Старый 02.10.2014, 09:47   #211
По умолчанию Re: Устанавливаем USB Flash диск в OpenWrt
А пакет kmod-fs-vfat установлен?
Старый 02.10.2014, 09:50   #212
rapid
rapid is an unknown quantity at this point
флешка определяется системой sda,sda1. Пробовал напрямую и через USB хаб
установлен, а на команду отвечает: invalid argument
Последний раз редактировалось rapid; 02.10.2014 в 10:07.
rapid вне форума   Ответить с цитированием
Старый 02.10.2014, 10:07   #213
А если без указания FS
mount /dev/sda1 /mnt
Старый 02.10.2014, 10:29   #214
rapid
root@OpenWrt:~# mount /dev/sda1 /mnt
mount: mounting /dev/sda1 on /mnt failed: Invalid argument
Вот dmesg:
[    0.000000] MyLoader: sysp=444ba8b5, boardp=5fbcaeef, parts=ebc66edc
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU revision is: 00019374 (MIPS 24Kc)
[    0.000000] SoC: Atheros AR9330 rev 1
[    0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
[    0.000000] Determined physical RAM map:
[    0.000000]  memory: 02000000 @ 00000000 (usable)
[    0.000000] Initrd not found or empty - disabling initrd
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x00000000-0x01ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00000000-0x01ffffff]
[    0.000000] On node 0 totalpages: 8192
[    0.000000] free_area_init_node: node 0, pgdat 803109b0, node_mem_map 81000000
[    0.000000]   Normal zone: 64 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 8192 pages, LIFO batch:0
[    0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[    0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 8128
[    0.000000] Kernel command line:  board=TL-MR3020 console=ttyATH0,115200 rootfstype=squashfs,jffs2 noinitrd
[    0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
[    0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Writing ErrCtl register=00000000
[    0.000000] Readback ErrCtl register=00000000
[    0.000000] Memory: 28784k/32768k available (2243k kernel code, 3984k reserved, 599k data, 228k init, 0k highmem)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS:51
[    0.080000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
[    0.080000] pid_max: default: 32768 minimum: 301
[    0.080000] Mount-cache hash table entries: 512
[    0.090000] NET: Registered protocol family 16
[    0.100000] MIPS: machine is TP-LINK TL-MR3020
[    0.350000] bio: create slab <bio-0> at 0
[    0.360000] Switching to clocksource MIPS
[    0.370000] NET: Registered protocol family 2
[    0.370000] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[    0.370000] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[    0.370000] TCP: Hash tables configured (established 512 bind 512)
[    0.380000] TCP: reno registered
[    0.380000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.390000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.400000] NET: Registered protocol family 1
[    0.400000] PCI: CLS 0 bytes, default 32
[    0.420000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.420000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.440000] msgmni has been set to 56
[    0.440000] io scheduler noop registered
[    0.440000] io scheduler deadline registered (default)
[    0.450000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[    0.450000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) is a AR933X UART
[    0.460000] console [ttyATH0] enabled, bootconsole disabled
[    0.470000] ath79-spi ath79-spi: master is unqueued, this is deprecated
[    0.480000] m25p80 spi0.0: found s25sl032p, expected m25p80
[    0.480000] m25p80 spi0.0: s25sl032p (4096 Kbytes)
[    0.490000] 5 tp-link partitions found on MTD device spi0.0
[    0.490000] Creating 5 MTD partitions on "spi0.0":
[    0.500000] 0x000000000000-0x000000020000 : "u-boot"
[    0.510000] 0x000000020000-0x0000001227bc : "kernel"
[    0.510000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[    0.520000] 0x0000001227bc-0x0000003f0000 : "rootfs"
[    0.530000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[    0.540000] mtd: device 2 (rootfs) set to be root filesystem
[    0.550000] 1 squashfs-split partitions found on MTD device rootfs
[    0.550000] 0x0000003a0000-0x0000003f0000 : "rootfs_data"
[    0.560000] 0x0000003f0000-0x000000400000 : "art"
[    0.570000] 0x000000020000-0x0000003f0000 : "firmware"
[    0.590000] libphy: ag71xx_mdio: probed
[    1.140000] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY]
[    1.150000] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode:MII
[    1.160000] TCP: cubic registered
[    1.160000] NET: Registered protocol family 17
[    1.160000] 8021q: 802.1Q VLAN Support v1.8
[    1.180000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
[    1.190000] Freeing unused kernel memory: 228K (80327000 - 80360000)
[    4.130000] usbcore: registered new interface driver usbfs
[    4.140000] usbcore: registered new interface driver hub
[    4.140000] usbcore: registered new device driver usb
[    4.160000] SCSI subsystem initialized
[    4.170000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.180000] ehci-platform: EHCI generic platform driver
[    4.180000] ehci-platform ehci-platform: EHCI Host Controller
