned [mem 0x80c00000-0x80ffffff] [ 0.940000] pci 0000:00:00.0: BAR 0: assigned [mem 0x81000000-0x8101ffff] [ 0.950000] pci 0000:00:03.0: BAR 0: assigned [mem 0x81020000-0x8103ffff] [ 0.960000] Switching to clocksource MIPS [ 0.990000] NET: Registered protocol family 2 [ 1.040000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes) [ 1.130000] TCP established hash table entries: 512 (order: 0, 4096 bytes) [ 1.210000] TCP bind hash table entries: 512 (order: -1, 2048 bytes) [ 1.290000] TCP: Hash tables configured (established 512 bind 512) [ 1.360000] TCP reno registered [ 1.400000] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 1.470000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 1.550000] NET: Registered protocol family 1 [ 1.600000] PCI: CLS 0 bytes, default 16 [ 1.600000] Radio config found at offset 0xf8(0x1f8) [ 1.690000] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 1.760000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc. [ 1.870000] msgmni has been set to 25 [ 1.920000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254) [ 2.010000] io scheduler noop registered [ 2.060000] io scheduler deadline registered (default) [ 2.120000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled [ 2.220000] serial8250: ttyS0 at MMIO 0xb1100003 (irq = 37) is a 16550A [ 2.340000] gpiodev: gpio device registered with major 253 [ 2.420000] Searching for RedBoot partition table in spiflash at offset 0x3d0000 [ 2.560000] Searching for RedBoot partition table in spiflash at offset 0x3e0000 [ 2.690000] 7 RedBoot partitions found on MTD device spiflash [ 2.760000] Creating 7 MTD partitions on "spiflash": [ 2.820000] 0x000000000000-0x000000030000 : "RedBoot" [ 2.890000] 0x000000030000-0x000000120000 : "kernel" [ 2.960000] 0x000000120000-0x0000003c0000 : "rootfs" [ 3.030000] mtd: partition "rootfs" set to be root filesystem [ 3.100000] mtd: partition "rootfs_data" created automatically, ofs=2D0000, len=F0000 [ 3.200000] 0x0000002d0000-0x0000003c0000 : "rootfs_data" [ 3.270000] 0x0000003c0000-0x0000003e0000 : "cfg" [ 3.340000] 0x0000003e0000-0x0000003ef000 : "FIS directory" [ 3.420000] 0x0000003ef000-0x0000003f0000 : "RedBoot config" [ 3.490000] 0x0000003f0000-0x000000400000 : "boardconfig" [ 3.650000] eth0: Atheros AR231x: 00:15:6d:f1:96:db, irq 4 [ 3.900000] ar231x_eth_mii: probed [ 3.940000] eth0: attached PHY driver [Generic PHY] (mii_bus ![]() [ 4.040000] Registered led device: gpio1 [ 4.040000] Registered led device: gpio2 [ 4.040000] Registered led device: gpio3 [ 4.040000] Registered led device: gpio4 [ 4.040000] Registered led device: wlan [ 4.050000] TCP cubic registered [ 4.090000] NET: Registered protocol family 17 [ 4.140000] Bridge firewalling registered [ 4.190000] 8021q: 802.1Q VLAN Support v1.8 [ 4.260000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2. [ 4.350000] Freeing unused kernel memory: 168k freed [ 12.800000] JFFS2 notice: (462) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 6 of xref (0 dead, 0 orphan) found. [ 14.580000] SCSI subsystem initialized [ 14.980000] usbcore: registered new interface driver usbfs [ 15.050000] usbcore: registered new interface driver hub [ 15.120000] usbcore: registered new device driver usb [ 16.310000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 16.480000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 16.650000] uhci_hcd: USB Universal Host Controller Interface driver [ 16.850000] Initializing USB Mass Storage driver... [ 16.910000] usbcore: registered new interface driver usb-storage [ 16.990000] USB Mass Storage support registered. [ 42.140000] Compat-drivers backport release: compat-drivers-2012-09-04-2-gddac993 [ 42.230000] Backport based on wireless-testing.git master-2012-09-07 [ 42.310000] compat.git: wireless-testing.git [ 42.460000] cfg80211: Calling CRDA to update world regulatory domain [ 42.540000] cfg80211: World regulatory domain updated: [ 42.600000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 42.700000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 42.790000] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm) [ 42.880000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm) [ 42.980000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 43.070000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 44.850000] ath: EEPROM regdomain: 0x0 [ 44.850000] ath: EEPROM indicates default country code should be used [ 44.850000] ath: doing EEPROM country->regdmn map search [ 44.850000] ath: country maps to regdmn code: 0x3a [ 44.850000] ath: Country alpha2 being used: US [ 44.850000] ath: Regpair used: 0x3a [ 44.850000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht' [ 44.860000] ath5k: phy0: Atheros AR2315 chip found (MAC: 0x86, PHY: 0x48) [ 44.950000] cfg80211: Calling CRDA for country: US [ 45.000000] cfg80211: Regulatory domain changed to country: US [ 45.070000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 45.170000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm) [ 45.270000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm) [ 45.360000] cfg80211: (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 45.450000] cfg80211: (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 45.540000] cfg80211: (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 45.640000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm) [ 47.830000] NTFS driver 2.1.30 [Flags: R/O MODULE]. [ 48.590000] PPP generic driver version 2.4.2 [ 49.190000] ip_tables: (C) 2000-2006 Netfilter Core Team [ 49.770000] NET: Registered protocol family 24 [ 50.140000] nf_conntrack version 0.5.0 (204 buckets, 816 max) [ 70.870000] device eth0 entered promiscuous mode [ 71.030000] br-lan: port 1(eth0) entered forwarding state [ 71.090000] br-lan: port 1(eth0) entered forwarding state [ 73.090000] br-lan: port 1(eth0) entered forwarding state root@OpenWrt:~# это после перезагрузки |
#8 |
в диру /tmp пакеты могу ставить, с стороны роуетра она видна, но на этом всё при установке самого пакета ругается нет места. Может есть смысл режим монитора плюс airodump-ng. Или кому попадалась непосредственно статья к наносу по установке железа разъёма усб или подключить nfs.
#9 |
am7528 уберите "простыни" под спойлер (кнопочка с плюсиком).
Развернуть для просмотраспойлер
[свернуть]
istarik.ru |
#10 |
хм, что- то кнопки -плюсика не вижу. |
