Старый 21.05.2014, 00:22   #11
По умолчанию Re: Проект yandexcamera.ru для видеонаблюдения
Пришлите PHP протестировать
Старый 21.05.2014, 00:24   #12
shveps
shveps has a reputation beyond reputeshveps has a reputation beyond reputeshveps has a reputation beyond reputeshveps has a reputation beyond reputeshveps has a reputation beyond reputeshveps has a reputation beyond reputeshveps has a reputation beyond reputeshveps has a reputation beyond reputeshveps has a reputation beyond reputeshveps has a reputation beyond reputeshveps has a reputation beyond repute
Код
<?php
$max_photos
=1000;
//cam init
$cams=Array (
"Моя комната|http://online.yandexcamera.ru/yandex/show/215/image?|rotate180|rec|",
"Парковка|http://online.yandexcamera.ru/yandex/show/3/image?|||",
//here is passwords for access cam view
$passwords=Array (
1=>"pass1"//pasha
2=>"pass2"//andrey
3=>"pass3",
4=>"pass4",
$salt="abcde12345"//your secret salt
$refresh_time=50//sec
$cam=doubleval(@$_GET['cam']);
$auth=0;
if(isset(
$_GET['pass'])) {$pass=$_GET['pass']; }elseif(isset($_POST['pass'])){ $pass=$_POST['pass']; }else {$pass="";}
if (!
preg_match('/^[a-zA-Z0-9-]+$/i',$pass)) { if ($pass!="") { $auth=2; } $pass="";}
if(isset(
$_GET['rec'])) {$rec=$_GET['rec']; }elseif(isset($_POST['rec'])){ $rec=$_POST['rec']; } else {$rec=0;}
if (!
preg_match('/^[0-9]+$/i',$rec)) { $rec=0;}
$hache=md5($_SERVER['HTTP_HOST'].$salt);
session_cache_limiter ('nocache');
session_name($hache);
session_start();
$sid=session_id();
$ids="s".md5($hache);
if (!isset(
$_SESSION[$ids])){$_SESSION[$ids]=0; }
$divst="";
?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
   "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en">
<head><meta http-equiv="Content-Type" content="text/html; charset=windows-1251" />
<title>Cams by eurowebcart.ru</title>
<link href="http://getbootstrap.com/2.3.2/assets/css/bootstrap.css" rel="stylesheet">
<link href="http://getbootstrap.com/2.3.2/assets/css/bootstrap-responsive.css" rel="stylesheet">
<link href="http://getbootstrap.com/2.3.2/assets/css/docs.css" rel="stylesheet">
<link href="http://getbootstrap.com/2.3.2/assets/js/google-code-prettify/prettify.css" rel="stylesheet">
<!--[if lt IE 9]>
<script src="http://getbootstrap.com/2.3.2/assets/js/html5shiv.js"></script>
<![endif]-->
<script src="http://getbootstrap.com/2.3.2/assets/js/jquery.js"></script>
<script src="http://getbootstrap.com/2.3.2/assets/js/bootstrap-transition.js"></script>
<script src="http://getbootstrap.com/2.3.2/assets/js/bootstrap-alert.js"></script>
<script src="http://getbootstrap.com/2.3.2/assets/js/bootstrap-modal.js"></script>
<script src="http://getbootstrap.com/2.3.2/assets/js/bootstrap-dropdown.js"></script>
<script src="http://getbootstrap.com/2.3.2/assets/js/bootstrap-tooltip.js"></script>
