#261 | |
![]() По старой памяти: mtd0=uboot mtd5=mtd1(kernel)+mtd2(rootfs )+mtd3(rootfs_data) mtd4=art А вот и картинка |
#262 |
Кто может собрать u-boot 16mb для роутера 842nd v1?
#263 |
Вот от 3420V1. Железо одинаковое. Когда то себе собирал.
Измени в HEXe МАК и модель на свои. Или читай как самому.https://forum.openwrt.org/viewtopic.php?id=32512 Последний раз редактировалось melsem; 28.12.2014 в 12:33. |
#264 |
Это случайно не один и тот же u-boot ? пост #3820 http://satsat.info/sharing/24867-sha...220-a-382.html
Если да, я его поставил, и получил такой лог: Код:
U-Boot 1.1.4 (Feb 3 2013 - 01:21:42) AP99 (ar7241 - Virian) U-boot DRAM: sri ar7240_ddr_initial_config(133): virian ddr1 init #### TAP VALUE 1 = 0xf, 2 = 0x10 [0x0: 0x1f] 32 MB id read 0x100000ff sector count = 256 Flash: 16 MB Using default environment RK▒▒ɥ▒▒5 Out: serial Err: serial Net: ag7240_enet_initialize... No valid address in Flash. Using fixed address No valid address in Flash. Using fixed address Virian MDC CFG Value ==> 4 : cfg1 0xf cfg2 0x7014 eth0: 00:03:7f:09:0b:ad eth0 up Virian MDC CFG Value ==> 4 : cfg1 0xf cfg2 0x7214 Y+▒▒▒҂▒Һ2▒09:0b:ad ATHRS26: resetting s26 ATHRS26: s26 reset done ▒th1 up eth0, eth1 Autobooting in 1 seconds ▒# Booting image at 9f020000 ... Uncompressing Kernel Image ... OK Starting kernel ... ▒C▒▒ ▒▒]▒сkernel loader for AR7XXX/AR9XXX Copyright (C) 2011 Gabor Juhos <[email protected]> Looking for OpenWrt image... found at 0xbf022000 Decompressing kernel... ▒one! Starting kernel at 80060000... +▒r▒▒▒▒▒▒▒Linux version 3.3.8 (papo4ka3d@LinuxMint) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #3 Mon Dec 22 19:30:21 EET 2014 [ 0.000000] bootconsole [early0] enabled [ 0.000000] CPU revision is: 00019374 (MIPS 24Kc) [ 0.000000] SoC: Atheros AR7241 rev 1 [ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:5.000 MHz [ 0.000000] Determined physical RAM map: [ 0.000000] memory: 02000000 @ 00000000 (usable) [ 0.000000] Initrd not found or empty - disabling initrd [ 0.000000] Zone PFN ranges: [ 0.000000] Normal 0x00000000 -> 0x00002000 [ 0.000000] Movable zone start PFN for each node [ 0.000000] Early memory PFN ranges [ 0.000000] 0: 0x00000000 -> 0x00002000 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 8128 [ 0.000000] Kernel command line: board=TL-MR3420 console=ttyS0,115200 rootfs type=squashfs,jffs2 noinitrd [ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes) [ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes. [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes [ 0.000000] Writing ErrCtl register=00000000 [ 0.000000] Readback ErrCtl register=00000000 +▒r▒▒▒▒▒▒▒Memory: 29116k/32768k available (2115k kernel code, 3652k reserved, 40 6k data, 208k init, 0k highmem) [ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, No des=1 [ 0.000000] NR_IRQS:51 [ 0.000000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104) [ 0.080000] pid_max: default: 32768 minimum: 301 [ 0.080000] Mount-cache hash table entries: 512 [ 0.090000] NET: Registered protocol family 16 +▒r▒ʂ▒▒▒▒gpiochip_add: registered GPIOs 0 to 17 on device: ath79 [ 0.100000] MIPS: machine is TP-LINK TL-MR3420 ▒ 0.500000] registering PCI controller with io_map_base unset [ 0.540000] bio: create slab <bio-0> at 0 [ 0.550000] PCI host bridge to bus 0000:00 [ 0.550000] pci_bus 0000:00: root bus resource [mem 0x10000000-0x13ffffff] [ 0.560000] pci_bus 0000:00: root bus resource [io 0x0000] [ 0.560000] pci 0000:00:00.0: fixup device configuration +▒r▒▒▒▒▒▒▒pci 0000:00:00.0: BAR 0: assigned [mem 0x10000000-0x1000ffff 64bit] [ 0.570000] pci 0000:00:00.0: using irq 40 for pin 1 +▒r▒�▒▒▒▒Switching to clocksource MIPS +▒r▒�▒▒▒▒NET: Registered protocol family 2 [ 0.590000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.590000] TCP established hash table entries: 1024 (order: 1, 8192 bytes) [ 0.600000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes) [ 