Старый 12.05.2019, 23:27   #1
Вес репутации: 1033
По умолчанию WiFi в Debian
Что-то пошло не так и консоль в нетбуке заваливает повторяющимися сообщениями:
Флуд в консоли
[ 2069.762666] wlan0: authenticate with 28:28:5d:68:e8:ba
[ 2069.775498] wlan0: send auth to 28:28:5d:68:e8:ba (try 1/3)
[ 2069.938397] wlan0: authenticated
[ 2069.944092] wlan0: associate with 28:28:5d:68:e8:ba (try 1/3)
[ 2069.948762] wlan0: RX AssocResp from 28:28:5d:68:e8:ba (capab=0xc11 status=0 aid=4)
[ 2069.952259] wlan0: associated
[ 2069.955938] cfg80211: Calling CRDA for country: RU
[ 2069.969938] ath: EEPROM regdomain: 0x8283
[ 2069.969949] ath: EEPROM indicates we should expect a country code
[ 2069.969958] ath: doing EEPROM country->regdmn map search
[ 2069.969965] ath: country maps to regdmn code: 0x3
[ 2069.969971] ath: Country alpha2 being used: RU
[ 2069.969977] ath: Regpair used: 0x3
[ 2069.969984] ath: regdomain 0x8283 dynamically updated by country IE
[ 2069.970054] cfg80211: Regulatory domain changed to country: RU
[ 2069.974953] cfg80211:  DFS Master region: ETSI
[ 2069.975096] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 2069.984616] cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 2069.989599] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 2069.994626] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 2069.999552] cfg80211:   (5650000 KHz - 5730000 KHz @ 80000 KHz), (N/A, 3000 mBm), (0 s)
[ 2070.004388] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 2070.009158] cfg80211:   (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 2076.864287] cfg80211: Calling CRDA to update world regulatory domain
[ 2076.879159] cfg80211: World regulatory domain updated:
[ 2076.882408] cfg80211:  DFS Master region: unset
[ 2076.882501] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 2076.888815] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 2076.892159] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 2076.895505] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 2076.898916] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 2076.902325] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 2076.905668] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 2076.908976] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 2076.912280] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 2077.766525] wlan0: authenticate with 28:28:5d:68:e8:ba
[ 2077.778897] wlan0: send auth to 28:28:5d:68:e8:ba (try 1/3)
[ 2077.936063] wlan0: authenticated
[ 2077.940158] wlan0: associate with 28:28:5d:68:e8:ba (try 1/3)
[ 2077.948928] wlan0: RX AssocResp from 28:28:5d:68:e8:ba (capab=0xc11 status=0 aid=4)
[ 2077.954104] wlan0: associated
[ 2077.959454] cfg80211: Calling CRDA for country: RU
[ 2077.972808] ath: EEPROM regdomain: 0x8283
[ 2077.972817] ath: EEPROM indicates we should expect a country code
[ 2077.972823] ath: doing EEPROM country->regdmn map search
[ 2077.972828] ath: country maps to regdmn code: 0x3
[ 2077.972832] ath: Country alpha2 being used: RU
[ 2077.972835] ath: Regpair used: 0x3
[ 2077.972840] ath: regdomain 0x8283 dynamically updated by country IE
[ 2077.972896] cfg80211: Regulatory domain changed to country: RU
[ 2077.976212] cfg80211:  DFS Master region: ETSI
[ 2077.976309] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 2077.982777] cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 2077.986167] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 2077.989574] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 2077.992906] cfg80211:   (5650000 KHz - 5730000 KHz @ 80000 KHz), (N/A, 3000 mBm), (0 s)
[ 2077.996185] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 2077.999391] cfg80211:   (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 2084.832463] cfg80211: Calling CRDA to update world regulatory domain
[ 2084.847887] cfg80211: World regulatory domain updated:
[ 2084.851166] cfg80211:  DFS Master region: unset
[ 2084.851272] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 2084.857605] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 2084.860980] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 2084.864381] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 2084.867770] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 2084.871173] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 2084.874515] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 2084.877837] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 2084.881171] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[свернуть]
Причем флудит в любую актиыную консоль, то есть переключаюсь Alt+F2 и начинает сыпать туда. Соединение при этом рвется и снова устанавливается.
Чипсет ar5b95, драйвер ath9k. раньше вроде нормально работало, вот только не помню с текущим роутером или со старым...
Старый 14.05.2019, 00:02   #2
Вес репутации: 1602
Попробовать обновить - firmware для начала)
Текущее время: 13:25. Часовой пояс GMT +3.
