#1 |
с сайта http://wiki.openwrt.org/doc/howto/wview смущает строка
# opkg install wview zlib libpng libreadline gawk libgd libsqlite3 radlib libcurl возможно где-то в репах опенврт он и находится? или я ошибаюсь? |
#2 |
Возможно
#3 |
Доброго дня, Админ! Кинь свой взор на http://downloads.openwrt.org/attitud...51e_ar71xx.ipk, возможно это то что нужно. Спасибо.
#4 |
А описание и хеш файла есть? Для какого роутера он был скомпилирован?
#5 |
wview
Version: 5.19.0-jgoerzen-7bfac6c11e756290c38e7b5862a4c51b6bc6c51e Depends: libc, libcurl, zlib, libpng, libgd, libreadline, libsqlite3, libusb-1.0, radlib, sqlite3-cli Provides: Source: feeds/packages/utils/wview Section: utils Status: unknown ok not-installed Essential: no Priority: optional Maintainer: OpenWrt Developers Team <[email protected]> Architecture: ar71xx Installed-Size: 641990 Filename: wview_5.19.0-jgoerzen-7bfac6c11e756290c38e7b5862a4c51b6bc6c51e _ar71xx.ipk Size: 634716 MD5Sum: 09baf6d3d5718f69e4b1131de436dd7e Description: Wview is a collection of linux/unix daemons which interface with a supported weather station to retrieve archive records (if generated by the station) and current conditions. If the station does not generate archive records internally, wview will auto-generate archive records based on the sensor readings collected for that interval. The archive records and High/Low (HILOW) data are stored in SQLite3 databases. At a configurable interval, wview will utilize the archive history and current conditions to generate weather images (buckets, dials and graphs) and HTML web pages based on user-configurable HTML templates. After install you need to create a directory holding archive and create the database there by running there sqlite3 wview-archive.sdb '.read /etc/wview/wview-archive.sql' Then copy all your theme files to the appropriate place (on a non-volatile storage), and html-templates.conf to /etc/wview/; then wviewconfig to configure the system. Read and amend /etc/init.d/wview appropriately for your particular setup! |
#6 |
находится сиё безобразие там же где и http://downloads.openwrt.org/attitud...s2-factory.bin
#7 |
прикладываю скомпилированный модуль для системы Noolite. для работы ему требуется libusb. Но вроде все зависимости указал верно. При установке должен вытянуть из репозитория сам.
noolite_1_ar71xx.zip Может вы его включите в стандартную сборку ![]() Управляющие команды можно получить вызвав noolite -help |
#8 | |
Был бы свисток с выключателем, проверил бы |
#9 |
Описание к пакету выложите, я сегодня добавлю оба пакета в репозиторий
#10 |
Модуль скомпилирован с этих исходников. Описание полное лежит на github
Ссылка Единственное необходимо уточнить все ли зависимости я учел. ![]() Описание проекта целиком лежит тут И второе требование usb адаптеров от компании noolite, они работают на Usb 1.0 а в роутере 2.0. И адаптер будет работать только через хаб. Прямое подключение не работает ![]() |
