Старый 24.10.2013, 11:59   #171
Gremlin
Gremlin is an unknown quantity at this point
До сих пор не могу настроить 3Г .
После попытки установить соединение logread дает такой лог:
Oct 24 07:53:51 OpenWrt daemon.notice pppd[6912]: pppd 2.4.5 started by root, uid 0
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: abort on (BUSY)
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: abort on (NO CARRIER)
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: abort on (ERROR)
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: report (CONNECT)
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: timeout set to 12 seconds
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: send (AT&F^M)
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: expect (OK)
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: AT&F^M^M
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: OK
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: -- got it
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: send (ATE1^M)
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: ^M
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: ATE1^M^M
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: send (AT+CGDCONT=1,"IP","internet.mts.ru"^M)
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: timeout set to 15 seconds
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: AT+CGDCONT=1,"IP","internet.mts.ru"^M^M
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: send (ATD*99#^M)
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: expect (CONNECT)
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: ATD*99#^M^M
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: CONNECT
Oct 24 07:53:52 OpenWrt local2.info chat[6917]: send ( ^M)
Oct 24 07:53:52 OpenWrt daemon.debug pppd[6912]: Script USE_APN=internet.mts.ru /usr/sbin/chat -t5 -v -E -f /etc/chatscripts/3g.chat finished (pid 6916), status = 0x0
Oct 24 07:53:52 OpenWrt daemon.info pppd[6912]: Serial connection established.
Oct 24 07:53:52 OpenWrt daemon.debug pppd[6912]: using channel 4
Oct 24 07:53:52 OpenWrt daemon.info pppd[6912]: Using interface 3g-wan
Oct 24 07:53:52 OpenWrt daemon.notice pppd[6912]: Connect: 3g-wan <--> /dev/ttyUSB1
Oct 24 07:53:53 OpenWrt daemon.debug pppd[6912]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0xebd02ef5>]
Oct 24 07:53:56 OpenWrt daemon.debug pppd[6912]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0xebd02ef5>]
Oct 24 07:53:59 OpenWrt daemon.debug pppd[6912]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0xebd02ef5>]
Связи с интернетом нет... ОпСоС - МТС, модем ZTE MF112
Gremlin вне форума   Ответить с цитированием
Старый 24.10.2013, 16:47   #172
cray888
cray888 is an unknown quantity at this point
Всем добрый вечер! Подскажите пожалуйста, где я сделал что-то не так. Прошил роутер mr3020 по инструкции с этого форума (Инструкция), только роутер настроил в качестве wifi client. Все подключилось и работает, если бы не одно но, когда делаю ping ya.ru (или любой другой адрес) очень долго происходит запрос IP адреса по имени DNS (около 10 секунд), хотя ping 8.8.8.8 отрабатывает моментально, складывается впечатление что он пытается подключиться сперва к другому DNS серверу, а не к тому что указан в wwan. Сталкивался кто с такой проблемой?
root@OpenWrt:~# cat /etc/config/network
config interface 'loopback'
        option ifname 'lo'
        option proto 'static'
        option ipaddr '127.0.0.1'
        option netmask '255.0.0.0'
config interface 'lan'
        option ifname 'eth0'
        option type 'bridge'
        option ipaddr '192.168.2.1'
config interface 'wwan'
        option ipaddr '192.168.1.20'
        option gateway '192.168.1.1'
        option dns '192.168.1.1'
root@OpenWrt:~# cat /etc/config/wireless
config wifi-device  radio0
        option type     mac80211
        option macaddr  64:66:b3:94:0e:34
        option hwmode   11ng
        option htmode   HT20
        list ht_capab   SHORT-GI-20
        list ht_capab   SHORT-GI-40
        list ht_capab   RX-STBC1
        list ht_capab   DSSS_CCK-40
        # REMOVE THIS LINE TO ENABLE WIFI:
        # option disabled 0
        option chanel '7'
        option country 'RU'
        option txpower '20'
config wifi-iface