0.600000] TCP: Hash tables configured (established 1024 bind 1024) [ 0.610000] TCP reno registered [ 0.610000] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.620000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.630000] NET: Registered protocol family 1 +▒r▒▒▒▒▒▒▒squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.650000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY ) (c) 2001-2006 Red Hat, Inc. +▒r▒▒▒▒▒▒▒msgmni has been set to 56 [ 0.670000] io scheduler noop registered [ 0.670000] io scheduler deadline registered (default) [ 0.680000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled +▒r▒▒▒▒▒▒▒serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11) is a 16550A [ 0.710000] console [ttyS0] enabled, bootconsole disabled [ 0.710000] console [ttyS0] enabled, bootconsole disabled [ 0.730000] m25p80 spi0.0: found w25q128, expected m25p80 [ 0.730000] m25p80 spi0.0: w25q128 (16384 Kbytes) [ 0.740000] 5 tp-link partitions found on MTD device spi0.0 [ 0.740000] Creating 5 MTD partitions on "spi0.0": [ 0.750000] 0x000000000000-0x000000020000 : "u-boot" [ 0.760000] 0x000000020000-0x000000103a00 : "kernel" [ 0.760000] mtd: partition "kernel" must either start or end on erase block b oundary or be smaller than an erase block -- forcing read-only [ 0.780000] 0x000000103a00-0x000000ff0000 : "rootfs" [ 0.780000] mtd: partition "rootfs" must either start or end on erase block b oundary or be smaller than an erase block -- forcing read-only [ 0.790000] mtd: partition "rootfs" set to be root filesystem [ 0.800000] mtd: partition "rootfs_data" created automatically, ofs=650000, l en=9A0000 [ 0.810000] 0x000000650000-0x000000ff0000 : "rootfs_data" +▒r�▒▒▒▒▒0x000000ff0000-0x000001000000 : "art" +▒r�▒▒▒▒▒0x000000020000-0x000000ff0000 : "firmware" [ 0.850000] ag71xx_mdio: probed [ 0.850000] eth0: Atheros AG71xx at 0xba000000, irq 5 [ 1.410000] eth0: Found an AR7240/AR9330 built-in switch +▒r▒▒▒▒▒▒▒eth1: Atheros AG71xx at 0xb9000000, irq 4 [ 2.990000] ag71xx ag71xx.0: eth1: connected to PHY at ag71xx-mdio.1:04 [uid= 004dd041, driver=Generic PHY] [ 3.000000] TCP cubic registered [ 3.000000] NET: Registered protocol family 17 [ 3.010000] 8021q: 802.1Q VLAN Support v1.8 [ 3.020000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2. [ 3.030000] Freeing unused kernel memory: 208k freed - preinit - ▒ress the [f] key and hit [enter] to enter failsafe mode +▒r▒▒▒▒▒▒▒eth0: link up (1000Mbps/Full duplex) - regular preinit - [ 9.980000] JFFS2 notice: (423) jffs2_build_xattr_subsystem: complete buildin g xattr subsystem, 1 of xdatum (0 unchecked, 0 orphan) and 15 of xref (0 dead, 2 orphan) found. +▒▒r�▒▒▒▒▒SCSI subsystem initialized [ 11.060000] usbcore: registered new interface driver usbfs [ 11.070000] usbcore: registered new interface driver hub +▒▒r▒�▒▒▒▒usbcore: registered new device driver usb +▒▒r�▒▒▒▒▒ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 11.810000] ehci-platform ehci-platform: Generic Platform EHCI Controller [ 11.820000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1 [ 11.850000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000 [ 11.870000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00 [ 11.870000] hub 1-0:1.0: USB hub found [ 11.880000] hub 1-0:1.0: 1 port detected [ 11.950000] Initializing USB Mass Storage driver... [ 11.960000] usbcore: registered new interface driver usb-storage [ 11.960000] USB Mass Storage support registered. +▒▒r▒▒▒▒▒▒▒usb 1-1: new high-speed USB device number 2 using ehci-platform +▒▒r▒▒▒▒▒▒▒hub 1-1:1.0: USB hub found +▒▒r▒▒▒▒▒▒▒hub 1-1:1.0: 4 ports detected [ 12.650000] usb 1-1.1: new high-speed USB device number 3 using ehci-platform [ 12.780000] scsi0 : usb-storage 1-1.1:1.0 +▒▒r▒ʂ▒▒▒▒usb 1-1.2: new full-speed USB device number 4 using ehci-platform +▒▒r▒▒▒▒▒▒▒usb 1-1.4: new high-speed USB device number 5 using ehci-platform +▒▒r▒▒▒▒▒▒▒hub 1-1.4:1.0: USB hub