Старый 29.03.2014, 11:14   #21
kirex
kirex is an unknown quantity at this point
По умолчанию Re: Акваконтроллер
А примеры работают? чтоб проверить аппаратную часть
например вот такой
//Sample using LiquidCrystal library
#include <LiquidCrystal.h>
This program will test the LCD panel and the buttons
Mark Bramwell, July 2010
// select the pins used on the LCD panel
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
// define some values used by the panel and buttons
int lcd_key     = 0;
int adc_key_in  = 0;
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
// read the buttons
int read_LCD_buttons()
adc_key_in = analogRead(0);      // read the value from the sensor
 // my buttons when read are centered at these valies: 0, 144, 329, 504, 741
 // we add approx 50 to those values and check to see if we are close
if (adc_key_in > 1000) return btnNONE; // We make this the 1st option for speed reasons since it will be the most likely result
 // For V1.1 us this threshold
if (adc_key_in < 50)   return btnRIGHT;
 if (
adc_key_in < 250)  return btnUP;
 if (
adc_key_in < 450)  return btnDOWN;
 if (
adc_key_in < 650)  return btnLEFT;
 if (
adc_key_in < 850)  return btnSELECT;
// For V1.0 comment the other threshold and use the one below:
 if (adc_key_in < 195)  return btnUP;
 if (adc_key_in < 380)  return btnDOWN;
 if (adc_key_in < 555)  return btnLEFT;
 if (adc_key_in < 790)  return btnSELECT;
return btnNONE;  // when all others fail, return this...
lcd.begin(16, 2);              // start the library
lcd.setCursor(0,0);
lcd.print("Push the buttons"); // print a simple message
lcd.setCursor(9,1);            // move cursor to second line "1" and 9 spaces over
lcd.print(millis()/1000);      // display seconds elapsed since power-up
lcd.setCursor(0,1);            // move to the begining of the second line
lcd_key = read_LCD_buttons();  // read the buttons
switch (lcd_key)               // depending on which button was pushed, we perform an action
   case
btnRIGHT:
lcd.print("RIGHT ");
     break;
   case
btnLEFT:
lcd.print("LEFT   ");
     break;
   case
btnUP:
lcd.print("UP    ");
     break;
   case
btnDOWN:
lcd.print("DOWN  ");
     break;
   case
btnSELECT:
lcd.print("SELECT");
     break;
     case
btnNONE:
lcd.print("NONE  ");
     break;
Да этот пример работает без проблем.
kirex вне форума   Ответить с цитированием
Старый 29.03.2014, 11:17   #22
kirex
а как надо?
Смысл вот в чём:
Допустим в автомате свет включается в 17.00 и выключается в 22.00. Иногда, особенно когда на улице пассмурно, необходимо включить свет например на час, для того чтобы поменять воду или покормить рыб. А потом опять в автомат.
Тоже самое с обогревом Н2. Когда меняю воду мне его надо выключить, а потом например через пол часа или через час опять включить в автомат.
Старый 29.03.2014, 12:21   #23
Bulatovor
Вес репутации: 801
теперь в этом примере добавь, кроме вывода на экран, управление реле -пока только кнопками без температурного датчика -сам сможешь? Так дополняя и проверяя скетч и составим программу.
С портом умеешь работать(Serial.print)? -для отладки очень помогает вывод отладочных сообщений
У меня просто нет такого железа, поэтому будем так потихонбку составлять программу -заодно и в програмировании разберешься
Последний раз редактировалось Bulatovor; 29.03.2014 в 12:25.
Старый 29.03.2014, 13:05   #24
kirex
Вот так кнопкой RIGHT выключается, а кнопкой LEFT включается.
Код HTML:
int Relay_Off = HIGH;
int Relay_On = LOW;
int lcd_key     = 0;
int adc_key_in  = 0;
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
// read the buttons
 if (adc_key_in < 250)  return btnUP;
 if (adc_key_in < 450)  return btnDOWN;
 if (adc_key_in < 650)  return btnLEFT;
 if (adc_key_in < 850)  return btnSELECT;
void setup()
  pinMode(41, OUTPUT);
 lcd.setCursor(0,0);
void loop()
 lcd.setCursor(13,1);            // move cursor to second line "1" and 9 spaces over
   case btnRIGHT:
     digitalWrite(41, Relay_Off);
  lcd.setCursor(7, 1);
  lcd.print("H2-Off");
     break;
   case btnLEFT:
     digitalWrite(41, Relay_On);
  lcd.print("H2-On ");
     break;
   case btnUP:
     lcd.print("UP    ");
     break;
   case btnDOWN:
     lcd.print("DOWN  ");
     break;
   case btnSELECT:
     break;
     case btnNONE:
     lcd.print("NONE  ");
     break;
Старый 29.03.2014, 14:02   #25
Bulatovor
Вес репутации: 801
Замечательно, теперь на кнопку Select добавь изменение флага(типа как в моем примере - изменение значения переменной по вкусу)с ручного режима на автоматический, следующим этапом будет добавление датчика температуры
Старый 29.03.2014, 14:30   #26
kirex
Спасибо за помощь.
Попробую сделать, только ближе к вечеру.
Сейчас нужно уехать, обещал детям в парк.
До вечера.