<script src="http://getbootstrap.com/2.3.2/assets/js/bootstrap-popover.js"></script>
<script src="http://getbootstrap.com/2.3.2/assets/js/bootstrap-button.js"></script>
<script src="http://getbootstrap.com/2.3.2/assets/js/bootstrap-carousel.js"></script>
<script src="http://getbootstrap.com/2.3.2/assets/js/google-code-prettify/prettify.js"></script>
if ($pass!="") {
if (
$pass=="exit") {
$_SESSION[$ids]=0;
} else {
$auth=2;
while (list(
$k,$v)=each($passwords)) {
if (
$v==$pass) {$_SESSION[$ids]=1$auth=1; }
if (
$auth==2) { $divst=" error"; }
unset (
$k,$v,$passwords);
if (
$_SESSION[$ids]==1) {
function
savefoto ($camnum$data$rotate) {
global
$max_photos;
if(
is_dir("./cams")!=true) { mkdir("./cams",0755); }
$dir="./cams/cam".$camnum;
if(
is_dir($dir)!=true) { mkdir($dir,0755); }
$t=@file($dir."/count.txt");
$count=doubleval(trim(@$t[0]));
$count++;
if (
$count>=$max_photos) { $count==0; }
$fp=fopen($dir."/count.txt","w");
fputs($fp,"$count");
fclose($fp);
unlink($dir."/$count".".jpg");
$fp=fopen($dir."/$count".".jpg","w");
fputs($fp,$data);
fclose($fp);
function
img2data ($camnum$title=string,$req=string$rotate=string$rec=string$link=string) {
global
$_SESSION;
if (
$req) {
$img="";
$req.=time();
if (
function_exists('curl_init')) {
$ch curl_init($req);
curl_setopt($chCURLOPT_HEADERFALSE);
curl_setopt($chCURLOPT_FOLLOWLOCATIONTRUE);
curl_setopt($chCURLOPT_RETURNTRANSFERTRUE);
$img curl_exec($ch);
curl_close($ch);
} else {
$img=file_get_contents($req);
if (
$img=="") {
return
"<div style=\"padding: 5px;\"><i class=\"icon-facetime-video icon-white\"></i> <strong>$title</strong></div><div style=\"padding: 5px;\">No Signal</div>";
} else {
$rclass="";
$rico="";
$rscr="parent.document.getElementById('modalimg').className='';";
$l1="";
$l2="";
if (
$link!="") { $l1="<a href=\"$link\" target=\"blank\">"$l2="</a>"; }
if (
$rotate!="") { $rclass="class=$rotate"$rscr="parent.document.getElementById('modalimg').className='$rotate';"$rico="<i class=\"icon-repeat icon-white\" title=\"$rotate\"></i>";}
if (
$rec!="") { $rico.="<div class=pull-right>$l1<img border=0 src=\"data:image/gif;base64,R0lGODlhEAAQAIABAP8AAP///yH/C05FVFNDQVBFMi4wAwEAAAAh/wtYTVAgRGF0YVhNUDw/eHBhY2tldCBiZWdpbj0i77u/IiBpZD0i".
"VzVNME1wQ2VoaUh6cmVTek5UY3prYzlkIj8+IDx4OnhtcG1ldGEgeG1sbnM6eD0iYWRvYmU6bnM6bWV0YS8iIHg6eG1wdGs9IkFkb2JlIFhNUCBDb3JlIDUuMy1jMDExIDY2LjE0NTY2MSwgMjAxMi8wMi8wNi0xNDo1NjoyNyAgICAgICAgIj".
"4gPHJkZjpSREYgeG1sbnM6cmRmPSJodHRwOi8vd3d3LnczLm9yZy8xOTk5LzAyLzIyLXJkZi1zeW50YXgtbnMjIj4gPHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9IiIgeG1sbnM6eG1wPSJodHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAv".
"IiB4bWxuczp4bXBNTT0iaHR0cDovL25zLmFkb2JlLmNvbS94YXAvMS4wL21tLyIgeG1sbnM6c3RSZWY9Imh0dHA6Ly9ucy5hZG9iZS5jb20veGFwLzEuMC9zVHlwZS9SZXNvdXJjZVJlZiMiIHhtcDpDcmVhdG9yVG9vbD0iQWRvYmUgUGhvdG".