found +▒▒r▒▒▒▒▒▒▒hub 1-1.4:1.0: 4 ports detected +▒▒rº▒▒▒▒▒scsi 0:0:0:0: Direct-Access silicon-power PMAP PQ: 0 A NSI: 4 [ 15.420000] sd 0:0:0:0: [sda] 30283008 512-byte logical blocks: (15.5 GB/14.4 GiB) +▒▒r▒▒▒▒▒▒▒sd 0:0:0:0: [sda] Write Protect is off [ 15.440000] sd 0:0:0:0: [sda] No Caching mode page present [ 15.440000] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 15.450000] sd 0:0:0:0: [sda] No Caching mode page present [ 15.460000] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 15.500000] sda: sda1 sda2 [ 15.510000] sd 0:0:0:0: [sda] No Caching mode page present [ 15.520000] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 15.530000] sd 0:0:0:0: [sda] Attached SCSI removable disk switching to jffs2 - init - +▒▒r▒▒▒▒▒▒▒eth0: link down +▒▒rʲ▒▒▒▒▒Loading modules backported from Linux version master-2014-05-22-0-gf20 32ea [ 34.970000] Backport generated by backports.git backports-20140320-37-g5c33da 0 +▒▒r▒▒▒▒▒▒▒cfg80211: Calling CRDA to update world regulatory domain [ 35.150000] cfg80211: World regulatory domain updated: [ 35.160000] cfg80211: DFS Master region: unset [ 35.160000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gai n, max_eirp), (dfs_cac_time) [ 35.170000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 m Bm), (N/A) [ 35.180000] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 m Bm), (N/A) [ 35.190000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 m Bm), (N/A) [ 35.200000] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 m Bm), (N/A) [ 35.210000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 m Bm), (N/A) [ 35.210000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A) +▒▒r▒▒▒▒▒▒▒PCI: Enabling device 0000:00:00.0 (0000 -> 0002) [ 36.170000] ieee80211 phy0: Atheros AR9287 Rev:2 mem=0xb0000000, irq=40 [ 36.170000] cfg80211: Calling CRDA for country: US [ 36.180000] cfg80211: Regulatory domain changed to country: US [ 36.190000] cfg80211: DFS Master region: FCC [ 36.190000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gai n, max_eirp), (dfs_cac_time) [ 36.200000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 m Bm), (N/A) [ 36.210000] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 m Bm), (N/A) [ 36.220000] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 m Bm), (0 s) [ 36.220000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 m Bm), (N/A) [ 36.230000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 40 00 mBm), (N/A) +▒▒r▒▒▒▒▒▒▒NET: Registered protocol family 8 [ 36.280000] NET: Registered protocol family 20 [ 36.610000] PPP generic driver version 2.4.2 [ 37.180000] PPP MPPE Compression module registered [ 37.290000] L2TP core driver, V2.0 +▒▒r▒▒▒▒▒▒▒L2TP netlink interface +▒▒r▒▒▒▒▒▒▒GRE over IPv4 demultiplexor driver [ 37.430000] GRE over IPv4 tunneling driver [ 37.780000] ip_tables: (C) 2000-2006 Netfilter Core Team [ 38.010000] NET: Registered protocol family 24 [ 38.180000] nf_conntrack version 0.5.0 (458 buckets, 1832 max) [ 38.650000] PPPoL2TP kernel driver, V2.0 +▒▒r▒▒▒▒▒▒▒PPTP driver version 0.8.5 [ 39.170000] xt_time: kernel timezone is -0000 +▒▒rª▒▒▒▒▒i2c /dev entries driver [ 39.910000] usbcore: registered new interface driver cdc_acm [ 39.910000] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 40.090000] usbcore: registered new interface driver snd-usb-audio [ 40.230000] usbcore: registered new interface driver usblp [ 40.260000] usbcore: registered new interface driver usbserial [ 40.270000] USB Serial support registered for generic [ 40.270000] usbcore: registered new interface driver usbserial_generic [ 40.280000] usbserial: USB Serial Driver core [ 40.440000] Linux video capture interface: v2.00 +▒▒r▒▒▒▒▒▒▒usbcore: registered new interface driver cdc_ether [ 40.660000] usbcore: registered new interface driver rndis_host [ 40.760000] USB Serial support registered for ch341-uart [ 40.770000] usbcore: registered new interface