[    4.190000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[    4.200000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[    4.220000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[    4.220000] hub 1-0:1.0: USB hub found
[    4.220000] hub 1-0:1.0: 1 port detected
[    4.230000] uhci_hcd: USB Universal Host Controller Interface driver
[    4.240000] usbcore: registered new interface driver usb-storage
[    4.680000] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    4.830000] hub 1-1:1.0: USB hub found
[    4.830000] hub 1-1:1.0: 4 ports detected
[    5.110000] usb 1-1.2: new high-speed USB device number 3 using ehci-platform
[    5.240000] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[    5.240000] scsi0 : usb-storage 1-1.2:1.0
[    6.430000] scsi 0:0:0:0: Direct-Access     ADATA    USB Flash Drive  1100 PQ: 0 ANSI: 4
[    6.440000] sd 0:0:0:0: [sda] 7826688 512-byte logical blocks: (4.00 GB/3.73 GiB)
[    6.440000] sd 0:0:0:0: [sda] Write Protect is off
[    6.450000] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[    6.450000] sd 0:0:0:0: [sda] No Caching mode page found
[    6.450000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    6.460000] sd 0:0:0:0: [sda] No Caching mode page found
[    6.470000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    6.480000]  sda: sda1
[    6.480000] sd 0:0:0:0: [sda] No Caching mode page found
[    6.490000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    6.490000] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    8.310000] jffs2: notice: (339) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 17 of xref (0 dead, 4 orphan) found.
[    8.360000] jffs2: notice: (336) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 17 of xref (0 dead, 4 orphan) found.
[   10.830000] NET: Registered protocol family 10
[   10.860000] nf_conntrack version 0.5.0 (453 buckets, 1812 max)
[   10.870000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   10.890000] Loading modules backported from Linux version master-2014-05-22-0-gf2032ea
[   10.900000] Backport generated by backports.git backports-20140320-37-g5c33da0
[   10.910000] ip_tables: (C) 2000-2006 Netfilter Core Team
[   10.940000] usbcore: registered new interface driver usbserial
[   10.950000] usbcore: registered new interface driver usbserial_generic
[   10.960000] usbserial: USB Serial support registered for generic
[   10.980000] xt_time: kernel timezone is -0000
[   11.020000] cfg80211: Calling CRDA to update world regulatory domain
[   11.020000] cfg80211: World regulatory domain updated:
[   11.030000] cfg80211:  DFS Master region: unset
[   11.030000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   11.040000] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   11.050000] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   11.060000] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[   11.060000] cfg80211:   (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
[   11.070000] cfg80211:   (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   11.080000] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   11.090000] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   11.100000] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[   11.180000] PPP generic driver version 2.4.2
[   11.190000] NET: Registered protocol family 24
[   11.230000] usbcore: registered new interface driver option
[   11.230000] usbserial: USB Serial support registered for GSM modem (1-port)
[   11.270000] ath: EEPROM regdomain: 0x0
[   11.270000] ath: EEPROM indicates default country code should be used
[   11.270000] ath: doing EEPROM country->regdmn map search
[   11.270000] ath: country maps to regdmn code: 0x3a
[   11.270000] ath: Country alpha2 being used: US
[   11.270000] ath: Regpair used: 0x3a
[   11.280000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   11.290000] cfg80211: Calling CRDA for country: US
[   11.300000] cfg80211: Regulatory domain changed to country: US
[   11.300000] cfg80211:  DFS Master region: FCC
[   11.300000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   11.310000] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[   11.320000] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm), (N/A)
[   11.330000] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm), (0 s)
[   11.340000] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[   11.350000] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[   11.350000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
[   16.460000] FAT-fs (sda1): codepage cp437 not found
[   19.920000] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   19.920000] device eth0 entered promiscuous mode
[   19.940000] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[   20.390000] eth0: link up (100Mbps/Full duplex)
[   20.390000] br-lan: port 1(eth0) entered forwarding state
[   20.400000] br-lan: port 1(eth0) entered forwarding state
[   20.400000] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   20.420000] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[   22.400000] br-lan: port 1(eth0) entered forwarding state
Старый 02.10.2014, 10:57   #215
Папка /mnt создана?