"9zaG9wIENTNiAoV2luZG93cykiIHhtcE1NOkluc3RhbmNlSUQ9InhtcC5paWQ6Rjk0NjFCQUZFMDQwMTFFMzgzRkVBREZDRkI5NTA0NEQiIHhtcE1NOkRvY3VtZW50SUQ9InhtcC5kaWQ6Rjk0NjFCQjBFMDQwMTFFMzgzRkVBREZDRkI5NTA0".
"NEQiPiA8eG1wTU06RGVyaXZlZEZyb20gc3RSZWY6aW5zdGFuY2VJRD0ieG1wLmlpZDpGOTQ2MUJBREUwNDAxMUUzODNGRUFERkNGQjk1MDQ0RCIgc3RSZWY6ZG9jdW1lbnRJRD0ieG1wLmRpZDpGOTQ2MUJBRUUwNDAxMUUzODNGRUFERkNGQj".
"k1MDQ0RCIvPiA8L3JkZjpEZXNjcmlwdGlvbj4gPC9yZGY6UkRGPiA8L3g6eG1wbWV0YT4gPD94cGFja2V0IGVuZD0iciI/PgH//v38+/r5+Pf29fTz8vHw7+7t7Ovq6ejn5uXk4+Lh4N/e3dzb2tnY19bV1NPS0dDPzs3My8rJyMfGxcTDwsHA".
"v769vLu6ubi3trW0s7KxsK+urayrqqmop6alpKOioaCfnp2cm5qZmJeWlZSTkpGQj46NjIuKiYiHhoWEg4KBgH9+fXx7enl4d3Z1dHNycXBvbm1sa2ppaGdmZWRjYmFgX15dXFtaWVhXVlVUU1JRUE9OTUxLSklIR0ZFRENCQUA/Pj08Ozo5OD".
"c2NTQzMjEwLy4tLCsqKSgnJiUkIyIhIB8eHRwbGhkYFxYVFBMSERAPDg0MCwoJCAcGBQQDAgEAACH5BAkyAAEALAAAAAAQABAAAAIhjI+pAQ17nHxqzmQtytdwzXySJzpkSYXiVmLfwkFnKtcFACH5BAUyAAEALAAAAAAQABAAAAIOjI+py+0P".
"o5y02ouzPgUAOw==\"><font color=white>REC</font>$l2</div>";}
$data=base64_encode($img);
$fotocache=md5($img);
if (!isset(
$_SESSION['cam_'+$camnum])) {$_SESSION['cam_'+$camnum]="";}
if (
$_SESSION['cam_'+$camnum]!=$fotocache) { $_SESSION['cam_'+$camnum]==$data; if ($rec!="") { savefoto($camnum,$img,$rotate); } }
$r="<div style=\"padding: 5px;\">$rico<i class=\"icon-facetime-video icon-white\"></i> <strong>$title</strong> ".date("H:i:s",time())."</div><a href=\"#fullscreen\" title=\"Fullscreen\">";
if (
$link=="") {
$r.="<img onclick=\"parent.document.getElementById('modalframe').innerHTML='';
parent.document.getElementById('modalimg').src=this.src;
parent.document.getElementById('myModalLabel').innerHTML='"
.str_replace("'""",str_replace("\""""strip_tags($title)))."';
.$rscr."parent.$('#myModal').modal('show');\"";
} else {
$r.="<img onclick=\"parent.document.getElementById('modalframe').innerHTML='<iframe class=preview src=".$link."></iframe>';
$r.=" id=cam".$camnum." src=\"data:image/jpg;base64," $data."\" style=\"cursor: zoom-in;\"".$rclass." /></a>";
return
$r;
if (
$cam==0) {
if (
count($cams)>0) {
$camnum=1;
echo
"<style>
.frame {
margin-right: 5px;
margin-bottom: 5px;
width: 320px;
height: 270px;
overflow: hidden;
.preview {
position: absolute;
width: 100%;
height: 100%;
overflow: hidden;
border: none;
.rotate180 {
     -moz-transform:    rotate(180deg)
                         scale(1);
     -o-transform:      rotate(180deg)
                         scale(1);
     -webkit-transform: rotate(180deg)
                         scale(1);
                         scale(1);
.modal {
    position: fixed;
    top: 1%;
    left: 25%;
    z-index: 1050;
    min-width: 50%;
    max-width: 100%;
