Старый 29.03.2014, 10:05   #1
Bulatovor
Вес репутации: 800
По умолчанию Re: Акваконтроллер
А примеры работают? чтоб проверить аппаратную часть
например вот такой
//Sample using LiquidCrystal library
#include <LiquidCrystal.h>
This program will test the LCD panel and the buttons
Mark Bramwell, July 2010
// select the pins used on the LCD panel
LiquidCrystal lcd(894567);
// define some values used by the panel and buttons
int lcd_key     0;
int adc_key_in  0;
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
// read the buttons
int read_LCD_buttons()
adc_key_in analogRead(0);      // read the value from the sensor
 // my buttons when read are centered at these valies: 0, 144, 329, 504, 741
 // we add approx 50 to those values and check to see if we are close
if (adc_key_in 1000) return btnNONE// We make this the 1st option for speed reasons since it will be the most likely result
 // For V1.1 us this threshold
if (adc_key_in 50)   return btnRIGHT;
 if (
adc_key_in 250)  return btnUP
 if (
adc_key_in 450)  return btnDOWN
 if (
adc_key_in 650)  return btnLEFT
 if (
adc_key_in 850)  return btnSELECT;
// For V1.0 comment the other threshold and use the one below:
 if (adc_key_in < 50)   return btnRIGHT;
 if (adc_key_in < 195)  return btnUP;
 if (adc_key_in < 380)  return btnDOWN;
 if (adc_key_in < 555)  return btnLEFT;
 if (adc_key_in < 790)  return btnSELECT;
return btnNONE;  // when all others fail, return this...
void setup()
lcd.begin(162);              // start the library
lcd.setCursor(0,0);
lcd.print("Push the buttons"); // print a simple message
void loop()
lcd.setCursor(9,1);            // move cursor to second line "1" and 9 spaces over
lcd.print(millis()/1000);      // display seconds elapsed since power-up
lcd.setCursor(0,1);            // move to the begining of the second line
lcd_key read_LCD_buttons();  // read the buttons
switch (lcd_key)               // depending on which button was pushed, we perform an action
   case
btnRIGHT:
lcd.print("RIGHT ");
     break;
   case
btnLEFT:
lcd.print("LEFT   ");
     break;
   case
btnUP:
lcd.print("UP    ");
     break;
   case
btnDOWN:
lcd.print("DOWN  ");
     break;
   case
btnSELECT:
lcd.print("SELECT");
     break;
     case
btnNONE:
lcd.print("NONE  ");
     break;
Старый 29.03.2014, 11:14   #2
kirex
kirex is an unknown quantity at this point
например вот такой
int lcd_key     0;
int adc_key_in  0;
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
// read the buttons
 if (
 if (
 if (
 if (
void setup()
lcd.setCursor(0,0);
void loop()
   case
btnRIGHT:
     break;
   case
btnLEFT:
lcd.print("LEFT   ");
     break;
   case
btnUP:
lcd.print("UP    ");
     break;
   case
btnDOWN:
lcd.print("DOWN  ");
     break;
   case
btnSELECT:
     break;
     case
btnNONE:
lcd.print("NONE  ");
     break;
Да этот пример работает без проблем.
kirex вне форума   Ответить с цитированием
Текущее время: 08:34. Часовой пояс GMT +3.
