Старый 08.10.2014, 18:35   #171
WB789
WB789 is an unknown quantity at this point
По умолчанию Re: Отзывы и предложения
Доброго дня, Админ! Кинь свой взор на http://downloads.openwrt.org/attitud...51e_ar71xx.ipk, возможно это то что нужно. Спасибо.
WB789 вне форума   Ответить с цитированием
Старый 08.10.2014, 19:31   #172
А описание и хеш файла есть? Для какого роутера он был скомпилирован?
Старый 09.10.2014, 00:16   #173
WB789
wview
Version: 5.19.0-jgoerzen-7bfac6c11e756290c38e7b5862a4c51b6bc6c51e
Depends: libc, libcurl, zlib, libpng, libgd, libreadline, libsqlite3, libusb-1.0, radlib, sqlite3-cli
Provides:
Source: feeds/packages/utils/wview
Section: utils
Status: unknown ok not-installed
Essential: no
Priority: optional
Maintainer: OpenWrt Developers Team <[email protected]>
Architecture: ar71xx
Installed-Size: 641990
Filename: wview_5.19.0-jgoerzen-7bfac6c11e756290c38e7b5862a4c51b6bc6c51e _ar71xx.ipk
MD5Sum: 09baf6d3d5718f69e4b1131de436dd7e
Description: Wview is a collection of linux/unix daemons which interface with a supported
weather station to retrieve archive records (if generated by the station) and
current conditions. If the station does not generate archive records
internally, wview will auto-generate archive records based on the sensor
readings collected for that interval. The archive records and High/Low (HILOW)
data are stored in SQLite3 databases. At a configurable interval, wview will
utilize the archive history and current conditions to generate weather images
(buckets, dials and graphs) and HTML web pages based on user-configurable HTML
templates.
After install you need to create a directory holding archive and create the
database there by running there
sqlite3 wview-archive.sdb '.read /etc/wview/wview-archive.sql'
Then copy all your theme files to the appropriate place (on a non-volatile
storage), and html-templates.conf to /etc/wview/; then wviewconfig to configure
the system.
Read and amend /etc/init.d/wview appropriately for your particular setup!
Старый 09.10.2014, 00:19   #174
WB789
находится сиё безобразие там же где и http://downloads.openwrt.org/attitud...s2-factory.bin
Старый 09.10.2014, 11:21   #175
lenz
lenz is an unknown quantity at this point
прикладываю скомпилированный модуль для системы Noolite. для работы ему требуется libusb. Но вроде все зависимости указал верно. При установке должен вытянуть из репозитория сам.
noolite_1_ar71xx.zip
Может вы его включите в стандартную сборку
Управляющие команды можно получить вызвав noolite -help
lenz вне форума   Ответить с цитированием
Старый 09.10.2014, 11:35   #176
Описание к пакету выложите, я сегодня добавлю оба пакета в репозиторий
Старый 09.10.2014, 11:54   #177
lenz
Модуль скомпилирован с этих исходников. Описание полное лежит на github
Ссылка
Единственное необходимо уточнить все ли зависимости я учел. За давностью компиляции мог что то упустить. А проверить к сожалению пока не на чем.
Описание проекта целиком лежит тут
И второе требование usb адаптеров от компании noolite, они работают на Usb 1.0 а в роутере 2.0. И адаптер будет работать только через хаб. Прямое подключение не работает
Старый 09.10.2014, 11:56   #178
lenz
Следующий вопрос, есть ли необходимость в выкладывании полностью скомпилированной прошивки для MR3020 c функционалом shairport. Аналог airplay для IOS. Или попытаться надергать скомпилированные модули, и устанавливать их по отдельности? В стандартной версии роутера банально не хватает места , если ставить модули по отдельности, если роутер с увеличенным обьемом памяти то тогда все нормально.
Старый 09.10.2014, 12:42   #179
Мне нужно описание пакета из репозитория, вот пример
Provides:
Section: utils
Essential: no
Priority: optional
Старый 09.10.2014, 13:37   #180
lenz
Каким образом его можно получить? я не выкладывал свой пакет в репозиторий. ОН был скомпилирован для личных нужд только. Если подскажете как взять всю информацию буду признателен.
Текущее время: 03:05. Часовой пояс GMT +3.