    height: 90%;
    margin-left: 0px;
    background-color: #FFF;
    border: 1px solid rgba(0, 0, 0, 0.3);
    border-radius: 6px;
    outline: medium none;
    box-shadow: 0px 3px 7px rgba(0, 0, 0, 0.3);
    background-clip: padding-box;
.modal-body {
    height: 100%;
    padding: 0px;
    overflow-y: auto;
</style></head><body style=\"padding:10px; margin:0; color:#000; background-color:#fff;\"><div class=well>
<a href=\""
.$_SERVER['PHP_SELF']."?pass=exit\" class=\"btn btn-info pull-right\" style=\"margin-left: 10px;\"><i class=\"icon-off icon-white\"></i> Exit</a>";
while (list(
$k,$v)=each($cams)) {
echo
"<iframe class=\"thumbnail pull-left frame\" src=\"".$_SERVER['PHP_SELF']."?".SID."&cam=$camnum\"></iframe>";
$camnum++;
echo
"<div style=\"clear: both;\"></div></div>";
echo
" <!-- Modal -->
    <div id=\"myModal\" class=\"modal hide\" tabindex=\"-1\" role=\"dialog\" aria-labelledby=\"myModalLabel\" aria-hidden=\"true\">
    <div class=\"modal-header\">
    <button type=\"button\" class=\"close\" data-dismiss=\"modal\" aria-hidden=\"true\">&times;</button>
    <h3 id=\"myModalLabel\" style=\"color: #000;\"></h3>
    </div>
    <div class=\"modal-body\">
    <p><img id=modalimg /><span id=modalframe></span></p>
    </div>
    </div>"
} else {
echo
"No cams detected!";
} else {
if (
$rec==0) {
echo
"<META HTTP-EQUIV=\"REFRESH\" CONTENT=\"".($refresh_time+$cam).";URL=".$_SERVER['PHP_SELF']."?".SID."&cam=$cam\">";
echo
"<style>
.rotate180 {
                         scale(1);
                         scale(1);
                         scale(1);
                         scale(1);
if (
$rec!=0) {
echo
".carousel-fade .carousel-inner .item {
  opacity: 0;
  -webkit-transition-property: opacity;
  -moz-transition-property: opacity;
  -o-transition-property: opacity;
.carousel-fade .carousel-inner .active {
  opacity: 1;
.carousel-fade .carousel-inner .active.left,
.carousel-fade .carousel-inner .active.right {
  left: 0;
  opacity: 0;
  z-index: 1;
.carousel-fade .carousel-inner .next.left,
.carousel-fade .carousel-inner .prev.right {
  opacity: 1;
.carousel-fade .carousel-control {
  z-index: 2;
  background: none;
  border: none;
html,
body,
.carousel,
.carousel-inner,
  height: 100%;
  width: 100%;
  overflow-y: hidden;
.carousel-caption {  background: none; text-shadow: 0px 1px 1px rgba(0, 0, 0, 0.8); }
echo
</style>
</head><body style=\"padding:0; margin:0; color:#fff; background-color:#000;\">"
$camnum=1;
while (list(
if (
$camnum==$cam) {
$t=explode("|"$v);
if (
$rec==0) {
echo
img2data($cam,$t[0],$t[1],$t[2],$t[3],$_SERVER['PHP_SELF']."?".SID."&cam=$cam&rec=1");
} else {
$recs=Array();
$ff=0;
$rdir="./cams/cam".$cam;