Старый 30.03.2014, 02:18   #27
kirex
Сделал вот так:
Код HTML:
int Relay_On = LOW;
int reg=0;// вводим флаг для автоматического (при значении-0) или ручного регулирования -1
int lcd_key     = 0;
int adc_key_in  = 0;
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
// read the buttons
void setup()
 lcd.setCursor(0,0);
void loop()
   case btnRIGHT:
     break;
   case btnLEFT:
     break;
   case btnUP:
     lcd.print("UP    ");
     break;
   case btnDOWN:
     lcd.print("DOWN  ");
     break;
   case btnSELECT:
     if(reg==1)
   {reg=0;
  lcd.setCursor(13, 1);
  lcd.print("Aut");}
  else
   {reg=1;
  lcd.print("Man");}
     break;
     case btnNONE:
     lcd.print("NONE  ");
     break;
Старый 30.03.2014, 10:40   #28
Bulatovor
Вес репутации: 801
Если работает, то замечательно, следующий этап - обработка значений датчика температуры. Сначала просто вставь чтение датчика и вывод температуры на LCD. Если работает нормально - тогда добавить переключение реле в зависимости от показаний датчика.
Старый 30.03.2014, 12:02   #29
Bulatovor
Вес репутации: 801
Замечания по предыдущему скетчу :
описательную часть
уже с полным правом можешь заменить на свое описание программы или просто удалить, чтоб мусора небыло
вот эту часть тоже можно удалить я думаю, вряд ли когда вернешься к старым версиям шилда
Старый 30.03.2014, 17:07   #30
kirex
Вот что получилсь:
Код HTML:
#include <OneWire.h>
#include <DallasTemperature.h>
OneWire  ds(53);  // Подключаем датчик температуры к 53 цифровому пину
int Relay_On = LOW;
int lcd_key     = 0;
int adc_key_in  = 0;
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
// read the buttons
void setup()
  pinMode(40, OUTPUT);
  digitalWrite(40, Relay_On);
void loop()
 analogWrite(10, 100);
 byte i;
  byte type_s;
  byte data[12];
  byte addr[8];
  float celsius, fahrenheit;
  // Ищем алрес датчика
  if ( !ds.search(addr)) {
    Serial.println("No more addresses.");
    Serial.println();
    ds.reset_search();
    delay(250);
    return;
  // Проверяем не было ли помех при передаче
  if (OneWire::crc8(addr, 7) != addr[7]) {
      Serial.println("CRC is not valid!");
      return;
  Serial.println();
  // Определяем серию датчика
  switch (addr[0]) {
    case 0x10:
      Serial.println("  Chip = DS18S20");
      type_s = 1;
      break;
    case 0x28:
      Serial.println("  Chip = DS18B20");
      type_s = 0;
      break;
    case 0x22:
      Serial.println("  Chip = DS1822");
      type_s = 0;
      break;
    default:
      Serial.println("Device is not a DS18x20 family device.");
      return;
  ds.reset();
  ds.select(addr);       // Выбираем адрес
  ds.write(0x44, 1);     // Производим замер, в режиме паразитного питания
  delay(750);
  ds.reset();
  ds.select(addr);
  ds.write(0xBE);         // Считываем оперативную память датчика
  for ( i = 0; i < 9; i++) {
    data[i] = ds.read();  // Заполняем массив считанными данными
  // Данные о температуре содержатся в первых двух байтах, переведем их в одно значение и преобразуем в шестнадцатиразрядное число
  unsigned int raw = (data[1] << 8) | data[0];
  // Переводим температуру в шкалы по Цельсию и Фаренгейту
  if (type_s)
    raw = raw << 3;
  if (data[7] == 0x10)
    raw = (raw & 0xFFF0) + 12 - data[6];
  } else {
    byte cfg =  (data[4] & 0x60);
    if (cfg == 0x00)
      raw = raw << 3;
    else if  (cfg == 0x20)
      raw = raw << 2;
    else if  (cfg == 0x40) \
      raw = raw << 1;
  // Вывод текущего значения температуры на дисплей
  celsius = (float)raw / 16.0;
  lcd.setCursor(0, 0);
  lcd.print("T=");
  lcd.setCursor(2, 0);
  lcd.print(celsius);
  delay (10);
  fahrenheit = celsius * 1.8 + 32.0;
  Serial.print("Temp = ");
  Serial.print(celsius);
  Serial.print(" C, ");
  Serial.print(fahrenheit);
  Serial.println(" F");
  // Если температура достигает 28,3 (с погрешностью), отключаем кипятильник
  if (celsius > 28.3)
     digitalWrite(40, Relay_Off);
  lcd.setCursor(0, 1);
  lcd.print("H1-Off");
  if (celsius < 28.0)
  lcd.print("H1-On ");
// Если температура достигает 28,5 (с погрешностью), отключаем кипятильник
  if (celsius > 28.5)
  if (celsius < 28.0)
   case btnRIGHT:
     break;
   case btnLEFT:
     break;
   case btnUP:
     lcd.print("UP    ");
     break;
   case btnDOWN:
     lcd.print("DOWN  ");
     break;
   case btnSELECT:
     if(reg==1)
   {reg=0;
  lcd.print("Aut");}
  else
   {reg=1;
  lcd.print("Man");}
     break;
     case btnNONE:
     break;
Пока держишь кнопку реле срабатывает, отпускаешь - возвращается в первоначальное положение.
Текущее время: 18:18. Часовой пояс GMT +3.