        option device   radio0
        option network  lan
        option mode     sta
        option ssid     DrayTek
        option bssid    00:50:7F:C5:16:00
        option key      qwer1234
        option encryption psk2
        option network  wwan
root@OpenWrt:~# cat /etc/config/firewall
config defaults
        option syn_flood        1
        option input            ACCEPT
        option output           ACCEPT
        option forward          ACCEPT
# Uncomment this line to disable ipv6 rules
#       option disable_ipv6     1
config zone
        option name             lan
        option network          'lan'
        option input            ACCEPT
config zone
        option name             wan
        option network          'wan'
        option input            ACCEPT
        option masq             1
        option mtu_fix          1
        option network          'wan wwan'
config forwarding
        option src              lan
        option dest             wan
config forwarding
        option src              wan
        option dest             lan
# We need to accept udp packets on port 68,
# see https://dev.openwrt.org/ticket/4108
config rule
        option name             Allow-DHCP-Renew
        option src              wan
        option proto            udp
        option dest_port        68
        option target           ACCEPT
        option family           ipv4
# Allow IPv4 ping
config rule
        option name             Allow-Ping
        option src              wan
        option proto            icmp
        option icmp_type        echo-request
        option family           ipv4
# Allow DHCPv6 replies
# see https://dev.openwrt.org/ticket/10381
config rule
        option name             Allow-DHCPv6
        option src              wan
        option proto            udp
        option src_ip           fe80::/10
        option src_port         547
        option dest_ip          fe80::/10
        option dest_port        546
        option family           ipv6
# Allow essential incoming IPv6 ICMP traffic
config rule
        option name             Allow-ICMPv6-Input
        option src              wan
        option proto    icmp
        list icmp_type          echo-request
        list icmp_type          echo-reply
        list icmp_type          destination-unreachable
        list icmp_type          packet-too-big
        list icmp_type          time-exceeded
        list icmp_type          bad-header
        list icmp_type          unknown-header-type
        list icmp_type          router-solicitation
        list icmp_type          neighbour-solicitation
        list icmp_type          router-advertisement
        list icmp_type          neighbour-advertisement
        option limit            1000/sec
        option family           ipv6
# Allow essential forwarded IPv6 ICMP traffic
config rule
        option name             Allow-ICMPv6-Forward
        option src              wan
        option dest             *
        option proto            icmp
        option family           ipv6
# include a file with users custom iptables rules
config include
        option path /etc/firewall.user
cray888 вне форума   Ответить с цитированием
Старый 24.10.2013, 18:23   #173
А если option dns '192.168.1.1'
Тоже долгий отклик?
Старый 24.10.2013, 19:41   #174
andr128
Аватар для andr128
Вес репутации: 1605
а чуть ниже читали http://cyber-place.ru/showpost.php?p=1708&postcount=5
без relayed режим клиента не работает как надо.
Старый 24.10.2013, 20:01   #175
cray888
Тоже долгий отклик?
У меня в секции config interface 'wwan' уже прописан. Или еще куда необходимо вставит этоту опцию DNS?
Старый 24.10.2013, 20:02   #176
cray888
Попробуем.
Старый 27.10.2013, 17:00   #177
Sascha69
Sascha69 is an unknown quantity at this point
andr128
#28
Для работы модема необходимо установить следующие пакеты:
opkg update
opkg install comgt
opkg install kmod-usb-core
opkg install kmod-usb-serial
opkg install kmod-usb-serial-option
opkg install kmod-usb-uhci
opkg install usb-modeswitch
opkg install usb-modeswitch-data
День добрый, все настройки установил. Вопрос в следующем, где брать пакеты, как и куда их ставить?
Последний раз редактировалось Sascha69; 27.10.2013 в 17:03.