$rst="";
if (
$t[2]!="") { $rst=" class=".$t[2];}
if (
$handle opendir($rdir)) {
    while (
false !== ($fn readdir($handle))) {
    if (
substr($fn,-4)==".jpg") {
$recs[filemtime($rdir."/".$fn)]=$fn;
$ff++;
closedir($handle);
if (
$ff>0) {
echo
"<div id=\"myCarousel\" class=\"carousel carousel-fade\" data-interval=\"50\" data-pause=\"hover\">
<div class=\"carousel-inner\">"
ksort($recs);
$a="";
array_reverse($recs);
reset($recs);
$c=count($recs)-1;
$z=0;
while (list(
$k1,$v1)=each($recs)) {
if (
$z==$c) { $a=" active"; }
echo
"<div class=\"item".$a."\">
<img"
.$rst." src=\"cams/cam".$cam."/".$v1."\">
<div class=\"carousel-caption\">Frame <b>"
.($z+1)."/".($c+1)."</b> ".date("d.m.Y H:i:s"doubleval($k1))."<a class=\"pull-right\" href=\"".$_SERVER['PHP_SELF']."?".SID."&cam=$cam&rec=1\" title=\"Refresh scene\"><font color=white><i class=\"icon-refresh icon-white icon-large\"></i></i></a>
</div>
</div>"
$z++;
echo
"</div>
    <a class=\"carousel-control left\" href=\"#myCarousel\" data-slide=\"prev\">&lsaquo;</a>
    <a class=\"carousel-control right\" href=\"#myCarousel\" data-slide=\"next\">&rsaquo;</a>
    </div>"
$camnum++;
} else {
echo
"</head><body style=\"padding:10px; margin:0; color:#000; background-color:#fff;\">
<div class=\"well\" align=center>
<script type=\"text/javascript\">
function submit_auth(e)
    if (e.keyCode == 13)
        document.getElementById('form').submit();
        return false;
</script>
<form action=\""
.$_SERVER['PHP_SELF']."\" id=form method=POST>
<input type=hidden name=cam value=
$cam>
<div class=\"control-group"
.$divst."\">
<br>
<h3>Enter Password:</h3>
<br><input type=password name=pass value=\"\" placeholder=\"password\" onkeyup=\"submit_auth(event);\" autocomplete=\"off\">
<br><br></div>
</form>
</div>"
</body></html>
shveps вне форума   Ответить с цитированием
Старый 21.05.2014, 00:27   #13
shveps
псевдо видео запускается кнопкой карусели вправо и отведения мыши в сторону. после чего останавливается наведением на видео. и запускается сведением с него мышки.
скорость прокрутки кадров 50ms но можно увеличить. просто я сделал чтобы можно было сутки глядеть.
Последний раз редактировалось shveps; 21.05.2014 в 00:35.
Старый 21.05.2014, 18:01   #14
shveps
Хотел вообще освободиться от зависимости от Яндекс камеры - но у меня на апаче нет WebDav
Придется включать запись по крон, если не поставлю WebDav.
Вот оптимизированный движок - подготовленный для крона и с исправленными ошибками (пока без WebDav):
<?php
$max_photos
=1000;
//cam init
$cams=Array (
$passwords=Array (
1=>"pass1"//pasha
2=>"pass2"//andrey
3=>"pass3",
4=>"pass4",
$auth=0;
if(isset(
if (!
if(isset(
if (!