driver ch341 [ 40.790000] USB Serial support registered for cp210x [ 40.800000] usbcore: registered new interface driver cp210x [ 40.800000] cp210x: v0.09:Silicon Labs CP210x RS232 serial adaptor driver [ 40.840000] USB Serial support registered for FTDI USB Serial Device [ 40.840000] usbcore: registered new interface driver ftdi_sio [ 40.850000] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver +▒▒rº▒▒▒▒▒USB Serial support registered for GSM modem (1-port) [ 40.880000] usbcore: registered new interface driver option [ 40.890000] option: v0.7.2:USB Driver for GSM modems [ 40.910000] USB Serial support registered for pl2303 [ 40.920000] usbcore: registered new interface driver pl2303 [ 40.920000] pl2303: Prolific PL2303 USB to serial adaptor driver [ 41.110000] usbcore: registered new interface driver uvcvideo [ 41.110000] USB Video Class driver (1.1.1) +▒▒r▒▒▒▒▒▒▒Adding 102396k swap on /dev/sda1. Priority:-1 extents:1 across:102396k [ 44.750000] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null) [ 48.860000] eth0: link up (1000Mbps/Full duplex) +▒▒r▒▒▒▒▒▒▒eth0: link down [ 50.390000] device eth0 entered promiscuous mode +▒▒r▒ʂ▒▒▒▒eth0: link up (1000Mbps/Full duplex) [ 50.990000] br-lan: port 1(eth0) entered forwarding state [ 51.000000] br-lan: port 1(eth0) entered forwarding state +▒▒r▒▒▒▒▒▒▒eth1: link up (100Mbps/Full duplex) +▒▒r▒▒▒▒▒▒▒br-lan: port 1(eth0) entered forwarding state [ 54.020000] cfg80211: Calling CRDA for country: UA [ 54.020000] cfg80211: Regulatory domain changed to country: UA [ 54.030000] cfg80211: DFS Master region: ETSI [ 54.030000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time) [ 54.040000] cfg80211: (2400000 KHz - 2483000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A) [ 54.050000] cfg80211: (5150000 KHz - 5350000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A) [ 54.060000] cfg80211: (5490000 KHz - 5670000 KHz @ 80000 KHz), (N/A, 2000 mBm), (0 s) [ 54.070000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A) [ 54.070000] cfg80211: (57240000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A) [ 58.230000] device wlan0 entered promiscuous mode [ 58.250000] br-lan: port 2(wlan0) entered forwarding state [ 58.260000] br-lan: port 2(wlan0) entered forwarding state +▒▒r▒▒▒▒▒▒▒br-lan: port 2(wlan0) entered forwarding state No valid address in Flash. Using fixed address No valid address in Flash. Using fixed address Это если оперативки 32 мб и флешь 16 то через веб прошить роутер нельзя, только программатором шить? нужно 64 ставить тогда через веб будет? Не получается убрать в логе крякозяблики, микруха стоит max3232, такие резисторы пробовал ставить 6.8кОм, 10кОм, 15кОм, 18кОм, 20кОм, 22кОм., гдето больше их, где меньше. Последний раз редактировалось 3D_STAR; 28.12.2014 в 13:11. |
#265 |
Да это тот же u-boot.
Через веб прошивается. Что бы убрать крякозяблики, надо выпаять резисторы, которые на подтяжку ставишь. И кинуть перемычку (убрать RC-фильтр), как на фотке нарисовал красным. Фото не мое. Резисторов на подтяжку не ставлю. |
#266 |
Здравствуйте уважаемые,мог бы кто нибуть скинуть дамп флэшки на 8мб для MR3020
с cyberwrt |
#267 |
на 4мб есть только что слил с прогромматоро !
#268 |
ребята у меня такая проблема ! прошил флешь через прогромматор тепер LAN порт работает , по интернету отлично а безпроводная сеть он её находит в компе но всего на зночке горит 2 палочки ..до перепрошивке флешь у меня всё были палочки сейчас 2 ели тянет интернет по безпроводной сети ну а lan порту работает отлично в чём можит быт дело ?
#269 |
к стати пробовал флешь в паят от ( роутера TD-W8901G) уже залил прошивку на прогромматоре после пайке , просто горит синий индекатор .. пришлос снова ставит родную флешь наза только запаял с родным демпам и родную фешь , сразу замигал индекатор и я только подключил LAN кабель по проводной сети пошёл интернет а вот по безпроводной ели тянет .
#270 |