Еще нужно установить пакет kmod-nls-cp437
Старый 02.10.2014, 11:12   #216
rapid
папка /mnt создана, а вот пакет не установлен (только kmod-nls-base). Буду собирать отдельно
Старый 02.10.2014, 11:55   #217
AndreyNag
AndreyNag is an unknown quantity at this point
Exclamation Re: Устанавливаем USB Flash диск в OpenWrt
Сообщение от rapid Посмотреть сообщение
папка /mnt создана
Желательно создавать подпапки для каждого монтируемого ресурса.
Т.е. /mnt/sda, /mnt/home, etc.
AndreyNag вне форума   Ответить с цитированием
Старый 06.10.2014, 16:32   #218
LostInEcho
LostInEcho is an unknown quantity at this point
не могу отформатировать флешку((
root@OpenWrt:~# mkfs.ext4 /dev/sda
-ash: mkfs.ext4: not found
появилась еще проблемка
root@OpenWrt:~# mount -t ext4 /dev/sda1 /mnt/usb -o rw,sync
mount: mounting /dev/sda1 on /mnt/usb failed: Invalid argument
Вот что имеем:
root@OpenWrt:~# fdisk -l
Disk /dev/mtdblock0: 0 MB, 131072 bytes
255 heads, 63 sectors/track, 0 cylinders, total 256 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk /dev/mtdblock1: 1 MB, 1036288 bytes
255 heads, 63 sectors/track, 0 cylinders, total 2024 sectors
Disk /dev/mtdblock2: 2 MB, 2960896 bytes
255 heads, 63 sectors/track, 0 cylinders, total 5783 sectors
Disk /dev/mtdblock3: 1 MB, 1376256 bytes
255 heads, 63 sectors/track, 0 cylinders, total 2688 sectors
Disk /dev/mtdblock4: 0 MB, 65536 bytes
255 heads, 63 sectors/track, 0 cylinders, total 128 sectors
Disk /dev/mtdblock5: 3 MB, 3997696 bytes
255 heads, 63 sectors/track, 0 cylinders, total 7808 sectors
Disk /dev/sda: 4026 MB, 4026531840 bytes
124 heads, 62 sectors/track, 1022 cylinders, total 7864320 sectors
Disk identifier: 0x2c4bfd2a
Device Boot Start End Blocks Id System
/dev/sda1 * 133120 7864319 3865600 83 Linux
/dev/sda2 2048 133119 65536 82 Linux swap / Solaris
Последний раз редактировалось LostInEcho; 06.10.2014 в 16:55.
LostInEcho вне форума   Ответить с цитированием
Старый 06.10.2014, 17:41   #219
amod-cccp
Аватар для amod-cccp
Вес репутации: 634
Сообщение от LostInEcho Посмотреть сообщение
Предварительно создав папку и примонтировав
mkdir -p /mnt/sda1
mount -t ext4 /dev/sda1 /mnt/sda1 -o rw,sync
форматируем
mkfs.ext4 /dev/sda1
Старый 06.10.2014, 21:32   #220
rapid
Папка /mnt создана?