Sascha69 вне форума   Ответить с цитированием
Старый 27.10.2013, 19:46   #178
Пакеты в репозитории
Достаточно выполнить в консоли, то что Вам предложили
opkg update
opkg install comgt
Старый 29.10.2013, 01:16   #179
borey
borey is an unknown quantity at this point
Помогите и мне, пожалуйста, знатоки,
бьюсь второй день - не могу победить.. (
поднято два интерфейса - проводный - на комп в сети 10.10.10.0/24 ("коробка" - 10.10.10.10, комп - 10.10.10.1, он же назначен шлюзом на коробке для lan) и wi-fi - на второй маршрутизатор - подсеть 192.168.1.1/24 (коробка - 192.168.1.10, маршрутизатор - 192.168.1.2, она же шлюз для wwan):
#config interface 'loopback'
#       option ifname 'lo'
#       option proto 'static'
#       option ipaddr '127.0.0.1'
#       option netmask '255.0.0.0'
#       option dns '8.8.8.8'
        option dns '10.10.10.1'
        option ipaddr '10.10.10.10'
        option gateway '10.10.10.1'
        option broadcast '10.10.10.255'
        option metric '1'
        option _orig_ifname 'wlan0'
        option _orig_bridge 'false'
        option ipaddr '192.168.1.10'
        option broadcast '192.168.1.255'
        option dns '192.168.1.2'
        option gateway '192.168.1.2'
        option metric '0'
Проблемы две:
1. DNS не работают:
ping my.skylocker.ru
ping: bad address 'my.skylocker.ru'
ping 95.140.148.146
PING 95.140.148.146 (95.140.148.146): 56 data bytes
64 bytes from 95.140.148.146: seq=0 ttl=56 time=5.691 ms
64 bytes from 95.140.148.146: seq=1 ttl=56 time=2.977 ms
64 bytes from 95.140.148.146: seq=2 ttl=56 time=2.864 ms
64 bytes from 95.140.148.146: seq=3 ttl=56 time=3.240 ms
^C
2. пакеты идут не туда
Изначально метрики были выставлены так: lan=1, wwan=2 yjgfrtns вообще не ходили (( Сча назначил приоритетным wwan и пакеты наружу уходят, но криво:
- сначала идут по wwan на маршрутизатор 192.168.1.2
- оттуда - на второй маршрутизатор 192.168.0.1
- оттуда - уже наружу
 traceroute  95.140.148.146
traceroute to 95.140.148.146 (95.140.148.146), 30 hops max, 38 byte packets
 1  192.168.1.2 (192.168.1.2)  1.130 ms  0.811 ms  0.781 ms
 2  192.168.0.1 (192.168.0.1)  5.109 ms  6.082 ms  1.517 ms
 3  94.242.24.129 (94.242.24.129)  8.355 ms  2.497 ms  1.902 ms
 4  94.242.0.1 (94.242.0.1)  47.636 ms  3.818 ms  3.950 ms
 5  194.226.100.34 (194.226.100.34)  3.176 ms  5.695 ms  2.574 ms
 6  212.1.242.210 (212.1.242.210)  2.714 ms  3.796 ms  6.171 ms
 7  80.90.176.33 (80.90.176.33)  2.951 ms  5.292 ms  2.695 ms
 8  *  *  *
а я хочу, чтоб они летели на 10.10.10.1 (по lan) и далее - комп направит их (поставлю kerio для тестов или бридж сооружу из двух сетевух на win7) на 192.168.0.1
Что делать?
ЗЫ:
Еще раз. Вот так пакеты ходят, но через wwan:
netstat -nr
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
0.0.0.0         192.168.1.2     0.0.0.0         UG        0 0          0 wlan0
0.0.0.0         10.10.10.1      0.0.0.0         UG        0 0          0 br-lan
10.10.10.0      0.0.0.0         255.255.255.0   U         0 0          0 br-lan
192.168.1.0     0.0.0.0         255.255.255.0   U         0 0          0 wlan0
Вот так пакеты не ходят вообще (когда ставлю у wwan metric больше, чем у lan):
netstat -nr
Последний раз редактировалось borey; 29.10.2013 в 01:24.
borey вне форума   Ответить с цитированием
Старый 06.11.2013, 17:27   #180
Sherkhan
Sherkhan is an unknown quantity at this point
Здесь роутер имеет 2 IP адреса
внутренний для LAN из др. подсети: 192.168.2.1
и внешний для WWAN: 192.168.1.55
за переключение между внутр. и внешней сетью отвечает демон relayd
он делает этот процесс прозрачным и мы не замечаем подсеть 192.168.2.x
Я конечно дико извиняюсь, но невкурю КАК 3020 (клиент) подключается к "серверу" Нетгиру адресом из сети .2.0/24 если у "сервера" сеть .1.0/24 ...они же в разных сетях...
Верю, что это не опечатка, и все работает, но КАК?
Я бы еще понял, если бы между Нетгиром и 3020 была общая сеть (предположим .1.0/24 ), а далее 3020 раздает сеть в сторону компа(он же уже в эту сторону как АР работает) сеть .2.0/24
Sherkhan вне форума   Ответить с цитированием
Текущее время: 03:47. Часовой пояс GMT +3.