session_start();
$sid=session_id();
if (!isset(
$divst="";
<!--[if lt IE 9]>
<![endif]-->
if ($pass!="") {
if (
$pass=="exit") {
$_SESSION[$ids]=0;
} else {
$auth=2;
while (list(
if (
if (
unset (
$k,$v,$passwords);
if (
function
global
$max_photos;
$count++;
if (
fclose($fp);
rename ($dir."/image.jpeg"$dir."/$count".".jpg");
function
if (
$req) {
if(
if(
$o=@fopen($dir."/image.jpeg","r");
$cur=@fread($o,@filesize($dir."/image.jpeg"));
fclose($o);
$img="";
$req.=time();
if (
curl_close($ch);
} else {
if (
$img=="") {
return
} else {
if (
$cur!=$img) {
if (
$o=fopen($dir."/image.jpeg","w");
fputs($o,$img);
fclose($o);
$cur=$img;
$rclass="";
$rico="";
$l1="";
$l2="";
if (
if (
if (
$data=base64_encode($cur);
if (
$link=="") {
} else {
$r.=" id=cam".$camnum." src=\"data:image/jpeg;base64,".$data."\" style=\"cursor: zoom-in;\"".$rclass." /></a>";
return
$r;
if (
$cam==0) {
if (
count($cams)>0) {
$camnum=1;
echo
"<style>
.frame {
margin-right: 5px;
margin-bottom: 5px;
width: 320px;
height: 270px;
overflow: hidden;
.preview {
position: absolute;
width: 100%;
height: 100%;
overflow: hidden;
border: none;
.rotate180 {
                         scale(1);
                         scale(1);
                         scale(1);
                         scale(1);
.modal {
    position: fixed;
    top: 1%;
    left: 25%;
    z-index: 1050;
    min-width: 50%;
    max-width: 100%;
    height: 90%;
    margin-left: 0px;
    border-radius: 6px;
.modal-body {
    height: 100%;
    padding: 0px;
    overflow-y: auto;
<a href=\""
while (list(
echo
$camnum++;
echo
echo
" <!-- Modal -->
    </div>
    </div>
    </div>"
} else {
echo
} else {
if (
$rec==0) {
echo
echo
"<style>
.rotate180 {
                         scale(1);
                         scale(1);
                         scale(1);
                         scale(1);
if (
$rec!=0) {
echo
  opacity: 0;
  opacity: 1;
  left: 0;
  opacity: 0;
  z-index: 1;
  opacity: 1;
  z-index: 2;
  background: none;
  border: none;
html,
body,
.carousel,
.carousel-inner,
  height: 100%;
  width: 100%;
  overflow-y: hidden;
echo
</style>
$camnum=1;
while (list(
if (
$camnum==$cam) {
$t=explode("|"$v);
if (
$rec==0) {
echo
} else {
$recs=Array();
$ff=0;
$rst="";
if (
if (
    while (
    if (
$ff++;
closedir($handle);
echo
"<div id=\"myCarousel\" class=\"carousel carousel-fade\" data-interval=\"100\" data-pause=\"hover\">
$z=0;
if (
$ff>0) {
ksort($recs);
$a="";
reset($recs);
$c=count($recs);
while (list(
echo
"<div class=\"item\">
<img"
.($z+1)."/".($c+1)."</b> ".date("d.m.Y H:i:s"doubleval($k1))."<a class=\"pull-right\" href=\"".$_SERVER['PHP_SELF']."?".SID."&cam=$cam&rec=1\" title=\"Refresh scene\"><font color=white><i class=\"icon-refresh icon-white icon-large\"></i></font></a>
</div>
</div>"
$z++;
echo
"<div class=\"item active\">
<img"
.$rst." src=\"cams/cam".$cam."/image.jpeg?".time()."\">
<div class=\"carousel-caption\"><b>NOW</b> "
.date("d.m.Y H:i:s"time())."<a class=\"pull-right\" href=\"".$_SERVER['PHP_SELF']."?".SID."&cam=$cam&rec=1\" title=\"Refresh scene\"><font color=white><i class=\"icon-refresh icon-white icon-large\"></i></font></a>
</div>
</div>
</div>
    </div>"
$camnum++;
} else {
echo
        return false;
</script>
<form action=\""
$cam>
.$divst."\">
<br>
<br></div>
</form>
</div>"
</body></html>
cyberwrt, mr3020, webcam, yandexcamera, камера
Текущее время: 15:35. Часовой пояс GMT +3.