Скомпилировал прошивку с этим пакетом, та же проблема
Перечень пакетов:
base-files - 156-r42165
block-mount - 2014-06-22-e0430f5c62f367e5a8e02755412977b02c3fc45e
busybox - 1.22.1-2
chat - 2.4.6-2
comgt - 0.32-22
dnsmasq - 2.71-3
dropbear - 2014.65-1
firewall - 2014-08-11a
fstools - 2014-06-22-e0430f5c62f367e5a8e02755412977b02c3fc45e
hostapd-common - 2014-06-03-1
ip6tables - 1.4.21-1
iptables - 1.4.21-1
iw - 3.15-1
iwinfo - 50
jshn - 2014-07-16-bd388d2b6c2c151bf513c1e449417d18ce02d10b
jsonfilter - 2014-06-19-cdc760c58077f44fc40adbbe41e1556a67c1b9a9
kernel - 3.10.49-1-dbf3129fc00fae28219b9b4740d294ba
kmod-ath - 3.10.49+2014-05-22-1
kmod-ath9k - 3.10.49+2014-05-22-1
kmod-ath9k-common - 3.10.49+2014-05-22-1
kmod-cfg80211 - 3.10.49+2014-05-22-1
kmod-crypto-aes - 3.10.49-1
kmod-crypto-arc4 - 3.10.49-1
kmod-crypto-core - 3.10.49-1
kmod-fs-vfat - 3.10.49-1
kmod-gpio-button-hotplug - 3.10.49-1
kmod-ip6tables - 3.10.49-1
kmod-ipt-conntrack - 3.10.49-1
kmod-ipt-core - 3.10.49-1
kmod-ipt-nat - 3.10.49-1
kmod-ipt-nathelper - 3.10.49-1
kmod-ipv6 - 3.10.49-1
kmod-ledtrig-usbdev - 3.10.49-1
kmod-lib-crc-ccitt - 3.10.49-1
kmod-mac80211 - 3.10.49+2014-05-22-1
kmod-nls-base - 3.10.49-1
kmod-nls-cp437 - 3.10.49-1
kmod-ppp - 3.10.49-1
kmod-pppoe - 3.10.49-1
kmod-pppox - 3.10.49-1
kmod-scsi-core - 3.10.49-1
kmod-slhc - 3.10.49-1
kmod-usb-core - 3.10.49-1
kmod-usb-serial - 3.10.49-1
kmod-usb-serial-option - 3.10.49-1
kmod-usb-serial-wwan - 3.10.49-1
kmod-usb-storage - 3.10.49-1
kmod-usb-uhci - 3.10.49-1
kmod-usb2 - 3.10.49-1
libblobmsg-json - 2014-07-16-bd388d2b6c2c151bf513c1e449417d18ce02d10b
libc - 0.9.33.2-1
libgcc - 4.8-linaro-1
libip4tc - 1.4.21-1
libip6tc - 1.4.21-1
libiwinfo - 50
libjson-c - 0.11-2
libjson-script - 2014-07-16-bd388d2b6c2c151bf513c1e449417d18ce02d10b
libnl-tiny - 0.1-3
libopenssl - 1.0.1i-1
libpcre - 8.35-2
libpthread - 0.9.33.2-1
librt - 0.9.33.2-1
libubox - 2014-07-16-bd388d2b6c2c151bf513c1e449417d18ce02d10b
libubus - 2014-07-03-f688c7ad0b2435a89bfd13f5496cabf596b54c8f
libuci - 2014-04-11.1-1
libxtables - 1.4.21-1
mtd - 20
netifd - 2014-08-13-732074385389b1bb766a0b09b967d6883c357813
odhcp6c - 2014-07-21-67b311ab81736b35858664219d345844ab08fcc7
odhcpd - 2014-08-13-f41da55f11f06361e23f11a87f179aa56565c106
opkg - 9c97d5ecd795709c8584e972bfdf3aee3a5b846d-7
ppp - 2.4.6-2
procd - 2014-07-30-35e01a9601292b2f609e65c2ddb3990cba8f378e
swconfig - 10
uboot-envtools - 2014.07-1
ubox - 2014-05-30-c3d4118eee505f41c4d20a87f326479530837569
ubusd - 2014-07-03-f688c7ad0b2435a89bfd13f5496cabf596b54c8f
wpad-mini - 2014-06-03-1
zlib - 1.2.8-1
Текущее время: 01:04. Часовой пояс GMT +3.
