#1 |
Что за камера?
Попробовал разрешение 320х240? |
#2 |
Конечно пробовал.
Хз что за камера. Выдернута с мертвого ноута. root@OpenWrt:~# dmesg ... [ 384.300000] usb 1-1: new high-speed USB device number 2 using ehci-platform [ 384.460000] uvcvideo: Found UVC 1.00 device USB 2.0 Camera (0c45:62c0) [ 384.470000] input: USB 2.0 Camera as /devices/platform/ehci-platform/usb1/1-1/1-1:1.0/input/input0 помогло изменения параметра f до 25 ![]() Код:
root@OpenWrt:/usr/bin# mjpg_streamer -i "input_uvc.so -d /dev/video0 -y -r 640x480 -f 25 -q 50" -o "output_http.so -w /www/web cam -p 8080" MJPG Streamer Version: svn rev: exported i: Using V4L2 device.: /dev/video0 i: Desired Resolution: 640 x 480 i: Frames Per Second.: 25 i: Format............: YUV i: JPEG Quality......: 50 Adding control for Pan (relative) UVCIOC_CTRL_ADD - Error: Invalid argument Adding control for Tilt (relative) UVCIOC_CTRL_ADD - Error: Invalid argument Adding control for Pan Reset UVCIOC_CTRL_ADD - Error: Invalid argument Adding control for Tilt Reset UVCIOC_CTRL_ADD - Error: Invalid argument Adding control for Pan/tilt Reset UVCIOC_CTRL_ADD - Error: Invalid argument Adding control for Focus (absolute) UVCIOC_CTRL_ADD - Error: Invalid argument mapping control for Pan (relative) UVCIOC_CTRL_MAP - Error: Invalid argument mapping control for Tilt (relative) UVCIOC_CTRL_MAP - Error: Invalid argument mapping control for Pan Reset UVCIOC_CTRL_MAP - Error: Invalid argument mapping control for Tilt Reset UVCIOC_CTRL_MAP - Error: Invalid argument mapping control for Pan/tilt Reset UVCIOC_CTRL_MAP - Error: Invalid argument mapping control for Focus (absolute) UVCIOC_CTRL_MAP - Error: Invalid argument mapping control for LED1 Mode UVCIOC_CTRL_MAP - Error: Invalid argument mapping control for LED1 Frequency UVCIOC_CTRL_MAP - Error: Invalid argument mapping control for Disable video processing UVCIOC_CTRL_MAP - Error: Invalid argument mapping control for Raw bits per pixel UVCIOC_CTRL_MAP - Error: Invalid argument o: www-folder-path...: /www/webcam/ o: HTTP TCP port.....: 8080 o: username:password.: disabled o: commands..........: enabled P.S. TL-MR3220\\openwrt.org/attitude_adjustment/12.09 P.S.2 Проц не хило так "колбасит". ![]() Код:
Mem: 21700K used, 7512K free, 0K shrd, 1648K buff, 5664K cached CPU: 99% usr 0% sys 0% nic 0% idle 0% io 0% irq 0% sirq Load average: 1.05 0.93 0.55 2/44 1251 PID PPID USER STAT VSZ %VSZ %CPU COMMAND 1167 1162 root S 17368 59% 99% mjpg_streamer -i input_uvc.so -d /dev 1251 1246 root R 1500 5% 0% top 1245 1089 root S 1216 4% 0% /usr/sbin/dropbear -P /var/run/dropbe 608 1 root S 1532 5% 0% /sbin/netifd 594 1 root S 1508 5% 0% /sbin/syslogd -C16 1 0 root S 1504 5% 0% init 1246 1245 root S 1504 5% 0% -ash 1162 1161 root S 1504 5% 0% -ash 477 1 root S 1504 5% 0% init 713 608 root S 1500 5% 0% udhcpc -p /var/run/udhcpc-eth1.pid -s 1158 1 root S 1500 5% 0% /usr/sbin/ntpd -n -p 0.openwrt.pool.n 775 1 root S 1500 5% 0% /sbin/watchdog -t 5 /dev/watchdog 596 1 root S 1488 5% 0% /sbin/klogd 1161 1089 root S 1244 4% 0% /usr/sbin/dropbear -P /var/run/dropbe 1089 1 root S 1152 4% 0% /usr/sbin/dropbear -P /var/run/dropbe 1111 1 root S 1132 4% 0% /usr/sbin/uhttpd -f -h /www -r OpenWr 1145 1 nobody S 944 3% 0% /usr/sbin/dnsmasq -C /var/etc/dnsmasq 604 1 root S 872 3% 0% /sbin/ubusd 598 1 root S 860 3% 0% /sbin/hotplug2 --override --persisten 256 2 root SW 0 0% 0% [kworker/0:1] Код:
Mem: 18968K used, 10244K free, 0K shrd, 1648K buff, 5664K cached CPU: 90% usr 0% sys 0% nic 9% idle 0% io 0% irq 0% sirq Load average: 1.09 0.96 0.80 2/45 1278 PID PPID USER STAT VSZ %VSZ %CPU COMMAND 1255 1162 root S 16700 57% 90% mjpg_streamer -i input_uvc.so -d Последний раз редактировалось Tarik; 01.08.2013 в 20:48. Причина: Добавил лог |
